Komatsu Engine S4D95L-1K-C 135080-UP Parts Catalog
Model: Komatsu S4D95L-1K-C Engine
Serial Number: 135080-UP
Number of Pages: 79 Pages
S4D95L-1K-C S N 135080-UP
FRONT HANGER
HEAD COVER (WITH BYPASS FILTER)
AIR INTAKE MANIFOLD
HEATER SWITCH
AIR CLEANER (SINGLE ELEMENT TYPE)
AIR CLEANER (DOUBLE ELEMENT TYPE)
CYLINDER BLOCK (WITH BYPASS FILTER)
OIL PUMP (WITH BYPASS FILTER)
MAIN POWER TAKE OFF
BYPASS FILTER
OIL COOLER (6-ELEMENT TYPE)
OIL COOLER (WITH BYPASS FILTER¤ 6-ELEMENT TYPE)
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
WATER PUMP PULLEY
WATER PUMP PULLEY (LARGE TYPE)
COOLING FAN (10-BLADE TYPE)
ALTERNATOR MOUNTING (25A)
STARTING MOTOR MOUNTING (5 (1)
HARNESS CAP
NAME PLATE AND CAUTION (ENGLISH) (AIR CLEANER SINGLE ELEMENT TYPE)
NAME PLATE AND CAUTION (ENGLISH) (AIR CLEANER DOUBLE ELEMENT TYPE)
