Komatsu Engine S4D95L-1K-C 135080-UP Parts Catalog
Model: Komatsu S4D95L-1K-C Engine
Serial Number: 135080-UP
Number of Pages: 79 Pages
S4D95L-1K-C S N 135080-UP
ENGINE
CYLINDER HEAD
FRONT HANGER
REAR HANGER
HEAD COVER
HEAD COVER (WITH BYPASS FILTER)
AIR INTAKE MANIFOLD
HEATER SWITCH
AIR CLEANER (SINGLE ELEMENT TYPE)
AIR CLEANER (DOUBLE ELEMENT TYPE)
EXHAUST MANIFOLD
TURBOCHARGER OIL PIPING
TURBOCHARGER (INNER PARTS)
HEAT SHIELD
MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK (WITH BYPASS FILTER)
OIL PUMP
OIL PUMP (WITH BYPASS FILTER)
FRONT COVER
IDLER GEAR
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
PISTON
CRANK PULLEY
ROCKER ARM
CAMSHAFT AND TAPPET
MAIN POWER TAKE OFF
OIL FILTER
BYPASS FILTER
OIL COOLER (6-ELEMENT TYPE)
OIL COOLER (WITH BYPASS FILTER¤ 6-ELEMENT TYPE)
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
WATER PUMP
WATER PUMP PULLEY
WATER PUMP PULLEY (LARGE TYPE)
COOLING FAN (10-BLADE TYPE)
CORROSION RESISTOR
ALTERNATOR MOUNTING (25A)
ALTERNATOR (25A) (INNER PARTS)
STARTING MOTOR MOUNTING (5
STARTING MOTOR MOUNTING (5 (1)
STARTING MOTOR (5
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
SPARE PARTS
HARNESS CAP
NAME PLATE AND CAUTION (ENGLISH) (AIR CLEANER SINGLE ELEMENT TYPE)
NAME PLATE AND CAUTION (ENGLISH) (AIR CLEANER DOUBLE ELEMENT TYPE)
ENGINE
CYLINDER HEAD
FRONT HANGER
REAR HANGER
HEAD COVER
AIR INTAKE MANIFOLD
HEATER SWITCH
EXHAUST MANIFOLD
HEAT SHIELD
MUFFLER
CYLINDER BLOCK
OIL PUMP
FRONT COVER
IDLER GEAR
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
PISTON
CRANK PULLEY
ROCKER ARM
CAMSHAFT AND TAPPET
MAIN POWER TAKE OFF
OIL FILTER
BYPASS FILTER
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
WATER PUMP
WATER PUMP PULLEY
CORROSION RESISTOR
STARTING MOTOR (5
SPARE PARTS
HARNESS CAP
- KOMATSU Fault Codes
