Komatsu Engine NHC-4-CI-1S 5787-UP Parts Catalog
Model: Komatsu NHC-4-CI-1S Engine
Serial Number: 5787-UP
Number of Pages: 98 Pages
KOMATSU NHC-4-CI-1S S N 5787-UP
COMPRESSION RELEASE
WATER MANIFOLD
EXHAUST MANIFOLD AND MUFFLER
REAR COVER
GEAR CASE COVER AND ENGINE FRONT SUPPORT
OIL PAN AND OIL FILLER BRACKET
OIL PAN AND OIL PAN HEATER(FOR COLD WEATHER)
FLYWHEEL AND HOUSING
CAM FOLLOWER AND PUSH ROD
COUNTER BALANCER
LUBRICATING OIL FULLFLOW FILTER AND MOUNTING
LUBRICATING OIL BYPASS FILTER
LUBRICATING OIL PIPE AND CONNECTION
TORQUE CONVERTER OIL COOLER AND PIPING
PT FUEL PUMP(1 3)
PT FUEL PUMP(2 3)
PT FUEL PUMP(3 3)
FUEL PUMP ACCESSORY DRIVE
INJECTOR AND FUEL CONNECTION
FUEL TUBING
FUEL FILTER AND BRACKET
FLOAT TANK
AIR VESSEL
WATER PUMP AND PULLEY
THERMOSTAT AND HOUSING
CORROSION RESISTER
AIR CLEANER AND MOUNTING
STARING MOTOR
GENERATOR AND MOUNTING(12A)
VOLTAGE REGULATOR AND SAFETY RELAY
STARTING MOTOR (HITACHI)
STARTING MOTOR (NIKKO DENKI)
GENERATOR (12A)
TOOL AND KIT
TOOL
