Komatsu Engine NHC-4-CI-1S 5787-UP Parts Catalog
Model: Komatsu NHC-4-CI-1S Engine
Serial Number: 5787-UP
Number of Pages: 98 Pages
KOMATSU NHC-4-CI-1S S N 5787-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
COMPRESSION RELEASE
WATER MANIFOLD
EXHAUST MANIFOLD AND MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK (1)
REAR COVER
GEAR CASE COVER AND ENGINE FRONT SUPPORT
OIL PAN AND OIL FILLER BRACKET
OIL PAN AND OIL PAN HEATER(FOR COLD WEATHER)
CRANKSHAFT
PISTON AND CONNECTING ROD
FLYWHEEL AND HOUSING
CAMSHAFT
CAM FOLLOWER AND PUSH ROD
COUNTER BALANCER
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
LUBRICATING OIL FULLFLOW FILTER AND MOUNTING
LUBRICATING OIL BYPASS FILTER
LUBRICATING OIL COOLER
LUBRICATING OIL PIPE AND CONNECTION
TORQUE CONVERTER OIL COOLER AND PIPING
FUEL SYSTEM
PT FUEL PUMP(1 3)
PT FUEL PUMP(2 3)
PT FUEL PUMP(3 3)
FUEL PUMP ACCESSORY DRIVE
INJECTOR AND FUEL CONNECTION
FUEL TUBING
FUEL FILTER AND BRACKET
FLOAT TANK
AIR VESSEL
COOLING AND ELECTRICAL SYSTEMS
WATER PUMP AND PULLEY
COOLING FAN
THERMOSTAT AND HOUSING
CORROSION RESISTER
AIR CLEANER AND MOUNTING
STARING MOTOR
GENERATOR AND MOUNTING(12A)
VOLTAGE REGULATOR AND SAFETY RELAY
STARTING MOTOR (HITACHI)
STARTING MOTOR (NIKKO DENKI)
GENERATOR (12A)
TOOL AND KIT
TOOL
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
COMPRESSION RELEASE
WATER MANIFOLD
CYLINDER BLOCK
CYLINDER BLOCK (1)
REAR COVER
CRANKSHAFT
CAMSHAFT
COUNTER BALANCER
FUEL SYSTEM
PT FUEL PUMP(1 3)
PT FUEL PUMP(2 3)
PT FUEL PUMP(3 3)
FUEL TUBING
FLOAT TANK
AIR VESSEL
COOLING FAN
CORROSION RESISTER
STARING MOTOR
GENERATOR (12A)
TOOL AND KIT
TOOL
GASKET KIT
- KOMATSU Fault Codes
