Komatsu Engine 6D105-1F 12218-UP Parts Catalog
Model: Komatsu 6D105-1F Engine
Serial Number: 12218-UP
Number of Pages: 119 Pages
6D105-1F S N 12218-UP
CYLINDER HEAD COVER
AIR CLEANER (PC200SS)
INTAKE SILENCER (PC200SS)
MUFFLER (PC200SS)
ENGINE SUPPORT
LUBRICATING OIL FLITER AND BRACKET
LUBRICATING OIL COOLER (COLD TREEAIN SPEC.)
ADDITIONAL FUEL FILTER
FUEL INJECTION PUMP (PUMP)
FUEL INJECTION PUMP (PUMP) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (COUPLING) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (FEED PUMP) (COLD TERRAIN SPEC.)
WATER PUMP AND COOLING FAN
CORROSION RESISTOR (FOR JAPAN #12218-49999) (EXCEPT JAPAN #1221:cool:
ALTERNATOR AND MOUNTING (25A)
ALTERNATOR AND MOUNTING (35A)
STARTING MOTOR AND MOUNTING
REGUALTOR AND HEATER SIGNAL
ALTERNATOR (35A)
STARTING MOTOR (7 (2)
ACCESSORY
AIR COMPRESSOR AND PIPING
AIR COMPRESSOR
TOOL AND ENGINE KIT
TOOL
