Komatsu Engine 6D105-1F 12218-UP Parts Catalog
Model: Komatsu 6D105-1F Engine
Serial Number: 12218-UP
Number of Pages: 119 Pages
6D105-1F S N 12218-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM
CYLINDER HEAD COVER
EXHAUST MANIFOLD
AIR CLEANER
AIR CLEANER (PC200SS)
INTAKE SILENCER (PC200SS)
MUFFLER (PC200SS)
MUFFLER
CYLINDER BLOCK
FRONT COVER
OIL PAN
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND TAPPET
ENGINE SUPPORT
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL FLITER AND BRACKET
LUBRICATING OIL COOLER
LUBRICATING OIL COOLER (COLD TREEAIN SPEC.)
FUEL SYSTEM
FUEL INJECTION PUMP AND PIPING
FUEL FILTER
ADDITIONAL FUEL FILTER
WATER SEPARATOR
FUEL NOZZLE AND SPILL PIPE
FUEL INJECTION PUMP (PUMP)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (COUPLING)
FUEL INJECTION PUMP (FEED PUMP)
FUEL INJECTION PUMP (PUMP) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (COUPLING) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (FEED PUMP) (COLD TERRAIN SPEC.)
COOLING AND ELECTRICAL SYSTEMS
WATER PUMP AND COOLING FAN
CORROSION RESISTOR (FOR JAPAN #12218-49999) (EXCEPT JAPAN #1221
ALTERNATOR AND MOUNTING (25A)
ALTERNATOR AND MOUNTING (35A)
STARTING MOTOR AND MOUNTING
REGUALTOR AND HEATER SIGNAL
ALTERNATOR (35A)
ALTERNATOR (25A)
STARTING MOTOR (7
STARTING MOTOR (7 (1)
STARTING MOTOR (7 (2)
ACCESSORY
AIR COMPRESSOR AND PIPING
AIR COMPRESSOR
TOOL AND ENGINE KIT
TOOL
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM
CYLINDER HEAD COVER
EXHAUST MANIFOLD
AIR CLEANER
MUFFLER (PC200SS)
MUFFLER
CYLINDER BLOCK
FRONT COVER
OIL PAN
CRANKSHAFT
CAMSHAFT AND TAPPET
ENGINE SUPPORT
FUEL SYSTEM
FUEL FILTER
WATER SEPARATOR
ALTERNATOR (35A)
ALTERNATOR (25A)
STARTING MOTOR (7
ACCESSORY
AIR COMPRESSOR
TOOL AND ENGINE KIT
TOOL
GASKET KIT
- KOMATSU Fault Codes
