Driver
98
289,323
Kobelco Excavator SK350-8 Acera Mark 8 Tier III Parts Catalog
Brand: Kobelco
Type of Machine: Excavator
Model: Kobelco SK350-8 Acera Mark 8 Tier III Excavator
Part Number: YC10-03501 and up
Number Of Pages: 786 Pages
Date: 2006
FUEL AND OIL FILTER ELEMENTS
HYDRAULIC SERVICE COMPONENTS (FITTINGS)
HYDRAULIC SERVICE COMPONENTS (4-BOLT FLANGE CAPS)
SPANNER WRENCHES, LUBRICANTS
UPPER FRAME ASSEMBLY LC52F00169P1
UPPER FRAME GROUP (H & W) LC52FU0009F1
FRAME, UPP (REWORK) LONG REACH LC52FU0008P1
COUNTERWEIGHT INSTALLATION LC60C00071F1
COUNTERWEIGHT INSTALLATION (LONG REACH) LC60CU0005F1
ENGINE INSTALLATION LC02P00034F1
RADIATOR INSTALLATION LC05P00042F1
RADIATOR GROUP LC05P00036F1
AIR CLEANER ASSEMBLY LC11P00016F1
MUFFLER ASSEMBLY LC12P00011F1
FUEL LINES LC21P00010F1
FUEL TANK INSTALLATIONLC20P00035F1
HYDRAULIC TANK ASSEMBLY LC33H00043F1
POWER TAKEOFF ASSEMBLY LC30P00010F1
COUPLING, HUB LC30P01023F1
SWING MOTOR INSTALLATION LC32W00008F1
VALVE INSTALLATION MAIN HYDRAULIC VALVE LC64H00113F1 & YN64H00190F1 (NIBBLER & BREAKER)
HYDRAULIC LINES PUMP SUCTION, DELIVERY (PUMP-TO-HYDRAULIC VALVE) LC30H00030F1
UPPER HYDRAULIC LINES - MAIN LC03H00054F1
UPPER HYDRAULIC LINES - NIBBLER AND BREAKER LC03H00055F1
HYDRAULIC LINES - SWIVEL LC19H00014F1
UPPER HYDRAULIC LINES RETURN LC03H00027F1
CONTROLS, OPERATORS YN03M00148F1
CONTROLS, OPERATORS (NO BOOST) LONG REACH YN03M00180F1
CONTROLS, OPERATORS (HAND NIBBLER AND BREAKER) YN03M00181F1
CONTROLS, OPERATORS YN03M00153F1
CONTROL BOX ASSY YN03M00149F1
GRIP ASSY YN03M01870F1
GRIP ASSY YN03M01974F1
RADIO INSTALLATION YN54E00010F1
ARM REST YN25M01180F1
ARM REST YN25M01183F1
LEVER ASSY, PROPEL YN50M00015F1
PEDAL ASSY YN55M00004F1
CONTROL LINES, REMOTE YN68H00129F1
CONTROL LINES, MAIN LC06H00045F1
CONTROL LINES VALVE LC64H00104F1
CONTROL LINES, VALVE LC64H00105F1 NIBBLER & BREAKER
CONTROL LINES, PUMP LC06H00042F1
CONTROL LINES, PROPEL LC62H00014F1
CONTROL LINES, BLOCK LC64H00088F1
CONTROL LINES, BLOCK LC64H00143F1 STD & BASE
CONTROL LINES, BLOCK LC64H00150F1 BASE
CONTROL LINES, BLOCK LC64H00150F1 STD
CONTROL LINES, BLOCK YN64H00183F1 STD
PLATE INSTALL, FLOOR YN03M00162F1
MIRROR INSTAL YN52C00017F1
CAB INSTALL YN02C00151F1
CAB ASSY YN02C00156F1
CAB ASSY WINDOW, ROOF YN02C03654F1
CAB ASSY WINDOW, FRONT YN50C00005F1
CAB ASSY DOOR ASSY
SEAT INSTALLATION YN25M00071F1
SEAT BELT ASSY YN25M00053F1
GUARD INSTALLATION LC21C00034F1
GUARD INSTALLATION LC21C00024F1
GUARD INSTALLATION LC21C000382F1
GUARD INSTALLATION LC21C00036F1
COVER ASSEMBLY, UNDER LC24C00022F1
INSTRUMENT PANEL ASSEMBLY YN17M00059F1
INSTRUMENT PANEL ASSEMBLY (NIBBLER & BREAKER) YN17M00056F1
CONTROLLER INSTALLATION LC22E00097F1
RELAY BOX ASSY YN24E00019F1
RELAY ASSY YN24E00017F1
BATTERY ASSY LC72E00007F1
AIR CONDITIONER LC20M00033F1
CONDITIONER ASSY, AIR YN20M00113F1
DRIER ASSY, AIR LC20M00019F1
COMPRESSOR ASSY, AIR YX91V00001F1
CONDITIONER ASSEMBLY, AIR YN20M00107F2
ELECT ASSY, UPP LC03E00008F1
LIGHT INSTALLATION, UPP YN80E00049F1
HARNESS ASSY, UPP LC13E00048F1
HARNESS ASSEMBLY CAB - LC14E00023F1
HARNESS ASSY, CAB YN14E00056F1
HARNESS ASSEMBLY, UPP PLATE, FLOOR LC13E00049F1
HARNESS ASSEMBLY ENGINE LC16E00010F1
HARNESS ASSEMBLY BOOM WORK LAMP LB15E00001F2
LOWER INSTALLATION STANDARD GROUP LC01F00021F1
MOTOR INSTAL, PROPEL (H & W) LC53DU003F1
LOW GROUP (STD GUIDE) (H & W) LC01FU0003F1
LOW GROUP (FULL GUIDE) LC01FU0003F2
FRAME ASSY, LOW (H & W) LC02FU0019P1
SLEWING RING ASSEMBLY LB40F00019F1
CRAWLER IDLER LC52D00025F1
CRAWLER IDLER ASSEMBLY LC52D00026F1
IDLER ASSEMBLY LC52D00032F1
IDLER ADJUST ASSEMBLY LC54D00009F1
TRACK ROLLER ASSEMBLY LC64D00004F3
UPPER ROLLER ASSEMBLY LC64D00003F1
ROLLER ASSY, UPP (H & W) LC64DU0019F1
SHOE ASSEMBLY 800MM LC60D00016F3
LOWER HYDRAULIC LINES LC02H00022F1
COVER ASSY, UNDER LC24C00027F1
BLOCK INSTALL LC02F0123P1
BOOM INSTAL STANDARD - 6.5M (21 FT - 4 IN) LC02B00155F1
BOOM ASSEMBLY LC02B00165F1 6.5M (21 FT - 4 IN)
HYD LINES, BOOM STD LC42H00175F1
HYD LINES, BOOM 6.5 M (21FT - 4 IN) (NIBBLER AND BREAKER) LC42H00178F1
HYD LINES, BOOM (NIBBLER AND BREAKER) LC42H00169F1
LIGHT INSTAL BOOM YN80E00026F1
ARM GROUP, 3.3M LC12B00266F1
ARM INSTAL, (LONG REACH) LC12B00393F1
ARM ASSY, 3.3M LC12B00383F1
ARM GROUP (LONG REACH) YM12B00044FD
ARM, LONG REACH LC12BU0014F1
ARM, LONG (ROTATION) LC12B00418F1
ARM, LONG (NIBBLER & BREAKER) LC12B00413F1
ARM STD ROTATION LC12B00387F1
ARM SHORT (ROTATION) LC12B00406F1
HYDRAULIC LINES ARM 3.3M (10FT 10IN) LC43H00081F1
HYD LINES, ARM LONG LC43H00121F1
HYD LINES, SHORT ARM (NIBBLER & BREAKER) LC43H00107F1
HYD LINES, LONG ARM (NIBBLER & BREAKER) LC43H00122F1
BUCKET INSTALLATION LC61B00088F1
BUCKET INSTALLATION (LONG REACH) YM61B00002F1
CASE ASSY, GEAR YN46W00001F2
CASE ASSY, GEAR YN46W00002F6
PUMP GEAR YF10V00003F1
VALVE INSTALLATION (ROTATION) YN64H00196F1
CYLINDER INSTALLATION, BUCKET (LONG REACH) YM12B00027F1
CYLINDER, BUCKET YM01V00009F1
BOOM, HOE ME (NIBBLER & BREAKER) LC02BU0008F1
TOOLS & ACCESSORIES LC01T00032F4
ELEMENT KIT LC30T00005F7
VALVE INSTALLATION YN64H00190F1 NIBBLER & BREAKER
HYD LINES,UPP (NIBBLER & BREAKER) LC03H00055F1
CONTROLS, OPERATORS YN55M0004F1 PEDAL ASSY
CONTROL LINES, VALVE LC64H000105F1 NIBBLER & BREAKER
CONTROL LINES, REMOTE LC68H00063F1 NIBBLER & BREAKER
CONTROL LINES, BLOCK LC64H00153F1 NIBBLER & BREAKER
PANEL ASSY, INSTRUMENT, SWITCH INSTALLATION, NIBBLER & BREAKER YN50E00021F1
HYD LINES, BOOM LC42H00169F1 NIBBLER AND BREAKER
HYD LINES, ARM LC43H00111F1 3.3M NIBBLER AND BREAKER
CONNECTOR ASSY YN43H01646F1 NIBBER & BREAKER
ARM, SHORT (NIBBLER & BREAKER) LC12B00402F1
ARM GROUP SHORT (2.6M) LC12B00408F1
HYD LINES, ARM SHORT LC43H00105F1
CONTROL LINES, VALVE (BOOM & ARM SAFETY) LC64H00085F1
HYD LINES, BOOM (ROTATION) LC42H00180F1
HYD LINES, CYLINDER BOOM (SAFETY) LC42H00227F1
HYD LINES, CYLINDER ARM (SAFETY) LC42H00186F1
CONTROL LINES, MULTI LC64H00140F1
CONTROL LINES, VALVE (W/ROTATION) LC64H00160F1
CONTROL LINES, VALVE (NIBBLER & BREAKER W/ROTATION) LC64H00159F1
HYD LINES, ARM (ROTATION & NIBBLER & BREAKER) LC43H00143F1
HYD LINES, ARM (STD ARM ROTATION) LC43H00144F1
HYD LINES, ARM LONG (ROTATION & NIBBLER & BREAKER) LC43H00146F1
HYD LINES, ARM LONG (ROTATION) LC43H00147F1
HYD LINES, ARM SHORT (ROTATION & NIBBLER & BREAKER) LC43H00149F1
HYD LINES, ARM SHORT (ROTATION) LC43H00150F1
HARNESS ASSY, UPP (NIBBLER & BREAKER, HAND) LC13E00052F1
HARNESS ASSY, UPP (NIBBLER & BREAKER, ROTATION, HAND) LC13E00051F1
HARNESS ASSY, UPP (ROTATION) LC13E00056F1
HARNESS ASSY, UPP (PATTERN CHANGE) LC13E00055F1
MIRROR INSTAL YN52C00019F1
ALARM ASSY LC53E00007F1
CAP ASSY YN02B01738F1
CAP ASSY YN12B02300F1
SHOE ASSEMBLY 600MM LC60D00016F1
SHOE ASSEMBLY 600MM (HD) LC60D00016F2
SHOE ASSEMBLY 700MM DOUBLE GROUSER LC60D00016F5
SHOE ASSEMBLY 700MM TRIPLE GROUSER LC60D00016F7
SHOE ASSEMBLY 900MM LC60D00016F4
CONTROL LINES, MAIN (ROTATION + NIBBLER & BREAKER) LC06H00057F1
HYD LINES, PUMP (ROTATION) LC30H00037F1
HYD LINES, UPP (ROTATION) BASE
HYD LINES, UPP (ROTATION) EXTRA LC03H00067F1
HYD LINES, UPP (ROTATION W/NIBBLER & BREAKER) LC03H00063F1
RING ASSY, SLEWING (H & W) LC40FU0002F1
SHOE ASSEMBLY (H & W) 600MM (HD) LC60DU0010F1
SHOE ASSEMBLY (H & W) 700MM DOUBLE GROUSER LC60DU0010F2
SHOE ASSEMBLY (H & W) 700MM TRIPLE GROUSER LC60DU0010F3
SHOE ASSEMBLY (H & W) 800MM LC60DU0010F4
SHOE ASSEMBLY (H & W) 900MM LC60DU0010F5
STEP INSTAL YN41CU0002F1-F3
VANDALISM GUARDS 1 OF 2 YN25C00008F1
VANDALISM GUARDS 2 OF 2 YN25C00008F1
HYD LINES,LOW (H & W) LC02HU0005F1
HYD LINES, SWIVEL (H & W) LC19HU0001F1
HYD LINES, PROPEL (H & W) LC12HU0001F1
NAME PLATE INSTALLATION, LUBRICATION CHART YN22T00333F3
NAME PLATE INSTALLATION, BOOM LC22T00017F1 LABEL
NAME PLATE INSTALLATION, FRAME YN22T00340F2 LABEL LOCATION
NAME PLATE FRAME LABELS YN22T00340F2
NAME PLATE YN22T00340F4 - CAUTION LABEL
NAME PLATE INSTALLATION, - CAB, LABEL LOCATION YN22T00341F1
NAME PLATE - CAB, LABELS YN22T00341F1
NAME PLATE INSTALLATION, CAB (NIBBLER & BREAKER), LABEL LOCATION YN22T00341F3
NAME PLATE INSTALLATION, CAB (NIBBLER & BREAKER) LABEL YN22T00341F3
NAME PLATE INSTALLATION, (EXTERIOR) LOCATION LC22TU0007F1
NAME PLATE INSTALLATION, (EXTERIOR) LABELS LC22TU0007F1
NAME PLATE INSTALLATION, LOCATION LC22T00097F1-F9
NAME PLATE INSTALLATION, LABEL LC22T00097F1-F3
NAME PLATE INSTALLATION, LABEL LC22T00097F4-F6
NAME PLATE INSTALLATION, LABEL LC22T00097F7-F9
NAME PLATE INSTALLATION, (ANTI-SKID) LOCATION LC22T00091F1
NAME PLATE INSTALLATION, (ANTI-SKID) LABEL LC22T00091F1
NAME PLATE INSTALLATION, (PATTERN CHANGE) LOCATION YN22T00341F2
NAME PLATE INSTALLATION, (PATTERN CHANGE) YN22T00341F2
NAME PLATE INSTALLATION, (PATTERN CHANGE) LOCATION YN22T00340F3
NAME PLATE INSTALLATION, (PATTERN CHANGE) YN22T00340F3
VALVE ASSY, CONTROL LC30V00028F1 (HC001)
VALVE ASSY PORT RELIEF YN22V00002F1-FJ (HC015)
VALVE ASSY, CONTROL YN30V00104F1 (HC100)
MOTOR ASSY (SWING) LC15V00022F1 (HC300)
REDUCTION ASSY (SWING) LC32W00007F1 (HC310)
VALVE ASSY, (SWING-REACTIONLESS) YN20V00004F1-F4 (HC315)
VALVE ASSY, RELIEF, RELIEF YN22V00014F1-FB (HC325)
MOTOR ASSY (PROPELLING) LC15V00023F1 (HC370)
PUMP ASSY LC10V00014F1 (HC400)
PUMP ASSY LC10V00020F1 (HC405)
REGULATOR ASSY LC10V01005F1 (HC410)
VALVE ASSY, RELIEF YN22V00014F1-FB (HC420)
CYLINDER ASSY, BOOM LC01V00044F1 (HC600)
CYLINDER ASSY, ARM LC01V00054F1,F2 (HC650)
CYLINDER ASSY, BUCKET LC01V00055F1,F2 (HC700)
VALVE ASSY, SOLENOID YN35V00049F1 (HC825)
VALVE ASSY, SOLENOID YN35V00047F1 (HC850)
VALVE ASSY, SOLENOID YN35V00048F1 (HC851)
VALVE ASSY, SOLENOID YN35V00049F1 (HC852)
VALVE ASSY, SOLENOID YN35V00050F1 (HC853)
VALVE ASSY, SOLENOID YN35V00051F1 (HC854)
VALVE ASSY. SELECTOR YN30V00117F1 (HC880)
VALVE ASSY, HOLDING YN28V00019F1, F2 (HC900)
JOINT ASSY, SWIVEL YN55V00053F1 (HC930)
CYLINDER HEAD 10-00-1 (HINO ENGINE TYPE J08ETM-KSDA)
CYLINDER HEAD 10-00-2 (HINO ENGINE TYPE J08ETM-KSDA)
CYLINDER BLOCKS 11-00-1 (HINO ENGINE TYPE J08ETM-KSDA)
CYLINDER BLOCKS 11-00-2 (HINO ENGINE TYPE J08ETM-KSDA)
TIMING GEAR COVER & FLY WHEEL HOUSING 11-10 (HINO ENGINE TYPE J08ETM-KSDA)
MAIN MOVING PARTS 12-00 (HINO ENGINE TYPE J08ETM-KSDA)
CAMSHAFT AND IDLE GEAR 13-00 (HINO ENGINE TYPE J08ETM-KSDA)
VALVE SYSTEM 13-10 (HINO ENGINE TYPE J08ETM-KSDA)
AIR INTAKE AND EXHAUST SYSTEM 13-20-1 (HINO ENGINE TYPE J08ETM-KSDA)
AIR INTAKE AND EXHAUST SYSTEM 13-20-2 (HINO ENGINE TYPE J08ETM-KSDA)
LUBRICATION SYSTEM 14-00 (HINO ENGINE TYPE J08ETM-KSDA)
OIL FILTER 14-51 (HINO ENGINE TYPE J08ETM-KSDA)
OIL COOLER 14-52 (HINO ENGINE TYPE J08ETM-KSDA)
FUEL SYSTEM 15-00 (HINO ENGINE TYPE J08ETM-KSDA)
FUEL FILTER 15-54 (HINO ENGINE TYPE J08ETM-KSDA)
COOLING SYSTEM 16-00 (HINO ENGINE TYPE J08ETM-KSDA)
ELECTRICAL PARTS 18-10-1 (HINO ENGINE TYPE J08ETM-KSDA)
ELECTRICAL PARTS 18-10-2 (HINO ENGINE TYPE J08ETM-KSDA)
ELECTRICAL PARTS 18-10-3 (HINO ENGINE TYPE J08ETM-KSDA)
TURBOCHARGER 18-30 (HINO ENGINE TYPE J08ETM-KSDA)
ENGINE ACCESSORY PARTS 18-40 (HINO ENGINE TYPE J08ETM-KSDA)
ALTERNATOR 19-04 (HINO ENGINE TYPE J08ETM-KSDA)
STARTING MOTOR 19-05 (HINO ENGINE TYPE J08ETM-KSDA)
GASKET KIT ENGINE OVERHAUL 19-91 (HINO ENGINE TYPE J08ETM-KSDA)
