JLG Boom Lift TOUCAN 8E to TOUCAN 26E Service & Maintenance Manual 31210476 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG
TOUCAN 8E
TOUCAN 20E
TOUCAN 10E
TOUCAN 26E
Part Number: 31210476
Publication Date: 2025
Number of Pages: 186 Pages
Brand: JLG
Model: JLG
TOUCAN 8E
TOUCAN 20E
TOUCAN 10E
TOUCAN 26E
Section 1. OPERATING SPECIFICATIONS
1.1 OPERATING SPECIFICATIONS
1.2 DIMENSIONAL data
1.3 PERFORMANCE DATA
1.4 CAPACITIES
1.5 COMPONENTS DATA
1.6 MAJOR COMPONENTS WEIGHTS
1.7 LUBRICATION
1.8 TORQUE REQUIREMENTS
1.9 SERIAL NUMBER LOCATIONS
1.10 CLEARSKY SMART FLEET™ (IF EQUIPPED)
Section 2. general service information
2.1 Machine preparation, inspection and maintenance
2.2 preventive maintenance and inspection schedule
2.3 Servicing and maintenance guidelines
2.4 Lubrication Information
2.5 Pressure Relief ValVe
2.6 HYDRAULIC CARTRIDGE INSTALLATION
Section 3. THEORY OF OPERATION
3.1 Overview
3.2 Modes of operation
3.3 Can Communications
3.4 Joysticks
3.5 Traction
3.6 Pump/structure movements
Section 4. CHASSIS MOUNTED COMPONENTS
4.1 ABM DRIVE MOTORS
4.2 DANA DRIVE MOTORS
4.3 Wheels and Tires
4.3 Steering Linkage
4.4 Front Wheel Hub
Section 5. TURNTABLE AND VERTICAL MAST
5.1 SWING BEARING
5.2 Swing Motor
5.3 Rollers
5.4 Mast and Rollers Setting
5.5 Lifting chains
5.6 Pulley - Pulley Support
5.7 Mast Cylinder Removal and Installation
Section 6. JIB AND PLATFORM
6.1 PLATFORM
6.2 OVERLAOD SYSTEM
6.3 Jib Cylinder Removal and Installation
Section 7. HYDRAULICS
7.1 HYDRAULIC TANK
7.2 Hydraulic Filter Replacement
7.3 Hydraulic Power Unit
7.4 SWING MOTOR
7.5 CYLINDERS HOLDING VALVES
7.6 CYLINDER REPAIR
Section 8. CONTROL COMPONENTS
8.1 Control components overview
8.2 Control Components - Service
8.3 CLEARSKY® LED MOTION / AMBER BEACON (CS550) (IF EQUIPPED)
8.4 Traction System
8.5 Power Module
8.6 Ground Module
8.7 Ground Control Station
8.8 Platform Control Station
Section 9. JLG CONTROL SYSTEM
9.1 HAND HELD ANALYZER
9.2 Analyzer screen layout
9.3 MACHINE SETUP PROGRAMMING INFORMATION
9.4 CALIBRATION INSTRUCTIONS
9.5 CALIBRATING STEERING SENSOR
9.6 Calibrating Tilt Sensor
9.7 CALIBRATING OVERLOAD SYSTEM
9.8 CALIBRATING THE JOYSTICKS
9.9 Calibrating the pressure relief valve
9.10 Calibrating the drive motor temperature sensor
9.11 Calibrating the charger
9.12 MACHINE PERSONALITY - ADJUSTMENT SETTINGS
9.13 SYSTEM TEST
9.14 CLEARSKY CS550 CONFIGURATION AND TROUBLESHOOTING
Section 10. DIAGNOSTIC TROUBLE CODES
10.1 INTRODUCTION
10.2 DTC INDEX
10.3 DTC CHECK TABLES
10.4 ClearSky CSV3 Smart Fleet DTC Fault Codes
Section 11. GENERAL ELECTRICAL INFORMATION & SCHEMATICS
11.1 GENERAL
11.2 Multimeter Basics
11.3 Checking Switches
11.4 Applying Silicone Dielectric Compound to Electrical Connections
11.5 AMP Connector
11.6 Deutsch Connectors
11.7 CONNECTORS IDENTIFICATION
11.8 ELECTRICAL SCHEMATIC 1001311640-b
11.9 Hydraulic schematic
- SuperPac Parts Manual
- StratoLift Parts Manual
