[JD] John Deere 640D 648D Grapple Skidder Technical Manual TM1440
Type of Manual: Technical Manual
Type of Machine: Grapple Skidder
Model: 640D, 648D
Part Number: TM1440
Number of Pages: 969 Pages
I-GENERAL INFORMATION
I -Safety Information
II -General Specifications
III -Torque Values
IV -Fuels and Lubricants
V -Inspection Procedure
WHEELS
Powered Wheels and Fastenings
AXLES AND SUSPENSION SYSTEM
Removal and Installation
Differential Or Bevel Drive
Input Drive Shafts And U-Joints
Axle Shaft, Bearings, And Reduction Gears
TRANSMISSION
Controls Linkage
Gears, Shafts, Bearings And Power Shift Clutch
ENGINE
ENGINE AUXILIARY SYSTEMS
Cold Weather Starting Aids
Cooling Systems
Speed Controls
Intake System
External Exhaust System
External Fuel Supply System
CLUTCH
Controls Linkage
Elements
STEERING SYSTEM
Secondary Steering
SERVICE BRAKES
Active Elements
PARK BRAKE
Active Elements
Controls Linkage
ELECTRICAL SYSTEM
Batteries, Supports and Cables
Alternator, Regulator and Charging System Wiring
Lighting System
Wiring Harness and Switches
Instruments and Indicators
FRAME, CHASSIS OR SUPPORT STRUCTURE
Frame Installation
Frame Bottom Guards
OPERATOR'S STATION
Operator Enclosure
Seat and Seat Belt
Heating and Air Conditioning
SHEET METAL AND STYLING
Hood or Engine Enclosure
Grille and Grille Housing
SAFETY, CONVENIENCE AND MISCELLANEOUS
Horn and Warning Devices
MAIN HYDRAULIC SYSTEM
WINCH
Controls Linkage
Drive and Clutch
BULLDOZERS (STACKING AND TRAILBUILDING BLADES)
Blades
Controls Linkage
ARCH OR BOOM
Frame
GRAPPLE
Grapple Mechanism
Controls Linkage
Frame
WINCH DRIVE
Input Drive Shaft
DEALER FABRICATED TOOLS
Dealer Fabricated Tools
Model: 640D, 648D
Part Number: TM1440
III -Torque Values
WHEELS
TRANSMISSION
Controls Linkage
ENGINE
Cooling Systems
Speed Controls
Intake System
CLUTCH
Controls Linkage
Elements
STEERING SYSTEM
Secondary Steering
SERVICE BRAKES
Active Elements
PARK BRAKE
Active Elements
Controls Linkage
ELECTRICAL SYSTEM
Lighting System
Frame Installation
Frame Bottom Guards
OPERATOR'S STATION
Operator Enclosure
Seat and Seat Belt
WINCH
Controls Linkage
Drive and Clutch
Blades
Controls Linkage
ARCH OR BOOM
Frame
GRAPPLE
Grapple Mechanism
Controls Linkage
Frame
WINCH DRIVE
Input Drive Shaft
- JOHN DEERE CODE DTC LIST
