Isuzu D-Max TFR&TFS Series 2026 Electronic Service Information Wiring Diagram TFHTML-WEN-2651
Type of Machine: Automotive Pickup
Type of Manual: Electronic Service Information - Mechanical Repair Procedures, Diagnostics Service Information - Troubleshooting(DTC), Wiring Diagram
Model: Isuzu D-Max TFR Series ; TFS Series 20 Cab Model Pickup
Date: 2026
Engine: Isuzu 4JJ3 Euro2 ; 4JJ3 Euro4 ; 4JJ3 Euro5 ; RZ4E-TC Euro2 ; RZ4E-TC Euro4 ; RZ4E-TC Euro5 Engine
Except Thailand (Date:2026/05/29)
Parts Number: TFHTML-WEN-2651
Purchase Options: You can buy the Full Package or click on the individual links below to buy them separately.
------ List of Files ------
1. Introduction Safety Information
2. [Mechanical Repair Procedures]
3. [Diagnostics Service Information - Troubleshooting(DTC)]
4. [Wiring Diagram]
Date: 2026
4. [Wiring Diagram]
LHD 4WD.pdf
LHD Anti-lock Brake.pdf
LHD Audio (1DIN or 2DIN).pdf
LHD Audio (Display Audio).pdf
LHD Audio (Surround View Monitor).pdf
LHD Automatic Dimming.pdf
LHD Automatic Transmission (AWR6B45).pdf
LHD Automatic Transmission (L-B500).pdf
LHD Backup Light.pdf
LHD Battery Sensor.pdf
LHD Body Control.pdf
LHD Combination Meter.pdf
LHD Controller Area Network (Central Gateway CU 4JJ3 RZ4E (Euro5 and less)).pdf
LHD Controller Area Network (Central Gateway CU RZ4F).pdf
LHD Controller Area Network (Except Central Gateway CU 4JJ3 RZ4E (Euro5 and less)).pdf
LHD Controller Area Network (Except Central Gateway CU RZ4F).pdf
LHD Data Recording.pdf
LHD Daytime Running Light.pdf
LHD Differential Lock.pdf
LHD DLC.pdf
LHD Dome Light (BCM).pdf
LHD Dome Light (Except BCM).pdf
LHD Driver Monitoring System.pdf
LHD eCall.pdf
LHD Electrical Socket.pdf
LHD Electronic Stability Control.pdf
LHD Engine Control (4JJ3 (Euro4 and less)).pdf
LHD Engine Control (4JJ3 (Euro5)).pdf
LHD Engine Control (RZ4E (Euro2 and less)).pdf
LHD Engine Control (RZ4E (Euro4)).pdf
LHD Engine Control (RZ4E (Euro5)).pdf
LHD Engine Control (RZ4F).pdf
LHD Fog Light (Front Fog Light).pdf
LHD Fog Light (Rear Fog Light).pdf
LHD Fuse Load.pdf
LHD Ground Distribution.pdf
LHD Headlight (BCM).pdf
LHD Headlight (Except BCM).pdf
LHD Headlight Leveling (Auto Leveling).pdf
LHD Headlight Leveling (Manual Leveling).pdf
LHD Horn.pdf
LHD HVAC (Automatic Air Conditioner).pdf
LHD HVAC (Manual Air Conditioner).pdf
LHD Idling Stop System.pdf
LHD Information Module.pdf
LHD Information System.pdf
LHD Outside Mirror.pdf
LHD Parking Aid.pdf
LHD Power Assisted System.pdf
LHD Power Distribution (Except Idling Stop System).pdf
LHD Power Distribution (Idling Stop System).pdf
LHD Power Door Locks (Except Wireless Access Module).pdf
LHD Power Door Locks (Wireless Access Module (Hi-version)).pdf
LHD Power Door Locks (Wireless Access Module (Mid-versionLo-version)).pdf
LHD Power Windows.pdf
LHD Radar Sensor (Type 1).pdf
LHD Radar Sensor (Type 2).pdf
LHD Seats (Heated Seat).pdf
LHD Seats (Power Seat).pdf
LHD SRS airbag (DriverPassenger).pdf
LHD SRS airbag (DriverPassengerSideCurtainKneeFar Side).pdf
LHD Starter and Charging (4JJ3 (Euro4 and less) Except Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (4JJ3 (Euro4 and less) Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (4JJ3 (Euro5) Except Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (4JJ3 (Euro5) Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (RZ4E (Euro2 and less) Except Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (RZ4E (Euro2 and less) Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (RZ4E (Euro4) Except Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (RZ4E (Euro4) Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (RZ4E (Euro5) Except Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (RZ4E (Euro5) Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (RZ4F Except Wireless Access Module (Hi-version)).pdf
LHD Starter and Charging (RZ4F Wireless Access Module (Hi-version)).pdf
LHD Stereo Camera.pdf
LHD Stoplight (BCM).pdf
LHD Stoplight (Except BCM).pdf
LHD Taillight (BCM).pdf
LHD Taillight (Except BCM).pdf
LHD Tire Pressure Monitoring System.pdf
LHD Trailer Socket.pdf
LHD Turn Signal Light (BCM).pdf
LHD Turn Signal Light (Except BCM).pdf
LHD Urea SCR.pdf
LHD Windshield Wiper and Washer (BCM (Design Blade Type)).pdf
LHD Windshield Wiper and Washer (BCM (Flat Blade Type)).pdf
LHD Windshield Wiper and Washer (Except BCM).pdf
RHD 4WD.pdf
RHD Anti-lock Brake.pdf
RHD Audio (1DIN2DIN).pdf
RHD Audio (Display Audio).pdf
RHD Audio (Surround View Monitor).pdf
RHD Automatic Dimming.pdf
RHD Automatic Transmission (AWR6B45).pdf
RHD Automatic Transmission (L-B500).pdf
RHD Backup Light.pdf
RHD Battery Sensor.pdf
RHD Body Control (4JJ3 (Euro4 and less) RZ4E (Euro4 and less) RZ4F (Euro5 (Malaysia))).pdf
RHD Body Control (4JJ3 (Euro5) RZ4F (Euro5 (Australia))).pdf
RHD Body Control (RZ4F (Euro6e)).pdf
RHD Combination Meter.pdf
RHD Controller Area Network (Central Gateway CU 4JJ3 (Euro4 and less) RZ4E (Euro4 and less) RZ4F (Euro5 (Malaysia))).pdf
RHD Controller Area Network (Central Gateway CU 4JJ3 (Euro5) RZ4F (Euro5 (Australia) Euro6e)).pdf
RHD Controller Area Network (Except Central Gateway CU).pdf
RHD Data Recording.pdf
RHD Daytime Running Light.pdf
RHD Differential Lock.pdf
RHD DLC.pdf
RHD Dome Light (BCM).pdf
RHD Dome Light (Except BCM).pdf
RHD Driver Monitoring System.pdf
RHD eCall.pdf
RHD Electrical Socket.pdf
RHD Electronic Stability Control.pdf
RHD Engine Control (4JJ3 (Euro4 and less)).pdf
RHD Engine Control (4JJ3 (Euro5)).pdf
RHD Engine Control (RZ4E (Euro2 and less)).pdf
RHD Engine Control (RZ4E (Euro4)).pdf
RHD Engine Control (RZ4F).pdf
RHD Fog Light (Front Fog Light).pdf
RHD Fog Light (Rear Fog Light).pdf
RHD Fuse Load.pdf
RHD Ground Distribution.pdf
RHD Headlight (BCM).pdf
RHD Headlight (Except BCM).pdf
RHD Headlight Leveling (Auto Leveling).pdf
RHD Headlight Leveling (Manual Leveling).pdf
RHD Horn.pdf
RHD HVAC (Automatic Air Conditioner).pdf
RHD HVAC (Manual Air Conditioner).pdf
RHD Idling Stop System.pdf
RHD Information Module.pdf
RHD Information System.pdf
RHD Outside Mirror.pdf
RHD Parking Aid.pdf
RHD Power Assisted System.pdf
RHD Power Distribution (Except Idling Stop System).pdf
RHD Power Distribution (Idling Stop System).pdf
RHD Power Door Locks (Except Wireless Access Module).pdf
RHD Power Door Locks (Wireless Access Module (Hi-version) 4JJ3 (Euro4 and less) RZ4E (Euro4 and less) RZ4F (Euro5 (Malaysia))).pdf
RHD Power Door Locks (Wireless Access Module (Hi-version) 4JJ3 (Euro5) RZ4F (Euro5 (Australia) Euro6e)).pdf
RHD Power Door Locks (Wireless Access Module (Mid-versionLo-version)).pdf
RHD Power Windows.pdf
RHD Radar Sensor (Type 1).pdf
RHD Radar Sensor (Type 2).pdf
RHD Seats (Heated Seat).pdf
RHD Seats (Power Seat).pdf
RHD SRS airbag (DriverPassenger).pdf
RHD SRS airbag (DriverPassengerSideCurtainKneeFar Side).pdf
RHD Starter and Charging (4JJ3 (Euro2) Except Wireless Access Module (Hi-version)).pdf
RHD Starter and Charging (4JJ3 (Euro2) Wireless Access Module (Hi-version)).pdf
RHD Starter and Charging (4JJ3 (Euro4) RZ4E (Euro4) RZ4F (Euro5 (Malaysia)) Except Wireless Access Module (Hi-version)).pdf
RHD Starter and Charging (4JJ3 (Euro4) RZ4E (Euro4) RZ4F (Euro5 (Malaysia)) Wireless Access Module (Hi-version)).pdf
RHD Starter and Charging (4JJ3 (Euro5) RZ4F (Euro5 (Australia) Euro6e) Except Wireless Access Module (Hi-version)).pdf
RHD Starter and Charging (4JJ3 (Euro5) RZ4F (Euro5 (Australia) Euro6e) Wireless Access Module (Hi-version)).pdf
RHD Starter and Charging (RZ4E (Euro2 and less) Except Wireless Access Module (Hi-version)).pdf
RHD Starter and Charging (RZ4E (Euro2 and less) Wireless Access Module (Hi-version)).pdf
RHD Stereo Camera.pdf
RHD Stoplight (BCM).pdf
RHD Stoplight (Except BCM).pdf
RHD Taillight (BCM).pdf
RHD Taillight (Except BCM).pdf
RHD Tire Pressure Monitoring System.pdf
RHD Trailer Socket (8Pins Trailer Socket).pdf
RHD Trailer Socket (16Pins Trailer Socket).pdf
RHD Turn Signal Light (BCM).pdf
RHD Turn Signal Light (Except BCM).pdf
RHD Urea SCR.pdf
RHD Windshield Wiper and Washer (BCM (Design Blade Type)).pdf
RHD Windshield Wiper and Washer (BCM (Flat Blade Type)).pdf
RHD Windshield Wiper and Washer (Except BCM).pdf
