Isuzu D-Max TFR&TFS Series 2026 Mechanical Repair Procedures TFHTML-WEN-2651
- Download this document, you need 8625 Gallons
Type of Machine: Automotive Pickup
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu D-Max TFR Series ; TFS Series 20 Cab Model Pickup
Date: 2026
Engine: Isuzu 4JJ3 Euro2 ; 4JJ3 Euro4 ; 4JJ3 Euro5 ; RZ4E-TC Euro2 ; RZ4E-TC Euro4 ; RZ4E-TC Euro5 Engine
Except Thailand (Date:2026/05/29)
Parts Number: TFHTML-WEN-2651
Number of Pages: 14194 Pages
1.1. Engine (4JJ3 (Euro2 and Euro4 specification))
Date: 2026
1B. Mechanical
Camshaft - inspection
Camshaft - installation
Camshaft - removal
Crankcase - disassembly
Crankcase - inspection
Crankcase - installation
Crankcase - reassembly
Crankcase - removal
Crankshaft - disassembly
Crankshaft - inspection
Crankshaft - installation
Crankshaft - reassembly
Crankshaft - removal
Crankshaft front oil seal - installation
Crankshaft front oil seal - removal
Crankshaft pulley - installation
Crankshaft pulley - removal
Crankshaft rear oil seal - installation
Crankshaft rear oil seal - removal
Cylinder block - inspection
Cylinder block - installation
Cylinder block - removal
Cylinder head - disassembly
Cylinder head - inspection
Cylinder head - installation
Cylinder head - reassembly
Cylinder head - removal
Cylinder head cover - installation
Cylinder head cover - removal
Engine - installation
Engine - removal
Engine mounting - installation
Engine mounting - removal
Exhaust manifold - inspection
Exhaust manifold - installation
Exhaust manifold - removal
Flywheel - disassembly
Flywheel - inspection
Flywheel - installation
Flywheel - reassembly
Flywheel - removal
Idle gear - disassembly
Idle gear - inspection
Idle gear - installation
Idle gear - reassembly
Idle gear - removal
Inlet manifold - installation
Inlet manifold - removal
Intake throttle valve - installation
Intake throttle valve - removal
Piston - disassembly
Piston - inspection
Piston - installation
Piston - reassembly
Piston - removal
Rear plate - installation
Rear plate - removal
Rocker arm shaft - installation
Rocker arm shaft - removal
Supplementary Information
Swirl control solenoid valve - installation
Swirl control solenoid valve - removal
Timing chain - installation
Timing chain - removal
Timing gear case - installation
Timing gear case - removal
1C. Fuel System
Common rail (fuel rail) - installation
Common rail (fuel rail) - removal
Filler neck - installation
Filler neck - removal
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel filler cap - inspection
Fuel filler cap - installation
Fuel filler cap - removal
Fuel filter - inspection
Fuel filter - installation
Fuel filter - removal
Fuel filter element - installation
Fuel filter element - removal
Fuel supply pump - installation
Fuel supply pump - removal
Fuel tank - installation
Fuel tank - removal
Fuel tank unit - inspection
Fuel tank unit - installation
Fuel tank unit - removal
Fuel tube - inspection
Fuel tube - installation
Fuel tube - removal
Injector - installation
Injector - removal
Pre-fuel filter - installation
Pre-fuel filter - removal
Water sedimenter switch - inspection
Water sedimenter switch - installation
Water sedimenter switch - removal
1D. Cooling
Coolant - inspection
Coolant - replacement
Cooling fan belt - inspection
Cooling fan belt - installation
Cooling fan belt - removal
Cooling fan clutch - inspection
Cooling fan clutch - installation
Cooling fan clutch - removal
Radiator - inspection
Radiator - installation
Radiator - removal
Radiator reserve tank - installation
Radiator reserve tank - removal
Thermostat - inspection
Thermostat - installation
Thermostat - removal
Water pump - inspection
Water pump - installation
Water pump - removal
1E. Lubrication
Engine oil - inspection
Engine oil - replacement
Oil cooler - installation
Oil cooler - removal
Oil filter - installation
Oil filter - removal
Oil filter element - installation
Oil filter element - removal
Oil pan - installation
Oil pan - removal
Oil pressure switch - inspection
Oil pressure switch - installation
Oil pressure switch - removal
Oil pump - inspection
Oil pump - installation
Oil pump - removal
Oil tray - installation
Oil tray - removal
1F. Induction
Air cleaner element - inspection
Air cleaner element - installation
Air cleaner element - removal
Intercooler - inspection
Intercooler - installation
Intercooler - removal
Turbocharger - inspection
Turbocharger - installation
Turbocharger - removal
1G. Exhaust
Catalytic converter - installation
Catalytic converter - removal
Exhaust pipe - inspection
Exhaust pipe - installation
Exhaust pipe - removal
1H. Aux. Emission Control Devices
EGR cooler - inspection
EGR cooler - installation
EGR cooler - removal
EGR pipe - installation
EGR pipe - removal
EGR valve - inspection
EGR valve - installation
EGR valve - removal
1I. Speed Control Systems
Accelerator pedal - inspection
Accelerator pedal - installation
Accelerator pedal - removal
1J. Electrical
Generator - inspection
Generator - installation
Generator - removal
Glow plug - inspection
Glow plug - installation
Glow plug - removal
Starter motor - disassembly
Starter motor - inspection
Starter motor - installation
Starter motor - reassembly
Starter motor - removal
1Z. Engine Electrical Control
Boost pressure sensor - inspection
Boost pressure sensor - installation
Boost pressure sensor - removal
CKP sensor - inspection
CKP sensor - installation
CKP sensor - removal
CMP sensor - inspection
CMP sensor - installation
CMP sensor - removal
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
Engine coolant temperature sensor - inspection
Engine coolant temperature sensor - installation
Engine coolant temperature sensor - removal
Fuel temperature sensor - inspection
Fuel temperature sensor - installation
Fuel temperature sensor - removal
MAF and IAT sensor - inspection
MAF and IAT sensor - installation
MAF and IAT sensor - removal
1.2. Engine (4JJ3 (Euro5 specification))1B. Mechanical
Camshaft - removal
Crankcase - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Fuel tube - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
Oil tray - removal
1F. Induction
1G. Exhaust
DPD - inspection
DPD - installation
DPD - removal
EGR cooler bypass control solenoid valve - installation
EGR cooler bypass control solenoid valve - removal
EGR cooler bypass valve - inspection
EGR cooler bypass valve - installation
EGR cooler bypass valve - removal
EGR valve - removal
1J. Electrical
Battery sensor - installation
Battery sensor - removal
Generator - removal
Glow control unit - installation
Glow control unit - removal
Glow plug - removal
Charge air cooler temperature sensor 1 - inspection
Charge air cooler temperature sensor 1 - installation
Charge air cooler temperature sensor 1 - removal
Charge air cooler temperature sensor - inspection
Charge air cooler temperature sensor - installation
Charge air cooler temperature sensor - removal
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
EGR gas pressure sensor - inspection
EGR gas pressure sensor - installation
EGR gas pressure sensor - removal
EGR gas temperature sensor 1 (exhaust manifold side) - inspection
EGR gas temperature sensor 1 (exhaust manifold side) - installation
EGR gas temperature sensor 1 (exhaust manifold side) - removal
EGR gas temperature sensor 2 (EGR valve side) - inspection
EGR gas temperature sensor 2 (EGR valve side) - installation
EGR gas temperature sensor 2 (EGR valve side) - removal
Exhaust differential pressure sensor - inspection
Exhaust differential pressure sensor - installation
Exhaust differential pressure sensor - removal
Exhaust gas temperature sensor 1 (Front of DPD filter) - inspection
Exhaust gas temperature sensor 1 (Front of DPD filter) - installation
Exhaust gas temperature sensor 1 (Front of DPD filter) - removal
Exhaust gas temperature sensor 2 (Front of LNT catalyst) - inspection
Exhaust gas temperature sensor 2 (Front of LNT catalyst) - installation
Exhaust gas temperature sensor 2 (Front of LNT catalyst) - removal
Exhaust gas temperature sensor 2 (Front of oxidation catalyst) - inspection
Exhaust gas temperature sensor 2 (Front of oxidation catalyst) - installation
Exhaust gas temperature sensor 2 (Front of oxidation catalyst) - removal
Heated oxygen sensor 1 - installation
Heated oxygen sensor 1 - removal
Idling stop system control unit - installation
Idling stop system control unit - removal
Idling stop system control unit - setting
Oil level sensor - inspection
Oil level sensor - installation
Oil level sensor - removal
1.3. Engine (RZ4E-TC (Euro2 and less specification))1B. Mechanical
Camshaft - disassembly
Camshaft - reassembly
Camshaft - removal
Crankcase - removal
Engine - removal
Flywheel - removal
Flywheel housing - installation
Flywheel housing - removal
Front cover - installation
Front cover - removal
Idle gear - removal
Inlet cover - installation
Inlet cover - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
FRP regulator - installation
FRP regulator - removal
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Fuel tube - removal
Injector - removal
Pre-fuel filter element - installation
Pre-fuel filter element - removal
Pressure limiter - installation
Pressure limiter - removal
1D. Cooling
Auto tensioner - inspection
Auto tensioner - installation
Auto tensioner - removal
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - disassembly
Oil pump - reassembly
Oil pump - removal
1F. Induction
Relief valve - installation
Relief valve - removal
Relief valve control solenoid valve - installation
Relief valve control solenoid valve - removal
Turbocharger control solenoid valve - inspection
Turbocharger control solenoid valve - installation
Turbocharger control solenoid valve - removal
1G. Exhaust
EGR - inspection
EGR - installation
EGR - removal
EGR control solenoid valve - installation
EGR control solenoid valve - removal
1J. Electrical
Generator - removal
Glow plug - removal
ICR relay - inspection
ICR relay - installation
ICR relay - removal
Barometric pressure sensor - inspection
Barometric pressure sensor - installation
Barometric pressure sensor - removal
Boost pressure and CAC temperature sensor - inspection
Boost pressure and CAC temperature sensor - installation
Boost pressure and CAC temperature sensor - removal
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
FRP sensor - inspection
FRP sensor - installation
FRP sensor - removal
1.4. Engine (RZ4E-TC (Euro4 specification))1B. Mechanical
Camshaft - removal
Crankcase - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Fuel tube - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
EGR - inspection
EGR - installation
EGR - removal
1J. Electrical
Generator - removal
Glow plug - removal
ICR relay - removal
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
Engine oil temperature sensor - inspection
Engine oil temperature sensor - installation
Engine oil temperature sensor - removal
1.5. Engine (RZ4E-TC (Euro5 specification))1B. Mechanical
Camshaft - removal
Crankcase - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Fuel tube - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
DPD - inspection
DPD - installation
DPD - removal
EGR - inspection
EGR - installation
EGR - removal
1J. Electrical
Generator - removal
Glow plug - removal
ICR relay - removal
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
EGR gas temperature sensor - inspection
EGR gas temperature sensor - installation
EGR gas temperature sensor - removal
Heated oxygen sensor - installation
Heated oxygen sensor - removal
1.6. Engine (RZ4F-TC (Euro5 specification))1B. Mechanical
Camshaft - removal
Crankcase - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Fuel tube - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
DPD - inspection
DPD - installation
DPD - removal
EGR - inspection
EGR - installation
EGR - removal
1J. Electrical
Generator - removal
Glow plug - removal
ICR relay - removal
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
1.7. Engine (RZ4F-TC (Euro6d and Euro6e specification))1B. Mechanical
Camshaft - removal
Crankcase - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Fuel tube - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
DPD - inspection
DPD - installation
DPD - removal
Dosing module - installation
Dosing module - removal
EGR - inspection
EGR - installation
EGR - removal
Urea fluid - inspection
Urea fluid electro-thermal heater - installation
Urea fluid electro-thermal heater - removal
Urea fluid supply module - disassembly
Urea fluid supply module - reassembly
Urea fluid tank - installation
Urea fluid tank - removal
Urea SCR - inspection
Urea SCR - installation
Urea SCR - removal
1J. Electrical
Generator - removal
Glow plug - removal
ICR relay - removal
DCU - installation
DCU - removal
DCU - setting
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
Exhaust gas temperature sensor (urea SCR) - inspection
Exhaust gas temperature sensor (urea SCR) - installation
Exhaust gas temperature sensor (urea SCR) - removal
Heated oxygen sensor 1 (Front of LNT catalyst) - installation
Heated oxygen sensor 1 (Front of LNT catalyst) - removal
Heated oxygen sensor 2 (Rear of DPD filter) - installation
Heated oxygen sensor 2 (Rear of DPD filter) - removal
NOx sensor 1 - inspection
NOx sensor 1 - installation
NOx sensor 1 - removal
NOx sensor 2 - inspection
NOx sensor 2 - installation
NOx sensor 2 - removal
PM sensor - installation
PM sensor - removal
2. Suspension2B. Front Suspension
Independent suspension - disassembly
Independent suspension - inspection
Independent suspension - installation
Independent suspension - reassembly
Independent suspension - removal
2C. Rear Suspension
Leaf rigid suspension - disassembly
Leaf rigid suspension - inspection
Leaf rigid suspension - installation
Leaf rigid suspension - reassembly
Leaf rigid suspension - removal
2D. Wheel, Tire System
Disc wheel and tire - inspection
Disc wheel and tire - installation
Disc wheel and tire - removal
Tire air pressure sensor - installation
Tire air pressure sensor - removal
Tire air pressure sensor - setting
3. Driveline, Axle3B. Differentials
Differential oil - inspection
Differential oil - replacement
Front final drive (φ194 mm { 7.64 in }) - disassembly
Front final drive (φ194 mm { 7.64 in }) - inspection
Front final drive (φ194 mm { 7.64 in }) - installation
Front final drive (φ194 mm { 7.64 in }) - reassembly
Front final drive (φ194 mm { 7.64 in }) - removal
Rear final drive (φ220 mm { 8.66 in }) (LSD) - disassembly
Rear final drive (φ220 mm { 8.66 in }) (LSD) - inspection
Rear final drive (φ220 mm { 8.66 in }) (LSD) - installation
Rear final drive (φ220 mm { 8.66 in }) (LSD) - reassembly
Rear final drive (φ220 mm { 8.66 in }) (LSD) - removal
Rear final drive (φ220 mm { 8.66 in }) - disassembly
Rear final drive (φ220 mm { 8.66 in }) - inspection
Rear final drive (φ220 mm { 8.66 in }) - installation
Rear final drive (φ220 mm { 8.66 in }) - reassembly
Rear final drive (φ220 mm { 8.66 in }) - removal
Rear final drive (φ220 mm { 8.66 in })(differential lock) - disassembly
Rear final drive (φ220 mm { 8.66 in })(differential lock) - inspection
Rear final drive (φ220 mm { 8.66 in })(differential lock) - installation
Rear final drive (φ220 mm { 8.66 in })(differential lock) - reassembly
Rear final drive (φ220 mm { 8.66 in })(differential lock) - removal
3C. Drive Shaft System
Front axle shaft - disassembly
Front axle shaft - inspection
Front axle shaft - installation
Front axle shaft - reassembly
Front axle shaft - removal
Front drive axle - disassembly
Front drive axle - inspection
Front drive axle - installation
Front drive axle - reassembly
Front drive axle - removal
Front hub - disassembly
Front hub - inspection
Front hub - installation
Front hub - reassembly
Front hub - removal
Front propeller shaft - disassembly
Front propeller shaft - inspection
Front propeller shaft - installation
Front propeller shaft - reassembly
Front propeller shaft - removal
Knuckle - inspection
Knuckle - installation
Knuckle - removal
Rear axle - disassembly
Rear axle - inspection
Rear axle - installation
Rear axle - reassembly
Rear axle - removal
Rear axle shaft - disassembly
Rear axle shaft - inspection
Rear axle shaft - installation
Rear axle shaft - reassembly
Rear axle shaft - removal
Rear propeller shaft - disassembly
Rear propeller shaft - inspection
Rear propeller shaft - installation
Rear propeller shaft - reassembly
Rear propeller shaft - removal
Shift on the fly system - disassembly
Shift on the fly system - inspection
Shift on the fly system - installation
Shift on the fly system - reassembly
Shift on the fly system - removal
Shift on the fly system oil - inspection
Shift on the fly system oil - replacement
Wheel alignment check
3D. Transfer Case
Front output shaft oil seal - installation
Front output shaft oil seal - removal
Rear output shaft oil seal - installation
Rear output shaft oil seal - removal
Transfer - disassembly
Transfer - inspection
Transfer - installation
Transfer - reassembly
Transfer - removal
Transfer oil - inspection
Transfer oil - replacement
3Z. Driveline, Axle Electrical Control
Rear differential lock control unit - installation
Rear differential lock control unit - removal
Rear differential lock control unit - setting
TCCM - installation
TCCM - removal
TCCM - setting
4. Brakes4B. Brake System
Blend proportioning valve - inspection
Blend proportioning valve - installation
Blend proportioning valve - removal
Brake booster - inspection
Brake booster - installation
Brake booster - removal
Brake fluid - inspection
Brake fluid - replacement
Brake master cylinder - disassembly
Brake master cylinder - inspection
Brake master cylinder - installation
Brake master cylinder - reassembly
Brake master cylinder - removal
Brake pedal - inspection
Brake pedal - installation
Brake pedal - removal
Disc brake pad - inspection
Disc brake pad - installation
Disc brake pad - removal
Front disc brake - disassembly
Front disc brake - inspection
Front disc brake - installation
Front disc brake - reassembly
Front disc brake - removal
Rear drum brake - inspection
Rear drum brake - installation
Rear drum brake - removal
Rear wheel cylinder - disassembly
Rear wheel cylinder - inspection
Rear wheel cylinder - installation
Rear wheel cylinder - reassembly
Rear wheel cylinder - removal
Stoplight switch - inspection
Stoplight switch - installation
Stoplight switch - removal
Vacuum switch - inspection
Vacuum switch - installation
Vacuum switch - removal
4C. Parking Brake System
Parking brake - inspection
Parking brake - installation
Parking brake - removal
Parking brake lever - installation
Parking brake lever - removal
Parking brake switch - inspection
Parking brake switch - installation
Parking brake switch - removal
4D. ABS
Front exciter ring - installation
Front exciter ring - removal
Rear exciter ring - inspection
Rear exciter ring - installation
Rear exciter ring - removal
4Z. Brake Electrical Control
EHCU - installation
EHCU - removal
EHCU - setting
Front wheel speed sensor - inspection
Front wheel speed sensor - installation
Front wheel speed sensor - removal
Rear wheel speed sensor - inspection
Rear wheel speed sensor - installation
Rear wheel speed sensor - removal
5.1. Transmission, Transaxle (AWR6B45)5B. Automatic
ATF - inspection
ATF - replacement
ATF cooler_warmer - installation
ATF cooler_warmer - removal
Automatic transmission control cable - installation
Automatic transmission control cable - removal
Brake piston No.1 - disassembly
Brake piston No.1 - reassembly
Brake piston No.2 - disassembly
Brake piston No.2 - reassembly
Breather hose clip - disassembly
Breather hose clip - reassembly
Forward clutch assembly - disassembly
Forward clutch assembly - inspection
Forward clutch assembly - reassembly
Front planetary ring gear - disassembly
Front planetary ring gear - inspection
Front planetary ring gear - reassembly
Inhibitor switch - inspection
Inhibitor switch - installation
Inhibitor switch - removal
Middle planetary ring gear - disassembly
Middle planetary ring gear - reassembly
Rear planetary ring gear - disassembly
Rear planetary ring gear - inspection
Rear planetary ring gear - reassembly
Selector lever - disassembly
Selector lever - installation
Selector lever - reassembly
Selector lever - removal
Transmission - disassembly
Transmission - inspection
Transmission - installation
Transmission - reassembly
Transmission - removal
5Z. Transmission Electrical Control
Output speed sensor - inspection
Output speed sensor - installation
Output speed sensor - removal
TCM - installation
TCM - removal
TCM - setting
Turbine speed sensor - inspection
Turbine speed sensor - installation
Turbine speed sensor - removal
5.2. Transmission, Transaxle (L-B500)5B. Automatic
ATF - inspection
ATF - replacement
Brake cylinder assembly - disassembly
Brake cylinder assembly - inspection
Brake cylinder assembly - reassembly
Clutch No.1 assembly - disassembly
Clutch No.1 assembly - inspection
Clutch No.1 assembly - reassembly
Clutch No.2 assembly - disassembly
Clutch No.2 assembly - inspection
Clutch No.2 assembly - reassembly
Clutch No.3 assembly - disassembly
Clutch No.3 assembly - inspection
Clutch No.3 assembly - reassembly
Clutch No.4 assembly - disassembly
Clutch No.4 assembly - inspection
Clutch No.4 assembly - reassembly
TCM - installation
TCM - removal
TCM - setting
5.3. Transmission, Transaxle (MVL)5C. Manual
Input shaft - disassembly
Input shaft - inspection
Input shaft - reassembly
Main shaft - disassembly
Main shaft - inspection
Main shaft - reassembly
Rear case - disassembly
Rear case - inspection
Rear case - reassembly
Rear oil seal - installation
Rear oil seal - removal
Transmission oil - inspection
Transmission oil - replacement
5E. Clutch System
Clutch - inspection
Clutch - installation
Clutch - removal
Clutch control - inspection
Clutch control - installation
Clutch control - removal
Clutch master cylinder - inspection
Clutch master cylinder - installation
Clutch master cylinder - removal
Clutch switch - installation
Clutch switch - removal
Shift fork - inspection
Shift fork - installation
Shift fork - removal
Slave cylinder (CSC type) - inspection
Slave cylinder (CSC type) - installation
Slave cylinder (CSC type) - removal
Slave cylinder - disassembly
Slave cylinder - inspection
Slave cylinder - reassembly
Vehicle speed sensor - inspection
Vehicle speed sensor - installation
Vehicle speed sensor - removal
6. Steering6B. Power Assisted System
Power steering fluid - replacement
Power steering oil pump (4JJ3) - disassembly
Power steering oil pump (4JJ3) - inspection
Power steering oil pump (4JJ3) - installation
Power steering oil pump (4JJ3) - reassembly
Power steering oil pump (4JJ3) - removal
Power steering oil pump (RZ4E) - disassembly
Power steering oil pump (RZ4E) - inspection
Power steering oil pump (RZ4E) - installation
Power steering oil pump (RZ4E) - reassembly
Power steering oil pump (RZ4E) - removal
Power steering oil pump (RZ4F-TC) - disassembly
Power steering oil pump (RZ4F-TC) - inspection
Power steering oil pump (RZ4F-TC) - installation
Power steering oil pump (RZ4F-TC) - reassembly
Power steering oil pump (RZ4F-TC) - removal
Power steering unit - disassembly
Power steering unit - inspection
Power steering unit - installation
Power steering unit - reassembly
Power steering unit - removal
Power steering unit - setting
Steering column - inspection
Steering column - installation
Steering column - removal
6Z. Steering Electrical Control
Steering angle sensor - installation
Steering angle sensor - removal
Steering angle sensor - setting
7. HVAC7B. Heater Ventilator Airconditioner
A_C compressor (4JJ3) - installation
A_C compressor (4JJ3) - removal
A_C compressor (RZ4E) - installation
A_C compressor (RZ4E) - removal
A_C compressor (RZ4F) - installation
A_C compressor (RZ4F) - removal
A_C compressor drive belt(4JJ3) - inspection
A_C compressor drive belt(4JJ3) - installation
A_C compressor drive belt(4JJ3) - removal
A_C compressor magnet clutch - inspection
A_C compressor magnet clutch - installation
A_C compressor magnet clutch - removal
Actuator - installation
Actuator - removal
Blower - installation
Blower - removal
Blower module - inspection
Blower module - installation
Blower module - removal
Blower motor - inspection
Blower motor - installation
Blower motor - removal
Blower resistor - inspection
Blower resistor - installation
Blower resistor - removal
Condenser - installation
Condenser - removal
Control panel and control lever - inspection
Control panel and control lever - installation
Control panel and control lever - removal
Control panel and control lever - setting
Evaporator core - installation
Evaporator core - removal
Heater core - installation
Heater core - removal
Heater evaporator unit - installation
Heater evaporator unit - removal
Intake door - installation
Intake door - removal
Pressure switch - inspection
Pressure switch - installation
Pressure switch - removal
Rear ventilation duct - installation
Rear ventilation duct - removal
Vent grille - installation
Vent grille - removal
7Z. HVAC Control
Inside air temperature sensor - inspection
Inside air temperature sensor - installation
Inside air temperature sensor - removal
Outside air temperature sensor - inspection
Outside air temperature sensor - installation
Outside air temperature sensor - removal
Sun sensor - inspection
Sun sensor - installation
Sun sensor - removal
8. Restraints8B. Airbag Systems
Curtain airbag - installation
Curtain airbag - removal
Curtain airbag - scrapping
Driver airbag - installation
Driver airbag - removal
Driver airbag - scrapping
Far side air bag - installation
Far side air bag - removal
Far side air bag - scrapping
Knee air bag - installation
Knee air bag - removal
Knee air bag - scrapping
Passenger airbag - installation
Passenger airbag - removal
Passenger airbag - scrapping
Side airbag - installation
Side airbag - removal
Side airbag - scrapping
SRS coil - installation
SRS coil - removal
8C. Seat Belt Systems
Front buckle side seat belt - installation
Front buckle side seat belt - removal
Front tongue side seat belt (with pretensioner) (crew cab) - installation
Front tongue side seat belt (with pretensioner) (crew cab) - removal
Front tongue side seat belt (with pretensioner) (crew cab) - scrapping
Front tongue side seat belt (with pretensioner) (extend cab) - installation
Front tongue side seat belt (with pretensioner) (extend cab) - removal
Front tongue side seat belt (with pretensioner) (extend cab) - scrapping
Front tongue side seat belt (with pretensioner) (regular cab) - installation
Front tongue side seat belt (with pretensioner) (regular cab) - removal
Front tongue side seat belt (with pretensioner) (regular cab) - scrapping
Front tongue side seat belt (without pretensioner) (crew cab) - installation
Front tongue side seat belt (without pretensioner) (crew cab) - removal
Front tongue side seat belt (without pretensioner) (extend cab) - installation
Front tongue side seat belt (without pretensioner) (extend cab) - removal
Front tongue side seat belt (without pretensioner) (regular cab) - installation
Front tongue side seat belt (without pretensioner) (regular cab) - removal
Rear buckle side seat belt - installation
Rear buckle side seat belt - removal
Rear tongue side seat belt (with pretensioner) - installation
Rear tongue side seat belt (with pretensioner) - removal
Rear tongue side seat belt (with pretensioner) - scrapping
Rear tongue side seat belt (without pretensioner) - installation
Rear tongue side seat belt (without pretensioner) - removal
8Z. Seat Belt and SRS Airbag Electrical Control
Door side airbag sensor - installation
Door side airbag sensor - removal
Floor side airbag sensor - installation
Floor side airbag sensor - removal
Front airbag sensor - installation
Front airbag sensor - removal
Rear side airbag sensor (crew cab) - installation
Rear side airbag sensor (crew cab) - removal
Rear side airbag sensor (extend cab) - installation
Rear side airbag sensor (extend cab) - removal
SRS control unit - installation
SRS control unit - removal
SRS control unit - setting
9. Body, Cab, Accessories9A. Lighting Systems
Backup light bulb - installation
Backup light bulb - removal
Clearance light bulb - installation
Clearance light bulb - removal
Combination switch - inspection
Combination switch - installation
Combination switch - removal
Dome light bulb - installation
Dome light bulb - removal
Door switch - inspection
Door switch - installation
Door switch - removal
Fog daytime running light - installation
Fog daytime running light - removal
Fog daytime running light bulb - installation
Fog daytime running light bulb - removal
Fog light - installation
Fog light - removal
Fog light bulb - installation
Fog light bulb - removal
Front turn signal light bulb - installation
Front turn signal light bulb - removal
Halogen headlight bulb - installation
Halogen headlight bulb - removal
Hazard warning flasher switch - inspection
Hazard warning flasher switch - installation
Hazard warning flasher switch - removal
Headlight - inspection
Headlight - installation
Headlight - removal
Headlight leveling switch - inspection
Headlight leveling switch - installation
Headlight leveling switch - removal
High mounted stoplight - installation
High mounted stoplight - removal
Key reminder switch - inspection
Key reminder switch - installation
Key reminder switch - removal
License plate light bulb - installation
License plate light bulb - removal
Map light bulb - installation
Map light bulb - removal
Rear fog light bulb - installation
Rear fog light bulb - removal
Rear turn signal light bulb - installation
Rear turn signal light bulb - removal
Side turn signal light (door mirror integrated type) - installation
Side turn signal light (door mirror integrated type) - removal
Side turn signal light bulb - installation
Side turn signal light bulb - removal
Tail stoplight bulb - installation
Tail stoplight bulb - removal
9B. Wiper, Washer Systems
Washer motor - inspection
Washer motor - installation
Washer motor - removal
Washer nozzle - installation
Washer nozzle - removal
Washer tank - installation
Washer tank - removal
Wiper arm - installation
Wiper arm - removal
Wiper blade rubber - installation
Wiper blade rubber - removal
Wiper linkage - installation
Wiper linkage - removal
Wiper motor - inspection
Wiper motor - installation
Wiper motor - removal
9C. Electrical Control, Entertainment
4WD switch - inspection
4WD switch - installation
4WD switch - removal
Accessory socket - installation
Accessory socket - removal
Antenna - installation
Antenna - removal
Audio and navigation system - installation
Audio and navigation system - removal
Audio and navigation system - setting
Audio control steering wheel switch - inspection
Audio control steering wheel switch - installation
Audio control steering wheel switch - removal
Cruise control steering wheel switch - inspection
Cruise control steering wheel switch - installation
Cruise control steering wheel switch - removal
DC-DC converter (rearview mirror base USB charge) - installation
DC-DC converter (rearview mirror base USB charge) - removal
Differential lock switch - inspection
Differential lock switch - installation
Differential lock switch - removal
Engine start_stop button - inspection
Engine start_stop button - installation
Engine start_stop button - removal
ESC OFF switch - inspection
ESC OFF switch - installation
ESC OFF switch - removal
Front door speaker - inspection
Front door speaker - installation
Front door speaker - removal
Front seat USB port - installation
Front seat USB port - removal
Heated seat switch - inspection
Heated seat switch - installation
Heated seat switch - removal
Hill descent control switch - inspection
Hill descent control switch - installation
Hill descent control switch - removal
Horn - inspection
Horn - installation
Horn - removal
Horn switch - inspection
Horn switch - installation
Horn switch - removal
Idling stop system OFF switch - inspection
Idling stop system OFF switch - installation
Idling stop system OFF switch - removal
Ignition switch - inspection
Ignition switch - installation
Ignition switch - removal
Illumination control switch - installation
Illumination control switch - removal
Parking aid system OFF switch - inspection
Parking aid system OFF switch - installation
Parking aid system OFF switch - removal
Passenger airbag cut off switch - inspection
Passenger airbag cut off switch - installation
Passenger airbag cut off switch - removal
Rear door speaker - inspection
Rear door speaker - installation
Rear door speaker - removal
Rear seat USB charge port - installation
Rear seat USB charge port - removal
Rearview mirror base USB charge - installation
Rearview mirror base USB charge - removal
Roof speaker - inspection
Roof speaker - installation
Roof speaker - removal
Rough terrain mode switch - inspection
Rough terrain mode switch - installation
Rough terrain mode switch - removal
SOS button - inspection
SOS button - installation
SOS button - removal
TPMS load selector switch - inspection
TPMS load selector switch - installation
TPMS load selector switch - removal
Tweeter - installation
Tweeter - removal
9E. Instrumentation, Driver Info
Antenna - removal
DC-DC converter (idling stop system) - installation
DC-DC converter (idling stop system) - removal
Driver monitor camera - installation
Driver monitor camera - removal
Forward collision warning light - installation
Forward collision warning light - removal
Front camera - installation
Front camera - removal
Instrument panel cluster - diagnostics
Instrument panel cluster - installation
Instrument panel cluster - removal
Instrument panel cluster - setting
Microphone - installation
Microphone - removal
Passenger airbag indicator - installation
Passenger airbag indicator - removal
Radar sensor (Type 1) - installation
Radar sensor (Type 1) - removal
Radar sensor (Type 1) - setting
Radar sensor (Type 2) - installation
Radar sensor (Type 2) - removal
Radar sensor (Type 2) - setting
Rearview camera - installation
Rearview camera - removal
Side camera - installation
Side camera - removal
Sonar sensor - installation
Sonar sensor - removal
Speaker microphone - installation
Speaker microphone - removal
Stereo camera - cleaning
Stereo camera - installation
Stereo camera - removal
Stereo camera - setting
Stereo camera - writing
9G. Hood, Fenders, Doors
Engine hood - installation
Engine hood - removal
Engine hood control cable - installation
Engine hood control cable - removal
Engine hood lock - installation
Engine hood lock - removal
Front door - disassembly
Front door - installation
Front door - reassembly
Front door - removal
Front fender panel - installation
Front fender panel - removal
Rear door - disassembly
Rear door - installation
Rear door - reassembly
Rear door - removal
Rear mudguard - installation
Rear mudguard - removal
Side access panel - disassembly
Side access panel - installation
Side access panel - reassembly
Side access panel - removal
Transmission air deflector - installation
Transmission air deflector - removal
Underguard - installation
Underguard - removal
9H. Cab Structure
Air outlet valve - installation
Air outlet valve - removal
Back panel seal - installation
Back panel seal - removal
Front bumper - disassembly
Front bumper - installation
Front bumper - reassembly
Front bumper - removal
Radiator grille - installation
Radiator grille - removal
Rear step bumper - disassembly
Rear step bumper - installation
Rear step bumper - reassembly
Rear step bumper - removal
Rear underrun protector - installation
Rear underrun protector - removal
Roof rail - installation
Roof rail - removal
Side step - installation
Side step - removal
9I. Seats
Driver seat - disassembly
Driver seat - installation
Driver seat - reassembly
Driver seat - removal
Passenger seat - disassembly
Passenger seat - installation
Passenger seat - reassembly
Passenger seat - removal
Rear seat - disassembly
Rear seat - installation
Rear seat - reassembly
Rear seat - removal
9J. Security and Locks
Anti theft horn - installation
Anti theft horn - removal
Center in-vehicle antenna - installation
Center in-vehicle antenna - removal
Electronic key - disassembly
Electronic key - reassembly
Electronic key - setting
External buzzer - installation
External buzzer - removal
Front door lock - inspection
Front door lock - installation
Front door lock - removal
Fuel filler lid cable - installation
Fuel filler lid cable - removal
Immobilizer coil - installation
Immobilizer coil - removal
Key cylinder (door) - installation
Key cylinder (door) - removal
Key cylinder (tailgate) - installation
Key cylinder (tailgate) - removal
Keyless entry key - disassembly
Keyless entry key - reassembly
Keyless entry key - setting
Rear door lock - inspection
Rear door lock - installation
Rear door lock - removal
Steering lock - installation
Steering lock - removal
Steering lock - setting
Steering lock barrel - installation
Steering lock barrel - removal
Transponder key - setting
9L. Exterior, Interior Trim
Center pillar upper trim cover - installation
Center pillar upper trim cover - removal
Console box - installation
Console box - removal
Front pillar trim cover - installation
Front pillar trim cover - removal
Head lining (crew cab) - disassembly
Head lining (crew cab) - installation
Head lining (crew cab) - reassembly
Head lining (crew cab) - removal
Head lining (extended cab) - disassembly
Head lining (extended cab) - installation
Head lining (extended cab) - reassembly
Head lining (extended cab) - removal
Head lining (regular cab) - installation
Head lining (regular cab) - removal
Instrument panel - installation
Instrument panel - removal
Rear end trim cover - installation
Rear end trim cover - removal
Rear pillar trim cover (crew cab) - installation
Rear pillar trim cover (crew cab) - removal
Rear pillar trim cover (extended cab) - installation
Rear pillar trim cover (extended cab) - removal
Rear pillar trim cover (regular cab) - installation
Rear pillar trim cover (regular cab) - removal
Reinforcement - installation
Reinforcement - removal
9P. Unibody Sub-frames
Body mounting - installation
Body mounting - removal
Rear body - installation
Rear body - removal
Tail gate - installation
Tail gate - removal
9T. Glass, Windows, Mirrors
Backlight glass - installation
Backlight glass - removal
Front door power window switch - inspection
Front door power window switch - installation
Front door power window switch - removal
Front door power window switch - setting
Front windshield glass - installation
Front windshield glass - removal
Outside rearview mirror - disassembly
Outside rearview mirror - installation
Outside rearview mirror - reassembly
Outside rearview mirror - removal
Rear door power window switch - inspection
Rear door power window switch - installation
Rear door power window switch - removal
Remote control mirror switch - inspection
Remote control mirror switch - installation
Remote control mirror switch - removal
9Z. Body, Cab, Accessories Electrical Control
BCM - installation
BCM - removal
BCM - setting
Central gateway control unit - installation
Central gateway control unit - removal
Central gateway control unit - setting
DRM - installation
DRM - removal
ECall unit - installation
ECall unit - removal
ECall unit - setting
ECall unit backup battery - installation
ECall unit backup battery - removal
Headlight auto leveling control unit - installation
Headlight auto leveling control unit - removal
Headlight auto leveling control unit - setting
Heated seat control unit - installation
Heated seat control unit - removal
Image processing unit (driver monitor camera) - installation
Image processing unit (driver monitor camera) - removal
Image processing unit (driver monitor camera) - setting
Information module - installation
Information module - removal
Information module - setting
MAP unit - installation
MAP unit - removal
MAP unit - setting
Parking aid system control unit - installation
Parking aid system control unit - removal
Parking aid system control unit - setting
Rain and light sensor - installation
Rain and light sensor - removal
Surround view control unit - installation
Surround view control unit - removal
Surround view control unit - setting
Surround view control unit - writing
Wireless access module - installation
Wireless access module - removal
Wireless access module - setting (with passive entry and start system)
Wireless access module - setting (without passive entry and start system)
