Isuzu D-Max TFR&TFS Series 2025 Electronic Service Information Wiring Diagram TFHTML-WEN-2541
Download this document, you need 15000 Gallons
Type of Machine: Automotive-Pickup
Type of Manual: Electronic Service Information - Mechanical Repair Procedures, Diagnostics Service Information, Wiring Diagram
Model: Isuzu D-Max TFR Series, TFS Series 20 Cab model
Date: 2025
Engine: Isuzu 4JJ3 Euro2 ; 4JJ3 Euro4 ; 4JJ3 Euro5 ; RZ4E-TC Euro2 ; RZ4E-TC Euro4 ; RZ4E-TC Euro5 Engine
3rd edition, Except Thailand (Date: 2025/12/19)
Parts Number: TFHTML-WEN-2541
Purchase Options: You can buy the Full Package or click on the individual links below to buy them separately.
------ List of Files ------
1. [Mechanical Repair Procedures]
2. [Diagnostics Service Information]
3. [Wiring Diagram]
LHD 4WD.pdf​
LHD Anti-lock Brake.pdf​
LHD Audio (1DIN or 2DIN).pdf​
LHD Audio (Display Audio).pdf​
LHD Automatic Dimming.pdf​
LHD Automatic Transmission (4JJ3 RZ4E (Euro5 and less)).pdf​
LHD Automatic Transmission (RZ4E (Euro6d Euro6e)).pdf​
LHD Backup Light.pdf​
LHD Battery Sensor.pdf​
LHD Body Control (4JJ3 RZ4E (Euro5 and less)).pdf​
LHD Body Control (RZ4E (Euro6d Euro6e)).pdf​
LHD Combination Meter.pdf​
LHD Controller Area Network (Central Gateway CU 4JJ3 RZ4E (Euro5 and less)).pdf​
LHD Controller Area Network (Central Gateway CU RZ4E (Euro6d Euro6e)).pdf​
LHD Controller Area Network (Except Central Gateway CU 4JJ3 RZ4E (Euro5 and less)).pdf​
LHD Controller Area Network (Except Central Gateway CU RZ4E (Euro6d Euro6e)).pdf​
LHD Data Recording.pdf​
LHD Daytime Running Light.pdf​
LHD Differential Lock.pdf​
LHD DLC.pdf​
LHD Dome Light (BCM).pdf​
LHD Dome Light (Except BCM).pdf​
LHD eCall.pdf​
LHD Electrical Socket.pdf​
LHD Electronic Stability Control (4JJ3 RZ4E (Euro5 and less)).pdf​
LHD Electronic Stability Control (RZ4E (Euro6d Euro6e)).pdf​
LHD Engine Control (4JJ3 (Euro4 and less)).pdf​
LHD Engine Control (4JJ3 (Euro5 Euro6)).pdf​
LHD Engine Control (RZ4E (Euro2 and less)).pdf​
LHD Engine Control (RZ4E (Euro4)).pdf​
LHD Engine Control (RZ4E (Euro5)).pdf​
LHD Engine Control (RZ4E (Euro6d Euro6e)).pdf​
LHD ERA-GLONASS.pdf​
LHD Fog Light (Front Fog Light).pdf​
LHD Fog Light (Rear Fog Light).pdf​
LHD Fuse Load.pdf​
LHD Ground Distribution.pdf​
LHD Headlight (BCM).pdf​
LHD Headlight (Except BCM).pdf​
LHD Headlight Leveling (Auto Leveling).pdf​
LHD Headlight Leveling (Manual Leveling).pdf​
LHD Horn.pdf​
LHD HVAC (Automatic Air Conditioner).pdf​
LHD HVAC (Manual Air Conditioner).pdf​
LHD Idling Stop System.pdf​
LHD Information Module.pdf​
LHD Information System.pdf​
LHD Outside Mirror.pdf​
LHD Parking Aid.pdf​
LHD Power Assisted System.pdf​
LHD Power Distribution (4JJ3 RZ4E (Euro5 and less)).pdf​
LHD Power Distribution (RZ4E (Euro6d Euro6e)).pdf​
LHD Power Door Locks (Except Wireless Access Module).pdf​
LHD Power Door Locks (Wireless Access Module (Hi-version)).pdf​
LHD Power Door Locks (Wireless Access Module (Mid-versionLo-version)).pdf​
LHD Power Windows.pdf​
LHD Radar Sensor (Type 1).pdf​
LHD Radar Sensor (Type 2).pdf​
LHD Seats (Heated Seat).pdf​
LHD Seats (Power Seat).pdf​
LHD SRS airbag (DriverPassenger).pdf​
LHD SRS airbag (DriverPassengerSideCurtainKneeFar Side).pdf​
LHD Starter and Charging (4JJ3 (Euro4 and less) Except Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (4JJ3 (Euro4 and less) Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (4JJ3 (Euro5 Euro6) Except Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (4JJ3 (Euro5 Euro6) Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (RZ4E (Euro2 and less) Except Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (RZ4E (Euro2 and less) Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (RZ4E (Euro4) Except Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (RZ4E (Euro4) Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (RZ4E (Euro5) Except Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (RZ4E (Euro5) Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (RZ4E (Euro6d Euro6e) Except Wireless Access Module (Hi-version)).pdf​
LHD Starter and Charging (RZ4E (Euro6d Euro6e) Wireless Access Module (Hi-version)).pdf​
LHD Stereo Camera.pdf​
LHD Stoplight (BCM).pdf​
LHD Stoplight (Except BCM).pdf​
LHD Taillight (BCM).pdf​
LHD Taillight (Except BCM).pdf​
LHD Tire Pressure Monitoring System.pdf​
LHD Trailer Socket.pdf​
LHD Turn Signal Light (BCM).pdf​
LHD Turn Signal Light (Except BCM).pdf​
LHD Urea SCR.pdf​
LHD Windshield Wiper and Washer (BCM (Design Blade Type)).pdf​
LHD Windshield Wiper and Washer (BCM (Flat Blade Type)).pdf​
LHD Windshield Wiper and Washer (Except BCM).pdf​
RHD 4WD.pdf​
RHD Anti-lock Brake.pdf​
RHD Audio (2DIN).pdf​
RHD Audio (Display Audio).pdf​
RHD Automatic Dimming.pdf​
RHD Automatic Transmission (4JJ3 RZ4E (Euro5 and less)).pdf​
RHD Automatic Transmission (RZ4E (Euro6d Euro6e)).pdf​
RHD Automatic Transmission (RZ4F).pdf​
RHD Backup Light.pdf​
RHD Battery Sensor.pdf​
RHD Body Control (4JJ3 (Euro4 and less) RZ4E (Euro4 and less)).pdf​
RHD Body Control (4JJ3 (Euro5) RZ4E (Euro5) RZ4F).pdf​
RHD Body Control (RZ4E (Euro6d Euro6e)).pdf​
RHD Combination Meter.pdf​
RHD Controller Area Network (Central Gateway CU 4JJ3 (Euro4 and less) RZ4E (Euro4 and less)).pdf​
RHD Controller Area Network (Central Gateway CU 4JJ3 (Euro5) RZ4E (Euro5 Euro6d Euro6e) RZ4F).pdf​
RHD Controller Area Network (Except Central Gateway CU 4JJ3 (Euro4 and less) RZ4E (Euro4 and less)).pdf​
RHD Controller Area Network (Except Central Gateway CU RZ4E (Euro6d Euro6e)).pdf​
RHD Data Recording.pdf​
RHD Daytime Running Light.pdf​
RHD Differential Lock.pdf​
RHD DLC.pdf​
RHD Dome Light (BCM).pdf​
RHD Dome Light (Except BCM).pdf​
RHD eCall.pdf​
RHD Electrical Socket.pdf​
RHD Electronic Stability Control.pdf​
RHD Engine Control (4JJ3 (Euro4 and less)).pdf​
RHD Engine Control (4JJ3 (Euro5)).pdf​
RHD Engine Control (RZ4E (Euro2 and less)).pdf​
RHD Engine Control (RZ4E (Euro4)).pdf​
RHD Engine Control (RZ4E (Euro5)).pdf​
RHD Engine Control (RZ4E (Euro6d Euro6e)).pdf​
RHD Engine Control (RZ4F).pdf​
RHD Fog Light (Front Fog Light).pdf​
RHD Fog Light (Rear Fog Light).pdf​
RHD Fuse Load.pdf​
RHD Ground Distribution.pdf​
RHD Headlight (BCM).pdf​
RHD Headlight (Except BCM).pdf​
RHD Headlight Leveling (Auto Leveling).pdf​
RHD Headlight Leveling (Manual Leveling 4JJ3 RZ4E (Euro4 and less) RZ4F).pdf​
RHD Headlight Leveling (Manual Leveling RZ4E (Euro6d Euro6e)).pdf​
RHD Horn.pdf​
RHD HVAC (Automatic Air Conditioner).pdf​
RHD HVAC (Manual Air Conditioner).pdf​
RHD Idling Stop System.pdf​
RHD Information Module.pdf​
RHD Information System.pdf​
RHD Outside Mirror.pdf​
RHD Parking Aid.pdf​
RHD Power Assisted System.pdf​
RHD Power Distribution (4JJ3 (Except Idling Stop System) RZ4E (Euro5 and less)).pdf​
RHD Power Distribution (4JJ3 (Idling Stop System) RZ4E (Euro6d Euro6e) RZ4F).pdf​
RHD Power Door Locks (Except Wireless Access Module).pdf​
RHD Power Door Locks (Wireless Access Module (Hi-version) 4JJ3 (Euro4 and less) RZ4E (Euro4 and less)).pdf​
RHD Power Door Locks (Wireless Access Module (Hi-version) 4JJ3 (Euro5) RZ4E (Euro5 Euro6d Euro6e) RZ4F).pdf​
RHD Power Door Locks (Wireless Access Module (Mid-versionLo-version)).pdf​
RHD Power Windows.pdf​
RHD Radar Sensor (Type 1).pdf​
RHD Radar Sensor (Type 2).pdf​
RHD Seats (Heated Seat).pdf​
RHD Seats (Power Seat).pdf​
RHD SRS airbag (DriverPassenger).pdf​
RHD SRS airbag (DriverPassengerSideCurtainKneeFar Side).pdf​
RHD Starter and Charging (4JJ3 (Euro2) Except Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (4JJ3 (Euro2) Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (4JJ3 (Euro4) RZ4E (Euro4) Except Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (4JJ3 (Euro4) RZ4E (Euro4) Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (4JJ3 (Euro5 Except Idling Stop System) RZ4E (Euro5) Except Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (4JJ3 (Euro5 Except Idling Stop System) RZ4E (Euro5) Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (4JJ3 (Euro5 Idling Stop System) RZ4F Except Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (4JJ3 (Euro5 Idling Stop System) RZ4F Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (RZ4E (Euro2 and less) Except Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (RZ4E (Euro2 and less) Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (RZ4E (Euro6d Euro6e) Except Wireless Access Module (Hi-version)).pdf​
RHD Starter and Charging (RZ4E (Euro6d Euro6e) Wireless Access Module (Hi-version)).pdf​
RHD Stereo Camera.pdf​
RHD Stoplight (BCM).pdf​
RHD Stoplight (Except BCM).pdf​
RHD Taillight (BCM).pdf​
RHD Taillight (Except BCM).pdf​
RHD Tire Pressure Monitoring System.pdf​
RHD Trailer Socket (8Pins Trailer Socket).pdf​
RHD Trailer Socket (16Pins Trailer Socket).pdf​
RHD Turn Signal Light (BCM).pdf​
RHD Turn Signal Light (Except BCM).pdf​
RHD Urea SCR.pdf​
RHD Windshield Wiper and Washer (BCM (Design Blade Type)).pdf​
RHD Windshield Wiper and Washer (BCM (Flat Blade Type)).pdf​
RHD Windshield Wiper and Washer (Except BCM).pdf​
