Isuzu D-Max TFR&TFS Series 2025 Mechanical Repair Procedures TFHTML-WEN-2541
Type of Machine: Automotive-Pickup
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu D-Max TFR Series, TFS Series 20 Cab model
Date: 2025
Engine: Isuzu 4JJ3 Euro2 ; 4JJ3 Euro4 ; 4JJ3 Euro5 ; RZ4E-TC Euro2 ; RZ4E-TC Euro4 ; RZ4E-TC Euro5 Engine
3rd edition, Except Thailand (Date: 2025/12/19)
Parts Number: TFHTML-WEN-2541
Number of Pages: 13749 Pages
1.1. Engine (4JJ3 (Euro2 and Euro4 specification))
1B. Mechanical​
Camshaft - inspection​
Camshaft - installation​
Camshaft - removal​
Crankcase - disassembly​
Crankcase - inspection​
Crankcase - installation​
Crankcase - reassembly​
Crankcase - removal​
Crankshaft - disassembly​
Crankshaft - inspection​
Crankshaft - installation​
Crankshaft - reassembly​
Crankshaft - removal​
Crankshaft front oil seal - installation​
Crankshaft front oil seal - removal​
Crankshaft pulley - installation​
Crankshaft pulley - removal​
Crankshaft rear oil seal - installation​
Crankshaft rear oil seal - removal​
Cylinder block - inspection​
Cylinder block - installation​
Cylinder block - removal​
Cylinder head - disassembly​
Cylinder head - inspection​
Cylinder head - installation​
Cylinder head - reassembly​
Cylinder head - removal​
Cylinder head cover - installation​
Cylinder head cover - removal​
Engine - installation​
Engine - removal​
Engine mounting - installation​
Engine mounting - removal​
Exhaust manifold - inspection​
Exhaust manifold - installation​
Exhaust manifold - removal​
Flywheel - disassembly​
Flywheel - inspection​
Flywheel - installation​
Flywheel - reassembly​
Flywheel - removal​
Idle gear - disassembly​
Idle gear - inspection​
Idle gear - installation​
Idle gear - reassembly​
Idle gear - removal​
Inlet manifold - installation​
Inlet manifold - removal​
Intake throttle valve - installation​
Intake throttle valve - removal​
Piston - disassembly​
Piston - inspection​
Piston - installation​
Piston - reassembly​
Piston - removal​
Rear plate - installation​
Rear plate - removal​
Rocker arm shaft - installation​
Rocker arm shaft - removal​
Supplementary Information​
Swirl control solenoid valve - installation​
Swirl control solenoid valve - removal​
Timing chain - installation​
Timing chain - removal​
Timing gear case - installation​
Timing gear case - removal​
1C. Fuel System​
Common rail (fuel rail) - installation​
Common rail (fuel rail) - removal​
Filler neck - installation​
Filler neck - removal​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Fuel filler cap - inspection​
Fuel filler cap - installation​
Fuel filler cap - removal​
Fuel filter - inspection​
Fuel filter - installation​
Fuel filter - removal​
Fuel filter element - installation​
Fuel filter element - removal​
Fuel supply pump - installation​
Fuel supply pump - removal​
Fuel tank - installation​
Fuel tank - removal​
Fuel tank unit - inspection​
Fuel tank unit - installation​
Fuel tank unit - removal​
Fuel tube - inspection​
Fuel tube - installation​
Fuel tube - removal​
Injector - installation​
Injector - removal​
Pre-fuel filter - installation​
Pre-fuel filter - removal​
Water sedimenter switch - inspection​
Water sedimenter switch - installation​
Water sedimenter switch - removal​
1D. Cooling​
Coolant - inspection​
Coolant - replacement​
Cooling fan belt - inspection​
Cooling fan belt - installation​
Cooling fan belt - removal​
Cooling fan clutch - inspection​
Cooling fan clutch - installation​
Cooling fan clutch - removal​
Radiator - inspection​
Radiator - installation​
Radiator - removal​
Radiator reserve tank - installation​
Radiator reserve tank - removal​
Thermostat - inspection​
Thermostat - installation​
Thermostat - removal​
Water pump - inspection​
Water pump - installation​
Water pump - removal​
1E. Lubrication​
Engine oil - inspection​
Engine oil - replacement​
Oil cooler - installation​
Oil cooler - removal​
Oil filter - installation​
Oil filter - removal​
Oil filter element - installation​
Oil filter element - removal​
Oil pan - installation​
Oil pan - removal​
Oil pressure switch - inspection​
Oil pressure switch - installation​
Oil pressure switch - removal​
Oil pump - inspection​
Oil pump - installation​
Oil pump - removal​
Oil tray - installation​
Oil tray - removal​
1F. Induction​
Air cleaner element - inspection​
Air cleaner element - installation​
Air cleaner element - removal​
Intercooler - inspection​
Intercooler - installation​
Intercooler - removal​
Turbocharger - inspection​
Turbocharger - installation​
Turbocharger - removal​
1G. Exhaust​
Catalytic converter - installation​
Catalytic converter - removal​
Exhaust pipe - inspection​
Exhaust pipe - installation​
Exhaust pipe - removal​
1H. Aux. Emission Control Devices​
EGR cooler - inspection​
EGR cooler - installation​
EGR cooler - removal​
EGR valve - inspection​
EGR valve - installation​
EGR valve - removal​
1I. Speed Control Systems​
Accelerator pedal - inspection​
Accelerator pedal - installation​
Accelerator pedal - removal​
1J. Electrical​
Generator - inspection​
Generator - installation​
Generator - removal​
Glow plug - inspection​
Glow plug - installation​
Glow plug - removal​
Starter motor - disassembly​
Starter motor - inspection​
Starter motor - installation​
Starter motor - reassembly​
Starter motor - removal​
1Z. Engine Electrical Control​
Boost pressure sensor - inspection​
Boost pressure sensor - installation​
Boost pressure sensor - removal​
CKP sensor - inspection​
CKP sensor - installation​
CKP sensor - removal​
CMP sensor - inspection​
CMP sensor - installation​
CMP sensor - removal​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
Engine coolant temperature sensor - inspection​
Engine coolant temperature sensor - installation​
Engine coolant temperature sensor - removal​
Fuel temperature sensor - inspection​
Fuel temperature sensor - installation​
Fuel temperature sensor - removal​
MAF and IAT sensor - inspection​
MAF and IAT sensor - installation​
MAF and IAT sensor - removal​
1.2. Engine (4JJ3 (Euro5 and Euro6 specification))
1B. Mechanical​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Piston - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
1D. Cooling​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pump - removal​
Oil tray - removal​
1F. Induction​
1G. Exhaust​
DPD - inspection​
DPD - installation​
DPD - removal​
EGR cooler bypass control solenoid valve - installation​
EGR cooler bypass control solenoid valve - removal​
EGR cooler bypass valve - inspection​
EGR cooler bypass valve - installation​
EGR cooler bypass valve - removal​
1J. Electrical​
Battery sensor - installation​
Battery sensor - removal​
Glow control unit - installation​
Glow control unit - removal​
Charge air cooler temperature sensor 1 - inspection​
Charge air cooler temperature sensor 1 - installation​
Charge air cooler temperature sensor 1 - removal​
Charge air cooler temperature sensor - inspection​
Charge air cooler temperature sensor - installation​
Charge air cooler temperature sensor - removal​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
EGR gas pressure sensor - inspection​
EGR gas pressure sensor - installation​
EGR gas pressure sensor - removal​
EGR gas temperature sensor 1 (exhaust manifold side) - inspection​
EGR gas temperature sensor 1 (exhaust manifold side) - installation​
EGR gas temperature sensor 1 (exhaust manifold side) - removal​
EGR gas temperature sensor 2 (EGR valve side) - inspection​
EGR gas temperature sensor 2 (EGR valve side) - installation​
EGR gas temperature sensor 2 (EGR valve side) - removal​
Exhaust differential pressure sensor - inspection​
Exhaust differential pressure sensor - installation​
Exhaust differential pressure sensor - removal​
Exhaust gas temperature sensor 1 (Front of DPD filter) - inspection​
Exhaust gas temperature sensor 1 (Front of DPD filter) - installation​
Exhaust gas temperature sensor 1 (Front of DPD filter) - removal​
Exhaust gas temperature sensor 2 (Front of LNT catalyst) - inspection​
Exhaust gas temperature sensor 2 (Front of LNT catalyst) - installation​
Exhaust gas temperature sensor 2 (Front of LNT catalyst) - removal​
Exhaust gas temperature sensor 2 (Front of oxidation catalyst) - inspection​
Exhaust gas temperature sensor 2 (Front of oxidation catalyst) - installation​
Exhaust gas temperature sensor 2 (Front of oxidation catalyst) - removal​
Heated oxygen sensor 1 - installation​
Heated oxygen sensor 1 - removal​
Heated oxygen sensor 2 - installation​
Heated oxygen sensor 2 - removal​
Idling stop system control unit - installation​
Idling stop system control unit - removal​
Idling stop system control unit - setting​
Oil level sensor - inspection​
Oil level sensor - installation​
Oil level sensor - removal​
PM sensor - installation​
PM sensor - removal​
1.3. Engine (RZ4E-TC (Euro2 and less specification))
1B. Mechanical​
Camshaft - disassembly​
Camshaft - reassembly​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Flywheel housing - installation​
Flywheel housing - removal​
Front cover - installation​
Front cover - removal​
Inlet cover - installation​
Inlet cover - removal​
Piston - removal​
1C. Fuel System​
FRP regulator - installation​
FRP regulator - removal​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
Pre-fuel filter element - installation​
Pre-fuel filter element - removal​
Pressure limiter - installation​
Pressure limiter - removal​
1D. Cooling​
Auto tensioner - inspection​
Auto tensioner - installation​
Auto tensioner - removal​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pump - disassembly​
Oil pump - reassembly​
Oil pump - removal​
1F. Induction​
Relief valve - installation​
Relief valve - removal​
Relief valve control solenoid valve - installation​
Relief valve control solenoid valve - removal​
Turbocharger control solenoid valve - inspection​
Turbocharger control solenoid valve - installation​
Turbocharger control solenoid valve - removal​
1G. Exhaust​
EGR - inspection​
EGR - installation​
EGR - removal​
EGR control solenoid valve - installation​
EGR control solenoid valve - removal​
1J. Electrical​
ICR relay - inspection​
ICR relay - installation​
ICR relay - removal​
Barometric pressure sensor - inspection​
Barometric pressure sensor - installation​
Barometric pressure sensor - removal​
Boost pressure and CAC temperature sensor - inspection​
Boost pressure and CAC temperature sensor - installation​
Boost pressure and CAC temperature sensor - removal​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
FRP sensor - inspection​
FRP sensor - installation​
FRP sensor - removal​
1.4. Engine (RZ4E-TC (Euro4 specification))
1B. Mechanical​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Piston - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
1D. Cooling​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pump - removal​
1F. Induction​
1G. Exhaust​
EGR - inspection​
EGR - installation​
EGR - removal​
1J. Electrical​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
Engine oil temperature sensor - inspection​
Engine oil temperature sensor - installation​
Engine oil temperature sensor - removal​
1.5. Engine (RZ4E-TC (Euro5 specification))
1B. Mechanical​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Piston - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
1D. Cooling​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pump - removal​
1F. Induction​
1G. Exhaust​
DPD - inspection​
DPD - installation​
DPD - removal​
EGR - inspection​
EGR - installation​
EGR - removal​
1J. Electrical​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
EGR gas temperature sensor - inspection​
EGR gas temperature sensor - installation​
EGR gas temperature sensor - removal​
Heated oxygen sensor - installation​
Heated oxygen sensor - removal​
1.6. Engine (RZ4E-TC (Euro6d and Euro6e specification))
1B. Mechanical​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Piston - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
1D. Cooling​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pump - removal​
1F. Induction​
Electric water pump - installation​
Electric water pump - removal​
Sub radiator - inspection​
Sub radiator - installation​
Sub radiator - removal​
Sub radiator sub tank - installation​
Sub radiator sub tank - removal​
1G. Exhaust​
DPD - inspection​
DPD - installation​
DPD - removal​
Dosing module - installation​
Dosing module - removal​
EGR - inspection​
EGR - installation​
EGR - removal​
Low pressure EGR - installation​
Low pressure EGR - removal​
Low pressure EGR filter - installation​
Low pressure EGR filter - removal​
Urea fluid - inspection​
Urea fluid electro-thermal heater - installation​
Urea fluid electro-thermal heater - removal​
Urea fluid supply module - disassembly​
Urea fluid supply module - reassembly​
Urea fluid tank - installation​
Urea fluid tank - removal​
Urea SCR - inspection​
Urea SCR - installation​
Urea SCR - removal​
1J. Electrical​
DCU - installation​
DCU - removal​
DCU - setting​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
Exhaust gas temperature sensor 1 (Front of LNT catalyst) - inspection​
Exhaust gas temperature sensor 1 (Front of LNT catalyst) - installation​
Exhaust gas temperature sensor 1 (Front of LNT catalyst) - removal​
Exhaust gas temperature sensor 2 (Front of DPD filter) - inspection​
Exhaust gas temperature sensor 2 (Front of DPD filter) - installation​
Exhaust gas temperature sensor 2 (Front of DPD filter) - removal​
Exhaust gas temperature sensor (urea SCR) - inspection​
Exhaust gas temperature sensor (urea SCR) - installation​
Exhaust gas temperature sensor (urea SCR) - removal​
Heated oxygen sensor 1 (Front of LNT catalyst) - installation​
Heated oxygen sensor 1 (Front of LNT catalyst) - removal​
Heated oxygen sensor 2 (Rear of DPD filter) - installation​
Heated oxygen sensor 2 (Rear of DPD filter) - removal​
Low pressure EGR cooler differential pressure sensor - installation​
Low pressure EGR cooler differential pressure sensor - removal​
Low pressure EGR gas temperature sensor - inspection​
Low pressure EGR gas temperature sensor - installation​
Low pressure EGR gas temperature sensor - removal​
NOx sensor 1 (DPD) - inspection​
NOx sensor 1 (DPD) - installation​
NOx sensor 1 (DPD) - removal​
NOx sensor 2 (urea SCR) - inspection​
NOx sensor 2 (urea SCR) - installation​
NOx sensor 2 (urea SCR) - removal​
1.7. Engine (RZ4F-TC)
1B. Mechanical​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Piston - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
1D. Cooling​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pump - removal​
1F. Induction​
1G. Exhaust​
DPD - inspection​
DPD - installation​
DPD - removal​
EGR - inspection​
EGR - installation​
EGR - removal​
1J. Electrical​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
2. Suspension
2B. Front Suspension​
Independent suspension - disassembly​
Independent suspension - inspection​
Independent suspension - installation​
Independent suspension - reassembly​
Independent suspension - removal​
2C. Rear Suspension​
Leaf rigid suspension - disassembly​
Leaf rigid suspension - inspection​
Leaf rigid suspension - installation​
Leaf rigid suspension - reassembly​
Leaf rigid suspension - removal​
2D. Wheel, Tire System​
Disc wheel and tire - inspection​
Disc wheel and tire - installation​
Disc wheel and tire - removal​
Tire air pressure sensor - installation​
Tire air pressure sensor - removal​
Tire air pressure sensor - setting​
3. Driveline, Axle
3B. Differentials​
Differential oil - inspection​
Differential oil - replacement​
Front final drive (φ194 mm { 7.64 in }) - disassembly​
Front final drive (φ194 mm { 7.64 in }) - inspection​
Front final drive (φ194 mm { 7.64 in }) - installation​
Front final drive (φ194 mm { 7.64 in }) - reassembly​
Front final drive (φ194 mm { 7.64 in }) - removal​
Rear final drive (φ220 mm { 8.66 in }) (LSD) - disassembly​
Rear final drive (φ220 mm { 8.66 in }) (LSD) - inspection​
Rear final drive (φ220 mm { 8.66 in }) (LSD) - installation​
Rear final drive (φ220 mm { 8.66 in }) (LSD) - reassembly​
Rear final drive (φ220 mm { 8.66 in }) (LSD) - removal​
Rear final drive (φ220 mm { 8.66 in }) - disassembly​
Rear final drive (φ220 mm { 8.66 in }) - inspection​
Rear final drive (φ220 mm { 8.66 in }) - installation​
Rear final drive (φ220 mm { 8.66 in }) - reassembly​
Rear final drive (φ220 mm { 8.66 in }) - removal​
Rear final drive (φ220 mm { 8.66 in })(differential lock) - disassembly​
Rear final drive (φ220 mm { 8.66 in })(differential lock) - inspection​
Rear final drive (φ220 mm { 8.66 in })(differential lock) - installation​
Rear final drive (φ220 mm { 8.66 in })(differential lock) - reassembly​
Rear final drive (φ220 mm { 8.66 in })(differential lock) - removal​
3C. Drive Shaft System​
Front axle shaft - disassembly​
Front axle shaft - inspection​
Front axle shaft - installation​
Front axle shaft - reassembly​
Front axle shaft - removal​
Front drive axle - disassembly​
Front drive axle - inspection​
Front drive axle - installation​
Front drive axle - reassembly​
Front drive axle - removal​
Front hub - disassembly​
Front hub - inspection​
Front hub - installation​
Front hub - reassembly​
Front hub - removal​
Front propeller shaft - disassembly​
Front propeller shaft - inspection​
Front propeller shaft - installation​
Front propeller shaft - reassembly​
Front propeller shaft - removal​
Knuckle - inspection​
Knuckle - installation​
Knuckle - removal​
Rear axle - disassembly​
Rear axle - inspection​
Rear axle - installation​
Rear axle - reassembly​
Rear axle - removal​
Rear axle shaft - disassembly​
Rear axle shaft - inspection​
Rear axle shaft - installation​
Rear axle shaft - reassembly​
Rear axle shaft - removal​
Rear propeller shaft - disassembly​
Rear propeller shaft - inspection​
Rear propeller shaft - installation​
Rear propeller shaft - reassembly​
Rear propeller shaft - removal​
Shift on the fly system - disassembly​
Shift on the fly system - inspection​
Shift on the fly system - installation​
Shift on the fly system - reassembly​
Shift on the fly system - removal​
Shift on the fly system oil - inspection​
Shift on the fly system oil - replacement​
Wheel alignment check​
3D. Transfer Case​
Front output shaft oil seal - installation​
Front output shaft oil seal - removal​
Rear output shaft oil seal - installation​
Rear output shaft oil seal - removal​
Transfer - disassembly​
Transfer - inspection​
Transfer - installation​
Transfer - reassembly​
Transfer - removal​
Transfer oil - inspection​
Transfer oil - replacement​
3Z. Driveline, Axle Electrical Control​
Rear differential lock control unit - installation​
Rear differential lock control unit - removal​
Rear differential lock control unit - setting​
TCCM - installation​
TCCM - removal​
TCCM - setting​
4. Brakes
4B. Brake System​
Blend proportioning valve - inspection​
Blend proportioning valve - installation​
Blend proportioning valve - removal​
Brake booster - inspection​
Brake booster - installation​
Brake booster - removal​
Brake fluid - inspection​
Brake fluid - replacement​
Brake master cylinder - disassembly​
Brake master cylinder - inspection​
Brake master cylinder - installation​
Brake master cylinder - reassembly​
Brake master cylinder - removal​
Brake pedal - inspection​
Brake pedal - installation​
Brake pedal - removal​
Disc brake pad - inspection​
Disc brake pad - installation​
Disc brake pad - removal​
Front disc brake - disassembly​
Front disc brake - inspection​
Front disc brake - installation​
Front disc brake - reassembly​
Front disc brake - removal​
Rear drum brake - inspection​
Rear drum brake - installation​
Rear drum brake - removal​
Rear wheel cylinder - disassembly​
Rear wheel cylinder - inspection​
Rear wheel cylinder - installation​
Rear wheel cylinder - reassembly​
Rear wheel cylinder - removal​
Stoplight switch - inspection​
Stoplight switch - installation​
Stoplight switch - removal​
Vacuum switch - inspection​
Vacuum switch - installation​
Vacuum switch - removal​
4C. Parking Brake System​
Parking brake - inspection​
Parking brake - installation​
Parking brake - removal​
Parking brake lever - installation​
Parking brake lever - removal​
Parking brake switch - inspection​
Parking brake switch - installation​
Parking brake switch - removal​
4D. ABS​
Front exciter ring - installation​
Front exciter ring - removal​
Rear exciter ring - inspection​
Rear exciter ring - installation​
Rear exciter ring - removal​
4Z. Brake Electrical Control​
EHCU - installation​
EHCU - removal​
EHCU - setting​
Front wheel speed sensor - inspection​
Front wheel speed sensor - installation​
Front wheel speed sensor - removal​
Rear wheel speed sensor - inspection​
Rear wheel speed sensor - installation​
Rear wheel speed sensor - removal​
5.1. Transmission, Transaxle (AWR6B45)
5B. Automatic​
ATF - inspection​
ATF - replacement​
ATF cooler_warmer - installation​
ATF cooler_warmer - removal​
Automatic transmission control cable - installation​
Automatic transmission control cable - removal​
Brake piston No.1 - disassembly​
Brake piston No.1 - reassembly​
Brake piston No.2 - disassembly​
Brake piston No.2 - reassembly​
Breather hose clip - disassembly​
Breather hose clip - reassembly​
Forward clutch assembly - disassembly​
Forward clutch assembly - inspection​
Forward clutch assembly - reassembly​
Front planetary ring gear - disassembly​
Front planetary ring gear - inspection​
Front planetary ring gear - reassembly​
Inhibitor switch - inspection​
Inhibitor switch - installation​
Inhibitor switch - removal​
Middle planetary ring gear - disassembly​
Middle planetary ring gear - reassembly​
Rear planetary ring gear - disassembly​
Rear planetary ring gear - inspection​
Rear planetary ring gear - reassembly​
Selector lever - disassembly​
Selector lever - installation​
Selector lever - reassembly​
Selector lever - removal​
Transmission - disassembly​
Transmission - inspection​
Transmission - installation​
Transmission - reassembly​
Transmission - removal​
5Z. Transmission Electrical Control​
Output speed sensor - inspection​
Output speed sensor - installation​
Output speed sensor - removal​
TCM - installation​
TCM - removal​
TCM - setting​
Turbine speed sensor - inspection​
Turbine speed sensor - installation​
Turbine speed sensor - removal​
5.2. Transmission, Transaxle (L-B500)
5B. Automatic​
ATF - inspection​
ATF - replacement​
Brake cylinder assembly - disassembly​
Brake cylinder assembly - inspection​
Brake cylinder assembly - reassembly​
Clutch No.1 assembly - disassembly​
Clutch No.1 assembly - inspection​
Clutch No.1 assembly - reassembly​
Clutch No.2 assembly - disassembly​
Clutch No.2 assembly - inspection​
Clutch No.2 assembly - reassembly​
Clutch No.3 assembly - disassembly​
Clutch No.3 assembly - inspection​
Clutch No.3 assembly - reassembly​
Clutch No.4 assembly - disassembly​
Clutch No.4 assembly - inspection​
Clutch No.4 assembly - reassembly​
TCM - installation​
TCM - removal​
TCM - setting​
5.3. Transmission, Transaxle (MVL)
5C. Manual​
Input shaft - disassembly​
Input shaft - inspection​
Input shaft - reassembly​
Main shaft - disassembly​
Main shaft - inspection​
Main shaft - reassembly​
Rear case - disassembly​
Rear case - inspection​
Rear case - reassembly​
Rear oil seal - installation​
Rear oil seal - removal​
Transmission oil - inspection​
Transmission oil - replacement​
5E. Clutch System​
Clutch - inspection​
Clutch - installation​
Clutch - removal​
Clutch control - inspection​
Clutch control - installation​
Clutch control - removal​
Clutch master cylinder - inspection​
Clutch master cylinder - installation​
Clutch master cylinder - removal​
Clutch switch - installation​
Clutch switch - removal​
Shift fork - inspection​
Shift fork - installation​
Shift fork - removal​
Slave cylinder - disassembly​
Slave cylinder - inspection​
Slave cylinder - reassembly​
Vehicle speed sensor - inspection​
Vehicle speed sensor - installation​
Vehicle speed sensor - removal​
6. Steering
6B. Power Assisted System​
Power steering fluid - replacement​
Power steering oil pump (4JJ3) - disassembly​
Power steering oil pump (4JJ3) - inspection​
Power steering oil pump (4JJ3) - installation​
Power steering oil pump (4JJ3) - reassembly​
Power steering oil pump (4JJ3) - removal​
Power steering oil pump (RZ4E) - disassembly​
Power steering oil pump (RZ4E) - inspection​
Power steering oil pump (RZ4E) - installation​
Power steering oil pump (RZ4E) - reassembly​
Power steering oil pump (RZ4E) - removal​
Power steering unit - disassembly​
Power steering unit - inspection​
Power steering unit - installation​
Power steering unit - reassembly​
Power steering unit - removal​
Power steering unit - setting​
Steering column - inspection​
Steering column - installation​
Steering column - removal​
6Z. Steering Electrical Control​
Steering angle sensor - installation​
Steering angle sensor - removal​
Steering angle sensor - setting​
7. HVAC
7B. Heater Ventilator Airconditioner​
A_C compressor (4JJ3) - installation​
A_C compressor (4JJ3) - removal​
A_C compressor (RZ4E) - installation​
A_C compressor (RZ4E) - removal​
A_C compressor (RZ4F) - installation​
A_C compressor (RZ4F) - removal​
A_C compressor drive belt(4JJ3) - inspection​
A_C compressor drive belt(4JJ3) - installation​
A_C compressor drive belt(4JJ3) - removal​
A_C compressor magnet clutch - inspection​
A_C compressor magnet clutch - installation​
A_C compressor magnet clutch - removal​
Actuator - installation​
Actuator - removal​
Blower - installation​
Blower - removal​
Blower module - inspection​
Blower module - installation​
Blower module - removal​
Blower motor - inspection​
Blower motor - installation​
Blower motor - removal​
Blower resistor - inspection​
Blower resistor - installation​
Blower resistor - removal​
Condenser - installation​
Condenser - removal​
Control panel and control lever - inspection​
Control panel and control lever - installation​
Control panel and control lever - removal​
Control panel and control lever - setting​
Evaporator core - installation​
Evaporator core - removal​
Heater core - installation​
Heater core - removal​
Heater evaporator unit - installation​
Heater evaporator unit - removal​
Intake door - installation​
Intake door - removal​
Pressure switch - inspection​
Pressure switch - installation​
Pressure switch - removal​
Rear ventilation duct - installation​
Rear ventilation duct - removal​
Vent grille - installation​
Vent grille - removal​
7Z. HVAC Control​
Inside air temperature sensor - inspection​
Inside air temperature sensor - installation​
Inside air temperature sensor - removal​
Outside air temperature sensor - inspection​
Outside air temperature sensor - installation​
Outside air temperature sensor - removal​
Sun sensor - inspection​
Sun sensor - installation​
Sun sensor - removal​
8. Restraints
8B. Airbag Systems​
Curtain airbag - installation​
Curtain airbag - removal​
Curtain airbag - scrapping​
Driver airbag - installation​
Driver airbag - removal​
Driver airbag - scrapping​
Far side air bag - installation​
Far side air bag - removal​
Far side air bag - scrapping​
Knee air bag - installation​
Knee air bag - removal​
Knee air bag - scrapping​
Passenger airbag - installation​
Passenger airbag - removal​
Passenger airbag - scrapping​
Side airbag - installation​
Side airbag - removal​
Side airbag - scrapping​
SRS coil - installation​
SRS coil - removal​
8C. Seat Belt Systems​
Front buckle side seat belt - installation​
Front buckle side seat belt - removal​
Front tongue side seat belt (with pretensioner) (crew cab) - installation​
Front tongue side seat belt (with pretensioner) (crew cab) - removal​
Front tongue side seat belt (with pretensioner) (crew cab) - scrapping​
Front tongue side seat belt (with pretensioner) (extend cab) - installation​
Front tongue side seat belt (with pretensioner) (extend cab) - removal​
Front tongue side seat belt (with pretensioner) (extend cab) - scrapping​
Front tongue side seat belt (with pretensioner) (regular cab) - installation​
Front tongue side seat belt (with pretensioner) (regular cab) - removal​
Front tongue side seat belt (with pretensioner) (regular cab) - scrapping​
Front tongue side seat belt (without pretensioner) (crew cab) - installation​
Front tongue side seat belt (without pretensioner) (crew cab) - removal​
Front tongue side seat belt (without pretensioner) (extend cab) - installation​
Front tongue side seat belt (without pretensioner) (extend cab) - removal​
Front tongue side seat belt (without pretensioner) (regular cab) - installation​
Front tongue side seat belt (without pretensioner) (regular cab) - removal​
Rear buckle side seat belt - installation​
Rear buckle side seat belt - removal​
Rear tongue side seat belt (with pretensioner) - installation​
Rear tongue side seat belt (with pretensioner) - removal​
Rear tongue side seat belt (with pretensioner) - scrapping​
Rear tongue side seat belt (without pretensioner) - installation​
Rear tongue side seat belt (without pretensioner) - removal​
8Z. Seat Belt and SRS Airbag Electrical Control​
Door side airbag sensor - installation​
Door side airbag sensor - removal​
Floor side airbag sensor - installation​
Floor side airbag sensor - removal​
Front airbag sensor - installation​
Front airbag sensor - removal​
Rear side airbag sensor (crew cab) - installation​
Rear side airbag sensor (crew cab) - removal​
Rear side airbag sensor (extend cab) - installation​
Rear side airbag sensor (extend cab) - removal​
SRS control unit - installation​
SRS control unit - removal​
SRS control unit - setting​
9. Body, Cab, Accessories
9A. Lighting Systems​
Backup light bulb - installation​
Backup light bulb - removal​
Clearance light bulb - installation​
Clearance light bulb - removal​
Combination switch - inspection​
Combination switch - installation​
Combination switch - removal​
Dome light bulb - installation​
Dome light bulb - removal​
Door switch - inspection​
Door switch - installation​
Door switch - removal​
Fog daytime running light - installation​
Fog daytime running light - removal​
Fog daytime running light bulb - installation​
Fog daytime running light bulb - removal​
Fog light - installation​
Fog light - removal​
Fog light bulb - installation​
Fog light bulb - removal​
Front turn signal light bulb - installation​
Front turn signal light bulb - removal​
Halogen headlight bulb - installation​
Halogen headlight bulb - removal​
Hazard warning flasher switch - inspection​
Hazard warning flasher switch - installation​
Hazard warning flasher switch - removal​
Headlight - inspection​
Headlight - installation​
Headlight - removal​
Headlight leveling switch - inspection​
Headlight leveling switch - installation​
Headlight leveling switch - removal​
High mounted stoplight - installation​
High mounted stoplight - removal​
Key reminder switch - inspection​
Key reminder switch - installation​
Key reminder switch - removal​
License plate light bulb - installation​
License plate light bulb - removal​
Map light bulb - installation​
Map light bulb - removal​
Rear fog light bulb - installation​
Rear fog light bulb - removal​
Rear turn signal light bulb - installation​
Rear turn signal light bulb - removal​
Side turn signal light (door mirror integrated type) - installation​
Side turn signal light (door mirror integrated type) - removal​
Side turn signal light bulb - installation​
Side turn signal light bulb - removal​
Tail stoplight bulb - installation​
Tail stoplight bulb - removal​
9B. Wiper, Washer Systems​
Washer motor - inspection​
Washer motor - installation​
Washer motor - removal​
Washer nozzle - installation​
Washer nozzle - removal​
Washer tank - installation​
Washer tank - removal​
Wiper arm - installation​
Wiper arm - removal​
Wiper blade rubber - installation​
Wiper blade rubber - removal​
Wiper linkage - installation​
Wiper linkage - removal​
Wiper motor - inspection​
Wiper motor - installation​
Wiper motor - removal​
9C. Electrical Control, Entertainment​
4WD switch - inspection​
4WD switch - installation​
4WD switch - removal​
Accessory socket - installation​
Accessory socket - removal​
Antenna - installation​
Antenna - removal​
Audio and navigation system - installation​
Audio and navigation system - removal​
Audio and navigation system - setting​
Audio control steering wheel switch - inspection​
Audio control steering wheel switch - installation​
Audio control steering wheel switch - removal​
Cruise control steering wheel switch - inspection​
Cruise control steering wheel switch - installation​
Cruise control steering wheel switch - removal​
DC-DC converter (rearview mirror base USB charge) - installation​
DC-DC converter (rearview mirror base USB charge) - removal​
Differential lock switch - inspection​
Differential lock switch - installation​
Differential lock switch - removal​
Engine start_stop button - inspection​
Engine start_stop button - installation​
Engine start_stop button - removal​
ESC OFF switch - inspection​
ESC OFF switch - installation​
ESC OFF switch - removal​
Front door speaker - inspection​
Front door speaker - installation​
Front door speaker - removal​
Front seat USB port - installation​
Front seat USB port - removal​
Heated seat switch - inspection​
Heated seat switch - installation​
Heated seat switch - removal​
Hill descent control switch - inspection​
Hill descent control switch - installation​
Hill descent control switch - removal​
Horn - inspection​
Horn - installation​
Horn - removal​
Horn switch - inspection​
Horn switch - installation​
Horn switch - removal​
Idling stop system OFF switch - inspection​
Idling stop system OFF switch - installation​
Idling stop system OFF switch - removal​
Ignition switch - inspection​
Ignition switch - installation​
Ignition switch - removal​
Illumination control switch - installation​
Illumination control switch - removal​
Parking aid system OFF switch - inspection​
Parking aid system OFF switch - installation​
Parking aid system OFF switch - removal​
Passenger airbag cut off switch - inspection​
Passenger airbag cut off switch - installation​
Passenger airbag cut off switch - removal​
Rear door speaker - inspection​
Rear door speaker - installation​
Rear door speaker - removal​
Rear seat USB charge port - installation​
Rear seat USB charge port - removal​
Rearview mirror base USB charge - installation​
Rearview mirror base USB charge - removal​
Roof speaker - inspection​
Roof speaker - installation​
Roof speaker - removal​
Rough terrain mode switch - inspection​
Rough terrain mode switch - installation​
Rough terrain mode switch - removal​
SOS button - inspection​
SOS button - installation​
SOS button - removal​
TPMS load selector switch - inspection​
TPMS load selector switch - installation​
TPMS load selector switch - removal​
Tweeter - installation​
Tweeter - removal​
9E. Instrumentation, Driver Info​
Antenna - removal​
DC-DC converter (idling stop system) - installation​
DC-DC converter (idling stop system) - removal​
Forward collision warning light - installation​
Forward collision warning light - removal​
Instrument panel cluster - diagnostics​
Instrument panel cluster - installation​
Instrument panel cluster - removal​
Instrument panel cluster - setting​
Microphone - installation​
Microphone - removal​
Passenger airbag indicator - installation​
Passenger airbag indicator - removal​
Radar sensor (Type 1) - installation​
Radar sensor (Type 1) - removal​
Radar sensor (Type 1) - setting​
Radar sensor (Type 2) - installation​
Radar sensor (Type 2) - removal​
Radar sensor (Type 2) - setting​
Rearview camera - installation​
Rearview camera - removal​
Sonar sensor - installation​
Sonar sensor - removal​
Speaker microphone - installation​
Speaker microphone - removal​
Stereo camera - cleaning​
Stereo camera - installation​
Stereo camera - removal​
Stereo camera - setting​
Stereo camera - writing​
9G. Hood, Fenders, Doors​
Engine hood - installation​
Engine hood - removal​
Engine hood control cable - installation​
Engine hood control cable - removal​
Engine hood lock - installation​
Engine hood lock - removal​
Front door - disassembly​
Front door - installation​
Front door - reassembly​
Front door - removal​
Front fender panel - installation​
Front fender panel - removal​
Rear door - disassembly​
Rear door - installation​
Rear door - reassembly​
Rear door - removal​
Rear mudguard - installation​
Rear mudguard - removal​
Side access panel - disassembly​
Side access panel - installation​
Side access panel - reassembly​
Side access panel - removal​
Transmission air deflector - installation​
Transmission air deflector - removal​
Underguard - installation​
Underguard - removal​
9H. Cab Structure​
Air outlet valve - installation​
Air outlet valve - removal​
Back panel seal - installation​
Back panel seal - removal​
Front bumper - disassembly​
Front bumper - installation​
Front bumper - reassembly​
Front bumper - removal​
Radiator grille - installation​
Radiator grille - removal​
Rear step bumper - disassembly​
Rear step bumper - installation​
Rear step bumper - reassembly​
Rear step bumper - removal​
Rear underrun protector - installation​
Rear underrun protector - removal​
Roof rail - installation​
Roof rail - removal​
Side step - installation​
Side step - removal​
9I. Seats​
Driver seat - disassembly​
Driver seat - installation​
Driver seat - reassembly​
Driver seat - removal​
Passenger seat - disassembly​
Passenger seat - installation​
Passenger seat - reassembly​
Passenger seat - removal​
Rear seat - disassembly​
Rear seat - installation​
Rear seat - reassembly​
Rear seat - removal​
9J. Security and Locks​
Anti theft horn - installation​
Anti theft horn - removal​
Center in-vehicle antenna - installation​
Center in-vehicle antenna - removal​
Electronic key - disassembly​
Electronic key - reassembly​
Electronic key - setting​
External buzzer - installation​
External buzzer - removal​
Front door lock - inspection​
Front door lock - installation​
Front door lock - removal​
Fuel filler lid cable - installation​
Fuel filler lid cable - removal​
Immobilizer coil - installation​
Immobilizer coil - removal​
Key cylinder (door) - installation​
Key cylinder (door) - removal​
Key cylinder (tailgate) - installation​
Key cylinder (tailgate) - removal​
Keyless entry key - disassembly​
Keyless entry key - reassembly​
Keyless entry key - setting​
Rear door lock - inspection​
Rear door lock - installation​
Rear door lock - removal​
Steering lock - installation​
Steering lock - removal​
Steering lock - setting​
Steering lock barrel - installation​
Steering lock barrel - removal​
Transponder key - setting​
9L. Exterior, Interior Trim​
Center pillar upper trim cover - installation​
Center pillar upper trim cover - removal​
Console box - installation​
Console box - removal​
Front pillar trim cover - installation​
Front pillar trim cover - removal​
Head lining (crew cab) - disassembly​
Head lining (crew cab) - installation​
Head lining (crew cab) - reassembly​
Head lining (crew cab) - removal​
Head lining (extended cab) - disassembly​
Head lining (extended cab) - installation​
Head lining (extended cab) - reassembly​
Head lining (extended cab) - removal​
Head lining (regular cab) - installation​
Head lining (regular cab) - removal​
Instrument panel - installation​
Instrument panel - removal​
Rear end trim cover - installation​
Rear end trim cover - removal​
Rear pillar trim cover (crew cab) - installation​
Rear pillar trim cover (crew cab) - removal​
Rear pillar trim cover (extended cab) - installation​
Rear pillar trim cover (extended cab) - removal​
Rear pillar trim cover (regular cab) - installation​
Rear pillar trim cover (regular cab) - removal​
Reinforcement - installation​
Reinforcement - removal​
9P. Unibody Sub-frames​
Body mounting - installation​
Body mounting - removal​
Rear body - installation​
Rear body - removal​
Tail gate - installation​
Tail gate - removal​
9T. Glass, Windows, Mirrors​
Backlight glass - installation​
Backlight glass - removal​
Front door power window switch - inspection​
Front door power window switch - installation​
Front door power window switch - removal​
Front door power window switch - setting​
Front windshield glass - installation​
Front windshield glass - removal​
Outside rearview mirror - disassembly​
Outside rearview mirror - installation​
Outside rearview mirror - reassembly​
Outside rearview mirror - removal​
Rear door power window switch - inspection​
Rear door power window switch - installation​
Rear door power window switch - removal​
Remote control mirror switch - inspection​
Remote control mirror switch - installation​
Remote control mirror switch - removal​
9Z. Body, Cab, Accessories Electrical Control​
BCM - installation​
BCM - removal​
BCM - setting​
Central gateway control unit - installation​
Central gateway control unit - removal​
Central gateway control unit - setting​
DRM - installation​
DRM - removal​
ECall unit - installation​
ECall unit - removal​
ECall unit - setting​
ECall unit backup battery - installation​
ECall unit backup battery - removal​
Headlight auto leveling control unit - installation​
Headlight auto leveling control unit - removal​
Headlight auto leveling control unit - setting​
Heated seat control unit - installation​
Heated seat control unit - removal​
Information module - installation​
Information module - removal​
Information module - setting​
MAP unit - installation​
MAP unit - removal​
MAP unit - setting​
Parking aid system control unit - installation​
Parking aid system control unit - removal​
Parking aid system control unit - setting​
Rain and light sensor - installation​
Rain and light sensor - removal​
Wireless access module - installation​
Wireless access module - removal​
Wireless access module - setting (with passive entry and start system)​
Wireless access module - setting (without passive entry and start system)​
