International DLB 06.2026 Remote Installation
Program Solution
Type of Vehicle: Truck
Interface Languages + Database Language: Only English
Region: All regions
Database Last Modified: 06.2026
OS: Window 10 32 & 64bit (Tested on Window 10 64bit)
After downloading send an email to "gallons@autorepairmanuals.ws, admin@autorepairmanuals.ws" to get the password.
MASTER LIST: " CLICK HERE "
Welcome to the International Diamond Logic Builder application.
Diamond Logic Builder is a configuration tool for the International electronic control system.
The main screen allows you to manage and edit vehicle configurations as well as program them into a connected ESC.
A logic block is customized logic that you write to control the behavior of your vehicle.
Logic blocks are created and edited using the Advanced Logic tab.
When multiple Logic Blocks are added to a vehicle the result is a combination of all of the logic blocks on the vehicle.
Use diagnostics to list faults and to watch signal values on a running ESC. Signal values can also be set and locked.
Recommended adapters:
NEXIQ ™ Technologies – USB-Link2
Dearborn Group Technologies – DPA 5
Noregon® Systems, Inc. – DLA +, DLA + Wireless
Recommended interface cables:
NEXIQ Technologies – Link-2
Noregon Systems, Inc. – DLA, DLA USB
Communication link controllers:
DLB uses RP1210A standard controllers for communication. The controllers are specific to the communications device and are not installed with DLB.
Software features:
Control of the control system
Watch
Record
Save
Play instant recordings
Problem diagnosis codes
Retrieve, View, Delete
HD-OBD Freeze Frame Data
HD-OBD monitors
Monitor the results
Preparation for diagnosis
Monitor the performance ratio
View, save print
Service Bay Tests
key on, engine off
Actuator tests
Intermittent fault sensor
Cold start test
Engine running
Air management test
Cylinder cutting test
Engine fan test (if equipped)
High pressure pump test
Post-treatment system tests
Procedures
Calibration of the sensor
Replacements of parts
Programmable parameters
Motor characteristics settings
See Programming
Change Programming
Restoration of the service interval
Program Solution
Region: All regions
Software features:
Watch
Record
Save
HD-OBD monitors
Monitor the results
View, save print
Service Bay Tests
key on, engine off
Actuator tests
Cold start test
Engine running
Air management test
Procedures
See Programming
Change Programming
- Service Ranger 4.2.1177.0
- International Truck onCommand ISIS [04.2015]
- Service Ranger 4
- Navistar Engine Diagnostics 2017
- International Truck onCommand ISIS [01.2014]
- International Truck Full Set Manual DVD
- Maxxforce Service Repair Manual Diesel Engines 2020 Full DVD PDF
- International Service Information Solution (ISIS) 2014-7 + Instruction Install
- International Diamons Logic Builder [12.2017]
- International Service Information Solutions Master Service Manual
- Navistar Truck 2021 Updated [01.2019] Full Models Manual PDF DVD
- International Truck All Models Full Manuals DVD
- Navistar Engine Diagnostics NED 01.2018 Diagnostic Software
- ServiceMaxx 44.20 [07.2016] Full
- Navistar OnCommand OCSI Q4.2020 2021 Service Information DVD
