Autorepairmanual
Manager
18
195,876
HYPro Hyster and Yale Programming Tool V3.2.3
Size: 19.2 MB (Winrar Files)
Type of Software: Programming Tool
Type of vehicle: Forklift
Interface languages: English, Spanish, Italian, German, French,
Make: Hyster, Yale
Version: V3.2.3
OS: Windows 7, Windows 10 32 & 64 bit (Tested on Windows 10 pro 22h2 64bit)
Supporter: Present
Instruction: Present
Installation: Multiple PCs
Home screen application software file use with HYPro Hyster and Yale Programing Tool
Detail Content
Introduction
HYPro v3.2 is a Windows based application used to update software for various truck
controller. The tool is applicable to NCEA components only and is not backward
compatible with previous platforms.
Purpose
The purpose of this guide is to describe the installation and use of the HYPro
programming tool. With the advent of the NCEA architecture and its global nature,
updating core components such as the VSM and display is more complicated than
previous platforms.
Scope
The scope of this document is to provide detailed information about:
Installing the tool
Programing a VSM
Programming a Display
Programming other controllers
Target Audience
This guide is intended for technicians and service personnel who will be using the tool
to update HYG products.
Assumption
It is assumed that the reader possesses a basic understanding of the Windows
operating system as well as familiarity with terminology associated with HYG trucks.
While it is assumed the user has a basic understanding of PC and Truck terminology,
the following glossary may provide useful guidance:
HYPro
Hyster-Yale Programming tool
NCEA
New Common Electrical Architecture. This term applies to
components developed to be common across all HYG truck types.
CAN
Acronym for “Controller Area Network”. A standard describing an
interface bus, originally conceived for automobiles, but extended to
trucks, that allows various electronics modules in a vehicle to
exchange information.
VSM
Vehicle System Manager. The main controller for the tuck.
The NCEA VSM has 3 internal processors that can be updated.
CDF
A file used by the VSM to configure the operation and performance
of internal truck functions.
MLM
Mini-lever Module. Used in e-hydraulics configurations.
RP1210
An industry standard programming interface (API) that allows
general purpose programs (such as the PC Service Tool) to send
and receive data from a wide variety of CAN bus adaptors. Without
this interface standard, a custom version of the PCST would be
needed for each type of adaptor. Variants include the “A” and “B”
version of the interface.
BSM
Battery System Manager.
BCM
Battery Cell Manager.
Zip or .zip
Name for a type of PC file typically used to distribute applications.
Used because it provides high compression of a file, shortening
storage requirements and download time.
