Hitachi Excavator ZX490-7 to ZX530LCH-7 Parts Catalog
Language: English, Japanese
Brand: Hitachi
Type of Machine: Excavator
Model: Hitachi ZX490-7 to ZX530LCH-7 Excavator
List of Files:
ZX490-7 to ZX530LCH-7 Equipment Component Parts Catalog PJAQA0-E1-1 (142 Pages)
ZX490-7 to ZX530LCH-7 Parts Catalog PJAQA0-E1-1 (740 Pages)
Brand: Hitachi
List of Files:
Pump
Motor
Valve
Joint, Center
Cylinder
COVER
MEMORANDUM
FOREWORD
ILLUSTRATION CONTENTS
CONTENTS
PERIODIC REPLACEMENT PARTS
FILTER, ELEMENT, BELT PARTS
BUCKET PARTS
CAB RELATED PARTS
FRAME, COVER
FRAME
FRAME PARTS (1)
FRAME PARTS (2)
SWING BEARING PARTS (UPPERSTRUCTURE)
CATWALK
STEP
COUNTERWEIGHT (9.08t)
COUNTERWEIGHT (9.08t)(WITH ROTATING BEACON SEAT)
COUNTERWEIGHT (9.78t)
COUNTERWEIGHT (9.78t)(WITH ROTATING BEACON SEAT)
COUNTERWEIGHT SUPPORT
COVER (1)
COVER (1)(MULTI LEVER)
COVER (2)
COVER (2)(ASSIST PIPING)
COVER (3)
COVER (3)(ASSIST PIPING)
COVER (4)
ENGINE COVER (1)
ENGINE COVER (2)
ENGINE COVER (3)
ENGINE COVER SUPPORT
RADIATOR COVER
ANTI-CIRCULATION COVER
UNDER COVER (REINFORCED TYPE)
HANDRAIL
HANDRAIL (CAB)
LUBRICATOR BOX
UREA WATER TANK COVER
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR SUPPORT
COOLANT PIPING
AIR CLEANER
AIR CLEANER PARTS
PRE-CLEANER
MUFFLER
MUFFLER PARTS (1)
MUFFLER PARTS (2)
EXPANSION TANK
FUEL TANK SUPPORT
FUEL CHARGING UNIT
FUEL PIPING
FUEL MAIN FILTER SUPPORT
FUEL PRE-FILTER
FUEL COOLER
UREA WATER TANK PARTS
UREA WATER TANK PIPING
FUEL FEED PUMP
HYDRAULIC SYSTEM
PUMP DEVICE
SWING DEVICE (R)
SWING DEVICE (L)
SWING DEVICE SUPPORT
SWING DEVICE DRAIN PIPING
CONTROL VALVE
CONTROL VALVE SUPPORT
FAN DRIVE
FAN VALVE (REVERSE)
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
RETURN PIPING (3)
PUMP DRAIN PIPING
DRAIN PIPING
FAN DRIVE PIPING
HYDRAULIC PIPING (MAIN)
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3-1)
MAIN PIPING (3-2)
SIDE BRANCH PIPING
HYDRAULIC PIPING (PILOT)
PILOT PIPING (1)(PUMP)
PILOT PIPING (1)(OIL TANK)
PILOT PIPING (2-1)
PILOT PIPING (2-2)
PILOT PIPING (2-3)
PILOT PIPING (3-1)
PILOT PIPING (3-2)
PILOT PIPING (3-3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)(MULTI LEVER)
PILOT PIPING (8)
PILOT PIPING (9)(MULTI LEVER)
PILOT PIPING (9)
PILOT PIPING (10)
LUBRICATION SYSTEM
LUBRICATOR PARTS (AUTO-LUB)
LUBRICATOR PARTS (MANUAL-LUB)
AUTO. LUBRICATE SYSTEM (1)(BASIC MACHINE)(3 POSITION)
AUTO. LUBRICATE SYSTEM (2)(BASIC MACHINE)(3 POSITION)
AUTO. LUBRICATE SYSTEM (FLOOR)(3 POSITION)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5-1)
ELECTRIC PARTS (5-2)
ELECTRIC PARTS (6)
ELECTRIC PARTS (7-1)
ELECTRIC PARTS (7-2)
ELECTRIC PARTS (7-3)
ELECTRIC PARTS (8)
ELECTRIC PARTS (9)
START SWITCH
START SWITCH (NS KEY)
ENGINE CONTROLLER SUPPORT
ENGINE STOP SWITCH
MOBILE COMMUNICATIONS TERMINAL
SATELLITE COMMUNICATIONS TERMINAL (IRIDIUM)
CONTROLLER (MC)
MONITOR CONTROLLER
SIDE CAMERA(L), REAR CAMERA SUPPORT
SIDE CAMERA (R)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UPPER)
FRONT HEAD LAMP (4 LAMP WITH RAIN GUARD UPPER)
FRONT HEAD LAMP (2 LAMP)(OPG TOPGUARD)
FRONT HEAD LAMP (4 LAMP)(OPG TOPGUARD)
REAR HEAD LAMP (FLOOR)
REAR HEAD LAMP (CAB)
ROTATING BEACON (FLOOR)
PERIPHERAL BEACON PARTS
OVER LOAD ALARM DEVICE (CAB)
OVER LOAD ALARM DEVICE (MAIN)
ELECTRIC CONTROL PARTS (CAB)
MICROPHONE
AERIAL ANGLE CONTROL UNIT
AERIAL ANGLE PARTS
PARALLEL LINK WIPER HARNESS
WIDE VIEW WIPER (CURVED SURFACE LAMINATED GLASS)
WIDE VIEW WIPER (PLANE GLASS)
WINDOW WASHER
TRAVEL, SWING MOTION ALARM DEVICE (CAB)
TRAVEL MOTION ALARM DEVICE (CAB)
SWING TRAVEL ALARM
SWING MOTION ALARM DEVICE (MAIN)
SWING MOTION ALARM (COUNTERWEIGHT)
CAB
CAB (STEEL ROOF)(MOBILE COMMUNICATIONS)
HD-CAB (MOBILE COMMUNICATIONS)
ZX490LCH-7 Series (ISUZU 6WG1-XBSA03) Engine Parts Catal (188 Pages)
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
005: ENGINE GASKET KIT (1/2)
005: ENGINE GASKET KIT (2/2)
010: CYLINDER HEAD COVER
011: CYLINDER HEAD (1/2)
011: CYLINDER HEAD (2/2)
012: CYLINDER BLOCK
013: OIL PAN AND LEVEL GAUGE(1/2)
013: OIL PAN AND LEVEL GAUGE(2/2)
014: CAMSHAFT AND VALVE (1/2)
014: CAMSHAFT AND VALVE (2/2)
015: CRANKSHAFT,PISTON ANDFLYWHEEL
020: TIMING GEAR CASE ANDFLYWHEEL HOUSING (1/2)
020: TIMING GEAR CASE ANDFLYWHEEL HOUSING (2/2)
025: INLET MANIFOLD (1/2)
025: INLET MANIFOLD (2/2)
027: EXHAUST MANIFOLD
028: VENTILATION SYSTEM (1/2)
028: VENTILATION SYSTEM (2/2)
030: WATER PUMP AND CORROSIONRESISTOR
031: THERMOSTAT AND HOUSING(1/2)
031: THERMOSTAT AND HOUSING(2/2)
032: WATER PIPING; ENGINE (1/7)
032: WATER PIPING; ENGINE (2/7)
032: WATER PIPING; ENGINE (3/7)
032: WATER PIPING; ENGINE (4/7)
032: WATER PIPING; ENGINE (5/7)
032: WATER PIPING; ENGINE (6/7)
032: WATER PIPING; ENGINE (7/7)
033: FAN AND FAN BELT
036: TURBOCHARGER SYSTEM
038: AIR COMPRESSOR PIPING;ENGINE SIDE
039: AIR COMPRESSOR; BRAKE
040: FUEL INJECTION SYSTEM (1/4)
040: FUEL INJECTION SYSTEM (2/4)
040: FUEL INJECTION SYSTEM (3/4)
040: FUEL INJECTION SYSTEM (4/4)
041: FUEL FILTER AND BRACKET(1/2)
041: FUEL FILTER AND BRACKET(2/2)
042: FUEL PUMP AND PIPE (1/2)
042: FUEL PUMP AND PIPE (2/2)
050: OIL COOLER AND OIL FILTER
051: OIL PUMP AND OIL STRAINER
052: OIL AND VACUUM PIPING;ENGINE (1/3)
052: OIL AND VACUUM PIPING;ENGINE (2/3)
052: OIL AND VACUUM PIPING;ENGINE (3/3)
057: EMISSION PIPING (1/3)
057: EMISSION PIPING (2/3)
057: EMISSION PIPING (3/3)
060: ENGINE ELECTRICAL CONTROLPARTS (1/3)
060: ENGINE ELECTRICAL CONTROLPARTS (2/3)
060: ENGINE ELECTRICAL CONTROLPARTS (3/3)
061: BATTERY AND ENGINEELECTRICAL PARTS
065: STARTER
066: GENERATOR
066: GENERATOR
146: DEF TANK AND PIPING
150: EXHAUST PIPE AND SILENCER(1/4)
150: EXHAUST PIPE AND SILENCER(2/4)
150: EXHAUST PIPE AND SILENCER(3/4)
150: EXHAUST PIPE AND SILENCER(4/4)
810: WIRING HARNESS AND FUSE
815: FIXING PARTS; WIRING HARNESS(1/2)
815: FIXING PARTS; WIRING HARNESS(2/2)
826: ELECTRICAL CONTROL ANDOTHER PARTS
PARTS INDEX
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
