Hitachi Excavator ZX160LC-6 Parts Catalog
Language: English, Japanese
Brand: Hitachi
Type of Machine: Excavator
Model: Hitachi ZX160LC-6 Excavator
List of Files:
ZX160LC-6 Engine Parts Catalog 4JJ1-XASA01-11 (161 Pages)
ZX160LC-6 Equipment Component Parts Catalog PDBR50-E1-2 (167 Pages)
ZX160LC-6 Parts Catalog PDBR50-1-2 (663 Pages)
Brand: Hitachi
List of Files:
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
005: ENGINE GASKET KIT (1/2)
005: ENGINE GASKET KIT (2/2)
010: CYLINDER HEAD COVER
011: CYLINDER HEAD (1/3)
011: CYLINDER HEAD (2/3)
011: CYLINDER HEAD (3/3)
012: CYLINDER BLOCK (1/2)
012: CYLINDER BLOCK (2/2)
013: OIL PAN AND LEVEL GAUGE
014: CAMSHAFT AND VALVE (1/2)
014: CAMSHAFT AND VALVE (2/2)
015: CRANKSHAFT,PISTON ANDFLYWHEEL
020: TIMING GEAR CASE AND FLYWHEELHOUSING (1/2)
020: TIMING GEAR CASE AND FLYWHEELHOUSING (2/2)
022: ENGINE MOUNTING
025: INLET MANIFOLD (1/2)
025: INLET MANIFOLD (2/2)
027: EXHAUST MANIFOLD
028: VENTILATION SYSTEM
030: WATER PUMP AND CORROSIONRESISTOR (1/2)
030: WATER PUMP AND CORROSIONRESISTOR (2/2)
031: THERMOSTAT AND HOUSING (1/2)
031: THERMOSTAT AND HOUSING (2/2)
032: WATER PIPING; ENGINE (1/2)
032: WATER PIPING; ENGINE (2/2)
033: FAN AND FAN BELT
036: TURBOCHARGER SYSTEM (1/2)
036: TURBOCHARGER SYSTEM (2/2)
040: FUEL INJECTION SYSTEM (1/2)
040: FUEL INJECTION SYSTEM (2/2)
041: FUEL FILTER AND BRACKET
050: OIL COOLER AND OIL FILTER
051: OIL PUMP AND OIL STRAINER
052: OIL AND VACUUM PIPING; ENGINE(1/5)
052: OIL AND VACUUM PIPING; ENGINE(2/5)
052: OIL AND VACUUM PIPING; ENGINE(3/5)
052: OIL AND VACUUM PIPING; ENGINE(4/5)
052: OIL AND VACUUM PIPING; ENGINE(5/5)
057: EMISSION PIPING (1/3)
057: EMISSION PIPING (2/3)
057: EMISSION PIPING (3/3)
060: ENGINE ELECTRICAL CONTROLPARTS (1/2)
060: ENGINE ELECTRICAL CONTROLPARTS (2/2)
065: STARTER
066: GENERATOR
066: GENERATOR
110: RADIATOR
131: AIR DUCT
146: DEF TANK AND PIPING
150: EXHAUST PIPE AND SILENCER (1/5)
150: EXHAUST PIPE AND SILENCER (2/5)
150: EXHAUST PIPE AND SILENCER (3/5)
150: EXHAUST PIPE AND SILENCER (4/5)
150: EXHAUST PIPE AND SILENCER (5/5)
810: WIRING HARNESS AND FUSE
815: FIXING PARTS; WIRING HARNESS
825: SWITCH AND RELAY; INSTRUMENTPANEL
826: ELECTRICAL CONTROL AND OTHERPARTS
PARTS INDEX
Pump
Motor
Valve
Joint, Center
Cylinder
COVER
MEMORANDUM
FOREWORD
ILLUSTRATION CONTENTS
CONTENTS
PERIODIC REPLACEMENT PARTS
FILTER, ELEMENT, BELT PARTS
BUCKET PARTS
FRAME, COVER
FRAME
FRAME
SWING BEARING SUPPORT (UPPERSTRUCTURE)
BOOM FOOT PIN
CENTER JOINT PARTS (UPPERSTRUCTURE)
COUNTERWEIGHT
COUNTERWEIGHT
COVER (1)
COVER (2)
COVER (2)(PRE-CLEANER)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
COVER (7)
COVER (8)
COVER (8)(MULTI)
RADIATOR COVER
UNDER COVER
TOOL BOX COVER
TOOL BOX COVER (FOR SIDE CAMERA)
ANTI-SLIP COVER (COVER (3))
ANTI-SLIP COVER (TOOL BOX)
ANTI SLIP COVER (FUEL TANK)
HANDRAIL
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
EXPANSION TANK
AIR CLEANER
AIR CLEANER (WITH PRE-CLEANER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
PRE-CLEANER
PRE-CLEANER (FOR SIDE VIEW CAMERA)
PRE CREANER PARTS
MUFFLER PARTS
MUFFLER PARTS
FUEL TANK
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING (WITH WATER SEPARATOR)
FUEL PIPING (WITH WARM UP SYSTEM, WATER SEPARATOR)
UREA WATER TANK PARTS
UREA WATER TANK PIPING (1)
UREA WATER TANK PIPING (2)
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE (WITH ADDITIONAL GEAR PUMP)
PUMP DEVICE SUPPORT
CONTROL VALVE
CONTROL VALVE SUPPORT
SWING DEVICE
SWING DEVICE SUPPORT
OIL TANK
OIL TANK PARTS (WITH INDICATOR)
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
HYDRAULIC PIPING (MAIN)
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
HYDRAULIC PIPING (PILOT)
SOLENOID VALVE (2 SECTION)
SOLENOID VALVE (3 SECTION)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9-1)
PILOT PIPING (9-2)
PILOT PIPING (10)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5-1)
ELECTRIC PARTS (5-2)
BATTERY
START SWITCH
BOOM LIGHT HARNESS
BOOM LIGHT (R)
BOOM LIGHT (R)(WITH LIGHT COVER)
ENGINE CONTROL UNIT
ENGINE STOP SWITCH
MOBILE COMMUNICATIONS TERMINAL
SATELLITE COMMUNICATIONS TERMINAL
CONTROLLER (MC)
MONITOR CONTROLLER
FRONT HEAD LAMP PARTS (2 LAMP)(FLOOR)
FRONT HEAD LAMP PARTS (4 LAMP)(FLOOR)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UPPER)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UNDER
FRONT HEAD LAMP (4 LAMP WITH RAIN GUARD UPPER)
FRONT HEAD LAMP (4 LAMP WITH RAIN GUARD UNDER)
REAR HEAD LAMP (CAB)
REAR HEAD LAMP PARTS (FLOOR)
ROTATING BEACON
ROTATING BEACON (FLOOR)
BRACKET (ADDITIONAL RELAY)
HORN
REAR CAMERA
OVER LOAD ALARM DEVICE
OVER LOAD ALARM DEVICE (CAB)
AUX PARTS
SWING MOTION ALARM (CAB)
SWING MOTION ALARM DEVICE
TRAVEL MOTION ALARM (CAB)
TRAVEL MOTION ALARM
RADIO (AM/FM)
QUICK HITCH PARTS
BEACON PARTS
WINDOW WASHER
SIDE CAMERA MONITOR
SIDE CAMERA
SIDE CAMERA (FOR PRE CLEANER)
CAB
CAB (POLYCARBONATE ROOF)(MOBILE COMMUNICATIONS)
CAB (POLYCARBONATE ROOF)(SATELLITE COMMUNICATIONS)
CAB (STEEL ROOF)(WITH FRONT GUARD SEAT)(MOBILE COMMUNICATIONS)
CAB (STEEL ROOF)(WITH FRONT GUARD SEAT)(SATELLITE COMMUNICATIONS)
CAB GUARD (ON FRONT, UNDER FRONT)
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
