Hyundai
86
176,684
Hitachi Excavator ZX135US-7 ZX225US-7 ZX225USLC-7 Operator Manual ENMDA4-1-2
Brand: Hitachi
Type of Machine: Excavator
Model: Hitachi ZX135US-7 ZX225US-7 ZX225USLC-7 Excavator
Part Number: ENMDA4-1-2
Publication Date: 2022
Number of Pages: 602 Pages
SAFETY
Recognize Safety Information​
Understand Signal Words​
Follow Safety Instructions​
Prepare for Emergencies​
Wear Protective Clothing​
Protect Against Noise​
Inspect Machine​
General Precautions for the Cab​
Use Handrail and Steps​
Adjust the Operator's Seat​
Ensure Safety Before Rising from or Leaving Operator's Seat​
Fasten Your Seat Belt​
Move and Operate Machine Safely​
Start the Engine Only from Operator's Seat​
Jump Starting​
Keep Riders off Machine​
Precautions for Operations​
Perform Job Site Risk Assessment Beforehand​
Install OPG Guard​
Restriction of Attachment Installation​
Provide Signals for Jobs Involving Multiple Machines​
Confirm Direction of Machine Travel​
Drive Machine Safely​
Avoid Injury from Rollaway Accidents​
Avoid Accidents from Reversing and Swing Operation​
Keep People Clear from Working Area​
Never Position the Bucket Over Anyone​
Avoid Undercutting​
Avoid Tipping​
Never Undercut a High Bank​
Dig with Caution​
Caution with an Overhead Obstacle​
Avoid Power Lines​
Precautions for Lightning​
Object Handling​
Protect Against Flying Debris and Falling Object​
Park Machine Safely​
Handle Fluids Safely−Avoid Fires​
Transport Safely​
Practice Maintenance Safely​
Warn Others of Service Work​
Support Machine Properly​
Stay Clear of Moving Parts​
Prevent Parts from Flying​
Avoid Injury from Attachment Falling Accident​
Prevent Burns​
Replace Rubber Hoses Periodically​
Avoid High-Pressure Fluids​
Prevent Fires​
Evacuating in Case of Fire​
Beware of Exhaust Fumes​
Precautions for Welding and Grinding​
Avoid Heating Near Pressurized Fluid Lines​
Avoid Applying Heat to Lines Containing Flammable Fluids​
Precautions for Handling Accumulator and Gas Damper​
Remove Paint Before Welding or Heating​
Beware of Asbestos and Silica Dust and Other Contamination​
Prevent Battery Explosions​
Service Air Conditioning System Safely​
Handle Chemical Products Safely​
Dispose of Waste Properly​
Never Ride Attachment​
Notes on Aftertreatment Device​
Precautions for Communication Terminal​
Precautions for Communication Terminal Equipment​
Notes on Protection by Operator's Station when the Machine Rolls Over​
Visibility Map for Machine Model ZX135US-7 with Monoblock Boom Personal Hazard​
Visibility Map for Machine Model ZX225US-7, 225USLC-7 with Monoblock Boom Personal Hazard​
Aerial Angle (Surround View) Visibility Map for ZX135US-7​
Aerial Angle (Surround View) Visibility Map for ZX225US-7, 225USLC-7​
Safety Signs​
BEFORE OPERATION
Name of Components​
Getting ON and OFF the Machine​
About Aftertreatment Device​
OPERATOR'S STATION
Layout of Equipment in Operator's Station (Illustration Contents)​
Multi Function Monitor​
Auto Air Conditioner​
Audio Operation​
Switch Panel (Content of Illustration)​
Switch Panel (for Optional Equipments)​
Control Lever​
Facilities in Operator's Station​
Aerial Angle​
Installation and Adjustment of Mirrors​
Emergency Exit​
Battery Disconnect Switch​
BREAK-IN
Observe Engine Operation Closely​
Every 8 Hours or Daily​
After the First 50 Hours​
After the First 100 Hours​
OPERATING THE ENGINE
Inspect Machine Daily Before Starting​
Before Starting the Engine​
Check Instruments After Starting​
Using the Booster Battery​
Stopping the Engine​
Engine Auto-Stop at Extremely Low Temperatures​
DRIVING THE MACHINE
Travel Levers and Pedals​
Travel Mode Switch​
Travel Alarm (Optional)​
Traveling on Soft Ground​
Raising One Track Using the Boom and Arm​
Retrieval​
Operating in Water or Mud​
Parking the Machine on Slopes​
Parking​
Prohibition of Sudden Control Operations when Traveling at High Speed​
Prohibition of Traveling for Long Periods​
OPERATING THE MACHINE
Control Lever (ISO Pattern)​
Pilot Shut-Off Lever​
Warming-Up Operation​
Engine Speed Control​
Auto-Idle​
Auto Shut-Down​
Aftertreatment Device Manual Regeneration​
Attachments​
Power Boost Switch​
Power Mode​
Attachment Settings​
Operating Backhoe​
Shovel​
Grading Operation​
Do Not Strike the Ground with Bucket Teeth​
Avoid Hammer Work​
Avoid Abusive Operation​
Never Move an Object Sideways with the Bucket​
Retracting the Arm and Bucket​
Never use Wide Track Shoes on Rough Ground​
Using the Towing Hole on the Track Frame​
Pilot Accumulator Functions​
How to Lower Boom in Case of Emergency and When Engine Stops (Without hose-rupture safety valve)​
How to Lower Front Equipment and Attachment in Case of Emergency and When Engine Stops (With hose-rupture safety valve)​
Precautions for After Operations​
TRANSPORTING
Transporting by Road​
Loading/Unloading on a Trailer​
Fastening the Machine for Transport​
Unloading​
Lifting the Machine​
MAINTENANCE
Correct Maintenance and Inspection Procedures​
Layout​
Inspection and Maintenance Intervals​
Preparation for Inspection and Maintenance​
Hood and Access Covers​
Maintenance Guide​
Periodic Replacement of Parts​
Kind of Oils​
List of Consumable Parts​
A. Greasing​
B. Engine​
C. Transmission​
D. Hydraulic System​
E. Fuel System​
F. Air Cleaner​
G. Cooling System​
H. Electrical System​
I. Miscellaneous​
J. Aftertreatment Device​
K. Urea SCR System (Except ZX135US-7)​
L. Aerial Angle​
Reference Information​
HYDRAULIC CIRCUIT
Hydraulic Circuit​
MAINTENANCE UNDER SPECIAL ENVIRONMENTAL CONDITIONS
STORAGE
Storing the Machine​
TROUBLESHOOTING
SPECIFICATIONS
Specifications ZX135US-7​
Working Ranges (Grouser shoe) ZX135US-7​
Shoe Types and Applications ZX135US-7​
Bucket Types and Applications ZX135US-7​
Specifications ZX225US-7, 225USLC-7​
Working Ranges (Grouser shoe) ZX225US-7, 225USLC-7​
Shoe Types and Applications ZX225US-7​
Shoe Types and Applications ZX225USLC-7​
Bucket Types and Applications ZX225US-7, 225USLC-7​
The Value of the Carbon Dioxide (CO2) emissions​
Noise Level Inside of Cab​
OPTIONAL ATTACHMENTS AND DEVICES
Long Arm​
Blade​
Bucket Teeth​
Hydraulic Breaker, Crusher, Quick Coupler​
Automatic Refueling Device​
INDEX
