Hako Sweeper Scrubmaster B175R Service Booklet 2022
Brand: Hako
Type of Machine: Sweeper
Type of Manual: Service Booklet
Model: Hako Scrubmaster B175R Sweeper
Part Number: 2022
Number of Pages: 138 Pages
1 Information
2 General Information
2.1 Settings
2.1.1 Control Panel
2.1.2 Machine Control Unit
2.2 Brief Description
2.2.1 Switching Off Suction / Waste Water Tank Full
2.2.2 Solution Tank Display
2.2.3 Machine Home Position
2.2.4 Seat Contact Switch (3.6.6.4.)
2.3 Diagnostics And Communications
2.3.1 Prerequisites
2.3.2 Diagnostic Software On The Diagnostic Computer
2.3.3 Connecting To The Diagnostic PC
2.3.4 Connection Scheme With The Diagnostic PC
2.3.5 Flashing The Software
2.3.6 Flashing The SD Card
2.4 Configuration Menu
2.4.1 Entering The Configuration Menu
2.4.2 Time And Date Setting Menu
2.4.3 Configuration Setting Menu
2.4.4 Settings, That Can Be Carried Out Without Code
2.4.5 Settings, That Can Only Be Carried Out With Code
2.4.6 Resetting The Last Error And Deleting The Error Memory
2.4.7 Deleting The Last Error On The Display Panel
2.4.8 Deleting Error Entries
3 Technical Data
4 Maintenance Intervals
4.1 Hako System Maintenance (Customer)
4.2 Hako System Maintenance I
4.3 Hako System Maintenance II
4.4 Hako System Maintenance S
5 Cleaning Programmes (FPV)
5.1 Cleaning Programmes (SOW)
6 Machine Settings
6.1 Basic Settings
6.1.1 Cleaning Units
6.1.2 Battery And Charger Settings
6.1.3 Battery Setting (LDS)
6.1.4 Charger
6.1.5 Charger Characteristic Curves
6.1.6 Charging Data Table Of The Integrated Charger
6.1.7 All-Wheel Drive Variant – X-Ac
6.1.8 SD Storage Medium In Control Panel
6.1.9 Logo On The Starting Screen
6.2 Customer-Specific Settings (PPV)
7 Mechanical Components
7.1 Squeegee
7.2 Rotating Brush Heads
7.3 Roller Brush Heads
7.4 Lifting Element Brush Head
7.4.1 Potentiometer In The Lifting Element For The Brush Head
8 Water Pump
8.1 Water Supply – Components On The Water Plate
8.2 Water Quantities
8.3 Water Pump Standstill Detection
8.4 Suction-And Speay Tool; Spray Nozzle
9 Drive System
9.1 DMC Drive Control Unit (Front)
9.1.1 Connection Description - Drive Control Unit (Front)
9.1.2 Service Codes - Drive Control Unit (Front)
9.1.3 Brake - Manual Release Of The Brake (Front)
9.1.4 Brake – Testing The Brake Function
9.2 DMC Drive Control Unit (Rear)
9.2.1 Connection Description - Drive Control Unit (Rear)
9.2.2 Service Codes - Drive Control Unit (Rear)
9.2.3 Brake At The Rear Axle
9.2.4 Steering Angle Sensor
10 Service Messages
10.1 Meaning Of Different Switch On Displays
10.2 Service Alarm Clock 3.3.1.1
11 Battery Charger
11.1 Operating Manual
11.2 Programming The Charger
12 Options
13 Electrical Components
13.1 Machine Control Unit A01
13.2 Dashboard A02
14 Notes
Brand: Hako
Part Number: 2022
1 Information
2.1 Settings
2.1.1 Control Panel
2.3.1 Prerequisites
3 Technical Data
6 Machine Settings
6.1 Basic Settings
6.1.4 Charger
7.1 Squeegee
8 Water Pump
9 Drive System
10 Service Messages
11 Battery Charger
12 Options
13.2 Dashboard A02
14 Notes
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
