118
6,911
Hako Sweeper Scrubmaster B175R Service Booklet 2019
Brand: Hako
Type of Machine: Sweeper
Type of Manual: Service Booklet
Model: Hako Scrubmaster B175R Sweeper
Publication Date: 2019
Number of Pages: 124 Pages
1 Information
2 General Information
2.1 Settings
2.1.1 Control Panel
2.1.2 Machine Control Unit
2.2 Brief Description
2.2.1 Switching Off Suction / Waste Water Tank Full
2.2.2 Solution Tank Display
2.2.3 Machine Home Position
2.2.4 Seat Contact Switch (3.6.6.4.)
2.3 Diagnostics And Communications
2.3.1 Prerequisites
2.3.2 Diagnostic Software On The Diagnostic Computer
2.3.3 Connecting To The Diagnostic PC
2.3.4 Connection Scheme With The Diagnostic PC
2.3.5 Flashing The Software
2.4 Configuration Menu
2.4.1 Entering The Configuration Menu
2.4.2 Time And Date Setting Menu
2.4.3 Configuration Setting Menu
2.4.4 Settings, That Can Be Carried Out Without Code
2.4.5 Settings, That Can Only Be Carried Out With Code
2.4.6 Resetting The Last Error And Deleting The Error Memory
2.4.7 Deleting The Last Error On The Display Panel
2.4.8 Deleting Error Entries
3 Technical Data
4 Maintenance Intervals
4.1 Hako System Maintenance (Customer)
4.2 Hako System Maintenance I
4.3 Hako System Maintenance Ii
4.4 Hako System Maintenance S
5 Cleaning Programmes (FPV)
6 Machine Settings
6.1 Basic Settings
6.1.1 Cleaning Units
6.1.2 Battery And Charger Settings
6.1.3 Battery Setting (LDS)
6.1.4 Charger
6.1.5 Charger Characteristic Curves
6.1.6 Charging Data Table Of The Integrated Charger
6.1.7 All-Wheel Drive Variant – X-Ac
6.1.8 SD Storage Medium In Control Panel
6.2 Customer-Specific Settings (PPV)
7 Mechanical Components
7.1 Squeegee
7.2 Rotating Brush Heads
7.3 Roller Brush Heads
7.4 Lifting Element Brush Head
7.4.1 Potentiometer In The Lifting Element For The Brush Head
8 Water Pump
8.1 Water Quantities
8.2 Water Pump Standstill Detection
9 Drive
9.1 DMC Drive Control Unit (Front)
9.1.1 Connection Description - Drive Control Unit (Front)
9.1.2 Service Codes - Drive Control Unit (Front)
9.1.3 Brake - Manual Release Of The Brake (Front)
9.1.4 Brake – Testing The Brake Function
9.2 DMC Drive Control Unit (Rear)
9.2.1 Connection Description - Drive Control Unit (Rear)
9.2.2 Service Codes - Drive Control Unit (Rear)
9.2.3 Brake At The Rear Axle
9.2.4 Steering Angle Sensor
10 Service Messages
10.1 Meaning Of Different Switch On Displays
10.2 Service Alarm Clock 3.3.1.1
11 Battery Charger
11.1 Operating Manual
11.2 Programming The Charger
12 Options
13 Notes
