118
6,911
Hako Sweeper Citymaster 2000 Euro 3 Operation And Maintenance Instruction 88-10-2703 2007
Brand: Hako
Type of Machine: Sweeper
Type of Manual: Operation And Maintenance Instruction
Model: Hako Citymaster 2000 (1411) Euro 3 Sweeper
Part Number: 88-10-2703
Publication Date: 2007
Number of Pages: 178 Pages
1 Introduction
1.1 Notes On This Operation And Maintenance Manual
1.2 Notes On Using The Position Numbers
1.3 Abbreviations/Symbols
1.4 Vehicle Data
1.5 Brief Description
1.6 Implements
1.7 Regulations
1.8 Labels At The Machine
2 Safety Instructions
2.1 Identification Of Warnings And Dangers
2.2 Warranty
2.3 Designated Use And Exemption From Liability
2.4 General Conduct And Safety Instructions
2.5 Safety Instructions Regarding Operation
2.6 Safety Instructions For Maintenance
2.7 Warning Of Special Hazards
3 Operation
3.1 Introduction
3.2 Controls: Overview
3.2.1 Front View Of Vehicle
3.2.2 Rear View Of Vehicle
3.2.3 Vehicle Doors
3.2.4 Roof Console Controls
3.2.5 Centre Console Controls
3.2.6 Controls On Vehicle Exterior
3.3 Taking Into Service
3.3.1 Safety Instructions
3.3.2 Taking The Vehicle Into Service For The First Time
3.3.3 Check Lists
3.4 Indication And Operation Elements
3.4.1 Telltales And Warning Lights
3.4.2 Multifunction Display
3.4.3 Speedometer
3.4.4 Ignition Switch
3.4.5 Brakes
3.4.6 Steering
3.4.7 Power Train
3.4.8 Light And Signal System
3.4.9 Windscreen Washer Unit
3.4.10 Cab Heating And Ventilation
3.4.11 Operator's Seat/ Passenger's Seat
3.4.12 Seat Belt
3.4.13 Cab Doors
3.4.14 Tachograph (Option)
3.4.15 Electric Sockets
3.5 Driving The Citymaster
3.5.1 Before Starting The Engine
3.5.2 Starting The Engine
3.5.3 Before Moving Off
3.5.4 Moving Off
3.5.5 Driving
3.5.6 Stopping The Vehicle
3.5.7 Parking The Vehicle
3.5.8 Differential Lock
3.5.9 Towing And Transporting The Vehicle
3.6 Working With The Vehicle
3.6.1 Hydraulics
3.6.2 Work Speed Control
3.6.3 Hako Key
3.6.4 Front Power Lift
3.6.5 Suction Port
3.6.6 Sweeping Unit
3.6.7 Superstructure
3.6.8 Winter Service Operating Elements
3.6.9 Implements
4 Maintenance
4.1 Introduction
4.1.1 Accessibility To Assemblies
4.1.2 Removing The Cover
4.2 Fuel System
4.2.1 Specific Safety Instructions
4.2.2 Specification Of Diesel Fuel
4.2.3 Refuelling
4.2.4 Bleeding The Fuel System
4.2.5 Fuel Filter Maintenance
4.3 Engine Lubrication System
4.3.1 Engine Oil Specification
4.3.2 Checking The Oil Level
4.3.3 Topping Up Engine Oil
4.3.4 Changing The Engine Oil
4.3.5 Changing The Engine Oil Filter
4.4 Cooling Systems
4.4.1 Specific Safety Instructions
4.4.2 Specification Of Engine Coolant
4.4.3 Checking The Coolant Level / Topping Up The Coolant Level
4.4.4 Draining The Coolant
4.4.5 Cleaning The Cooling Ribs
4.4.6 Checking The V-Ribbed Belt
4.5 Air Filter
4.5.1 Replacing The Filter Cartridge
4.6 Hydraulic System
4.6.1 Specific Safety Instructions
4.6.2 Checking The Hydraulic Oil Level
4.6.3 Topping Up The Hydraulic Oil
4.6.4 Changing The Hydraulic Oil
4.6.5 Hydraulic Oil Filter
4.6.6 Breather Filter Of Hydraulic Oil Tank
4.6.7 Breather Filter Of The Vacuum Valves
4.6.8 Drive Hydraulics Pressure Filter
4.6.9 Hydraulic Pressure Lines
4.7 Gearbox
4.7.1 Reduction Gearbox And Transfer Gearbox
4.8 Axles
4.8.1 Rear Axle Differentials
4.8.2 Steering-Stub Bearing
4.9 Brake System
4.9.1 Specific Safety Instructions
4.9.2 Brake Fluid
4.9.3 Parking Brake Camshafts
4.10 Sweeping Unit
4.10.1 Adjust Sweeping Track
4.11 Suction Port
4.11.1 Adjust Suction Port
4.12 Superstructure
4.12.1 Hand-Held Suction Hose (So)
4.12.2 Refill And Empty Clear Water Tank
4.12.3 Refill Recirculatory Water
4.12.4 Fan
4.12.5 Lift/Lower Dirt Hopper With Hand Pump
4.13 Tyre Care
4.13.1 Inspection Work
4.13.2 Changing Wheels
4.13.3 Snow Chains (Option)
4.14 Windscreen Washer Unit
4.14.1 Filling Up The Windscreen Washer Unit
4.15 Electrical System
4.15.1 Specific Safety Instructions
4.15.2 Service And Maintenance Work At Regular Intervals
4.15.3 Instructions Concerning Specific Components
4.16 General Maintenance Work
4.16.1 Cleaning
4.16.2 Screw Connections
4.16.3 Pivots And Hinges
4.17 Proofs Of Maintenance
4.17 Engine Fluids And Lubricants
4.18 Maintenance Plan (Overview)
4.19 Lubrication Plan
5 Specifications
5.1 Frame
5.2 Engine
5.3 Cooling
5.4 Power Train
5.5 Steering
5.6 Tyres
5.7 Weights And Loads
5.8 Brakes
5.9 Cab
5.10 Sweeping Unit / Dirt Hopper
5.11 Vehicle Dimensions
5.12 Noise Levels
5.13 Vibration
5.14 Tightening Torques
5.14.1 General Screw Tightening Torques
5.14.2 Specific Tightening Torques
5.15 Electrical System
5.15.1 Fuse Box In Cab
5.15.2 Relay Assignment
