Hyundai
86
178,785
Foton Sauvana 2016 Workshop Manual
Download this document, you need 1000 Gallons
Brand: Foton
Type of Machine: Automotive
Type of Manual: Workshop Manual, Electric Diagrams
Model: Foton Sauvana 2016
List of Files:
4G69 Electric control multi-point fuel injection (MPI).pdf (884 Pages)
Foton Sauvana 2016 Workshop Manual Volume 1.pdf (954 Pages):
HOW TO USE THIS MANUAL
GENERAL
VEHICLE IDENTIFICATION NUMBER (VIN)
SERIAL NO. (SN)
OPERATION PRECAUTIONS
VEHICLE JACKING AND SUPPORTING POSITION
GENERAL
ABOUT USING DIAGNOSTIC DEVICE
HOW TO PERFORM TROUBLESHOOTING
ANALYZING FAULT DESCRIBED BY CUSTOMER
FAULT SYMPTOM CONFIRMATION AND DTC (AND DATA FLOW) DETECTION
SIMULATING DETECTION FOR SYMPTOM
DIAGNOSTIC TROUBLE CODES(DTC)LIST
SYMPTOM TABLE
DETECTION PROCEDURE OF CIRCUITS
ENGINE CONTROL SYSTEM
ENGINE MECHANICAL
FUEL
INTAKE
EXHAUST
COOLING
LUBRICATION
STARTING AND CHARGING
TRANSMISSION
CLUTCH
TRANSFER CASE
FRONT SUSPENSION
REAR SUSPENSION
TIRE AND WHEEL
AXLE AND TRANSMISSION SHAFT
SERVICE BRAKE
PARKING BRAKE
STEERING GEAR
POWER STEERING
HEATER & AIR CONDITIONING
SUPPLEMENTAL SAFEGUARD SYSTEM
ILLUMINATIONS
WIPER AND WASHER
AUDIO SYSTEM
VEHICLE CONTROL SYSTEM
THE HORN AND THE CIGARETTE LIGHTER
GLASS AND REAR-VIEW MIRROR
INSTRUMENT DESK AND SECONDARY INSTRUMENT DESK
SEAT
DOOR LOCKS
DOOR OF THE VEHICLE/ENGINE HOOD
INTERIOR AND EXTERIOR DECORATIONS
ENGINE MECHANICAL SYSTEM (ISF2.8)
ENGINE MECHANICAL SYSTEM (BJ486ZLEQ4)
ENGINE MECHANICAL SYSTEM(G01)
FUEL
INTAKE
EXHAUST
COOLING
LUBRICATION
IGN
TRANSMISSION(JC538)
TRANSMISSION(6HP21)
CLUTCH
TRANSFER
FRONT SUSPENSION
REAR SUSPENSION
TIRE AND WHEEL
SERVICE BRAKE
PARKING BRAKE
STEERING GEAR
POWER STEERING
ILLUMINATIONS
WIPER AND WASHER
SEAT
DOOR LOCKS
VEHICLE CARE
INSPECTION
REPLACEMENT
ENGINE CONTROL MODULE (ECM)
AIR fLOW METER
ELECTRONIC THROTTLE
INTAKE PRESSURE/TEMPERATURE SENSOR
COOLANT TEMPERATURE SENSOR
FRONT OXYGEN SENSOR
REAR OXYGEN SENSOR
SPEED SENSOR
PHASE SENSOR
CANISTER PURGE CONTROL VALVE
KNOCK SENSOR
OCV VALVE
IGNITION COIL
FUEL INJECTOR
ENGINE ASSEMBLY
ENGINE ACCESSORY BELT
ENGINE MECHANICAL
ENGINE ASSEMBLY
DRIVING BELT
TURBOCHARGER
INTAKE AND EXHAUST MANIFOLD
TIMING SPROCKET MECHANISM
CAMSHAFT
CYLINDER HEAD
VALVE
PISTON AND CONNECTING ROD
CRANKSHAFT AND FLYWHEEL
CYLINDER BLOCK
CRANKSHAFT OIL SEAL
CYLINDER HEAD SYSTEM
CYLINDER BLOCK SYSTEM
TIMING SYSTEM
LUBRICATING SYSTEM
Cooling system
Fuel system
Turbocharger subassembly
Drivetrain
Electric system
FUEL SYSTEM
FUEL TANK
FUEL LEVEL SENSOR ASSEMBLY
FUEL FILTER ASSEMBLY
FUEL TANK CAP COVER
FUEL TANK CAP
FUEL SYSTEM
FUEL TANK
FUEL TANK CAP COVER
FUEL TANK CAP
CANISTER SOLENOID VALVE
CANISTER
INTAKE AIR SYSTEM
AIR FILTER ASSEMBLY
INTER-COOLER ASSEMBLY
INTAKE LINE
INTAKE AIR SYSTEM
AIR FILTER ASSEMBLY
INTAKE LINE
EXHAUST SYSTEM
EXHAUST PIPE
EXHAUST SYSTEM
EXHAUST PIPE
COOLING SYSTEM
COOLANT
HEAT RADIATOR
ELECTRONIC FAN
COOLING SYSTEM
COOLANT
HEAT RADIATOR
ELECTRONIC FAN
LUBRICATING SYSTEM
ENGINE OIL
OIL FILTER
OIL SUMP
OIL DIPSTICK
OIL PUMP
START AND CHARGE SYSTEM
GENERATOR
STARTER
BATTERY
IGNITION SYSTEM
IGNITION COIL
SPARK PLUG
TRANSMISSION SHIFTING SYSTEM
TRANSMISSION ASSEMBLY
FIRST SHAFT & REVERSE SHAFT ASSEMBLY
SECOND SHAFT ASSEMBLY
INTERMEDIATE SHAFT ASSEMBLY
OIL PAN AND FILTER ELEMENT
HYDRAULIC TORQUE CONVERTER
INPUT SHAFT OIL SEAL
OUTPUT SHAFT OIL SEAL (2WD)
OUTPUT SHAFT OIL SEAL (4WD)
VENT PLUG
OIL COOLER ASSEMBLY
TRANSFER CASE
TRANSFER CASE CONTROL UNIT
Foton Sauvana 2016 Workshop Manual Volume 2.pdf (830 Pages):
FRONT SUSPENSION ASSEMBLY
FRONT WHEEL ALIGNMENT
FRONT SHOCK ABSORBER
UPPER SWING ARM
LOWER SWING ARM
STABILIZER BAR
REAR SUSPENSION ASSEMBLY
REAR SHOCK ABSORBER
REAR SWING ARM
TRANSVERSE ROD
RADIUS ROD
TIRE & WHEEL ASSEMBLY
FRONT TIRE & WHEEL
REAR TIRE & WHEEL
SPARE TIRE MOUNTING MECHANISM
TIRE PRESSURE MONITORING SYSTEM RECEIVER MODULE
FRONT AXLE ASSEMBLY
FRONT MAIN REDUCER ASSEMBLY
FRONT DIFFERENTIAL ASSEMBLY
DRIVING GEAR
FRONT HALF AXLE
FRONT AXLE ELECTRIC CLUTCH
FRONT RIM
STEERING KNUCKLE
TRANSMISSION SHAFT ASSEMBLY
CARDIN JOINT
MIDDLE BEARING
REAR AXLE ASSEMBLY
REAR HALF AXLE
REAR AXLE HOUSING ASSEMBLY
REAR DIFFERENTIAL ASSEMBLY
DRIVING GEAR
MAIN REDUCER GEAR OIL
BRAKE SYSTEM
BRAKE SYSTEM EMISSION
BRAKE PEDAL
MASTER BRAKE CYLINDER & VACUUM BOOSTER
VACUUM RESERVOIR (4WD)
FRONT BRAKE
REAR BRAKE
ESP EXECUTOR ASSEMBLY
WHEEL SPEED SENSOR
PARK BRAKE SYSTEM
PARK BRAKE LEVER
PARK BRAKE CABLE
PARKING BRAKE
STEERING MECHANISM
STEERING WHEEL
COMBINATION SWITCH
STEERING COLUMN ASSEMBLY
STEERING TRANSMISSION SHAFT
POWER STEERING SYSTEM
STEERING OIL
STEERING OIL PUMP ASSEMBLY
STEERING PIPE ASSEMBLY
STEERING GEAR ASSEMBLY
STEERING OIL CAN
HEATING AND AIR CONDITIONING
INSTRUMENT PANEL AIR PASSAGE
HEATING WATER PIPE
HEATER WATER PIPE SOLENOID VALVE
REFRIGERANT
COOLANT
A/C PIPE
EVAPORATOR
A/C COMPRESSOR
BLOWER
CONDENSER
OPERATING MECHANISM ASSEMBLY
A/C VALVE MOTOR
SPEED REGULATION RESISTOR
REAR EVAPORATOR ASSEMBLY
REAR BLOWER
REAR SPEED REGULATION RESISTOR
REAR AIR CONDITIONER CORE
SUPPLEMENTAL RESTRAINT SYSTEM
DRIVER AIRBAG
FRONT PASSENGER AIRBAG
CLOCK SPRING
AIRBAG CONTROL UNIT
SEAT BELT
SEAT BELT ALARM SYSTEM
DRIVER/FRONT PASSENGER SEAT BELT
MIDDLE ROW SEAT BELT
REAR ROW SEAT BELT
DRIVER/FRONT PASSENGER SEAT BUCKLE ASSEMBLY
RETRACTOR ASSEMBLY
SEAT BELT HEIGHT ADJUSTER ASSEMBLY
LIGHTING SYSTEM
FRONT COMBINATION LAMP ASSEMBLY
FRONT COMBINATION LAMP BULB
FRONT FOG LAMP ASSEMBLY
FRONT FOG LAMP BULB
DAY RUNNING LAMP
REAR COMBINATION LAMP ASSEMBLY
REAR COMBINATION LAMP BULB
TOP BRAKING LAMP ASSEMBLY
LICENSE PLATE LAMP
REAR FOG LAMP ASSEMBLY
REVERSING LAMP ASSEMBLY
FRONT INTERIOR LAMP ASSEMBLY
FRONT INTERIOR LAMP BULB
MIDDLE INTERIOR LAMP ASSEMBLY
REAR INTERIOR LAMP ASSEMBLY
MIDDLE INTERIOR LAMP BULB
REAR INTERIOR LAMP BULB
COURTESY LAMP ASSEMBLY
WIPER AND WASHER
WIPER ARM ASSEMBLY
WIPER ASSEMBLY
WIPER RESERVOIR ASSEMBLY
WIPER BLADE
WIPER NOZZLE
AUDIO SYSTEM
CD PLAYER ASSEMBLY
DVD & NAVIGATION ASSEMBLY
LEFT FRONT HIGH-TONE LOUDSPEAKER ASSEMBLY
LEFT FRONT SPEAKER ASSEMBLY
LEFT REAR SPEAKER ASSEMBLY
ANTENNA AMPLIFIER
ANTENNA ASSEMBLY
PARKING RADAR
PARKING RADAR SENSOR
CAMERA
IGNITION SWITCH
BODY CONTROLLER
ACCELERATOR PEDAL
HORN
CIGARETTE LIGHTER
FRONT DOOR ELECTRIC REGULATOR
REAR DOOR ELECTRIC REGULATOR
FRONT WINDSCREEN
REAR WINDSCREEN
INTERIOR REARVIEW MIRROR
EXTERIOR REARVIEW MIRROR
INSTRUMENT PANEL
AUXILIARY INSTRUMENT PANEL
COMBINATION INSTRUMENT
CROSS MEMBER
SEAT ASSEMBLY
DRIVER'S SEAT/FRONT PASSENGER SEAT
MIDDLE ROW SEAT
REAR ROW SEAT
FRONT DOOR LOCK
REAR DOOR LOCK
ENGINE HOOD LOCK
LIFTGATE LOCK
LIFTGATE SWITCH
ENGINE HOOD
FRONT DOOR
REAR DOOR
LIFTGATE
INTERIOR/EXTERIOR TRIM
FRONT GRILL
FRONT BUMPER ASSEMBLY
REAR BUMPER ASSEMBLY
MUDGUARD
SUN VISOR ASSEMBLY
FRONT DOOR INNER GUARD PANEL
REAR DOOR INNER GUARD PANEL
TAILGATE INNER SHIELD
A-PILLAR GUARD PANEL
B-PILLAR GUARD PANEL
C - PILLAR GUARD PANEL
CEILING GUARD PANEL ASSEMBLY
CARPET
FOOTBOARD
TRUNK TOOLBOX
SAFETY HANDRAIL
FENDER
SPOILER
LIFTGATE TRIM BAR
SUNROOF
SUNROOF MOTOR
Foton Sauvana 2016 Workshop Manual Volume 3.pdf (900 Pages):
CIRCUIT REVIEW
ELECTRICAL COMPONENTS SYMBOLS
BASIC MAINTENANCE
Fuse box
System principle drawing
Layout of connectors
DESCRIPTION OF CONNECTOR
SLOW, DULL AND IMBALANCED OF THE ACCELERATING REACTION
THE MOTOR WILL TURN OFF WHEN STARTS
THE ENGINE TURNS OFF WHEN IT COLD IDLES
HIGH IDLE SPEED (IDLE SPEED IS NOT WITHIN THE SPECIFIED VALUE)
UNSTABLE IDLING (FLUCTUATED)
THE COLD CAR STARTS DIFFICULTLY, THE CAR IS TREMBLED
THE STARTER ROTATES BUT THE MOTORCAN’T START
The diagnostic tool cannot communicate withthe ECU
Fault lists
P0300,P0301,P0302,P0303,P0304 - Misfire fault
P2127,P2128,P2132,P2133,P2135,P2140 - Electronic accelerator pedal position sensor fault
P0341,P0342,P0343,P0366,P0367,P0368 - Phase sensor fault
P000A,P000B,P0012,P0015,P0075,P0076,P0077,P0078,P0079,P0080 - VVT valve fault
BADACCELERATION,POOR PERFORMANCE
