I Followed these steps:
01) Use Daemon tools mount the image Ford ECAT
02) Choose an installation manual, installation location, as I chose D: \ FordEcat (recommended to use C: \ FordEcat)
03) restart your computer after you install
04) wait until after Windows has started end start e-CAT Domain Server (black box)
05) click on Start, Run, type in net stop FordEcatAppServer, stop waiting for the e-CAT Domain Server (the two black boxes)
06) copy the patch files (from folder patch_0B5HF) in the root of drive D: \ (drive C: \, if the program utanovlena on it)
07) in the file prepare.cmd change the line "echo Run prepare.cmd c: \ fordecat, where c: \ fordecat is the ecat installation path"
on the "echo Run prepare.cmd D: \ fordecat, where D: \ fordecat is the ecat installation path" (if the program is installed on drive C: \ skip this step)
08) click on Start, Run, type in cmd
09) in the window that opens, enter the command CD / DD: \ (if the program is installed on drive C: \, then enter the command CD / DC: \)
10) Enter the command prepare.cmd D: \ FordEcat (if the program is installed on drive C: \, then prepare.cmd C: \ FordEcat)
***** then I get this:
Unable to find file"c:\runtimes\applicationserver\domains\domain1\applications\j2ee-apps\EpcEar\EpcServiceEJB-5.08.04_jar\META-INF\MANIFEST.MF"
Make sure that the path supplied to the script is correct
I copy the patch files (from folder patch_0B67E)
but I got the same message
Is there any one can help me solve this problem ?
