ZAPI Can Console 0.58 Doosan (DLE) + Password
Interface Language: English, German, French, Other
Os: Winxp, Win7, Win10 (test on Win 10)
Instruction: Just run and use
Version: 0.58
Device Support: IXXAT, IFAK, PEAK USB, KVASER, VECTOR, INFREPID
Function: Parametter, Tester, Logbook, Motor Data, Monitor Canbus,...
PCCANCONSOLE
History release notes
Version 0.58
Fixed - SDO abort handling due to a read only object or value out of range
Fixed - Minor bug in DefaultParam
Fixed - Minor bug in Receive Par Ext
Version 0.58 beta
Added - New form for dynamic pdo handling
Added - Save/Load pdo dynamic pdo configuration
Fixed - Bug on ForceRemote config
Version 0.57
Added - Temporized data saving in RecordTester to prevent data loose in case of crash or disconnection
Added - ConnectedLabel with indication of the protocol in use
Fixed - Bug in DefaultParam
Version 0.56
Added - DefaultParam handling with ForceRemote protocol
Fixed - Bug in Read RAM
Fixed - SDO Abort index visualization
Version 0.55
Fixed - Various bugs
Version 0.55 beta
Fixed - Disabled STORE button on Param window
Fixed - Restore from file with WORD data
Fixed - Minor bug on SetNode windows
Fixed - Handling more than 255 param with Remote Protocol
Fixed - Handling of CAN speed through argument
Added - Reconnect after timeout
Added - LongTimeout option
Version 0.54
Added - Free Dongle Button
Improved - SDO Abort Handling
Improved - CSV Loading
Improved - SetNode window
Version 0.53
Fixed - Bug with IFAK dongle
Version 0.52
Fixed - Bug with IXXAT dongle
Version 0.51
Fixed - Pteach aquisition
Fixed - IXXAT driver loaded dynamically
Fixed - Minor bug with Vector
Added - New window to manipulate parameters
Added - Alarm on tester
Improved - SDO abort handling
Improved - 2 byte param handling
Version 0.50
Added - 20Kbps and 50Kbps Baud rate
Fixed - Minor bugs fixed
Version 0.49
Improved - Password handling
Version 0.48
Fixed - Various bugs fixed
Version 0.47
Added - Vector supports
Fixed - Bugs fixed
Version 0.46
Version 0.45
Version 0.44
Added - Kvaser supports
Added - Enhanced can-log propreties
Version 0.43
Added - Supports more than 255 parameters
Version 0.42
Fixed - Program VACC procedure requires password
Fixed - Parameter checksum visualisation (where supported)
Version 0.41
Fixed - Minor Bugs
Version 0.40
Added - Serial Number acquisition function
Added - Parameter Checksum acquisition function
Added - Information in .csv parameter file
Fixed - CanOpen ID change on the fly
Version 0.39
Version 0.38
Fixed - Minor Bugs
Version 0.37
Version 0.36
Version 0.35
Added - Master password
Version 0.34 beta
Fixed - Bug on clear alarm logbook
Fixed - Some minor bugs
Fixed - Bug on negative parameter's roll
Fixed - Bug on wakeup message with remote protocol
Fixed - Bug on tester menu value appearance for some parameters
Improved - "Teach" parameters' procedure
Improved - "Save/restore" procedure
Added - SDO library versioning for compatibility mode
Added - Security SDO messages on request
Added - Subnode selection for Standard protocol
Added - LEDs on select node form for Zapi node check
Version 0.33
Fixed - Bug on alarm logbook
Version 0.32
Improved - Node and subnode Zapi management.
Improved - Increase the max logbook alarm entry
Version 0.31
Fixed - Some bugs
Version 0.30
Improved - Stability
Fixed - Password function
Version 0.29
Fixed - Save and Clear EEPROM commands comply to CANopen standard
Version 0.28
Fixed - Problem with password
Version 0.27
Fixed - Problem with ifak device in connection
Version 0.26
Changed - Password management
Version 0.25
New - TxFromFile management
Added - CWconsole
Improved - Monitor Canbus
Added - Possibile to custom the new menu for Advanced Open Protocol
Version 0.24
Added - Monitor Canbus
Version 0.23
Added - New menu for Advanced Open Protocol
Version 0.22
Fixed - Fixed Ixxat filter for Advanced Open Protocol
Version 0.21
Added - WMconsole
Version 0.20
Added - Protocol Serial Ultra2 (3.13)
Improved - Save/Restore with ultra2 protocol
Improved - Save/Restore Speed.
Version 0.19
Improved - Menu management and disconnection
Version 0.18
Fixed - can open id
Version 0.17
Fixed - Fixed max parameters for save/restore
Version 0.15
Fixed - Fixed the max parameters
Version 0.14
Fixed - Fixed the error communication with peak and ifak
Version 0.13
Fixed - Error in tester menu
Fixed - Action on clear logbook.
Version 0.12
Version 0.11
Version 0.10
Fixed - Some bugs
Added - Peak device
Version 0.01
First Release.
Version: 0.58
PCCANCONSOLE
Version 0.58
Version 0.58 beta
Version 0.57
Version 0.56
Version 0.55
Version 0.55 beta
Version 0.54
Version 0.53
Version 0.52
Version 0.51
Version 0.50
Version 0.49
Version 0.48
Version 0.47
Fixed - Bugs fixed
Version 0.46
Version 0.45
Version 0.44
Version 0.43
Version 0.42
Version 0.41
Fixed - Minor Bugs
Version 0.40
Version 0.39
Version 0.38
Fixed - Minor Bugs
Version 0.37
Version 0.36
Version 0.35
Version 0.34 beta
Version 0.33
Version 0.32
Version 0.31
Fixed - Some bugs
Version 0.30
Version 0.29
Version 0.28
Version 0.27
Version 0.26
Version 0.25
Added - CWconsole
Version 0.24
Version 0.23
Version 0.22
Version 0.21
Added - WMconsole
Version 0.20
Version 0.19
Version 0.18
Fixed - can open id
Version 0.17
Version 0.15
Version 0.14
Version 0.13
Version 0.12
Version 0.11
Version 0.10
Fixed - Some bugs
Added - Peak device
Version 0.01
First Release.
- Hyster Zapi CAN PC Console-PCST Plugin 0.59.0
- ZpWinFlasher1.47
- ZpWinFlasher140_install
- ZAPI PC Can Console 0.90 Programs
- ZAPI WIN Console Version 1.20 Programs
- HYSTER YALE NACCO CANCONSOLE ZAPI
- ZAPI Can Flasher 0.55
- ZAPI PC Can Console 1.14
- ZAPI PC Console 0.72
- ZpWinFlasher 1.35
- Zapi Canconsole Full Collection Programming Program
- STILL PC Can Console 0.45 Diagnostic Solution
- Zapi PC Can Console 0.53
- Zapi ZpCanFlasher 0.50
- ZAPI PC Console v1.18
