Leonardobmt
140
1,146,792
ZAPI PC Can Console 0.90 Programs
ZAPI PC Can Console 090 Programs
Language: English, German, Italian
OS: Windows 7, Windows 8, Windows 10 32 & 64 bit(Tested on window 10 pro 1607 64bit)
Version: 0.90
Device Support: IXXAT, IFAK, PEAK USB, KVASER, VECTOR, INFREPID
Version 0.90
Added - Canopen protocol compliant logbook (if supported by controllers)
Version 0.89
Added - RMenu mode
Version 0.88
Improved - Compliant with standard canopen protocol. Specific controller that support it
are required
Version 0.87
Fixed - Cache directory saving
Version 0.86
Added - Z86 Files Download.
Version 0.84
Added - Eeprom range save on file.
Version 0.83
Improved - Timer Connection.
Fixed - Minor bugs
Version 0.77
Fixed - Fixed a bug in PTAB parameters' management
Version 0.75
Improved - Connection for Peak filter canbus off at the startup of the connection
Version 0.74
Improved - Window for PTab
Version 0.73
Improved - Window re-connection always at the top
Version 0.72
Improved - Stability
Version 0.71
Version 0.70
Added - Receive From Cache
Added - Nopti Options
Removed - Flicker on parameters form.
Version 0.69
Fixed - Various bugs
Version 0.68
Improved - AutoTeaching Motor
Version 0.67
Added - Calibration mode (for selected configurtations)
Version 0.66beta15
Parameters management for applications written using Zapi Platform software
Version 0.66beta14
Version 0.66beta13
Improved - PEAK devices management
Version 0.66beta10
Fixed - Acquisition gain current parameter.
Version 0.66beta8
Fixed - Timestamps during CAN log with IXXAT devices
Fixed - Active alarms cycle with SDO protocol
Added - PWORD management in Receive Par Ext
Version 0.66beta7
Added - Baudrate 800kbps and 1Mbps
Version 0.66
Fixed - Zapi console was able to connect to custom controllers
Version 0.65
Added - JAG Canconsole
Version 0.64
Fixed - Default parameter download via SDO
Version 0.63
Added - Handling PTAB parameters.
Version 0.62
Added - Extended Format for Ixxat, Peak device.
Version 0.61
Added - AutoTeaching Motor
Added - AutoTeaching Sensor
Version 0.60
Version 0.59
Bug fixed
Version 0.58
Fixed - SDO abort handling due to a read only object or value out of range
Fixed - Minor bug in DefaultParam
Fixed - Minor bug in Receive Par Ext
Version 0.58 beta
Added - New form for dynamic pdo handling
Added - Save/Load pdo dynamic pdo configuration
Fixed - Bug on ForceRemote config
Version 0.57
Added - Temporized data saving in RecordTester to prevent data loose in case of crash or disconnection
Added - ConnectedLabel with indication of the protocol in use
Fixed - Bug in DefaultParam
Version 0.56
Added - DefaultParam handling with ForceRemote protocol
Fixed - Bug in Read RAM
Fixed - SDO Abort index visualization
Version 0.55
Version 0.55 beta
Fixed - Disabled STORE button on Param window
Fixed - Restore from file with WORD data
Fixed - Minor bug on SetNode windows
Fixed - Handling more than 255 param with Remote Protocol
Fixed - Handling of CAN speed through argument
Added - Reconnect after timeout
Added - LongTimeout option
Version 0.54
Added - Free Dongle Button
Improved - SDO Abort Handling
Improved - CSV Loading
Improved - SetNode window
Version 0.53
Fixed - Bug with IFAK dongle
Version 0.52
Fixed - Bug with IXXAT dongle
Version 0.51
Fixed - Pteach aquisition
Fixed - IXXAT driver loaded dynamically
Fixed - Minor bug with Vector
Added - New window to manipulate parameters
Added - Alarm on tester
Improved - SDO abort handling
Improved - 2 byte param handling
Version 0.50
Added - 20Kbps and 50Kbps Baud rate
Fixed - Minor bugs fixed
Version 0.49
Improved - Password handling
Version 0.48
Fixed - Various bugs fixed
Version 0.47
Added - Vector supports
Fixed - Bugs fixed
Version 0.46
Version 0.45
Version 0.44
Added - Kvaser supports
Added - Enhanced can-log propreties
Version 0.43
Added - Supports more than 255 parameters
Version 0.42
Fixed - Program VACC procedure requires password
Fixed - Parameter checksum visualisation (where supported)
Version 0.41
Fixed - Minor Bugs
Version 0.40
Added - Serial Number acquisition function
Added - Parameter Checksum acquisition function
Added - Information in .csv parameter file
Fixed - CanOpen ID change on the fly
Version 0.39
Version 0.38
Fixed - Minor Bugs
Version 0.37
Version 0.36
Version 0.35
Added - Master password
Version 0.34 beta
Fixed - Bug on clear alarm logbook
Fixed - Some minor bugs
Fixed - Bug on negative parameter's roll
Fixed - Bug on wakeup message with remote protocol
Fixed - Bug on tester menu value appearance for some parameters
Improved - "Teach" parameters' procedure
Improved - "Save/restore" procedure
Added - SDO library versioning for compatibility mode
Added - Security SDO messages on request
Added - Subnode selection for Standard protocol
Added - LEDs on select node form for Zapi node check
Version 0.33
Fixed - Bug on alarm logbook
Version 0.32
Improved - Node and subnode Zapi management.
Improved - Increase the max logbook alarm entry
Version 0.31
Fixed - Some bugs
Version 0.30
Fixed - Password function
Version 0.29
Fixed - Save and Clear EEPROM commands comply to CANopen standard
Version 0.28
Fixed - Problem with password
Version 0.27
Fixed - Problem with ifak device in connection
Version 0.26
Changed - Password management
Version 0.25
New - TxFromFile management
Added - CWconsole
Improved - Monitor Canbus
Added - Possibile to custom the new menu for Advanced Open Protocol
Version 0.24
Added - Monitor Canbus
Version 0.23
Added - New menu for Advanced Open Protocol
Version 0.22
Fixed - Fixed Ixxat filter for Advanced Open Protocol
Version 0.21
Added - WMconsole
Version 0.20
Added - Protocol Serial Ultra2 (3.13)
Improved - Save/Restore with ultra2 protocol
Improved - Save/Restore Speed.
Version 0.19
Improved - Menu management and disconnection
Version 0.18
Fixed - can open id
Version 0.17
Fixed - Fixed max parameters for save/restore
Version 0.15
Fixed - Fixed the max parameters
Version 0.14
Fixed - Fixed the error communication with peak and ifak
Version 0.13
Fixed - Error in tester menu
Fixed - Action on clear logbook.
Version 0.12
Version 0.11
Version 0.10
Fixed - Some bugs
Added - Peak device
Version 0.01
First Release.
