Doosan Excavator DX480LC DX520LC 5001 and Up Shop Manual K1008703E
Brand: Doosan
Type of Machine: Track Excavator
Type of Manual: Shop Manual, Electrical Diagram, Hydraulic Diagram
Model: Doosan DX480LC DX520LC Excavator
Serial Number: 5001 and Up
Engine: DV11
Part Number: K1008703E
Number of Pages: 878 Pages
000 K1008703e(Dx480lc)Toc(2).Pdf
002 Sp000142(46).Pdf
Safety Precautions
Applicable Models
To The Operator Of A Doosan Daewoo Excavator
General Safety Essentials
Location Of Safety Labels
Summary Of Safety Precautions For Lifting In Digging Mode
Unauthorized Modifications
General Hazard Information
Before Starting Engine
Machine Operation
Maintenance
Battery
Towing
Shipping And Transportation
Lifting With Sling
003 S02specifications(2).Pdf
Specifications
004 Sp000143(30).Pdf
Specification For Dx480lc/ 520lc
005 S03general Maintenance(2).Pdf
General Maintenance
006 Sp000016(20).Pdf
General Maintenance Procedures
007 Sp000017(16).Pdf
Standard Torques
008 S04upper Structure(2).Pdf
Upper Structure
009 Sp000018(10).Pdf
Cabin
010 Sp000153(10).Pdf
Counterweight
011 Sp000155(16).Pdf
012 Sp000158(10).Pdf
Swing Bearing
013 Sp000160(46).Pdf
Swing Reduction Gear
014 S05lower Structure And Chassis(2).Pdf
Lower Structure And Chassis
015 Sp000171(40).Pdf
Track Assembly
016 Sp000025(38).Pdf
Air Conditioner Sp000025
017 S06engine And Drive Train(2).Pdf
Engine And Drive Train
018 Sp000026(8).Pdf
Drive Coupling (Main Pump)
019 S07hydraulics(2).Pdf
Hydraulics
020 Sp000179(38).Pdf
Hydraulic System Troubleshooting, Testing And Adjustment
021 Sp000028(8).Pdf
Accumulator
022 Sp000181(14).Pdf
Center Joint (Swivel)
023 Sp000193(16).Pdf
Cylinders
024 Sp000194(34)주의.Pdf
Swing Motor
025 Sp000185(64).Pdf
Travel Motor (With Gearbox) (A6v160hd) Sp000185
026 Sp000186(56).Pdf
Main Pump (Rexroth)
027 Sp000187(58).Pdf
Control Valve (Kayaba Model Kvmg-400-Da)
028 Sp000189(22).Pdf
Remote Control Valve (Work Lever / Joystick)
029 Sp000070(26).Pdf
Travel Control Valve (With Damper) Sp000070
030 Sp000191(14).Pdf
Solenoid Valve Assembly
031 Sp000192(12).Pdf
Breaker Eppr Valve (Opt)
032 Sp000209(22).Pdf
Fan Motor (Vane Type)
033 Sp000208(18).Pdf
Gear Pump (Fan Cooling Drive)
034 Sp000207(6).Pdf
Fan Cooling Flow In-Out Change Valve
035 Sp000212(10).Pdf
Hydraulic Schematic Dx480lc/ 520lc
036 S08electrical System(2).Pdf
037 Sp000197(116).Pdf
Electrical System Sp000197
038 Sp000213(10).Pdf
Electrical Schematic Dx480lc/ 520lc
039 S09attachments(2).Pdf
040 Sp000205(12).Pdf
Boom And Arm
041 Sp000206(10).Pdf
Bucket
Brand: Doosan
Engine: DV11
Safety Precautions
Applicable Models
Machine Operation
Maintenance
Battery
Towing
Lifting With Sling
Specifications
General Maintenance
Standard Torques
Upper Structure
Cabin
Counterweight
Swing Bearing
Track Assembly
018 Sp000026(8).Pdf
Hydraulics
021 Sp000028(8).Pdf
Accumulator
Cylinders
Swing Motor
Main Pump (Rexroth)
034 Sp000207(6).Pdf
Boom And Arm
Bucket
- Doosan Operation and Maintenance Manual Diesel Engine DB58, DB58S, DB58T ,DB58TI , DB58TIS
- Error codes doosan
- Doosan DX225LCA Operation and Maintenance Manual
- Doosan Diesel Engine Workshop Manual
- Doosan Diagnostic Software DMS+E-DOCTOR+CALBRATION INJECTOR DOC
- Doosan DX225LC Shop Manual
- Daewoo Doosan Solar 140LC-V Excavator Service Shop Manual
- Doosan Wheel Excavator ZF 2HL100 Transmission
- Doosan Maintenance Manual Diesel Engine DE12,DE12T,DE12TI,DE12TIS
- Doosan Common Rail Engines DL06,DL08 & DV11 Service Training
- Daewoo Doosan DB58,DB58T & DB58TI Diesel Engine Shop Manual
- Doosan E Doctor + Installation Manual
- Doosan DX140W/DX160W Operation and Maintenance Manual
- Doosan G424 Gasoline,LP Engine G424 LP Engine (Low Emission Version) G20E-3,G25E-3,G30 Service Manua
- Doosan MST M542 Spare Part Catalogue
