Doosan Articulated Dump Truck DA30 Shop Manual 531140 2012
Brand: Doosan
Type of Machine: Articulated Dump Truck
Type of Manual: Shop Manual, Hydraulic Diagram, Electrical Diagram
Model: Doosan DA30 Articulated Dump Truck
Part Number: 531140
Publication Date: 2012
List of Files:
DA30 Chapter 0 SENDA3000001.pdf (30 Pages)
DA30 Chapter 1 Engine SENDA3000002.pdf (234 Pages)
Trouble shooting Manual Scania.pdf
Index
White smoke
White smoke, water vapour
Black smoke when running/under load
Black smoke on starting
Blue smoke
Fuel in the oil
Cont.
Fuel in oil, cont.
Oil in coolant
Coolant/water in oil
Cont.
Coolant/water in oil, cont.
Low oil pressure
Cont.
Low oil pressure, cont.
Cont.
High oil pressure (engine warmed up)
Cont.
High oil pressure (engine warmed up), cont.
Abnormal wear (liner, piston rings, etc.)
Vibration, no driven components engaged
Vibration when the clutch or reverse gear is engaged
Vibration when alternator is in operation
Engine speed hunting - single-speed engines with RQ governor
Engine speed hunting - single-speed engines with RSV governor
Delivery pipe fractures
External corrosion on cylinder liner
Engine difficult to start
Cont.
Engine difficult to start, cont.
Fluid stroke
Cont.
Fluid stroke
Thermostat hunting, 14-series engine
Knocking/noise
Cont.
Knocking/noise, cont.
High oil consumption
High fuel consumption
Low compression
Low engine output
Cont.
Low engine output, cont.
Hot engine
Cont.
Hot engine, cont.
Cold engine
Coolant loss
Cont.
Coolant loss, cont.
Polluted coolant
Engine heater
High oil temperature
High exhaust temperature
Low charge air pressure
Low fuel pressure
Low system voltage
High system voltage
External oil leakage
Cont.
External oil leakage, cont.
External fuel leakage
External coolant leakage
Cont.
External coolant leakage, cont.
Oil pressed out via crankcase ventilation
Turbocharger breakdown
Compressed air system
Suggestions and views?
Blank Page
DA30 Chapter 2 Transmission SENDA3000003.pdf (47 Pages)
DA30 Chapter 3 Drive Line SENDA3000004.pdf (85 Pages)
DA30 Chapter 4 Lubrication System SENDA3000005.pdf (16 Pages)
DA30 Chapter 5 Hydraulic System SENDA3000006.pdf (65 Pages)
DA30 Chapter 6 Electrical System SENDA3000007.pdf (85 Pages)
DA30 Chapter 7 Front Wagon SENDA3000008.pdf (32 Pages)
DA30 Chapter 8 Rear Wagon SENDA3000009.pdf (4 Pages)
DA30 Chapter 9 Option SENDA3000010.pdf (7 Pages)
Brand: Doosan
Part Number: 531140
List of Files:
Index
White smoke
Blue smoke
Fuel in the oil
Cont.
Fuel in oil, cont.
Oil in coolant
Cont.
Low oil pressure
Cont.
Cont.
Cont.
Cont.
Fluid stroke
Cont.
Fluid stroke
Knocking/noise
Cont.
Low compression
Low engine output
Cont.
Hot engine
Cont.
Hot engine, cont.
Cold engine
Coolant loss
Cont.
Coolant loss, cont.
Polluted coolant
Engine heater
Low fuel pressure
Low system voltage
High system voltage
Cont.
Cont.
Blank Page
- Doosan Operation and Maintenance Manual Diesel Engine DB58, DB58S, DB58T ,DB58TI , DB58TIS
- Error codes doosan
- Doosan DX225LCA Operation and Maintenance Manual
- Doosan Diesel Engine Workshop Manual
- Doosan Diagnostic Software DMS+E-DOCTOR+CALBRATION INJECTOR DOC
- Doosan DX225LC Shop Manual
- Daewoo Doosan Solar 140LC-V Excavator Service Shop Manual
- Doosan Wheel Excavator ZF 2HL100 Transmission
- Doosan Maintenance Manual Diesel Engine DE12,DE12T,DE12TI,DE12TIS
- Doosan Common Rail Engines DL06,DL08 & DV11 Service Training
- Daewoo Doosan DB58,DB58T & DB58TI Diesel Engine Shop Manual
- Doosan E Doctor + Installation Manual
- Doosan DX140W/DX160W Operation and Maintenance Manual
- Doosan G424 Gasoline,LP Engine G424 LP Engine (Low Emission Version) G20E-3,G25E-3,G30 Service Manua
- Doosan MST M542 Spare Part Catalogue
