Martin Welker
104
230,310
Develon Wheel Loader DL480-7 Shop Manual 950106-02252_D_EN 2024
Brand: Develon
Type of Machine: Wheel Loader
Type of Manual: Shop Manual, Electric and Hydraulic Diagrams
Model: Develon DL480-7 Wheel Loader
Part Number: 950106-02252_D_EN
Publication Date: 2024
Number of Pages: 687 Pages
Safety, Specification and Systems Operation
Wheel Loader Safety​
Safety Instructions​
General​
Transportation​
Operation​
Long Term Storage​
Maintenance​
Environment and Circumstances​
General Specifications​
General​
Component Locations​
Working Range and Dimensions​
Working Capacities​
Performance Tests​
Preparation for Performance Tests​
Operational Performance Standard Table​
Operational Performance Test​
Approximate Weight of Workload Materials​
Engine Specifications​
Engine Specification​
Engine Performance Curves​
Tightening Torques​
Drivetrain Specifications​
Specification​
Hydraulic Systems Specifications​
Specification​
General Maintenance Instructions​
Welding Precautions and Instructions​
Hydraulic System - General Precautions​
Maintenance Service and Repair Procedure​
Hydraulic System Cleanliness and Oil Leaks​
Cleaning and Inspection​
Hydraulic Pressure Checks​
Standard Torques​
Torque Values for Standard Metric Fasteners​
Torque Values for Standard U.S. Fasteners​
Type 8 Phosphate Coated Hardware​
Torque Values for Hose Clamps​
ORFS Swivel Nut Recommended Torque​
Torque Values for Split Flanges​
Torque Wrench Extension Tools​
Loctite Applications​
Engine​
General Information​
Mechanical System​
Fuel System​
Lubricating System​
Cooling System​
Intake/Exhaust System​
Engine Control and Electrical System​
After Treatment System​
Transmission​
Transmission and Torque Converter​
Axle​
Front Axle​
Rear Axle​
Driveshaft​
General​
Steering​
Power Steering System​
Steering Unit​
Steering Pump​
Flow Amplifier​
Jerk Softener and Accumulator​
Brake​
Service Brake​
Brake and Pilot Supply Valve​
Charging Block​
Parking Brake​
Brake Pedal Valve​
Accumulator​
Brake Filter​
Cooling System​
Cooling System​
Fan and Brake Pump​
Fan Motor​
Radiator Assembly​
Hydraulic System​
Main Pump​
Main Control Valve​
Pilot System​
Hydraulic System​
Oil Tank​
Systems Operation and Description​
Power System​
Starting System​
Charging System​
Gauge Panel system​
Electric Steering​
EPOS system​
Air Conditioner System​
Refrigerant System Repairs​
Troubleshooting​
Removal and Installation
Before Removing and Installing​
Engine and Transmission Assembly​
DEF (adblue®) Quality Sensor​
ECU (Engine Control Unit)​
Alternator​
Starter Motor​
Sensors - After Treatment​
V-Belt​
Front Axle​
Rear Axle​
Drive Shaft​
Fuel Tank​
Joystick Valve (Work Lever)​
Cabin Assembly​
Undercovers​
Gauge Panel​
Battery Assembly​
Cabin Switches​
Cabin Photo Sensor​
DC-DC Controller​
Display Monitor​
EPOS Controller​
TCU Controller​
ACU Controller​
Smart Key Controller​
TMS Controller​
Wiper Motor​
Combination Switch​
Transmission Lever​
Troubleshooting Guide
Wiring Harness Layout​
Wiring Device​
Error Code​
VCU Error Code​
ECU Error Code​
TCU Error Code​
Electric Steering Error Code​
Schematics
Hydraulic Schematic​
Electric Schematic​
