DAS Xentry 7-2011 Installation Guide
This is the installation guide of DAS Xentry 7-2011 with some tricks.
Its not the best guide, But the 1st free one.
Testing results = Tup
DAS XENTRY 7-2011 Installation Guide:
Now we start
1: Install fresh WinXp SP3 and all drivers Tongue
2: Partion Ur HDD. Make sure C:Star D:Recover E:Wis FAS.
3: Make new user STAR.
4: Install JC softs and SDI as well + regedit for C4 + stop screen saver + edit power managment.
4: Delete C3 from regedit (H_K_Local_Machine ==> Softwares ==> StarDiagnosis).
5: Install IE 8
6: Install Netframe 3.5 Sp1
7: Copy Commonlic to system32 (Make read Only).
8: Copy commonlic to: C:\WINDOWS\Temp\{17B8B381-50E5-470D-A6B3-C494240AF33C}\{22A937EF-8C64-11D7-A9EE-00D009D07BEF} (It will look like this name But every restart, the name may change.
9: Copy Commonlic to C:\Documents and Settings\STAR\Local Settings\Temp\{892805C2-7E95-4EFB-8D58-5D8E9AD842A1}\{22A937EF-8C64-11D7-A9EE-00D009D07BEF}
(It will look like this name But every restart, the name may change).
Note: when installation Just starts, C:\WINDOWS\Temp\... folder will be created thus u make the replace. After 1st restart, C:\Documents and Settings\STAR\Local Settings\Temp\... will be created, so u make the replace right there. ( I added this note because one guy complained that he doesnt have these folders Big GrinBig GrinBig Grin ).
Note: Make shortcuts for the two folders mentioned (C:\WINDOWS\Temp & C:\Documents and Settings\STAR\Local Settings\Temp)
because everytime the PC will start u have to replace and b4 setup starts.
10: Replace Commonlic in Star utilities. Apply Keys and Move on.
11: Setup will go smooth and suddenly ull get error Code 5011: 0x80040707
Setup will terminate Sad
12: Apply JC unrestrict FIX to see all Drives because they will be hidden.
13: Copy SDflash from SD_DVD to F:\Programme\DAS
14: Goto F:\Programme\DAS\SDflash\Release\PKW and extract #FDOK
15: Goto F:\Programme\DAS\SDflash\Release\SMART and Extract #FDOK
16: Goto F:\Programme\DAS\SDflash\Release\Transp and Extarct #FDOK
17: Copy and Paste folder C:\USERDATA into F Drive. (Great members warned me about this point since I 4got to mention it when I just wrote this guide Listen ).
18: Place DAS SIM and DAS Shortcuts on desktop:
DAS shortcut target as: F:\Programme\DAS\bin\DAS32R2.exe -len
And for DAS SIM Target as: F:\Programme\DAS\bin\simdas.exe -*CALsimu -*ctxtsim.sli -*nolog -*len
19: If u want to RUN DAS Without Xentry so place the DAS32R2.exe Fix in DAS BIN and make shortcut.
20: Goto Drive Letter:\stardiag\Xentry_Frame and Start installing Xentry.
21: After Xentry Finish Installation, goto: Drive Letter:\stardiag\AddOn_Frame and start installing Addons.
22: B4 u restart, goto Run and type control userpasswords2 then reset STAR Password and Make windows Autologin in to STAR.
23: After restart, Apply Xentry Error Fix 3-2011 or 5-2011 ( All are working).
24: If ur using sdconnect then open cal.ini and change PLATFORM=PART_W (it was T B4).
25: Internet in ur pc will not work (sp browsing sites) to solve this goto: C:\Programme\SDnetControl and rename networkfilter Wink
next restart it will not load the networkfilter. U can stop networkfilter by: Ctrl + Alt + Dlt ==> proccess and stop it.
26:If ur using sdconnect, during diagnosis, pop message will appear about firmware update. You can disable the update message for Sdconnect by renaming Automatic update folder in: C:\Program Files\SDconnect Toolkit
In my case I renamed update special and manual as well so better U renamed them all Smile
Hope this help.
Done! Tested on SIM and real cars = working like a charm Drive
Note: No need edit DAS DVD and remove the antivirus. Just keep it as it is.
Note besides: maybe some steps are not imp but for my personal installation, I did as mentioned above.
Gd luck for all. Drive
Now we start
5: Install IE 8
Hope this help.
- Delphi/AuTocom 2013.2 with update 1 [Activation, CDP, CDP+,ADP186,SDP]
- Mitchell OnDemand 2015 + Mitchell Manager Torrent
- Autocom/delphi 2013.1 Full
- AutoCom/Delphi 2013.3 Activator!!!! Also Including My Delphi 2013.3 Super Easy Installer by SuperS
- Delphi/Autocom 2013.R3 How to install
- Autocom & Delphi 2013 R1 Activator patch Works Fine
- Autocom 2013 R2 Full
- TachoSoft Mileag Calculator 25.9 - 2016 full
- Autocom CDP 2013.R1 FULL
- KG Vivid Workshop DATA ATI v.10.2 + Instruction
- Autocom CDP+ Delphi 2014.Release 1 Update Full
- DELPHI DIAMAND [02.2016]
- Delphi><Autocom Keygen 2013.3 Xml file activator
- Autocom - Delphi 2012.3 Full
- NYO4 calculator Torrent
