Daewoo Excavator Solar 010 Shop Manual 2022-7153E 1997
Brand: Doosan
Type of Manual: Shop Manual, Electrical Diagram, Hydraulic Diagram
Model: Doosan Solar 010 Excavator
Engine: Yanmar 2TNE68
Part Number: 2022-7153E
Publication Date: 1997
Number of Pages: 268 Pages
1. SAFETY
1.1 General Safety Essentials
1.2 Use and Modification Precautions
1.3 Work Site Precautions
1.4 Operation
1.5 Equipment
1.6 Maintenance
1.7 Shipping and Transportation
2. SPECIFICATIONS
2.1 General Specifications
2.2 General Dimensions
2.3 Working Range
2.4 Engine Specifications
2.5 Engine Performance Curve
2.6 Hydraulic System Component Specifications
3. HYDRAULIC SYSTEM OPERATION
4. GEAR PUMP
4.1 Assembly Drawing
4.2 Overhauling Drawing
4.3 Pump Inspection and Repair
5. CONTROL VALVE
5.1 Tools
5.2 Disassembly
5.3 Assembly
5.4 Final Assembly and Testing
6. SWING MOTOR
6.1 Brake Valve Operation
6.2 Brake Valve Removal
6.3 Brake Valve Disassembly
6.4 Brake Valve Inspection and Cleaning
6.5 Brake Valve Reassembly
6.6 Brake Valve Installation
6.7 Swing Motor Parts Lift
6.8 Disassembly
6.9 Reassembly
7.1 Tools
7.2 Travel Motor Operation
7.3 Travel Motor Overhaul
7.4 End Cover Assembly Overhaul
7.5 Speed Reducer Overhaul
7.6 Assembly
8. ENGINE
8.1 Valve Adjustment Sequence
8.2 Wear Limits of Major Engine Components
8.3 Engine Oil Pump Rebuild
9. ELECTRICAL SYSTEM
9.1 General Description
9.2 Starting System
9.3 Charging System
9.4 Glow Plug System
9.5 Testing Starter
9.6 Testing Glow Plug
9.7 Testing Generator
9.8 TestingStator Coil Continuity
10. MAINTENANCE
10.1 General Description
10.2 Table of Recommended Lubricants
10.3 Lubrication Points
10.4 Standard Torques
10.5 Track Maintenance and Replacement
10.6 Adjusting Track Tension
11. TROUBLE SHOOTING
11.1 Engine
11.2 Gear Pump
11.3 Travel Motor
12. PERFORMANCE STANDARD AND TEST
12.1 Performance Standards
12.2 Performance Tests
Brand: Doosan
1. SAFETY
1.4 Operation
1.5 Equipment
1.6 Maintenance
2. SPECIFICATIONS
2.3 Working Range
4. GEAR PUMP
5. CONTROL VALVE
5.1 Tools
5.2 Disassembly
5.3 Assembly
6. SWING MOTOR
6.8 Disassembly
6.9 Reassembly
7.1 Tools
7.6 Assembly
8. ENGINE
9.2 Starting System
9.3 Charging System
9.5 Testing Starter
10. MAINTENANCE
11.1 Engine
11.2 Gear Pump
11.3 Travel Motor
- Doosan Operation and Maintenance Manual Diesel Engine DB58, DB58S, DB58T ,DB58TI , DB58TIS
- Error codes doosan
- Doosan DX225LCA Operation and Maintenance Manual
- Doosan Diesel Engine Workshop Manual
- Doosan Diagnostic Software DMS+E-DOCTOR+CALBRATION INJECTOR DOC
- Doosan DX225LC Shop Manual
- Daewoo Doosan Solar 140LC-V Excavator Service Shop Manual
- Doosan Wheel Excavator ZF 2HL100 Transmission
- Doosan Maintenance Manual Diesel Engine DE12,DE12T,DE12TI,DE12TIS
- Doosan Common Rail Engines DL06,DL08 & DV11 Service Training
- Daewoo Doosan DB58,DB58T & DB58TI Diesel Engine Shop Manual
- Doosan E Doctor + Installation Manual
- Doosan DX140W/DX160W Operation and Maintenance Manual
- Doosan G424 Gasoline,LP Engine G424 LP Engine (Low Emission Version) G20E-3,G25E-3,G30 Service Manua
- Doosan MST M542 Spare Part Catalogue
