503
1,875,891
Cummins Holset Air Compressors Master Repair Manual
Download this document, you need 200 Gallons
Type: exe
Do not need to set up just click and run
Bulletin Number: (3666121)
Plublished by Cummins 2000-2010
Front
(3666121-titlepage) Titlepage
(mrm-frwd) Foreword
Section i - Introduction
(99-204-002-mrm) About the Manual
(99-204-003-mrm) How to Use the Manual
(99-204-004) Symbols
(99-204-005) Illustrations
(99-204-006-mrm) General Safety Instructions
(99-204-007-mrm) General Repair Instructions
(99-204-008) General Cleaning Instructions
(99-204-009) Acronyms and Abbreviations
Section E - Component Identification
(04-208-001) Component Identification
(04-208-002) Component Diagrams
Section F - Familiarization
(04-209-999) Overview
Section G - Installation Guidelines
(04-210-001) Installation Procedure
(04-008-122) System Installation Instructions
Section TS - Troubleshooting Symptoms
(99-t00-001-tr) Troubleshooting Procedures and Techniques
(99-t00-002) Troubleshooting Symptoms Charts
(3666121-t004-tr) Air Compressor Air Pressure Rises Slowly
(3666121-t005-tr) Air Compressor Cycles Frequently
(3666121-t006-tr) Air Compressor Noise is Excessive
(3666121-t007-tr) Air Compressor Pumping Excess Lubricating Oil into the Air System
(3666121-t008-tr) Air Compressor Will Not Maintain Adequate Air Pressure (Not Pumping Continuously)
(3666121-t009-tr) Air Compressor Will Not Pump Air
(3666121-t010-tr) Air Compressor Will Not Stop Pumping
Section 12 - Compressed Air System
(04-022-001_12) Service Tools
(99-012-003) Air Compressor Carbon Buildup
(04-012-010) Air Compressor Pin Bore Wear
(04-012-013) Air Compressor Unloader and Valve Assembly
(04-012-014) Air Compressor
(04-012-017) Air Governor (Air Compressor Will Not Pump)
(04-012-018) Air Governor (Air Compressor Pumps Continuously)
(04-012-019) Air Leaks, Compressed Air System
(04-012-101) Air Compressor Cylinder Head (Holset® SS191 Model)
(04-012-102) Air Compressor (Holset® SS191 Model)
(04-012-103) Air Compressor Cylinder Head (Holset® SS and E-Type Models)
(04-012-104) Air Compressor Cylinder Head (Holset® QE Models)
(04-012-105) Air Compressor (Holset QS230, SS296, SS296E, QE296, SS338E, and QE338 Models)
(04-012-106) Air Compressor Cylinder Head (Holset® ST Models)
(04-012-107) Air Compressor (Holset® ST676 Model)
(04-012-108) Air Compressor (Holset® ST773 Model)
Section L - Service Literature
(04-205-001) Additional Service Literature
(99-205-002) Service Literature Ordering Location
(99-205-004) Cummins Customized Parts Catalog
Section V - Specifications
(04-018-022) Compressed Air System
(04-018-006) Engine Component Torque Values
(99-018-009) Capscrew Markings and Torque Values
(99-018-010) Fraction, Decimal, Millimeter Conversions
(99-018-011) Newton-Meter to Foot-Pound Conversions
(99-018-012) Pipe Plug Torque Values
(99-018-013) Tap-Drill Chart - U.S. Customary and Metric
(99-018-014) Weights and Measures - Conversion Factors
Back
