Cummins Engine M11 Series Shop Manual 3666075-00
Brand: Cummins
Type of Manual: Shop Manual
Model: Cummins M11 Engine
Part Number: 3666075-00
Number of Pages: 585 Pages
Main Menu
Cover Page
Introduction
About The Manual
Definition Of Terms
General Cleaning Instructions
General Repair Instructions
General Safety Instructions
How To Use The Manual
Illustrations
Simbolos
Symbole
Symboles
Symbols
Engine Identification
Engine Diagrams
Engine Indentification
Engine Specifications
Engine Disassembly And Assembly - Group 00
Engine Assembly
Engine Disassembly
Engine Disassembly And Assembly - General Information
Service Tools - Disassembly And Assembly
Cylinder Block - Group 01
Camshaft - Cleaning And Inspection For Reuse
Camshaft - Magnetic Crack Inspection
Camshaft Bushing - Replacement
Camshaft Gear - Replacement
Camshaft Or Idler Gear - Magnetic Crack Inspection
Connecting Rod - Bend And Twist Inspection
Connecting Rod - Cleaning And Inspection For Reuse
Connecting Rod - Magnetic Crack Inspection
Connecting Rod Bearings - Cleaning And Inspection For Reuse
Crankshaft - Cleaning And Inspections For Reuse
Crankshaft Gear - Replacement
Crankshaft Magnetic Crack Inspection
Crankshaft Pulley - Cleaning And Inspection For Reuse
Cylinder Block - Exploded View
Cylinder Block - General Information
Cylinder Block - Inspection For Reuse
Cylinder Liner - Cleaning And Inspection For Reuse
Dipstick Tube Bracket - Cleaning And Inspection For Reuse
Gear Cover - Cleaning And Inspection For Reuse
Gear Housing - Cleaning And Inspection For Reuse
Hand Hole Cover - Cleaning And Inspection For Reuse
Idler Gear Assembly - Cleaning And Inspection For Reuse
Main Bearings - Cleaning And Inspection For Reuse
Piston - Cleaning And Inspection For Reuse
Service Tools - Cylinder Block
Vibration Damper (Viscous) - Cleaning And Inspection For Reuse
Cylinder Head - Group 02
Cylinder Head - Cleaning And Inspection For Reuse
Cylinder Head - Exploded View
Cylinder Head - General Information
Cylinder Head - Pressure Test For Reuse
Cylinder Head - Rebuild
Cylinder Head - Vacuum Test Valve Seating
Cylinder Head - Valve Grinding
Cylinder Head Injector Sleeve - Replacement
Cylinder Head Oversize Valve Seat Insert - Installation
Cylinder Head Valve Guide - Replacement
Cylinder Head Valve Seat Insert - Replacement
Cylinder Head Valves - Magnetic Crack Inspection
Service Tools - Cylinder Head
Valve Crosshead - Cleaning And Inspection For Reuse
Valve Crosshead - Magnetic Crack Inspection
Rocker Levers - Group 03
Crankcase Breather (Internal) - Cleaning And Inspection
Rocker Housing And Cover (Automotive) - Exploded View
Rocker Lever - Magnetic Crack Inspection
Rocker Lever Assembly - Cleaning And Inspection For Reuse
Rocker Lever Assembly - Rebuild
Rocker Lever Bushing - Replacement
Rocker Lever Cover - Cleaning And Inspection For Reuse
Rocker Lever Housing - Cleaning And Inspection For Reuse
Rocker Levers - Exploded View
Rocker Levers - General Information
Service Tools - Rocker Levers
Cam Followers - Group 04
Cam Follower Assembly - Cleaning And Inspection For Reuse
Cam Follower Assembly - Exploded View
Cam Follower Assembly - General Information
Cam Follower Assembly - Rebuild
Cam Follower Lever - Magnetic Crack Inspection (Roller Removed)
Cam Follower Lever - Roller Replacement
Cam Follower Lever Socket - Replacement (Roller Removed)
Push Rods And Tubes - Cleaning And Inspection For Reuse
Service Tools - Cam Follower Assembly
Fuel System - Group 05
Fuel Pump - Cleaning And Inspection For Reuse
Fuel Pump - General Information
Fuel Pump - Rebuild
Injectors And Fuel Lines - Group 06
Fuel Tubes, Fittings And Mounting Parts - Cleaning And Inspection For Reuse
Injector - Celect - Exploded View
Injectors - Calibration
Injectors - Cleaning And Inspection For Reuse
Injectors - General Information
Injectors - Rebuild
Lubricating Oil System - Group 07
Lubricating Oil Cooler - Cleaning And Inspection For Reuse
Lubricating Oil Dipstick - Calibration
Lubricating Oil Dipstick And Dipstick Tube - Cleaning And Inspection For Reuse
Lubricating Oil Filter Head - Cleaning And Inspection For Reuse
Lubricating Oil Filter Head - Rebuild
Lubricating Oil Pan - Cleaning And Inspection For Reuse
Lubricating Oil Pan Transfer Tube - Cleaning And Inspection For Reuse
Lubricating Oil Pump - Cleaning And Inspection For Reuse
Lubricating Oil Pump - Rebuild
Lubricating Oil System - Exploded View
Lubricating Oil System - General Information
Service Tools - Lubricating Oil System
Cooling System - Group 08
Fan Hub - Cleaning And Inspection For Reuse
Fan Hub - Exploded View
Fan Hub And Fan Idler Pulley - General Information
Fan Hub (Belt Driven) - Rebuild
Fan Idler Pulley - Cleaning And Inspection For Reuse
Fan Idler Pulley - Rebuild
Fan Idler Pulley And Bracket - Exploded View
Heater Housing, Thermostat Support And Water Header Cover - Cleaning And Inspection
Service Tools - Cooling System
Thermostat - Operating Temperature Inspection
Thermostat Housing Assembly - Rebuild
Water Filter Head Assembly - Cleaning And Inspection For Reuse
Water Filter Head Assembly - Rebuild
Water Pump - Cleaning And Inspection For Reuse
Water Pump - Rebuild
Water Pump Assembly - Exploded View
Water Pump Assembly - General Information
Drive Units - Group 09
Accessory Drive Pulley - Cleaning And Inspection For Reuse
Drive Units - General Information
Fuel Pump And Compressor Drive - Cleaning Inspection For Reuse
Fuel Pump And Compressor Drive - Exploded View
Fuel Pump And Compressor Drive - Rebuild
Hydraulic Pump Drive - Cleaning And Inspection For Reuse
Hydraulic Pump Drive - Exploded View
Hydraulic Pump Drive - Rebuild
Service Tools - Drive Units
Air Intake System - Group 10
Air Intake System - General Information
Cac Air Intake System Expoded View
Intake Manifold - Cleaning And Inspection For Reuse
Service Tools - Air Intake System
Turbocharger - Cleaning And Inspection For Reuse
Exhaust System - Group 11
Exhaust Manifold - Cleaning Inspection For Reuse
Exhaust System - Exploded View
Exhaust System - General Information
Air Equipment - Group 12
Air Compressor - Cleaning And Inspection For Reuse
Air Equipment - General Information
Compressed Air Systems Flow Diagrams
Electrical Equipment - Group 13
Alternator Adjusting Link - Cleaning And Inspection For Reuse
Alternator Bracket - Cleaning And Inspection For Reuse
Alternator Bracket (Bus Applications) - Cleaning And Inspection For Reuse
Automatic Belt Tensioner Bracket (Bus Applications) - Cleaning And Inspection For Reuse
Automatic Belt Tensioner (Bus Applications) - Cleaning And Inspection For Reuse
Electrical Equipment - General Information
Starting Motor - Cleaning And Inspection For Reuse
Wiring Diagrams
Engine Testing - Group 14
Chassis Dynamometer
Dynamometer Worksheet
Engine Dynamometer - Install Engine
Engine Painting
Engine Run-In Procedure -Chassis Dynamometer
Engine Run-In Procedure - Engine Dynamometer
Engine Run-In Procedure - Without Dynamometer
Engine Storage - Long Term
Engine Storage - Short Term
Engine Testing - General Information
Engine Testing - Specifications
Service Tools - Engine Testing
Instruments And Controls - Group 15
Instruments And Controls - General Information
Mounting Adaptations - Group 16
Flywheel - Cleaning And Inspection For Reuse
Flywheel Housing - Cleaning And Inspection For Reuse
Flywheel Ring Gear - Replacement
Front Engine Support - Cleaning And Inspections
Mounting Adaptations - Exploded View
Mounting Adaptations - General Information
Rear Engine Power Takeoff - Exploded View
Rear Engine Power Takeoff (Repto) Rebuilding
Service Tools - Mounting Adaptations
Specifications - Group 18
Capscrew Markings And Torque Values
Component Specifications And Torque Values
Drive Belt Tension
Injections Timing Codes
Newton-Meter To Foot-Pound Converstion Chart
Pipe Plug Torque Values
Specifications - General Information
Tap-Drill Chart - U.S. Customary & Metric
Weight And Measures - Conversion Factors
Vehicle Braking - Group 20
Vehicle Braking - General Information
Service Literature
Additional Service Literature
Service Literature Ordering Location
Component Manufacturers: Names And Addresses
Component Manufacturers' Addresses
Air Compressors
Air Cylinders
Air Heaters
Air Starting Motors
Alternators
Auxiliary Brakes
Belts
Catalytic Converters
Clutches
Coolant Heaters
Drive Plates
Electric Starting Motors
Engine Protection Controls
Fan Clutches
Fans
Filters
Flexplates
Fuel Warmers
Gauges
Governors
Heat Sleeves
Hydraulic And Power Steering Pumps
Oil Heaters
Torque Converters
Index
