Cummins CELECT Electronic Control System L10,M11 and N14 Engines Troubleshooting and Repair Manual
Type: exe
Do not need to set up just click and run
Bulletin Number: 3666084
Plublished by Cummins 2000-2010
front
(3666084-titlepage) Titlepage
(tr-frwd) Foreword
Section i - Introduction
(99-204-002-tr) About the Manual
(99-204-003-tr) How to Use the Manual
(99-204-004) Symbols
(99-204-005) Illustrations
(99-204-006-tr) General Safety Instructions
(99-204-007-tr) General Repair Instructions
(99-204-008) General Cleaning Instructions
(99-204-009) Acronyms and Abbreviations
Section E - Engine Identification
(83-100-002) Engine Identification
Section F - Familiarization
(83-101-007) Electronic Controlled Fuel System
(00-022-999) Service Tools and Hardware - Overview
Section TF - Troubleshooting Fault Codes
(83-fc115) Engine Position Sensor (EPS) Circuit
(83-fc121) Engine Position Sensor (EPS) Circuit
(83-fc122) Intake Manifold Pressure Sensor Circuit
(83-fc123) Intake Manifold Pressure Sensor Circuit
(83-fc131) Accelerator Position Sensor Choice
(83-fc131iss) Accelerator Position Sensor Circuit
(83-fc131ivs) Accelerator Position Sensor Circuit
(83-fc132) Accelerator Position Sensor Choice
(83-fc132iss) Accelerator Position Sensor Circuit
(83-fc132ivs) Accelerator Position Sensor Circuit
(83-fc135) Oil Pressure Sensor Circuit
(83-fc141) Oil Pressure Sensor Circuit
(83-fc143) Oil Pressure - Engine Protection
(83-fc144) Coolant Temperature Sensor Circuit
(83-fc145) Coolant Temperature Sensor Circuit
(83-fc151) Coolant Temperature - Engine Protection
(83-fc153) Intake Manifold Air Temperature Sensor Circuit
(83-fc154) Intake Manifold Air Temperature Sensor Circuit
(83-fc155) Intake Manifold Air Temperature Sensor - Engine Protection
(83-fc212) Oil Temperature Sensor Circuit
(83-fc213) Oil Temperature Sensor Circuit
(83-fc214) Oil Temperature - Engine Protection
(83-fc221) Ambient Air Pressure Sensor Circuit
(83-fc222) Ambient Air Pressure Sensor Circuit
(83-fc234) Engine Overspeed
(83-fc235) Engine Coolant Level - Engine Protection
(83-fc241) Vehicle Speed Sensor (VSS) Circuit
(83-fc242) Vehicle Speed Sensor (VSS) Circuit
(83-fc243) Engine Brake Supply Circuit
(83-fc245) Engine Fan Clutch Supply Circuit
(83-fc254) Fuel Shutoff Solenoid Supply Circuit
(83-fc255) Fuel Shutoff, Fan Clutch, Engine Brake Supply Circuit
(83-fc311) Injector Circuit Number 1 Choice
(83-fc311n) Injector Circuit Number 1 N14
(83-fc311ml) Injector Circuit Number 1 M11 and L10
(83-fc312) Injector Circuit Number 5 Choice
(83-fc312n) Injector Circuit Number 5 N14
(83-fc312ml) Injector Circuit Number 5 M11 and L10
(83-fc313) Injector Circuit Number 3 Choice
(83-fc313n) Injector Circuit Number 3 N14
(83-fc313ml) Injector Circuit Number 3 M11 and L10
(83-fc314) Injector Circuit Number 6 Choice
(83-fc314n) Injector Circuit Number 6 N14
(83-fc314ml) Injector Circuit Number 6 M11 and L10
(83-fc315) Injector Circuit Number 2 Choice
(83-fc315n) Injector Circuit Number 2 N14
(83-fc315ml) Injector Circuit Number 2 M11 and L10
(83-fc321) Injector Circuit Number 4 Choice
(83-fc321n) Injector Circuit Number 4 N14
(83-fc321ml) Injector Circuit Number 4 M11 and L10
(83-fc322) Injector Circuit Number 1 Choice
(83-fc322n) Injector Circuit Number 1 N14
(83-fc322ml) Injector Circuit Number 1 M11 and L10
(83-fc323) Injector Circuit Number 5 Choice
(83-fc323n) Injector Circuit Number 5 N14
(83-fc323ml) Injector Circuit Number 5 M11 and L10
(83-fc324) Injector Circuit Number 3 Choice
(83-fc324n) Injector Circuit Number 3 N14
(83-fc324ml) Injector Circuit Number 3 M11 and L10
(83-fc325) Injector Circuit Number 6 Choice
(83-fc325n) Injector Circuit Number 6 N14
(83-fc325ml) Injector Circuit Number 6 M11 and L10
(83-fc331) Injector Circuit Number 2 Choice
(83-fc331n) Injector Circuit Number 2 N14
(83-fc331ml) Injector Circuit Number 2 M11 and L10
(83-fc332) Injector Circuit Number 4 Choice
(83-fc332n) Injector Circuit Number 4 N14
(83-fc332ml) Injector Circuit Number 4 M11 and L10
(83-fc333) Injector Circuit
(83-fc335) ECM RAM Memory
(83-fc341) ECM ROM Memory
(83-fc342) ECM
(83-fc343) Fault Processing Computer (FPC) Chip
(83-fc351) Injector Power Supply
(83-fc352) Sensor Supply Circuit
(83-fc411) Datalink Circuit - Control
(83-fc412) Datalink Circuit - Vehicle
(83-fc413) Datalink Circuit - Control
(83-fc414) Datalink Circuit - Vehicle
(83-fc415) Oil Pressure - Engine Protection
(83-fc422) Coolant Level Sensor Circuit
(83-fc431) Idle Validation Switch Choice
(83-fc431iss) Idle Validation Switch Circuit
(83-fc431ivs) Idle Validation Switch Circuit
(83-fc432) Accelerator Pedal Choice
(83-fc432iss) Accelerator Pedal Circuit
(83-fc432ivs) Accelerator Pedal Circuit
(83-fc433) Intake Manifold Pressure Sensor Circuit
(83-fc434) Unswitched Battery Supply Circuit
(83-fcmfc) Fault Code Multiple Choice
(83-fcmfc1) Fault Code Multiple A
(83-fcmfc2) Fault Code Multiple B
Section TS - Troubleshooting Symptoms
(99-t00-001-tr) Troubleshooting Procedures and Techniques
(99-t00-002) Troubleshooting Symptom Charts
(3666084-t016-tr) Communication Error - Electronic Service Tool or Control Device
(3666084-t033-tr) Engine Acceleration or Response Poor
(3666084-t041-tr) Engine Decelerates Slowly
(3666084-t043-tr) Engine Difficult to Start or Will Not Start (Exhaust Smoke)
(3666084-t044-tr) Engine Difficult to Start or Will Not Start (No Exhaust Smoke)
(3666084-t057-tr) Engine Power Output Low
(3666084-t058-tr) Engine Output Low- Performance Measurement
(3666084-t061-tr) Engine Runs Rough at Idle
(3666084-t062-tr) Engine Runs Rough or Misfires
(3666084-t064-tr) Engine Shuts Off Unexpectedly or Dies During Deceleration
(3666084-t066-tr) Engine Speed Surges At Low or High Idle
(3666084-t067-tr) Engine Speed Surges Under Load or in Operating Range
(3666084-t068-tr) Engine Speed Surges in PTO or Cruise Control
(3666084-t072-tr) Engine Starts But Will Not Keep Running
(3666084-t080-tr) Engine Will Not Reach Rated Speed (RPM)
(3666084-t081-tr) Engine Will Not Shut Off
(3666084-t083-tr) Fault Code Warning Lamps Stay On (No Apparent Reason)
(3666084-t084-tr) Fault Code Warning Lamps Do Not Illuminate
(3666084-t087-tr) Fuel Consumption Excessive
(3666084-t099-tr) Low Idle Adjust Switch Does Not Work
(3666084-t110-tr) Programmable Features or Parameters Not Correct
(3666084-t112-tr) PTO or Cruise Control Does Not Operate
(3666084-t116-tr) Smoke, Black - Excessive
(3666084-t118-tr) Smoke, White - Excessive
Section TT - Troubleshooting Symptoms (New Format)
(00-ttecm) ECM - No Communication Troubleshooting Tree
Section 19 - Electronic Engine Controls - Group 19
(83-022-001_19) Service Tools
(83-019-004) Barometric Air Pressure Sensor
(99-019-008) Battery Ground Circuit
(99-019-009) Clutch Pedal Position Switch
(99-019-010) Clutch Pedal Position Switch Circuit
(83-019-017) Engine Coolant Level Sensor
(83-019-019) Engine Coolant Temperature Sensor
(99-019-021) Cruise Control or PTO ON/OFF Switch
(99-019-022) Cruise Control or PTO ON/OFF Switch Circuit
(99-019-023) Cruise Control or PTO Set/Resume Select Switch
(99-019-024) Cruise Control or PTO Set/Resume Select Switch Circuit
(83-019-025) Data Link Circuit, Control
(99-019-027) Diagnostic Test Mode Switch
(83-019-031) Electronic Control Module (ECM)
(105-019-032) ECM Calibration Code
(83-019-033) Engine Brake Enable Circuit
(99-019-034) Engine Brake ON/OFF Switch
(99-019-035) Engine Brake ON/OFF Switch Circuit
(83-019-038) Engine Position Sensor (EPS)
(83-019-039) Engine Position Sensor (EPS) Circuit
(83-019-040) Engine Protection Warning Lamp
(83-019-041) Engine Protection Warning Lamp Circuit
(83-019-043) Engine Wiring Harness
(83-019-045) Fan Control Circuit
(99-019-046) Fault Lamp
(99-019-047) Fault Lamp Circuit
(83-019-049) Fuel Shutoff Valve Circuit
(83-019-050) Fuel Shutoff Valve
(99-019-052) Idle Adjust Switch
(99-019-053) Idle Adjust Switch Circuit
(99-019-054) Idle Validation Switch
(83-019-055) Idle Validation Switch Circuit
(83-019-057) Injector Solenoid
(83-019-058) Injector Solenoid Circuit
(83-019-059) Intake Manifold Air Temperature Sensor
(83-019-060) Intake Manifold Air Temperature Sensor Circuit
(83-019-061) Intake Manifold Pressure Sensor
(105-019-063) Internal Actuator Wiring Harness
(99-019-064) Key Switch Battery Supply Circuit
(83-019-066) Engine Oil Pressure Sensor
(83-019-067) Engine Oil Temperature Sensor
(99-019-071) OEM Wiring Harness
(99-019-078) Programmable Features and Parameters Not Correct
(99-019-079) Remote PTO Switch Circuit
(83-019-080) Remote PTO Switch
(83-019-083) Tachometer Circuit
(99-019-085) Accelerator Pedal or Lever Position Sensor
(83-019-086) Accelerator Pedal or Lever Position Sensor Circuit
(83-019-087) Unswitched Battery Supply Circuit
(99-019-088) Brake Pedal Position Switch
(99-019-090) Vehicle Speed Sensor, Digital Input
(99-019-091) Vehicle Speed Sensor, Magnetic Pick Up
(99-019-093) Vehicle Speed Sensor Circuit
(99-019-197) Ring Terminal
(99-019-198) Fuse, Harness In-Line
(99-019-199) Connector, Butt Splice
(83-019-200) Connector, Pass Trough
(99-019-201) Weather Pak Connector Series
(99-019-202) Metripack Connector Series
(99-019-203) AMP Connector Series
(99-019-204) Deutsch DRC Connector Series
(99-019-205) Deutsch DT Connector Series
(99-019-206) Deutsch DTM and DTP Connector Series
(99-019-207) Deutsch HD10 Connector Series
(99-019-208) Deutsch HDP20 and HD30 Connector Series
(99-019-209) ITT Cannon Connector Series
(99-019-210) AMP VP44 Connector Series
(99-019-211) Packard Relay Connector
(99-019-212) Ford™ Connector Series
(99-019-213) D-Sub Miniature Connector Series
(99-019-214) Bosch Actuator and Sensor Connector Series
(99-019-215) Bosch ECM Injector Drive Connector Series
(99-019-216) Bosch ECM Actuator and Sensor Connector Series
(99-019-217) Bosch ECM OEM Connector Series
(99-019-218) Framatone Connector Series
(99-019-220) Augat Connector Series
(83-019-341) Diagnostic Shorting Plug
(99-019-359) Multimeter Usage
(99-019-360) Resistance Measurement Using a Multimeter and a Wiring Diagram
(99-019-361) Component Connector and Pin Inspection
(99-019-362) Inactive or Intermittent Fault Code
(105-019-428) Engine Datalinks
(99-019-474) Bosch™ Aftertreatment DEF Controller Connector
Section L - Service Literature
(83-205-001) Additional Service Literature
(99-205-002) Service Literature Ordering Location
(99-205-004) Cummins Customized Parts Catalog
Section V - Specifications
(3666018) Specification
(99-018-009) Capscrew Markings and Torque Values
(99-018-010) Fraction, Decimal, Millimeter Conversions
(99-018-011) Newton-Meter to Foot-Pound Conversions
(99-018-012) Pipe Plug Torque Values
(99-018-013) Tap-Drill Chart - U.S. Customary and Metric
(99-018-014) Weights and Measures - Conversion Factors
back
Type: exe
front
(tr-frwd) Foreword
(83-fc342) ECM
back
- Engine Cummins QSC8.3 and QSL9 2006 Workshop Manual
- Cummins Wiring Diagrams
- Cummins ISX15 CM2250 4022234-04 Wiring Diagram
- Cummins Power Generation PCC2100 Control System Schematic
- Cummins ISB6.7 CM2250 Wiring Diagram
- Download Cummins ISM-QSM11 Series Engine Repair Manual
- Cummins QSB4.5-CM850 ECM 4021524-02 Wiring Diagram
- Cummins ISB & QSB 5.9 Engines Troublshooting & Repair Manual
- Cummins Engine QSK23 Workshop Manual
- Cummins Engine KTA50-G3 KTA50-G8 KTA50-G9 Parts Catalog
- Cummins Holset Air Compressors Master Repair Manual
- Cummins - ISX CM871 Schematic
- Cummins Insite 7.4 + FULL APP DIRECT
- Cummins QSX15 CM570 Power Generation Interface Wiring Diagram
- Cummins Power Generation PCC3100 Control System Schematic
