Crown Reach Truck ESR5000 Maintenance Manual_812577-006
Format : PDF
Language : English
Brand: Crown
Type of machine: Forklift
Type of document: Maintenance Manual
Model: Crown Reach Truck ESR5000
Number of Pages: 534 Pages
Order Number: 812577-006
Introduction
Format : PDF
Language : English
Brand: Crown
Introduction
Important Information
Specification Number
SafetySafety Notices
Basic Safety Notices
Lubrication & AdjustmentTransport and Storage
Truck Assembly and Commissioning
Placing the Truck in Storage
Component Access
Recommended Lubricants and Consumables
Planned Maintenance and Inspection
Torques
Load Wheels
Support Blocks
Cleaning the Truck and Components
Hydraulic SystemAbbreviations Used
Feature Descriptions
Hydraulic Components
Depressurising the Hydraulic System
Bleeding and Flushing the System
Drift Tests
Hydraulic Oil Reservoir
Replacing the Hydraulic Oil
Replacing the Filter
Replacing the Hydraulic Pump
Hydraulic Port Torques
Drive UnitGear Unit
Drive Wheel
Electrical SystemElectrical Components
Service Menu Structure
Service Menu - General
Analyzer Menu
Calibration Menu
Features Menu
Hour Meter Menu
Log Events Menu
Performance Menu
Utilities Menu
Event Codes
Event Codes 100 - 186
Event Codes 200 - 286
Event Codes 300 - 385
Event Codes 430 - 465
Event Codes 840 - 886
Control Modules and Display Screen
PMT Test
Replacing the Height Encoder
Replacing the HGT(R)S Switch
Replacing the Armrest Controls
Repairing Contactors
Repairing the Main Contactor
Replacing the Danaher Traction Motor
Replacing the Sensor Bearing on the Danaher Traction motor
Replacing the Crown Traction motor
Replacing the Pump Motor
Replacing the Sensor Bearing on the Danaher Pump Motor
Choosing the Correct Battery Cable Length
Brake SystemService and Parking Brake
Service and Parking Brake Danaher Motor
Parking Brake - Crown Motor
Load Wheel Brake
Testing and Adjusting the Brake Pedal Clearance
Adding Brake Fluid
Brake Power Control
SteeringFunction
Steering Errors
Proximity Switches SFS2 and SFS1 SA
Steer Motor and Steering Transmission
Steering Wheel
Replacing Encoder ECR2
Lifting MechanismMast
Adjusting the Mast Tilt
Mast Removal I Assembly
Dismantling and Assembling the Mast
Replacing the Mast Rollers
Integrated Sideshifter
Lift Cylinder Removal and Assembly
Reach Cylinder Removal and Assembly
Free Lift Cylinder Removal and Assembly
Chain Supports and Lift Chains
Inspecting Chain Supports and Lift Chains
Lubricating Lift Chains
Separating Lift Chains
Forks
Fork Inspection
Reach Carriage
CylindersGeneral
Tools
Rod Seal Removal and Assembly
Repairing Cylinders
Repairing Lift Cylinders
Repairing the Free Lift Cylinder
Repairing the Reach Cylinder
Repairing the Sideshifter Cylinder
Schematic DiagramsWire Colour Code
General Contact Symbol Abbreviations
Electrical Wiring Diagrams
Power Up Circuit
Wiring Diagram (Fingertip and Dual Axis Hydraulic Control Levers)
Wiring Diagram (Multitask Control Handle)
Main Harness, ESR 5000, Danaher Motor
Main Harness, ESR 5000, Crown Motor
Main Harness, ESR S000S, Crown Motor
Main Harness, ESR 5000S, Crown Motor
Harness, ESR 5000 Armrest
Harness, ESR 5000S Armrest
Wire Harness: Terminal to Reach Carriage
Cable Assy Truck, Reach Carriage
Cable Assy Valve Block, Mast
Fork Carriage Harness Extended, ESR 5000, Mast
Fork Carriage Harness Standard, ESR 5000, Mast
Fork Carriage Switch Assy, ESR 5000, Mast
Fork Carriage, 5th Function, ESR 5000, Mast
Fork Carriage, LS Bridge, ESR 5000, Mast
FKS Heater Assembly, Mast
Cable Mast 10 Core Assy, ESR 5000, Mast
Cable Mast 6 Core Assy. ESR 5000. Mast
VT Camera, Reach Carriage to Chassis, Option
VT Camera, DC I DC to Control Box, Option
VT Camera, Mast, Option
VT Camera, Box to Chassis, Option
Motec Camera, Supply to b/w Monitor, Option
Motec Camera, Component to Reach, Option
Motec Camera, Supply to Display Box, Option
Motec Camera, Fork Camera, Option
Motec Camera, Inner Mast, Option
Motec Camera, Reach to Display Box, Option
Motec Camera, Mast (Fork Camera), Option
Cold Store Harness, ESR 5000, Option
Cold Store, Armrest Harness, ESR 5000, Option
Cold Store, Armrest Harness, ESR 5000S, Option
Beacon Loom, Option
Beacon Loom, Option
Working Light 24V Loom, Option
Travel Alarm Harness, Option
Heated Seat, ESR 5000, Option
DC/DC Converter Loom, Option
Reading Light Harness, Option
Working Light 12V, Harness, Option
InfoLink, Harness, Option
DCDC Converter Loom NA, Option
DC/DC Converter Loom NA, Option
48V Supply, Option
Power Supply Cable, Option
Bypass Cable, Seat Heating Switch, Option
Supply Cable, ESR 5000, PSA
Lights 12V, PSA
Hydraulic SchematicHydraulic Symbols
Hydraulic Diagram
- Crown Rider Pallet Jack PE 4500 AC Service & Parts Manual_PF15302-006
- Crown Forklift SX3000 Series Parts Manual 812710-006
- Crown Forklift WAVE Service Manual
- Crown Forklift GPC2000 Series Maintenance Manual 812520-006-0M
- Crown Forklift WP3200S Series Maintenance Manual 812529-006
- Crown Reach Truck RR RD5700 AC Service & Parts Manual
- Crown Forklift WP2000 Series Service Manual
- Crown Forklift WP2300 Series Parts Manual 812684-006-0M
- Crown Forklift SC3200 Series Maintenance Manual 812548-006
- Crown Forklift WP2300 Series Maintenance Manual 812528-006-0M
- Crown Forklift WP2000S Series Service Manual
- Crown Reach Truck RR 5200 DC Service & Parts Manual_PF13364-006
- Crown Forklift WE WS 2000 Series Service Manual
- Crown Forklift GPW1000 Series Service and Parts Manual MP-GPW1000
