Changan Hunter Plus 2023 Workshop Manual
Brand: Changan
Type of Machine: Automotive
Type of Manual: Workshop Manual
Model: Changan Hunter Plus 2023
Number of Pages: 1904 Pages
Overview
Brand: Changan
Overview
Service Information
Overview
Identification Codes
Traction and Lifting
Maintenance Interval
Noise, Vibration and Harshness
General Schematic Diagram
EngineEngine - JL486ZQ5
Engine System - 2.0L
On-board Diagnosis
Mechanical System
Lubrication System
Intake System
Exhaust System
Fuel System
Ignition System
Starting System
Charging System
Engine Control System
Engine - 4D20M
On-board Diagnosis
Mechanical System
Lubrication System
Intake System
Exhaust System
Fuel System
Starting System
Charging System
Emission Control System
TransmissionManual Transmission (Gasoline)
Manual Transmission
Manual Gearshift Control System
Flywheel, Clutch
Manual Transmission (Diesel)
Specifications
Description and Operation
General Inspection
Symptom Diagnosis and Testing
Removal and Installation
Automatic Transmission
Electronic Gearshift Control Assembly
DrivelineDriveline System
Driveline System Overview-2WD
Driveline System Overview-4WD
Front Axle
Drive Shaft
Propeller Shaft
Transfer
Rear Axle
SuspensionSuspension System
Suspension System Overview
Front Suspension
Rear Suspension (Multilink Structure)
Rear Suspension (Leaf Spring Structure)
Wheel and Tire
Mounting System
BrakeBrake System
Brake System - General Information
Front Disc Brake
Rear Disc Brake (Mechanical Parking)
Front Wheel Speed Sensor Assembly
Rear Wheel Speed Sensor Assembly
Rear Disc Brake (Electronic Parking)
Electronic Parking Brake System
Parking Brake Control Mechanism
Hydraulic Brake Control
Power Brake System
Anti-lock Brake System/Electronic Stability Control System
SteeringSteering System (Gasoline)
Steering System - Overview
Steering Wheel - Mechanical
Power Steering Gear Assembly
Steering Gear and Tie Rod
Steering System (Diesel)
Steering System – Overview
Power Steering System
Steering Gear
Steering Column
Electrical SystemHeating, Ventilation and Air Conditioning
Specifications
DTC Diagnosis and Testing
Body Electrical
Instrument Cluster
Cigarette Lighter/Power Supply Socket
Multimedia Control System
Lighting System
Horn
Wiper and Washer
Vehicle Lock Assembly
Power Window
Immobilizer System
360° Panoramic View System
Keyless Control System
Drive Recorder
Reversing Radar
Rearview Monitor
Right Blind Spot
On-board Network System
Tire Pressure Monitoring System
Body Exterior (Exterior Trim Maintenance)Exterior Maintenance
Common Faults
Technical Parameters
Painting
Front Body
Hood
Front Door
Rear Door
Bumper
Body Exterior
Body InteriorBody Interior Repair
Common Faults
Front Interior
Center Interior
Rear Interior
Supplemental Restraint SystemSupplemental Restraint System
Fault Repair
Removal and Installation of Airbag
Removal and Installation of Seat Belt
Vehicle Body Maintenance (Accident Vehicle Maintenance)Vehicle Body Maintenance
Accident Vehicle Maintenance Operation
Technical Data
Front Part of Vehicle Body
Middle Part of Vehicle Body
Rear Part of Vehicle Body and Cargo Compartment
- Changan UNI-K iDD 2023 Wiring Diagram
- Changan CS35 Plus 2021 Electric Diagrams
- Changan UNI-K iDD DF722 Operation Manual 2023
- Changan CS75 FL 2018 Electric Diagrams
- Changan UNI-K iDD 2022 Electric Diagrams
- Changan UNI-V 2022 Workshop Manual
- Changan CS55 Plus 2019 Workshop Manual
- Changan Hunter Plus 2023 Electric Diagrams
- Changan Automotive CS55PLUS Workshop Manual
- Changan Automotive 2nd Gen CS55PLUS Wiring Diagram
