Caterpillar Flash Files Information
Type of software: ECM Flash files for CAT ET
Make: Caterpillar
Region: WorldWide
Languages: DE, ES, FR, IT, JP, PT, CHS
OS: Window 7, Window 8, Window 10 32 & 64bit (Tested on window 10 1607 64bit)
High-Speed link download
Cat Factory flash files for the Flash memory programming of onboard ECMs. For this purpose, you need the latest activated version of Caterpillar Electronic Technician application and the genuine Cat Diagnostic Adapter Interface to connect with the vehicle.
Please check if your flash file is included using any desktop browser search function. For this purpose Click Ctrl+F to open the Find in page bar, type the search phrase in it.
FLASH FILE CROSS REFERENCE SAVED FROM SIS WEB
3126E HEUI Flash File Cross Reference
Updated Jan 21, 2004
Released software to meet 2.09.2 Clean Power Phase II, Adem 2000,
Version 6, 7, & 8 ECM, MY2001 EPA Emission for April 2001
Production with 24 MHz ECM,
Support for 3.5 NOx FEL Truck Consent Decree, and
GM Two Speed Axle Switch Update.
Description Serial Flash Part IC Release
No. Range No. Date
175 HP @ 2200 CKM 1 and up 246-8293 219 NOV03
420 @ 1500 EPA Cert
190 HP @ 2400 CKM 1 and up 246-8292 229 NOV03
420 @ 1500 EPA Cert.
190 HP @ 2300 CKM 1 and up 246-8291 227 NOV03
520 @ 1500 EPA Cert. ***** HIGH PERFORMANCE AT545 *****
210 HP @ 2400 CKM 1 and up 246-8290 228 NOV03
****** Standard Ratings ***************
210 HP @ 2200 CKM 1 and up 246-8289 222 NOV03
210 HP @ 2200 CKM 1 and up 246-8288 223 NOV03
605 @ 1500 EPA Cert.
230 HP @ 2200 CKM 1 and up 246-8287 206 NOV03
660 @ 1500 EPA Cert.
250 HP @ 2200 CKM 1 and up 246-8286 207 NOV03
250 HP @ 2200 CKM 1 to CKM10423 246-8285 208 NOV03
800 @ 1500 EPA Cert.
250 HP @ 2200 CKM10424 and up 246-8284 205 NOV03
275 HP @ 2200 CKM 1 and up 246-8283 209 NOV03
275 HP @ 2200 CKM 1 and up 246-8282 210 NOV03
860 @ 1500 EPA Cert.
300 HP @ 2200 CKM 1 and up 246-8281 211 NOV03
300 HP @ 2200 CKM 1 and up 246-8280 212 NOV03
******************** Emergency Ratings *****************************
275 HP @ 2200 CKM 1 and up 246-8279 213 NOV03
800 @ 1500 Emergency.
275 HP @ 2200 CKM 1 and up 246-8278 214 NOV03
860 @ 1500 Emergency.
300 HP @ 2200 CKM 1 and up 246-8277 215 NOV03
300 HP @ 2200 CKM 1 and up 246-8276 216 NOV03
330 HP @ 2400 CKM 1 and up 246-8275 217 NOV03
******************* RV Rating **************************************
330 HP @ 2400 CKM 1 and up 246-8274 218 NOV03
860 @ 1500 RV
3116 HEUI Flash File Cross Reference
Updated Jan 22, 2004
1WM 7LZ 8WL AND 7AS flash files for engine rebuild kits
ADEM II AND ADEM III Low Nox engine rebuild kit flash files
Updated July 6, 2001
******************* 3116 Standard Ratings **************************
170 HP @ 2200 8WL 1 and up 188-8046 301 JAN00
420 @ 1560 EPA LoNox Cert.
185 HP @ 2200 8WL 1 and up 188-8047 302 JAN00
520 @ 1560 EPA LoNox Cert.
190 HP @ 2300 8WL 1 and up 188-8053 303 JAN00
195 HP @ 2200 8WL 1 and up 188-8048 303 JAN00
215 HP @ 2200 8WL 1 and up 188-8049 304 JAN00
605 @ 1560 EPA LoNox Cert.
230 HP @ 2200 8WL 1 and up 188-8050 305 JAN00
660 @ 1560 EPA LoNox Cert.
250 HP @ 2200 8WL 1 and up 188-8051 306 JAN00
275 HP @ 2200 8WL 1 and up 188-8052 307 JAN00
750 @ 1470 EPA LoNox Cert.
********************** 3126 Standard Ratings ************************
175 HP @ 2400 1WM/7LZ 1 and up 188-8054 301 JAN00
420 @ 1440 EPA LoNox Cert.
190 HP @ 2200 1WM/7LZ/4ES 1 and up 188-8055 302 JAN00
520 @ 1440 EPA LoNox Cert.
210 HP @ 2400 1WM/7LZ 1 and up 188-8056 303 JAN00
210 HP @ 2200 1WM/7LZ/4ES 1 and up 188-8057 304 JAN00
605 @ 1440 EPA LoNox Cert.
230 HP @ 2200 1WM/7LZ/4ES 1 and up 188-8058 305 JAN00
660 @ 1440 EPA LoNox Cert.
250 HP @ 2200 1WM/7LZ/4ES 1 and up 188-8059 306 JAN00
250 HP @ 2200 1WM/7LZ 1 and up 188-8060 307 JAN00
800 @ 1440 EPA LoNox Cert.
275 HP @ 2200 1WM/7LZ 1 and up 188-8061 308 JAN00
275 HP @ 2200 1WM/7LZ 1 and up 188-8062 309 JAN00
860 @ 1440 EPA LoNox Cert.
300 HP @ 2200 1WM/7LZ 1 and up 188-8063 311 JAN00
300 HP @ 2200 1WM/7LZ 1 and up 188-8064 310 JAN00
300 HP 1WM1 and Up 130-7832 16 OCT96
860 @ 1440 OWS
***************** Emergency Vehicles ********************************
275 HP @ 2200 1WM 1 and up 188-8065 312 JAN00
275 HP @ 2200 1WM 1 and up 188-8066 313 JAN00
300 HP @ 2200 1WM 1 and up 188-8067 314 JAN00
300 HP @ 2200 1WM 1 and up 188-8068 315 JAN00
330 HP @ 2200 1WM 1 and up 188-8069 320 JAN00
330 HP @ 2200 1WM 1 and up 188-8070 321 JAN00
**************************CEC Rating*********************************
250 HP @ 2200 1WM 1 and up 188-8071 319 JAN00
**************** Hi-performance AT/MT/HT Rating *********************
190 HP @ 2300 1WM/7LZ 1 and up 188-8072 302 JAN00
********************** 3126B Standard Ratings ************************
175 HP @ 2400 7AS 1 and up 246-8248 301 NOV03
190 HP @ 2200 7AS 1 and up 246-8247 302 NOV03
190 HP @ 2300 7AS 1 and up 246-8246 302 NOV03
210 HP @ 2400 7AS 1 and up 246-8245 332 NOV03
210 HP @ 2200 7AS 1 and up 246-8244 303 NOV03
210 HP @ 2200 7AS 1 and up 246-8243 304 NOV03
************************** DINA Only *******************************
210 HP @ 2200 7AS 1 and up 246-8242 329 NOV03
230 HP @ 2200 7AS 1 and up 246-8241 305 NOV03
250 HP @ 2200 7AS 1 and up 246-8240 306 NOV03
250 HP @ 2200 7AS 1 and up 246-8239 307 NOV03
275 HP @ 2200 7AS 1 and up 246-8238 308 NOV03
275 HP @ 2200 7AS 1 and up 246-8237 309 NOV03
300 HP @ 2200 7AS 1 and up 246-8236 310 NOV03
300 HP @ 2200 7AS 1 and up 246-8235 311 NOV03
275 HP @ 2200 7AS 1 and up 246-8234 312 NOV03
275 HP @ 2200 7AS 1 and up 246-8233 313 NOV03
300 HP @ 2200 7AS 1 and up 246-8232 314 NOV03
300 HP @ 2200 7AS 1 and up 246-8231 315 NOV03
330 HP @ 2400 7AS 1 and up 246-8230 316 NOV03
***************** Recreational Vehicles *****************************
330 HP @ 2400 7AS 1 and up 246-8229 317 NOV03
Updated JAN 29, 2001
******************* FMTV Vehicles Only ********************************
275 HP @ 2200 6PZ 1 and up 224-4622 119 SEP02
330 HP @ 2400 7JZ 1 and up 224-4623 120 SEP02
350 HP @ 2400 1AJ 1 and up 224-4627 45 SEP02
820 @ 1500 EPA LoNox Cert.
TEST ECM Primer Software file 188-9579 MAR00
NOTE: Flash this file into ADEM 2000 Test ECM before loading any engine
flash file.
3126B 8YL HEUI Flash File Cross Reference
The reason for this SEP 00 release was to provide Software features
Including:
For all ratings except Euro II:
Released software to meet 2.09 Version 6&7, 4g S.S.NOx MY2000
EPA emission for Sep 2000 production with 24 MHz ECM, support for
GM2001i truck, consent decree torque and timing readout, updated
idle quality adjustment maps, and modify progressive shift.
For Euro II rating:
Released software to meet 2.09 Version 6&7, 6g S.S.NOx MY2000 EPA emission
for Sep 2000 production with 24 MHz ECM, support for GM2001i truck,
consent decree torque and timing readout, updated idle quality adjustment
This software update also contains a fix for false logging of injector faults.
Revision to Exhaust Brake Special Test. Improvements to reduce ECM Engine software
Lock-Up.
Enhancements for vehicles with Allision AT/MT/HT transmission. Combines
Interlock codes for use on GM = IC1 and NON GM = IC2 chassis.
NOTE: Duel Fuel and Steel Piston Parts Service Only files are not in this release.
Description Serial Flash Part IC IC2 Release
No. Range No. Date
*************** 175 and 190 HP can be used with *******************
************** Allison AT545 Transmission *******************
175 HP @ 2200 8YL 1 to 8YL34999 246-8273 101 151 NOV03
420 @ 1500 EPA Cert
175 HP @ 2200 8YL35000 and up 246-8272 169 169 DEC03
420 @ 1500 EPA Cert
190 HP @ 2300 8YL 1 to 8YL34999 246-8271 102 152 NOV03
190 HP @ 2300 8YL35000 and up 246-8270 170 170 DEC03
****** 210HP Rating with an Allison AT545 *************
****** Transmission *************
210 HP @ 2400 8YL 1 to 8YL34999 246-8269 103 153 NOV03
210 HP @ 2400 8YL35000 & 9SZ 1 and up 246-8268 171 171 DEC03
210 HP @ 2200 8YL 1 to 8YL34999 246-8267 104 154 NOV03
210 HP @ 2200 8YL35000 & 9SZ 1 and up 246-8266 172 172 DEC03
210 HP @ 2200 8YL 1 to 8YL34999 246-8265 105 155 NOV03
210 HP @ 2200 8YL35000 & 9SZ 1 and up 246-8264 173 173 DEC03
230 HP @ 2200 8YL & 9SZ 1 and up 246-8263 106 156 DEC03
250 HP @ 2200 8YL 1 TO 8YL68263 246-8262 107 157 NOV03
250 HP @ 2200 8YL68264 & 9SZ 1 and up 246-8261 187 187 DEC03
250 HP @ 2200 8YL 1 TO 8YL68263 246-8260 108 158 NOV03
250 HP @ 2200 8YL68264 & 9SZ 1 and up 246-8259 188 188 DEC03
275 HP @ 2200 8YL & 9SZ 1 and up 246-8258 109 159 DEC03
275 HP @ 2200 8YL & 9SZ 1 and up 246-8257 110 160 DEC03
300 HP @ 2200 8YL & 9SZ 1 and up 246-8256 111 161 DEC03
300 HP @ 2200 8YL & 9SZ 1 and up 246-8255 112 162 DEc03
275 HP @ 2200 8YL & 9SZ 1 and up 246-8254 113 163 DEC03
275 HP @ 2200 8YL & 9SZ 1 and up 246-8253 114 164 DEC03
300 HP @ 2200 8YL & 9SZ 1 and up 246-8252 115 165 DEC03
300 HP @ 2200 8YL & 9SZ 1 and up 246-8251 116 166 DEC03
330 HP @ 2400 8YL & 9SZ 1 and up 246-8250 117 167 DEC03
330 HP @ 2400 8YL & 9SZ 1 and up 246-8249 118 168 DEC03
860 @ 1500 RV
3126 HEUI (8HW) EURO 2 FLASH File Cross Reference
Description Serial NO. FLASH PART IC Release
Range NO. Date
190 HP 8HW00001 & up 146-9883 22 DEC97
520 @ 1440
210 HP 8HW00001 & up 146-9880 23 DEC97
605 @ 1440
275 HP 8HW00001 & up 187-2097 24 NOV99
830 @ 1440
300 HP 8HW00001 & up 187-2096 25 NOV99
860 @ 1440
********** FULL FEATURE ECM FILES *****************************************
Description Serial NO. FLASH PART IC IC2 Release
Range NO. Date
190 HP @ 2300 8SZ00532 & up 212-4002 125 125 OCT01
520 @ 1440
210 HP @ 2200 8SZ00532 & up 212-4001 126 126 OCT01
605 @ 1440
250 HP @ 2200 8SZ00532 & up 212-4000 127 127 OCT01
800 @ 1440
275 HP @ 2200 8SZ00001 & up 212-3999 128 128 OCT01
830 @ 1440
300 HP @ 2200 8SZ00001 & up 212-3998 129 129 OCT01
860 @ 1440
************** 3126E HEP Flash File Reference *****************
Updated December 6, 2002
Emergency Vehicle Ratings
Serial No. Range
Part Number
Interlock Code Rating/Application Information
HEP1 - HEP07579
227-9339 3126 Truck 330HP 860 lb-ft, 2400 RPM ER Date Code SEP02
Interlock Code = 251
Replaced 225-2366
HEP07580 & UP
231-2609 3126 Truck 330HP 860 lb-ft, 2400 RPM ER Date Code OCT02
Interlock Code = 298
HEP1 - HEP07579
227-9341 3126 Truck 300HP 860 lb-ft, 2200 RPM ER Date Code SEP02
Interlock Code = 250
Replaced 225-2368
HEP07580 & UP
230-1562 3126 Truck 300HP 860 lb-ft, 2200 RPM RV Date Code OCT02
Interlock Code = 297
HEP1 - HEP07579
227-9342 3126 Truck 300HP 800 lb-ft, 2200 RPM ER Date Code SEP02
Interlock Code = 249
Replaced 225-2369
HEP07580 & UP
230-1563 3126 Truck 300HP 800 lb-ft, 2200 RPM ER Date Code OCT02
Interlock Code = 296
HEP1 - HEP07579
227-9343 3126 Truck 275HP 860 lb-ft, 2200 RPM ER Date Code SEP02
Interlock Code = 248
Replaced 225-2370
HEP07580 & UP
230-1564 3126 Truck 275HP 860 lb-ft, 2200 RPM ER Date Code OCT02
Interlock Code = 295
HEP1 - HEP07579
227-9344 3126 Truck 275HP 800 lb-ft, 2200 RPM ER Date Code SEP02
Interlock Code = 247
Replaced 225-2371
HEP07580 & UP
230-1565 3126 Truck 275HP 800 lb-ft, 2200 RPM ER Date Code OCT02
Interlock Code = 294
Recreational Vehicle Ratings
Serial No. Range
Part Number
HEP1 - HEP07579
227-9340 3126 Truck 330HP 860 lb-ft, 2400 RPM RV Date Code SEP02
Interlock Code = 252
Replaced 225-2367
HEP07580 & UP
230-1561 3126 Truck 330HP 860 lb-ft, 2400 RPM RV Date Code OCT02
Interlock Code = 299
Truck Ratings
Serial No. Range
Part Number
HEP1 - HEP07579
227-9345 3126 Truck 300HP 860 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 246
Replaced 225-2372
HEP07580 & UP
230-1566 3126 Truck 300HP 860 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 293
HEP1 - HEP07579
227-9346 3126 Truck 300HP 800 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 245
Replaced 225-2373
HEP07580 & UP
230-1567 3126 Truck 300HP 800 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 292
HEP1 - HEP07579
227-9347 3126 Truck 275HP 860 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 244
Replaced 225-2374
HEP07580 & UP
230-1568 3126 Truck 275HP 860 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 291
HEP1 - HEP07579
227-9348 3126 Truck 275HP 800 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 243
Replaced 225-2375
HEP07580 & UP
230-1569 3126 Truck 275HP 800 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 290
HEP1 - HEP07579
227-9349 3126 Truck 250HP 800 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 242
Replaced 225-2376
HEP07580 & UP
230-1570 3126 Truck 250HP 800 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 289
HEP1 - HEP07579
227-9350 3126 Truck 250HP 660 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 241
Replaced 225-2377
HEP07580 & UP
230-1571 3126 Truck 250HP 660 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 288
HEP1 - HEP07579
227-9351 3126 Truck 230HP 660 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 240
Replaced 225-2378
HEP07580 & UP
236-2149 3126 Truck 230HP 540 lb-ft, 2300 RPM Date Code MAR03
Interlock Code = 239
HEP07580 & UP
230-1572 3126 Truck 230HP 660 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 287
HEP1 - HEP07579
227-9352 3126 Truck 210HP 605 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 257
Replaced 225-2380
HEP07580 & UP
230-1573 3126 Truck 210HP 605 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 286
HEP1 - HEP07579
227-9353 3126 Truck 210HP 520 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 256
Replaced 225-2380
HEP07580 & UP
230-1574 3126 Truck 210HP 520 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 285
HEP1 & UP
227-9354 3126 Truck 210HP 520 lb-ft, 2400 RPM Date Code SEP02
High Performance Interlock Code = 255
Replaced 225-2381
HEP1 & UP
227-9355 3126 Truck 190HP 520 lb-ft, 2300 RPM Date Code SEP02
High Performance Interlock Code = 254
Replaced 225-2382
HEP1 & UP
227-9356 3126 Truck 190HP 420 lb-ft, 2400 RPM Date Code SEP02
Interlock Code = 253
Replaced 225-2383
C7C9 On-Highway Engine Flash files
Updated December 20, 2010
IMPORTANT: It is very important to select the CORRECT flash file for the injector part
number that is in the engine!!! Engines that have the "factory installed injector p/n"
can use the flash file for the s/n range listed. However, for the s/n ranges noted
below, if a "single" injector is replaced "all six" injectors MUST be updated to the
same part number and the appropriate "flash file" and "etrim" files MUST be installed
to match the "new" part number injector!
Please refer to Truck Engine News SEBD6764 dated January 2004
Please check for rerateability using the rerate charts at https://truck.cat.com
C7 (2007 Emissions A4 ECM) "Mid HP Ratings" 190HP to 300HP:
C7S0001-up Date Code Interlock Flash File
C7 190HP @ 2500 RPM JUL08 40/140 334-2353
Replaced 308-5717,309-1838,312-4768,313-9518,
316-7964,319-5927,321-7212,324-7626.326-9115,
328-0693
C7 210HP @ 2500 RPM Dec10 41/141 348-5528
Replaced 308-5718,309-1839,312-4769,313-9519,
316-7965,319-5928,321-7213,324-7627,326-9116,
328-0694,334-2354
C7 210HP @ 2500 RPM JUL08 42/142 334-2355
Replaced 308-5719,309-1840,312-4770,313-9520,
316-7966,319-5929,321-7214,324-7628,326-9117,
328-0695
C7 230HP @ 2500 RPM JUL08 43/143 334-2356
Replaced 308-5720,309-1841,312-4771,313-9521,
316-7967,319-5930,321-7215,324-7629,326-9118,
328-0696
C7 230HP @ 2500 RPM JUL08 44/144 334-2357
Replaced 300-1766,307-8355,309-1842,312-4772
313-9522,316-5997,316-7968,319-5931,321-7216,
324-7630326-9119,328-0697
C7 230HP @ 2400 RPM JUL08 45/145 334-2358
Replaced 300-1768,308-5721,309-1843,312-4773
313-9523,316-7969,319-5932,321-7217,324-7631,
326-9120,328-0698
C7 250HP @ 2400 RPM JUL08 46/146 334-2359
Replaced 308-5722,309-1844,312-4774
313-9524,316-7970,319-5933,321-7218,324-7632,
326-9121,328-0699
C7 250HP @ 2400 RPM JUL08 47/147 334-2360
Replaced 308-5723,309-1845,312-4775
313-9525,316-7971,319-5934,321-7219,324-7633,
326-9122,328-0700
C7 275HP @ 2400 RPM JUL08 48/148 334-2361
Replaced 308-5724,309-1846,312-4776
313-9526,316-7972,319-5935,321-7220,324-7634,
326-9123,328-0701
C7 300HP @ 2400 RPM JUL08 49/149 334-2362
Replaced 300-1776,307-8356,309-1847,312-4777
313-9527,316-7973,319-5936,321-7221,324-7635,
326-9124,328-0702
C7 300HP @ 2400 RPM ER JUL08 50/150 334-2363
Replaced 312-4778,313-9528,316-7974,319-5937
321-7222,324-7636,326-9125,328-0703
C7 330HP @ 2400 RPM ER JUL08 51/151 334-2364
Replaced 312-4779,313-9529,316-7975,319-5938
321-7223,324-7637,326-9126,328-0704
C7 350HP @ 2400 RPM ER JUL08 52/152 334-2365
Replaced 312-4780,313-9530,316-7976,319-5939
321-7224,324-7638,326-9127,328-0705
C7 360HP @ 2400 RPM ER JUL08 57/157 334-2370
Replaced 322-4567,324-7643,326-9132,328-0710
C7 300HP @ 2400 RPM RV JUL08 53/153 334-2366
Replaced 312-4781,313-9531,316-7977,319-5940
321-7225,324-7639,326-9128,328-0706
C7 330HP @ 2400 RPM RV JUL08 54/154 334-2367
Replaced 312-4782,313-9532,316-7978,321-7226,
324-7640,326-9129,328-0707
C7 350HP @ 2400 RPM RV JUL08 55/155 334-2368
Replaced 312-4783,313-9533,316-7979,321-7227,
324-7641,326-9130,328-0708
C7 360HP @ 2400 RPM RV JUL08 56/156 334-2369
Replaced 313-9535,316--7980,321-7228,
324-7642,326-9131,328-0709
C7 (KAL, SAP, WAX) "Low HP Ratings" 190HP to 210HP:
NOTE: C7 "Low HP Ratings" 190HP to 210HP KAL1-07985 were factory built with Injector
p/n 233-3536. If a "single" 233-3536 injector is replaced with a 243-4502 injector
w/seals (241-3238 p/n on injector... not serviced) then "all six" injectors MUST be
updated to the same part number and the appropriate flash file and "etrim" files MUST
be installed to match the "new" part number injector! Use list below to determine flash
file based on installed injector number!
S/N Range Injector P/N Date Code Interlock Flash File
C7 KAL 190HP 520 lb-ft ...* Important see note above for complete detail
KAL 1 - 07985 w/ Factory installed 233-3536 Injectors APR04 IC 1 247-4649
Replaced 242-8316,243-4420
KAL1-07985 w/ "Field installed" 241-3238 Injectors SEP06 IC 25 300-0446
Replaced 248-7461,251-7438,
254-0804,259-5558,265-3311,277-5700,295-2303
KAL07986-UP, SAP1-UP, WAX1-UP
w/ "Factory installed" 241-3238 Injectors SEP06 IC 25 300-0446
C7 KAL 210HP 520 lb-ft ...* Important see note above for complete detail
KAL 1 - 07985 w/ Factory installed 233-3536 Injectors APR04 IC 3 247-4648
Replaced 242-1847,243-4421
KAL1-07985 w/ "Field installed" 241-3238 Injectors SEP06 IC 26 300-0447
Replaced 248-7460,251-7439,
254-0805,259-5559,265-3312,277-5701,295-2304
w/ "Factory installed" 241-3238 Injectors SEP06 IC 26 300-0447
C7 KAL 210HP 605 lb-ft ...* Important see note above for complete detail
KAL 1 - 07985 w/ Factory installed 233-3536 Injectors APR04 IC 4 247-4647
Replaced 242-8317,243-4422
KAL1-07985 w/ "Field installed" 241-3238 Injectors SEP06 IC 27 300-0448
Replaced 248-7459,251-7440,
254-0806,259-5560,277-5702,295-2305
w/ "Factory installed" 241-3238 Injectors SEP06 IC 27 300-0448
C7 (KAL, SAP, WAX) "Mid HP Ratings" 230HP to 250HP 660lbft:
NOTE: C7 "Mid HP Ratings" 230HP to 250HP 660lbft KAL1-11870 were factory built with
Injector p/n 236-6011. If a "single" 236-6011 injector is replaced with a 243-4503
injector w/seals (241-3239 p/n on injector... not serviced) then "all six" injectors
MUST be updated to the same part number and the appropriate flash file and "etrim"
files MUST be installed to match the "new" part number injector! Use list below to
determine flash file based on installed injector number!
C7 KAL 230HP 540 lb-ft ...* Important see note above for complete detail
KAL 1 - 11870 w/ Factory installed 236-6011 Injectors APR04 IC 18 247-4646
Replaced 242-1845,243-4423
KAL1-11870 w/ "Field installed" 241-3239 Injectors SEP06 IC 28 300-0449
Replaced 248-7458,251-7441,
259-5561,265-3314,271-1678,277-5703,295-2306
KAL11871-UP, SAP1-UP, WAX1-UP
w/ "Factory installed" 241-3239 Injectors SEP06 IC 28 300-0449
C7 KAL 230HP 660 lb-ft ...* Important see note above for complete detail
KAL 1 - 11870 w/ Factory installed 236-6011 Injectors APR04 IC 5 247-4645
Replaced 242-1844,243-4424
KAL1-11870 w/ "Field installed" 241-3239 Injectors SEP06 IC 29 300-0450
Replaced 248-7457,251-7442,
259-5563,265-3315,271-1679,277-5704,295-2307
w/ "Factory installed" 241-3239 Injectors SEP06 IC 29 300-0450
C7 KAL 250HP 660 lb-ft ...* Important see note above for complete detail
KAL 1 - 11870 w/ Factory installed 236-6011 Injectors APR04 IC 6 247-4644
Replaced 242-1843,243-4425
KAL1-11870 w/ "Field installed" 241-3239 Injectors AUG08 IC 30 335-8257
Replaced 248-7456,251-7443,
259-5564,265-3316,277-5705,295-2308,300-0451
w/ "Factory installed" 241-3239 Injectors AUG08 IC 30 335-8257
C7 (KAL, SAP, WAX) "Hi HP Ratings" 250HP 800lbft to 330HP:
NOTE: C7 "Hi HP Ratings" 250HP 800lbft to 330HP KAL1-12897 were factory built with
Injector p/n 233-3535. If a "single" 233-3535 injector is replaced with a 241-3400
injector w/seals (238-8091 p/n on injector... not serviced) then "all six" injectors
C7 KAL 250HP @ 2200 800 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 7 247-4643
Replaced 245-0834
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 41 300-0465
Replaced 248-7641,251-7457,
254-0999,259-5609,265-3334,272-5324,295-2333
KAL12898-UP, SAP1-UP, WAX1-UP
w/ "Factory installed" 238-8091 Injectors SEP06 IC 41 300-0465
C7 KAL 275HP 800 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 8 247-4642
Replaced 245-0835
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 42 300-0464
Replaced 248-7640,251-7456,
254-0998,259-5608,265-3333,272-5323,295-2332
w/ "Factory installed" 238-8091 Injectors SEP06 IC 42 300-0464
CARB (California Bus only) MAR04 IC 59 251-6210
C7 KAL 275HP 860 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 9 247-4640
Replaced 245-0837
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 43 300-0462
Replaced 248-7638,251-7454,
254-0996,259-5606,265-3331,272-5321,295-2330
w/ "Factory installed" 238-8091 Injectors SEP06 IC 43 300-0462
C7 KAL 300HP 800 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 10 247-4638
Replaced 245-0839
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 44 300-0460
Replaced 248-7636,251-7452,
254-0994,259-5604,265-3329,272-5319,295-2328
w/ "Factory installed" 238-8091 Injectors SEP06 IC 44 300-0460
CARB (California Bus only) MAR04 IC 60 251-6209
C7 KAL 300HP @ 2200 860 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 11 247-4636
Replaced 245-0841
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 45 300-0458
Replaced 248-7634, 251-7450, 254-0992,259-5602,
265-3326,272-5317,295-2326
w/ "Factory installed" 238-8091 Injectors SEP06 IC 45 300-0458
C7 KAL 330HP 860 lb-ft (Truck) ...* Important see note above for complete detail
KAL1-UP w/ "Field installed" 238-8091 Injectors SEP06 IC 53 300-0456
Replaced 248-7645,251-7448,
254-0990,259-5600,265-3323,272-5315,295-2324
w/ "Factory installed" 238-8091 Injectors SEP06 IC 53 300-0456
*********************************** EMERGENCY RATINGS (ER) ***************************
C7 KAL 275HP 800 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 12 247-4641
Replaced 245-0836
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 46 300-0463
Replaced 248-7639,251-7455,
254-0997,259-5607,265-3332,272-5322,295-2331
w/ "Factory installed" 238-8091 Injectors SEP06 IC 46 300-0463
C7 KAL 275HP 860 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 13 247-4639
Replaced 245-0838
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 47 300-0461
Replaced 248-7637,251-7453,
254-0995,259-5605,265-3330,272-5320,295-2329
w/ "Factory installed" 238-8091 Injectors SEP06 IC 47 300-0461
C7 KAL 300HP 800 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 14 247-4637
Replaced 245-0840
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 48 300-0459
Replaced 248-7635,251-7451,
254-0993,259-5603,265-3327,272-5318,295-2327
w/ "Factory installed" 238-8091 Injectors SEP06 IC 48 300-0459
C7 KAL 300HP 860 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 15 247-4635
Replaced 245-0842
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 49 300-0457
Replaced 248-7633,251-7449,
254-0991,259-5601,265-3324,272-5316,295-2325
w/ "Factory installed" 238-8091 Injectors SEP06 IC 49 300-0457
C7 KAL 330HP 860 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 16 247-4634
Replaced 245-0843
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 50 300-0455
Replaced 248-7632,251-7447,
254-0989,259-5599,265-3322,272-5314,295-2323
w/ "Factory installed" 238-8091 Injectors SEP06 IC 50 300-0455
C7 KAL 350HP @ 2400 RPM (ER) SEP06 IC 54 300-0453
Replaced 272-1428,298-7453
******************************** RECREATION VEHICLE (RV) *******************************
C7 KAL 330HP 860 lb-ft (RV) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 17 247-4633
Replaced 245-0844
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 51 300-0454
Replaced 248-7631,251-7446,
254-0988,259-5598,265-3321,272-5313,295-2322
w/ "Factory installed" 238-8091 Injectors SEP06 IC 51 300-0454
C7 KAL 350HP @ 2400 860 lb-ft (RV) ...* Important see note above for complete detail
KAL1-UP w/ "Field installed" 238-8091 Injectors SEP06 IC 52 300-0452
Replaced 248-7630,251-7445,
254-0986,259-5597,265-3320,272-5312,295-2321
w/ "Factory installed" 238-8091 Injectors SEP06 IC 52 300-0452
******************** Family of Medium Tactical Vehicle (FMTV) **************************
C7 FML 275HP @ 2200 RPM 860 lb-ft (FMTV)
FML 1-UP w/ "Factory installed" 238-8091 Injectors NOV09 IC 55 353-8652
Replaced 248-7642,259-5595,266-4248,280-3274,
296-0076
C7 FMM 330HP @ 2400 RPM 860 lb-ft (FMTV)
FMM 1-UP w/ "Factory installed" 238-8091 Injectors NOV09 IC 56 353-8653
Replaced 248-7643,259-5596,266-4249,280-3275,
296-0077
C7 330HP @ 2600 RPM FMM 1-UP NOV09 IC 82 353-8655
Replaced 325-4611
C7 275HP @ 2600 RPM FML 1-UP NOV09 IC 83 353-8684
Replaced 330-4542
C7 350HP @ 2600 RPM JRT 1-UP NOV09 IC 80 355-2831
Replaced 286-5702,303-4272,335-9389,346-5217
C7 350HP @ 2400RPM-261KW (Bronco Tactical Vehicle) Mar09 IC 85 344-9633
Replaced N/A
C7 370HP @ 2600RPM-276KW (Bronco Tactical Vehicle) Aug09 IC 84 346-3689
Replaced 338-3672
EURO III Rating for use in Europe only - not for North America use**************
C7 GOV SERIAL NO. FLASH P/M RELEASE
HORSEPOWER TORQUE SPEED RANGE FILE CODE DATE
190 HP 2500 RPM 142 KW-EURO3 331-0117 71 APR08
Replaced 290-0419
210 HP 2500 RPM 157 KW-EURO3 331-0119 70 APR08
Replaced 290-0418
210 HP 2500 RPM 157 KW-EURO3 331-0118 72 APR08
Replaced 290-0420
230 HP 2400 RPM 172 KW-EURO3 331-0120 73 APR08
Replaced 290-0421
250 HP 2400 RPM 186 KW-EURO3 331-0121 74 APR08
Replaced 290-0422
275 HP 2400 RPM 205 KW-EURO3 331-0122 75 APR08
Replaced 290-0423
300 HP 2400 RPM 224 KW-EURO3 331-0123 76 APR08
Replaced 290-0424
330 HP 2400 RPM 246 KW-EURO3 331-0124 77 APR08
Replaced 290-0425
*********************************** C9 Files *****************************************
NOTE: C9 335HP and 350HP 9DG 1 -700 were factory built with Injector p/n 233-3534.
If a "single" 233-3534 injector is replaced with a 239-6871 Injector w/seals
(238-8092 p/n on injector... not serviced) then "all six" injectors
must be updated to the same part number and the appropriate flash file and "etrim"
Files must be installed to match the "new" part number injector. Use list below to
determine flash file based on installed injector number.
Reference Truck Engine News SEBD6774 November 2004
C9 MTB 285 HP @ 2100 RPM 890 lb-ft (Bus) JAN05 IC 20 270-9204
Replaced 246-4701,251-7416,265-2873
C9 MTB 330 HP @ 2100 RPM 1150 lb-ft (Bus) AUG07 IC 22 319-1842
HEV (Hybrid Electric Vehicle)
Replaced 255-1178,260-1435,286-9589
C9 MTB 330 HP @ 2100 RPM 1150 lb-ft (Bus) SEP04 IC 12 260-1438
MTB00001-00999
Replaced 242-8332,247-4650
C9 MTB 330 HP @ 2100 RPM 1150 lb-ft (Bus) FEB08 IC 21 326-2663
Replaced 246-4700, 251-7415,260-1449,
286-9588,319-1843
C9 9DG 335 HP @ 2100 RPM 1050 lb-ft (TRUCK)
9DG1-700 w/factory installed 233-3534 injectors OCT03 IC 10 247-4652
Replaced 242-1854
9DG1-700 w/field installed 238-8092 injectors MAR04 IC 18 252-0028
9DG1000-UP NOV06 IC 23 305-7997
Replaced 251-7420,260-1450,273-3788,
280-9032,292-5521,296-8233
C9 9DG 350 HP @ 2100 RPM 1100 lb-ft (TRUCK)
9DG1-700 w/factory installed 233-3534 injectors OCT03 IC 11 247-4651
Replaced 242-1852
9DG1-700 w/field installed 238-8092 injectors MAR04 IC 19 252-0029
9DG1000-UP JAN08 IC 24 324-7773
Replaced 251-7419,260-1451,273-3789,
280-9033,286-5300,296-8234,305-7998
C9 9DG 400 HP @ 2300 RPM NOV09 IC 39 355-2987
Replaced 275-2256
C9 9DG 400 HP @ 2200 RPM MAY05 IC 40 275-2257
Replaced N/A
C9 9DG 450 HP @ 2300 RPM Rating NOT Developed Nov09 IC 41 355-2988
Replaced 275-2258
C9 9DG 370 HP @ 2100 RPM 1100 lb-ft (RV) MAR04 IC 30 253-0979
Replaced 251-7418
C9 9DG 400 HP @ 2100 RPM 1100 lb-ft (RV) SEP07 IC 25 320-0329
Replaced 249-9196,251-7418,258-2347,
265-2872,282-8992,289-1223,305-7972
C9 9DG 335 HP @ 2300 RPM 1050 lb-ft (ER) JAN07 IC 42 308-4885
Replaced 264-1214,292-5522
C9 9DG 350 HP @ 2300 RPM 1100 lb-ft (ER) JAN07 IC 43 308-4886
Replaced 264-1215
C9 9DG 400 HP @ 2300 RPM 1100 lb-ft (ER) SEP07 IC 31 320-0330
Replaced 258-2348,282-8993,290-9008,305-7973
C9 9DG 350 HP @ 2100 RPM 1100 lb-ft JAN08 IC 44 324-7772
PSO (Parts service only)
Replaced 293-4644,299-5079,305-7971
C9 LFR 400 HP @ 2300 RPM 1100 lb-ft OCT06 IC 45 303-1504
Defense and Federal Products
Replaced N/A
C9 (2007 Emissions A4 ECM) "Mid HP Ratings" 300HP to 425HP:
C9S00001-up Date Code Interlock Flash File
C9 285HP @ 2200 RPM 890lb-ft JUN08 30/130 334-2371
Replaced 313-2608,313-9567,321-7469,324-7645,
328-0711
C9 335HP @ 2200 RPM 1150lb-ft JUN08 31/131 334-2372
Replaced 313-9568,321-7470,324-7646,328-0712
C9 335HP @ 2200 RPM 1150lb-ft JUN08 32/132 334-2373
Replaced 313-2610,313-9569,321-7471,324-7647,
328-0713
C9 350HP @ 2200 RPM 1250lb-ft JUN08 33/133 334-2374
Replaced 313-2611,313-9570,321-7472,324-7648,
328-0714
C9 365HP @ 2200 RPM 1250lb-ft JUN08 34/134 334-2375
Replaced 313-2612,313-9571,321-7473,324-7649,
328-0715
C9 400HP @ 2300 RPM 1250lb-ft (RV) JUN08 35/135 334-2376
Replaced 313-2613,313-9572,321-5296,321-7474,
324-7650,328-0716
C9 425HP @ 2300 RPM 1250lb-ft (RV) JUN08 37/137 334-2378
Replaced 313-2615,313-9574,321-5298,321-7476,
324-7652,328-0718
C9 425HP @ 2300 RPM 1350lb-ft (RV) JUN08 39/139 334-2380
Replaced 313-2617,313-9576,321-5300,321-7478,
324-7654,328-0720
C9 400HP @ 2300 RPM 1250lb-ft (FT) JUN08 36/136 334-2377
Replaced 313-2614,313-9573,321-5297,321-7475.
324-7651,328-0717
C9 425HP @ 2300 RPM 1250lb-ft (FT) JUN08 38/138 334-2379
Replaced 313-2616,313-9575,321-5299,321-7477,
324-7653,328-0719
C9 425HP @ 2300 RPM 1350lb-ft (FT) JUN08 40/140 334-2381
Replaced 313-2618,313-9577,321-5301,321-7479,
324-7655,328-0721
C-10/C-12/3176B LOW NOX FLASH FILE CROSS REFERENCE
UPDATED December 21, 2000
The Low NOx Software files listed below have the same interlock codes as the
Standard rating software for the specified engines with 300 added to the interlock
code.
LOW NOX EMISSIONS REBUILD SOFTWARE FOR '98 IRON C-10/C-12 ADEM II
PARTS SERVICE ONLY (PSO)
'98 MY C-10 IRON
DESCRIPTION GOV S/N FLASH ITRLCK RELEASE
305 HP 1800/2100 8YS1 - UP 191-9918 325 OCT 00
1150/1050 PT
305 HP 1800/2100 8YS1 - UP 191-9919 330 OCT 00
(208.5? FAN-ON TEMP)
1150/1050 PT
335 HP 1800/2100 8YS1 - UP 191-9921 326 OCT 00
1250/1350 PT
335 HP 1800/2100 8YS1 - UP 191-9922 331 OCT 00
(208.5? FAN-ON TEMP) 1250/1350 PT
335/370HP MT 1800 8YS1 - UP 191-9920 329 OCT 00
1250/1350 PT
350 HP 1800/2100 8YS1 - UP 191-9923 327 OCT 00
1350 PT
370 HP 1800 8YS1 - UP 191-9924 328 OCT 00
1350 PT
'98 MY C-12 IRON
335 HP 2100 9NS1 - UP 191-9926 329 OCT 00
1550 PT
355 HP 1800/2100 9NS1 - UP 191-9928 324 OCT 00
1350 PT
355 HP 1800 9NS1 - UP 191-9927 331 OCT 00
(208.5? FAN-ON TEMP) 1350 PT
355/410 MT 1800/2100 9NS1 - UP 191-9937 327 OCT 00
1350/1450/1550 PT
380 HP 1800/2100 9NS1 - UP 191-9930 321 OCT 00
1450 PT
380/410 MT 1800 9NS1 - UP 191-9935 328 OCT 00
1450/1550 PT
380/430 MT 1800 9NS1 - UP 191-9938 322 OCT 00
1450/1650 PT
380/430 MT 1800 9NS1 - UP 191-9936 322 OCT 00
(SERVICES 153-8417 - TOP 2 GEARS ONLY - MS CARRIERS CUSTOMER ONLY)
1450/1650 PT
395 HP 2100 9NS1 - UP 191-9931 325 OCT 00
1450 PT
410 HP 1800/2100 9NS1 - UP 191-9932 326 OCT 00
1450/1550 PT
425 HP 2100 9NS1 - UP 191-9934 330 OCT 00
(EMERGENCY VEHICLE, RV, AND BUS ONLY) 1450/1550 PT
430 HP 1800/2100 9NS1 - UP 191-9933 316 OCT 00
1650 PT
455 HP 2100 9NS1 - UP 191-9929 320 OCT 00
(EMERGENCY VEHICLE, RV, AND BUS ONLY) 1550 PT
LOW NOX REBUILD SOFTWARE - PARTS SERVICE ONLY (PSO)
'97 MY C-10 IRON
280 HP 1800 2PN1 - UP 190-0224 305 DEC 99
280 HP 2100 2PN1 - UP 190-0225 306 DEC 99
305 HP 1800 2PN1 - UP 190-0226 307 DEC 99
305 HP 2100 2PN1 - UP 190-0227 308 DEC 99
305 HP 1800 2PN1 - UP 190-0231 307 DEC 99
(208.5Œ FAN-ON TEMP)
325 HP 1800 2PN1 - UP 190-0229 310 DEC 99
(FIELD UPRATE FOR 280 OR 305 HP IRON)
325 HP 2100 2PN1 - UP 190-0228 309 DEC 99
335 HP 1800 2PN1 - UP 190-0221 302 DEC 99
335 HP 1800 2PN1 - UP 190-0230 302 DEC 99
335/370HP MT 1800 2PN1 - UP 190-0223 304 DEC 99
350 HP 1800 2PN1 - UP 190-0220 301 DEC 99
370 HP 1800 2PN1 - UP 190-0222 303 DEC 99
'97 MY C-12 IRON
335 HP 2100 1YN1 - UP 190-0241 315 DEC 99
355 HP 1800 1YN1 - UP 190-0233 302 DEC 99
355 HP 1800 1YN1 - UP 190-0242 323 DEC 99
355/410HP MT 1800 1YN1 - UP 190-0235 304 DEC 99
360 HP 2100 1YN1 - UP 190-0238 307 DEC 99
380 HP 1800 1YN1 - UP 190-0234 303 DEC 99
380/410HP MT 1800 1YN1 - UP 190-0236 305 DEC 99
390 HP 2100 1YN1 - UP 190-0239 308 DEC 99
410 HP 1800 1YN1 - UP 190-0232 301 DEC 99
410 HP 2100 1YN1 - UP 190-0237 306 DEC 99
425 HP 2100 1YN1 - UP 190-0240 309 DEC 99
3176B LOW NOX REBUILD SOFTWARE - PARTS SERVICE ONLY (PSO)
275 HP 1800 9CK1 - UP 188-8079 304 DEC 99
(STANDARD)
188-8091 304 DEC 99
(208.5ŒF FAN-ON TEMP)
300 HP 1800 9CK1 - UP 188-8080 305 DEC 99
325 HP 1800 9CK1-18308 188-8081 302 DEC 99
325 HP 1800 9CK18309-UP 188-8086 326 DEC 99
325/350 HP 1800 9CK18309-UP 188-8087 327 DEC 99
MULTI TORQUE
335/365 HP 1800 9CK1 - UP 188-8084 313 DEC 99
MULTI TORQUE
342 HP 1800 9CK1 - UP 188-8085 312 DEC 99
(OIL FIELD ONLY)
350 HP 1800 9CK1 - UP 188-8082 301 DEC 99
365 HP 1800 9CK1 - UP 188-8083 309 DEC 99
300 HP (2T7318) 1800 9CK1 - UP 188-8088 334 DEC 99
(FIELD UPRATE ONLY! W/ 275 HP IRON)
350 HP (2T7314) 1800 9CK1-18308 188-8089 335 DEC 99
(FIELD UPRATE ONLY! W/ 325 HP IRON)
365 HP (2T7316) 1800 9CK18309-UP 188-8090 336 DEC 99
(FIELD UPRATE ONLY! W/ 325 HP OR 350 HP IRON)
C-10 TRUCK 2001 MY - CLEAN POWER
DESCRIPTION GOV S/N FLASH P/M RELEASE
305 HP 1800/2100 3CS23000 - UP 215-7354 20 JAN02
1050/1150 PT
335 HP 1800/2100 3CS23000 - UP 215-7355 21 JAN02
1250 PT
350 HP 1800/2100 3CS23000 - UP 270-7024 22 APR05
1350 PT
REPLACED 215-7357,237-0713,
241-0760,251-1818
370 HP 1800 3CS23000 - UP 215-7358 23 JAN02
1350 PT
335/370 HP MT 1800 3CS23000 - UP 215-7359 24 JAN02
1250/1350 PT
C-10 TRUCK 2000 MY - EPA CERTIFIED
305 HP 1800/2100 3CS12000 - 22999 270-7006 10 APR05
REPLACED 220-6615,237-0699,
241-0759,251-1761
335 HP 1800/2100 3CS12000 - 22999 220-6617 11 MAR02
350 HP 1800/2100 3CS12000 - 22999 220-6619 12 MAR02
370 HP 1800 3CS12000 - 22999 220-6620 13 MAR02
335/370 HP MT 1800 3CS12000 - 22999 220-6622 14 MAR02
C-10 TRUCK '99 MY - EPA CERTIFIED
305 HP 1800/2100 3CS1 - 11999 215-7806 6 MAR02
335 HP 1800/2100 3CS1 - 11999 215-7807 2 MAR02
350 HP 1800/2100 3CS1 - 11999 215-7808 4 MAR02
370 HP 1800 3CS1 - 11999 215-7809 5 MAR02
335/370 HP MT 1800 3CS1 - 11999 215-7810 3 MAR02
Note: The LOW NOx FLASH files each have an personality module code which has been incremented by 300, compared to the interlock code of the original production FLASH file it is replacing. For example, FLASH file 185-1177,
with a personality module code of 333, replaces the DEC98 PSO FLASH file 170-8128, which had a personality module code of 33.
C-10 TRUCK - EPA CERTIFIED
305 HP 1800/2100 8YS1 - UP 191-9918 325 OCT00
(Replaces 191-2810)
305 HP 1800/2100 8YS1 - UP 191-9919 330 OCT00
(208.5° FAN-ON TEMP)(Replaces 191-2811)
335 HP 1800/2100 8YS1 - UP 191-9921 326 OCT00
(Replaces 191-2812)
335 HP 1800/2100 8YS1 - UP 191-9922 331 OCT00
208.5° FAN-ON TEMP)(Replaces 191-2813)
335/370HP MT 1800 8YS1 - UP 191-9920 329 OCT00
(Replaces 191-2817)
350 HP 1800/2100 8YS1 - UP 191-9923 327 OCT00
(Replaces 191-2814)
350 HP 1800/2100 8YS1 - UP 191-9925 327 OCT00
(208.5°F FAN-ON TEMP Replaces 191-2815)
370 HP 1800 8YS1 - UP 191-9924 328 OCT00
(Replaces 191-2816)
280 HP 1800 2PN1 - UP 190-0224 305 DEC99
(Replaces 170-8077)
280 HP 2100 2PN1 - UP 190-0225 306 DEC99
(Replaces 170-8078)
305 HP 1800 2PN1 - UP 190-0226 307 DEC99
(Replaces 170-8079)
305 HP 2100 2PN1 - UP 190-0227 308 DEC99
(Replaces 170-8080)
305 HP 1800 2PN1 - UP 190-0231 307 DEC99
(208.5? FAN-ON TEMP)(Replaces 170-8084)
325 HP 1800 2PN1 - UP 190-0229 310 DEC99
(Replaces 170-8082)
325 HP 2100 2PN1 - UP 190-0228 309 DEC99
(Replaces 170-8081)
335 HP 1800 2PN1 - UP 190-0221 302 DEC99
(Replaces 170-8074)
335 HP 1800 2PN1 - UP 190-0230 302 DEC99
(208.5? FAN-ON TEMP)(Replaces 170-8083)
335/370HP MT 1800 2PN1 - UP 190-0223 304 DEC99
(Replaces 170-8076)
350 HP 1800 2PN1 - UP 190-0220 301 DEC99
(Replaces 170-8073)
370 HP 1800 2PN1 - UP 190-0222 303 DEC99
(Replaces 170-8075)
C-12 TRUCK 2001 MY - CLEAN POWER
335 HP 2100 2KS72000 - UP 215-7360 50 JAN02
1550 PT
355 HP 1800/2100 2KS72000 - UP 215-7361 51 JAN02
1350 PT
380 HP 1800/2100 2KS72000 - UP 338-5263 52 OCT08
1450 PT
Replaced 215-7362,237-0714,
241-0766,251-1820,270-7026
395 HP 1800/2100 2KS72000 - UP 338-5260 53 OCT08
1450 PT
Replaced 215-7363,236-1023,
241-0765,251-1819,270-7025
355/410 MT 1800/2100 2KS72000 - UP 270-7031 54 APR05
1350/1450/1550 PT
Replaced 215-7364,241-0774,251-1825
380/410 MT 1800 2KS72000 - UP 270-7032 55 APR05
1450/1550 PT
Replaced 215-7365,241-0775,251-1826
410 HP 1800/2100 2KS72000 - UP 338-5262 56 OCT08
1450/1550 PT
Replaced 215-7366,237-9263,
241-0773,251-1824,270-7030,296-6024
425 HP 2100 2KS72000 - UP 215-7367 57 JAN02
1450/1550 PT
380/430 MT 1800 2KS72000 - UP 338-5264 58 OCT08
1450/1650 PT
Replaced 215-7368,237-0715,
241-0767,251-1821,270-7027
430 HP 1800/2100 2KS72000 - UP 338-5261 59 OCT08
1650 PT
Replaced 215-7369,237-0716,
241-0768,251-1822,270-7028
455 HP 2100 2KS72000 - UP 215-7370 60 JAN02
1550 PT
EMERGENCY VEHICLE,RV AND BUS ONLY
505 HP 2100 2KS72000 - UP 270-7029 61 APR05
1550 PT
RV/FT
Replaced 215-7373,226-2039,
237-0717,241-0769,251-1823
C-12 TRUCK 2000 MY - EPA CERTIFIED
335 HP 2100 2KS40000 - 71999 220-6623 20 MAR02
355 HP 1800/2100 2KS40000 - 71999 220-6624 21 MAR02
380 HP 1800/2100 2KS40000 - 71999 270-7011 22 APR05
1450 PT
REPLACED 220-6625,237-0700,
241-0762,251-1766
395 HP 1800/2100 2KS40000 - 71999 220-6627 23 MAR02
355/410 MT 1800/2100 2KS40000 - 71999 270-7012 24 APR05
Replaced 220-6629,237-0701,
241-0763,251-1767
380/410 MT 1800 2KS40000 - 71999 220-6630 25 MAR02
410 HP 1800/2100 2KS40000 - 71999 220-6631 26 MAR02
425 HP 2100 2KS40000 - 71999 220-6632 27 MAR02
380/430 MT 1800 2KS40000 - 71999 270-7014 28 APR05
Replaced 220-6633,237-9262,
241-0772,251-1769
430 HP 1800/2100 2KS40000 - 71999 270-7013 29 APR05
1650 PT
REPLACED 220-6634,237-0702,
241-0764,251-1768
455 HP 2100 2KS40000 - 71999 220-6635 30 MAR02
505 HP 2100 2KS40000 - 71999 220-6636 31 MAR02
1550 PT
RV/FT
C-12 TRUCK '99 MY - EPA CERTIFIED
SPEED F RANGE FILE CODE DATE
335 HP 2100 2KS1 - 39999 215-7811 11 MAR02
355 HP 1800/2100 2KS1 - 39999 215-7812 12 MAR02
380 HP 1800/2100 2KS1 - 39999 270-7010 4 APR05
Replaced 215-7813,241-0776,251-1765
355/410 MT 1800/2100 2KS1 - 39999 215-7817 3 MAR02
380/410 MT 1800 2KS1 - 39999 215-7818 9 MAR02
380/430 MT-4 1800 2KS1 - 39999 270-7009 10 APR05
(STANDARD RATING OR MT-4)
Replaced 215-7820,215,241-0771,251-1764
380/430 MT-2 1800 2KS1 - 39999 270-7008 14 APR05
Replaced 215-7819, 241-0770,251-1763
395 HP 1800/2100 2KS1 - 39999 215-7815 6 MAR02
410 HP 1800/2100 2KS1 - 39999 215-7816 7 MAR02
430 HP 1800/2100 2KS1 - 39999 270-7007 8 APR05
1650 PT
REPLACED 215-7822,237-0688,241-0761,251-1762
425 HP 2100 2KS1 - 39999 215-7821 15 MAR02
455 HP 2100 2KS1 - 39999 215-7823 16 MAR02
335 HP 2100 9NS1 - UP 191-9926 329 OCT00
(Replaces 191-2818)
355 HP 1800/2100 9NS1 - UP 191-9928 324 OCT00
(Replaces 191-2819)
355 HP 1800 9NS1 - UP 191-9927 331 OCT00
(208.5? FAN-ON TEMP)(Replaces 191-2820)
355/410 MT 1800/2100 9NS1 - UP 191-9937 327 OCT00
(Replaces 191-2827)
380 HP 1800/2100 9NS1 - UP 191-9930 321 OCT00
(Replaces 191-2821)
380/410 MT 1800 9NS1 - UP 191-9935 328 OCT00
(Replaces 191-2828)
380/430 MT 1800 9NS1 - UP 191-9938 322 OCT00
(Replaces 191-3727)
380/430 MT 1800 9NS1 - UP 191-9936 322 OCT00
(Replaces 168-7029)
395 HP 2100 9NS1 - UP 191-9931 325 OCT00
(Replaces 191-2822)
410 HP 1800/2100 9NS1 - UP 191-9932 326 OCT00
(Replaces 191-2823)
425 HP 2100 9NS1 - UP 191-9934 330 OCT00
(EMERGENCY VEHICLE, RV, AND BUS ONLY)(Replaces 191-2824)
430 HP 1800/2100 9NS1 - UP 191-9933 316 OCT00
(Replaces 191-2825)
455 HP 2100 9NS1 - UP 191-9929 320 OCT00
(EMERGENCY VEHICLE, RV, AND BUS ONLY) (Replaces 191-2826)
335 HP 1550 LB-FT 2100 1YN1 - UP 190-0241 315 DEC99
Replaced 170-8094
355 HP 1350 LB-FT 1800 1YN1 - UP 190-0233 302 DEC99
Replaced 170-8086
355 HP 1350 LB-FT 1800 1YN1 - UP 190-0242 323 DEC99
Replaced 170-8095
355/410HP MT 1800 1YN1 - UP 190-0235 304 DEC99
1350/1450/1550 LB-FT
Replaced 170-8088
360 HP 1350 LB-FT 2100 1YN1 - UP 190-0238 307 DEC99
Replaced 170-8091
380 HP 1450 LB-FT 1800 1YN1 - UP 190-0234 303 DEC99
Replaced 170-8087
380/410HP MT 1800 1YN1 - UP 190-0236 305 DEC99
1450/1550 LB-FT
Replaced 170-8089
390 HP 1450 LB-FT 2100 1YN1 - UP 190-0239 308 DEC99
Replaced 170-8092
410 HP 1800 1YN1 - UP 190-0232 301 DEC99
1450/1550 LB-FT
Replaced 170-8085
410 HP 2100 1YN1 - UP 190-0237 306 DEC99
1450/1550 LB-FT
Replaced 170-8090
425 HP 2100 1YN1 - UP 190-0240 309 DEC99
1450/1550 LB-FT
Replaced 170-8093
C-10/C-12 CLEAN POWER WITH AIR INLET SHUTOFF
335 HP 1800/2100 3CS23000 - UP 224-4619 26 AUG02
1250 PT
Replaced 215-7356,224-0816
410 HP 1800/2100 2KS72000 - UP 215-7371 63 JAN02
1450/1550 PT
410 HP 1800/2100 2KS72000 - UP 224-4620 67 AUG02
1450/1550 PT
Replaced 224-0817
430 HP 1800/2100 2KS72000 - UP 215-7372 62 JAN02
1650 PT
430 HP 1800/2100 2KS72000 - UP 224-4621 66 AUG02
1650 PT REPLACED 224-0818
C-10/C-12 WITH AIR INLET SHUTOFF
335 HP 1800/2100 3CS12000-22999 220-6618 15 MAR02
1250 PT
335 HP 1800/2100 3CS12000-22999 224-4616 17 AUG02
1250 PT REPLACED 224-0813
410 HP 1800/2100 2KS40000-71999 220-6637 35 MAR02
1450/1550 PT
410 HP 1800/2100 2KS40000-71999 224-4617 37 AUG02
1450/1550 PT REPLACED 224-0814
430 HP 1800/2100 2KS40000-71999 220-6638 34 MAR02
1650 PT
430 HP 1800/2100 2KS40000-71999 224-4618 36 AUG02
1650 PT REPLACED 224-0815
C-12 MTVR
355/410 MT 2100 9SM00001-1499 220-4351 18 APR02
355/410 MT 2100 9SM01500 - UP 220-4352 65 APR02
(Clean Power)
C13 TRUCK EURO3 (NOT FOR USE IN THE UNITED STATES)
380 HP 2100 JAM1 - UP 307-1467 66 DEC06
Replaced 273-8798,291-2044,295-1536
430 HP 2100 JAM1 - UP 307-1468 67 DEC06
Replaced 273-8799,291-2045,295-1537
470 HP 2100 JAM1 - UP 307-1469 68 DEC06
Replaced 273-8800,291-2046,295-1538
C-10/C-12 TRUCK EURO II CERTIFIED (NOT FOR USE IN THE UNITED STATES)
325 HP 1900 8YS1 - UP 191-0986 44 MAR 00
365 HP 1900 8YS1 - UP 191-0987 46 MAR 00
335 HP 1900 9NS1 - UP 191-0988 37 MAR 00
380 HP 1900 9NS1 - UP 191-0989 38 MAR 00
410 HP 1900 9NS1 - UP 191-0990 39 MAR 00
325 HP 1900 8YS1 - UP 158-9979 33 FEB 98
350 HP 1900 8YS1 - UP 158-9981 34 FEB 98
365 HP 1900 8YS1 - UP 158-9983 35 FEB 98
335 HP 1900 9NS1 - UP 158-2023 32 FEB 98
380 HP 1900 9NS1 - UP 153-9616 33 FEB 98
410 HP 1900 9NS1 - UP 153-9618 34 FEB 98
C-12 TRUCK EURO III CERTIFIED (NOT FOR USE IN THE UNITED STATES)
430 HP 1900 229-2780 47 APR 03
430 HP 1900 250-2988 47 APR 03
For GREECE truck engines
C-10 TRUCK EURO II CERTIFIED (NOT FOR USE IN THE UNITED STATES)
325 HP 1900 2PN1 - UP 120-8935 12 APR 99
350 HP 1900 2PN1 - UP 120-8951 11 APR 99
365 HP 1900 2PN1 - UP 120-8922 13 APR 99
C-10 CNF TRUCK - EPA CERTIFIED
335 HP (2000 MY) 1800/2100 3CS12000-22999 223-9987 11 APR 02
335 HP (1999 MY) 1800/2100 3CS1-11999 223-9986 2 APR 02
C-12 CNF TRUCK 2000 MY - EPA CERTIFIED
355 HP (1999 MY) 1800/2100 2KS00001 - 39999 223-9988 12 APR02
355 HP (2000 MY) 1800/2100 2KS40000 - 71999 223-9989 21 APR02
355 HP (2001 MY) 1800/2100 2KS72000 - UP 223-9992 51 APR02
355/410 HP (1999 MY) 1800/2100 2KS1 - 39999 223-9990 3 APR02
355/410 HP (2000 MY) 1800/2100 2KS40000 -71999 223-9991 24 APR02
355/410 HP (2001 MY) 1800/2100 2KS72000 - UP 223-9993 54 APR02
This Section is Industrail Engine with Truck Software
C13 440HP 2100 EMS1-UP 365-1096 205 Nov10
Replaced 312-3134
600HP 2100 PRM1-UP 364-9748 206 Nov10
Replaced 340-1103,347-3441,355-9837
C-15/C-16/C-18 Flash File Cross Reference
Truck Engines 6NZ and 7CZ and EGH (Gov.)
Updated January 15,2008 AJK
C-15 CLEAN POWER GOV SERIAL NO. FLASH P/M RELEASE
C-15 (6NZ) LOW HP ENGINE SERIAL NO. FLASH P/M RELEASE
RATING INFORMATION RANGE FILE CODE DATE
355 HP 1350 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7374 120 JAN02
REPLACED 208-5761
355 HP 1350/1450 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7375 121 JAN02
MULTITORQUE
REPLACED 208-5762
375 HP 1450 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7376 122 JAN02
REPLACED 208-5763
375 HP 1450/1550 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7377 123 JAN02
MULTITORQUE
REPLACED 208-5764
375/435 HP 1450/1550 LB-FT 1800 RPM 6NZ54000-UP 270-7116 124 APR05
MULTITORQUE
REPLACED 251-1526
410 HP 1450/1550 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7379 125 JAN02
REPLACED 208-5766
450 HP 1550/1650 LB-FT 2100 RPM 6NZ54000-UP 215-7383 129 JAN02
REPLACED 208-5770
C-15 (6NZ) HIGH HP ENGINE SERIAL NO. FLASH P/M RELEASE
435 HP 1550/1650 LB-FT 1800/2100 RPM 6NZ54000-UP 270-7115 126 APR05
REPLACED 251-1525
435HP 1550/1650 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7381 127 JAN02
MULTITORQUE
REPLACED 208-5768
435/500 HP 1550/1650 LB-FT 2100 RPM 6NZ54000-UP 300-1385 128 SEP06
MT SUPPORT ALLISON OWS 4700 TRANS
REPLACED 251-1533,270-7123
455 HP 1550/1650 LB-FT 1800/2100 RPM 6NZ54000-UP 338-5273 130 OCT08
REPLACED 251-1527,270-7117
455 HP 1550/1650 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7385 131 JAN02
MULTITORQUE
REPLACED 208-5773
455 HP 1550/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7386 132 JAN02
MULTITORQUE
REPLACED 208-5774
455 HP 1550/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7387 133 JAN02
MULTITORQUE BRAKESAVER
REPLACED 208-5775
475 HP 1650/1750 LB-FT 1800/2100 RPM 6NZ54000-UP 338-5268 134 OCT08
REPLACED 251-1528,270-7118
475HP 1650/1750 LB-FT 1800/2100 RPM 6NZ54000-UP 338-5269 135 OCT08
BRAKESAVER
REPLACED 251-1529,270-7119
475/500 HP 1650/1850 LB-FT 2100 RPM 6NZ54000-UP 215-7390 136 JAN02
TOP 2 GEAR MULTITORQUE
REPLACED 208-5778
475/500 HP 1650/1850 LB-FT 2100 RPM 6NZ54000-UP 215-7391 137 JAN02
REPLACED 208-5779
475/500 HP 1650/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7392 138 JAN02
REPLACED 208-5780
475/500HP 1650/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7393 139 JAN02
TOP 2 GEAR MULTITORQUE BRAKESAVER
REPLACED 208-5781
500HP 1650 LB-FT 2100 RPM 6NZ54000-UP 338-5272 140 OCT08
500HP FLEET 1750 LB-FT 2100 RPM
435/500 HP 1550/1650 LB-FT OIL WELL SERVICE
REPLACED 208-5782,215-7394,244-1565,328-1938
500 HP 1650/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7395 141 JAN02
BRAKESAVER
REPLACED 208-5783
500 HP 1850 LB-FT 2300 RPM 6NZ54000-UP 215-7396 142 JAN02
REPLACED 208-5784
500 HP 1850 LB-FT 2300 RPM 6NZ54000-UP 215-7397 143 JAN02
BRAKESAVER
REPLACED 208-5785
500 HP 1750/1850 LB-FT 2100 RPM 6NZ54000-UP 215-7398 144 JAN02
REPLACED 208-5786
500 HP 1750/1850 LB-FT 2100 RPM 6NZ54000-UP 215-7399 145 JAN02
REPLACED 208-5787
500 HP 1850 LB-FT 1800/2100 RPM 6NZ54000-UP 338-5270 146 OCT08
REPLACED 208-5788,215-7400,
237-0723,241-0788,244-1568
500 HP 1850 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7401 147 JAN02
BRAKESAVER
REPLACED 208-5789
550 HP 1850 LB-FT 2100 RPM 6NZ54000-UP 338-5274 148 OCT08
REPLACED 244-1567,305-2778,320-2698
550 HP 1850 LB-FT 2100 RPM 6NZ54000-UP 270-7120 149 APR05
BRAKESAVER
REPLACED 251-1530
550 HP 1850 LB-FT 2100 RPM 6NZ54000-UP 270-7121 150 APR05
2300 RPM TEL FIELD UPRATE ONLY
REPLACED 251-1531
550 HP 1850 LB-FT 2100 RPM 6NZ54000-UP 270-7122 151 APR05
BRAKESAVER
REPLACED 251-1532
355HP 1350PT 1800/2100RPM 6NZ1-53999 220-6640 70 MAR02
355HP 1350/1450PT 1800 RPM 6NZ1-53999 220-6641 71 MAR02
1350/1450PT 2100 RPM
MULTITORQUE
375HP 1450PT 1800/2100RPM 6NZ1-53999 220-6642 72 MAR02
375/435HP 1450/1550PT 1800PRM 6NZ1-53999 220-6644 55 MAR02
1450/1650PT 1800 RPM
MULTITORQUE
375HP MT 1450/1550PT 1800RPM 6NZ1-53999 220-6643 73 MAR02
1450/1550PT 2100RPM
410HP 1450/1550PT 1800/2100RPM 6NZ1-53999 220-6645 74 MAR02
FIELD UPRATE ONLY
450HP 1550/1650PT 2100RPM 6NZ1-53999 220-6650 78 MAR02
FIELD UPRATE ONLY
435HP 1550/1650PT 1800/2100RPM 6NZ1-53999 270-7073 75 APR05
Replaced 220-6646,241-0793,251-2217
435HP 1550/1650PT 1800/2100RPM 6NZ1-53999 220-6647 76 MAR02
BRAKESAVER
435/500HP 1550/1650 2100RPM 6NZ1-53999 270-7074 77 APR05
MULTITORQUE
Replaced 220-6649,241-0794,
251-2218
455HP 1550PT 2100RPM OR 6NZ1-53999 220-6651 79 MAR02
1650PT 1800/2100RPM
455HP 1550PT 2100RPM OR 6NZ1-53999 220-6652 80 MAR02
1650PT 1800/2100RPM BRAKESAVER
455HP 1550/1750PT 2100 RPM 6NZ1-53999 220-6653 81 MAR02
MULTITORQUE
455HP 1550/1750PT 2100 RPM 6NZ1-53999 220-6654 82 MAR02
BRAKESAVER MULTITORQUE
475HP 1650/1750PT 1800/2100RPM 6NZ1-53999 270-7067 6 APR05
REPLACED 220-6655,237-0703,
241-0777,251-2211
475HP 1650/1750PT 1800/2100RPM 6NZ1-53999 270-7068 83 APR05
BRAKESAVER
REPLACED 220-6657, 2370704,
241-0778,251-2212
475/500HP 1650/1850PT 2100 RPM 6NZ1-53999 220-6658 84 MAR02
475/500HP 1650/1850PT 2100 RPM 6NZ1-53999 220-6659 85 MAR02
475/500HP 1650/1750PT 2100 RPM 6NZ1-53999 220-6660 86 MAR02
475/500HP 1650/1750PT 2100 RPM 6NZ1-53999 220-6661 87 MAR02
500HP 1650PT 2100RPM, 6NZ1-53999 220-6662 88 MAR02
500HP FLEET 1750PT 2100RPM or
435/500HP 1550/1650 OIL WELL SERVICE
500HP 1650PT 2100RPM BRAKESAVER 6NZ1-53999 220-6664 89 MAR02
OR 500HP FLEET 1750PT 2100RPM BRAKESAVER
500HP 1850PT 1800/2100RPM 6NZ1-53999 220-6665 90 MAR02
2300RPM TEL FIELD UPRATE ONLY
500HP 1750/1850PT 2100 RPM 6NZ1-53999 220-6667 92 MAR02
500HP 1750/1850PT 2100 RPM 6NZ1-53999 220-6668 93 MAR02
500HP 1850PT 1800/2100RPM 6NZ1-53999 220-8235 94 MAR02
500HP 1850PT 1800/2100RPM 6NZ1-53999 220-8236 95 MAR02
BRAKESAVER
500HP 1850PT 1800/2100RPM 6NZ1-53999 220-6666 91 MAR02
BRAKESAVER 2300RPM TEL FIELD UPRATE ONLY
550HP 1850PT 2100RPM 6NZ1-53999 270-7069 7 APR05
REPLACED 220-8237, 237-0705,241-0779,251-2213
550HP 1850PT 2100RPM BRAKESAVER 6NZ1-53999 270-7070 96 APR05
REPLACED 220-8238, 237-0706,
241-0780,251-2214
550HP 1850PT 2100RPM 6NZ1-53999 270-7071 97 APR05
REPLACED 220-8239, 237-0707,241-0781,251-2215
550HP 1850PT 2100RPM BRAKESAVER 6NZ1-53999 270-7072 98 APR05
REPLACED 220-8240, 237-0708,241-0782,251-2216
C-16 CLEAN POWER GOV SERIAL NO. FLASH P/M RELEASE
575HP 1850PT 2100RPM 7CZ02800-UP 215-7406 152 JAN02
REPLACED 208-5794
575HP 1850PT 2100RPM 7CZ02800-UP 215-7407 153 JAN02
BRAKESAVER REPLACED 208-5795
575HP 1850PT 2100RPM 7CZ02800-UP 215-7408 154 JAN02
REPLACED 208-5796 TEL 2300RPM
575HP 1850PT 2100RPM 7CZ02800-UP 215-7409 155 JAN02
BRAKESAVER REPLACED 208-5797 TEL 2300RPM
575/600HP 1850/2050PT 2100RPM 7CZ02800-UP 215-7410 156 JAN02
MULTITORQUE REPLACED 208-5798
575/600HP 1850/2050PT 2100RPM 7CZ02800-UP 215-7411 157 JAN02
REPLACED 208-5799
600HP 2050PT 2100RPM 7CZ02800-UP 338-5275 158 OCT08
REPLACED 208-5800,215-7412,237-0728,
241-0800,251-1534,270-7124
600HP 2050PT 2100RPM 7CZ02800-UP 270-7125 159 APR05
BRAKESAVER
REPLACED 208-5801,215-7413,237-0729,241-0801,251-1535
600HP 2050PT 2100RPM 7CZ02800-UP 270-7126 160 APR05
TEL 2300RPM
REPLACED 208-5802,215-7414,237-0730,
241-0802,251-1536
600HP 2050PT 2100RPM 7CZ02800-UP 270-7127 161 APR05
BRAKESAVER TEL 2300RPM
REPLACED 208-5803,215-7415,237-0731,
241-0803,251-1537
650HP 2050PT 2100RPM 7CZ02800-UP 267-5143 162 JAN05
Aircraft Rescue Firetruck only - Oshkosh
REPLACED 208-0523,251-1626
680HP 1951PT 2100RPM 7CZ02800-UP 267-5143 162 JAN05
REPLACED 232-2644,243-0022,251-1626
C-16 (7CZ) ENGINE SERIAL NO. FLASH P/M RELEASE
575HP 1850PT 2100RPM 7CZ1-02799 220-8241 56 MAR02
REPLACES 198-3265
575HP 1850PT 2100RPM BRAKESAVER 7CZ1-02799 220-8242 99 MAR02
REPLACES 198-3266
575HP 1850PT 2100RPM 7CZ1-02799 220-8243 101 MAR02
REPLACES 198-3267
575HP 1850PT 2100RPM BRAKESAVER 7CZ1-02799 220-8244 100 MAR02
REPLACES 198-3268
575/600HP 1850/2050PT 2100RPM 7CZ1-02799 220-8245 102 MAR02
REPLACES 198-3269
MULTITORQUE
575/600HP MT 1850/2050PT 2100RPM 7CZ1-02799 220-8246 103 MAR02
BRAKESAVER
REPLACES 198-3270
600HP 2050PT 2100RPM 7CZ1-02799 270-7075 8 APR05
REPLACES 198-3271,220-8247,237-0709,
241-0796,251-2219
600HP 2050PT 2100RPM BRAKESAVER 7CZ1-02799 270-7076 104 APR05
REPLACES 198-3272,220-8248,237-0710,
241-0797,251-2220
600HP 2050PT 2100RPM 7CZ1-02799 270-7077 105 APR05
REPLACES 198-3273,220-8249,237-0711,
241-0798,251-2221
600HP 2050PT 2100RPM BRAKESAVER 7CZ1-02799 270-7078 106 APR05
REPLACES 198-3274,220-8250,237-0712,
241-0799,251-2222
650HP 2050PT 2100PRM 220-4294 162 FEB02
AIRCRAFT/FIRE FIGHTING APPLICATION
650HP 1951PT 2100/2300 TEL 7CZ1-02799 251-1629 163 APR04
REPLACES 232-2643, 235-6399,241-0816
C-18
C-18 700HP @2300RPM 1900PT@2100RPM MEP1-UP 241-0817 1 JUN03
Military only
REPLACED 217-3928,224-9318,227-5521,232-2647,
238-2680,239-4147
C-18 700HP @2300RPM 1900PT@2100RPM MEP1-UP 232-2648 1 NOV02
Military only
REPLACED 226-4417,227-5522
C-16 EGH
525 HP 1773 LB-FT 2100/2300 TEL 6NZ54000-UP 268-0221 164 APR05
(Government/Military) EGH
REPLACED 251-1628
2yg & 7lg Personality Module Cross Reference with Chips not Flashfiles
3176 2YG & 7LG PERSONALITY MODULE CROSS REFERENCE
UPDATED 6/22/95
DESCRIPTION S/N PART RE-MAN INTERLOCK RELEASE
RANGE NUMBER PART NUMBER CODE DATE
250 HP 2YG1 - UP 114-6689 0R6891 3 JUL 93
STANDARD
250 HP 2YG1 - UP 114-6707 0R6895 5 JUL 93
URBAN BUS
275 HP 2YG1 - UP 114-6691 0R6892 4 JUL 93
STANDARD
300 HP 2YG1 - UP 114-6694 0R6893 1 JUL 93
STANDARD
325 HP 2YG1 - UP 114-6698 0R6894 2 JUL 93
STANDARD
325 TO 350 2YG1 - UP 113-8969 NOT AVAIL 29 JUL 93
UPGRADE KIT
250 HP 7LG1-07499 112-2074 0R6851 8 JUL 93
STANDARD
250 HP 7LG1-07499 112-2078 0R6855 13 JUL 93
URBAN BUS
275 HP 7LG1-07499 112-2075 0R6852 9 JUL 93
STANDARD
275 HP 7LG1-07499 112-2082 NOT AVAIL 9 JUL 93
J1922
275 HP 7LG1-07499 112-2079 NOT AVAIL 9 JUL 93
BULK HAULER
300 HP 7LG1-07499 112-2076 0R6853 10 JUL 93
STANDARD
300 HP 7LG1-07499 112-2085 NOT AVAIL 10 JUL 93
J1922
300 HP 7LG1-07499 112-2080 NOT AVAIL 10 JUL 93
BULK HAULER
325 HP 7LG1-07499 112-2077 0R6854 11 JUL 93
STANDARD
325 HP 7LG1-07499 112-2087 0R6856 11 JUL 93
J1922
325 HP 7LG1-07499 112-2081 NOT AVAIL 11 JUL 93
BULK HAULER
325 TO 350 7LG1-07499 115-3011 NOT AVAIL 30 JUL 93
UPGRADE KIT
275 HP 7LG07500-15999 112-2072 0R6857 19 JUL 93
STANDARD
275 HP 7LG07500-15999 112-2068 0R6861 19 JUL 93
J1922
275 HP 7LG07500-15999 112-2063 NOT AVAIL 19 JUL 93
BULK HAULER
300 HP 7LG07500-15999 112-2071 0R6858 20 JUL 93
STANDARD
300 HP 7LG07500-15999 112-2067 0R6862 20 JUL 93
J1922
300 HP 7LG07500-15999 112-2062 NOT AVAIL 20 JUL 93
BULK HAULER
325 HP 7LG07500-15999 112-2070 0R6859 16 JUL 93
STANDARD
325 HP 7LG07500-15999 112-2065 0R6863 16 JUL 93
J1922
325 HP 7LG07500-15999 112-2061 NOT AVAIL 16 JUL 93
BULK HAULER
350 HP 7LG07500-15999 112-2069 0R6860 16 JUL 93
STANDARD
350 HP 7LG07500-15999 112-2064 0R6864 16 JUL 93
J1922
350 HP 7LG07500-15999 112-2060 NOT AVAIL 16 JUL 93
BULK HAULER
275 HP 7LG16000-UP 111-4156 0R6841 28 JUL 93
STANDARD
275 HP 7LG16000-UP 111-4150 0R6846 28 JUL 93
J1922
275 HP 7LG16000-UP 111-4188 NOT AVAIL 28 JUL 93
BULK HAULER
300 HP 7LG16000-UP 111-4154 0R6842 27 JUL 93
STANDARD
300 HP 7LG16000-UP 111-4148 0R6847 27 JUL 93
J1922
300 HP 7LG16000-UP 111-4186 NOT AVAIL 27 JUL 93
BULK HAULER
325 HP 7LG16000-UP 111-4158 0R6843 26 JUL 93
STANDARD
325 HP 7LG16000-UP 111-4146 0R6848 26 JUL 93
J1922
325 HP 7LG16000-UP 111-4184 NOT AVAIL 26 JUL 93
BULK HAULER
350 HP 7LG16000-UP 111-4152 0R6844 25 JUL 93
STANDARD
350 HP 7LG16000-UP 111-4144 0R6849 25 JUL 93
J1922
350 HP 7LG16000-UP 111-4182 NOT AVAIL 25 JUL 93
BULK HAULER
360 HP 7LG16000-UP 111-4160 0R6845 24 JUL 93
STANDARD
360 HP 7LG16000-UP 111-4173 0R6850 24 JUL 93
J1922
360 HP 7LG16000-UP 111-4162 NOT AVAIL 24 JUL 93
BULK HAULER
325 HP 7LG CHALLENGER 3E5491 OR6573 18 OCT 91
3176B FLASH FILE CROSS REFERENCE
UPDATED 5/21/98
WARNING!!!
The original personality modules in some 3176B and 3406E engines between
9CK1 - 5000 and 5EK1 - 5000 can NOT be flashed with NOV95 or newer
software. The Flash program may terminate at 20 to 25% complete when
attempting to flash these personality modules with NOV95 or newer software.
Many of the personality modules in the affected serial number range can be
flashed with NOV95 or newer software because the original personality
module was replaced with a compatible one during an earlier software update
or ECM replacement. However, before attempting to flash the personality
modules on engines in the affected range, make sure that there is a
106-9184 personality module available. If the flash attempt fails, try
again. If both attempts terminate at 20 to 25% complete, replace the
personality module with the 106-9184 module and repeat the flash
programming.
Since the flash process erases the file from the personality module before
programming it, a failure while flashing the personality module in the
affected range will render the engine inoperable. Once this occurs, there
are two options; 1) replace the personality module with a 106-9184 module
and re-flash or 2) flash the original personality module with pre-NOV95
software.
Option 1 is the preferred method since it makes the engine compatible with
all future software releases. However, if a new personality module is not
available option 2 can be used. The pre-NOV95 files have been put back on
the Caterpillar mailbox for downloading. They are listed below along with
the current files.
The latest flash files call for default injector codes to be entered. The
default injector code for 3176B, C-10, and C-12 engines is 2300.
TRUCK (Factory Ratings)
DESCRIPTION GOV S/N FLASH SERVICE ITRLCK RELEASE
SPEED RANGE CODE REPLACEMENT CODE DATE
275 HP 1800 9CK1 - UP 146-9259 146-9261 4 MAR 97
(STANDARD)
146-9368 4 MAR 97
125-7999 125-8001 4 JUN 95
(STANDARD)
300 HP 1800 9CK1 - UP 146-9262 146-9264 5 MAR 97
125-8002 125-8004 5 JUN 95
325 HP 1800 9CK1-18308 159-2840 2 FEB 98
129-2589 129-2591 2 JUN 95
325 HP 1800 9CK18309-UP 159-2838 26 FEB 98
(STANDARD)
141-9470 26 AUG 96
125-8018 125-8021 26 JUN 95
(STANDARD)
325/350 HP 1800 9CK18309-UP 159-2839 27 FEB 98
MULTI TORQUE 125-8022 125-8024 27 JUN 95
335/365 HP 1800 9CK1 - UP 159-2837 13 FEB 98
MULTI TORQUE 125-8012 125-8014 13 JUN 95
TRUCK (Factory Ratings)(cont'd)
342 HP 1800 9CK1 - UP 146-9276 146-9278 12 MAR 97
(OIL FIELD ONLY) 125-8015 125-8017 12 JUN 95
350 HP 1800 9CK1 - UP 159-2835 1 FEB 98
125-8005 125-8007 1 JUN 95
365 HP 1800 9CK1 - UP 159-2836 9 FEB 98
125-8008 125-8010 9 JUN 95
* MAR 97 effective with factory built 3176B engine S/N 9CK32702.
TRUCK (Field Uprate Ratings)
300 HP (2T7318)1800 9CK1 - UP 159-2841 34 FEB 98
132-9662 132-9664 34 FEB 96
350 HP (2T7314)1800 9CK1-18308 159-2842 35 FEB 98
132-9666 132-9668 35 FEB 96
365 HP (2T7316)1800 9CK18309-UP 159-2843 36 FEB 98
132-9671 132-9673 36 FEB 96
365 HP (2T7316)1800 9CK1 - UP 159-2843 36 FEB 98
(FIELD UPRATE ONLY! W/ 350 HP IRON)
3406B/C PEEC, PEEC II, PEEC 2.5, AND ELECTRONIC_PERSONALITY MODULE CROSS REF
PERSONALITY MODULE CROSS-REFERENCE
October 20,1997
ECM Eng S/N Range HP Rating IC PM
II 8TC1-1412 285 EPA 2 1019291-00
II 8TC1-1412 285 EPA 2 0R6666-00
II 8TC1413-10980 285 EPA 101 1019295-00
II 8TC1413-10980 285 EPA 101 0R6648-00
II 8TC1413-Up 285 CARB 102 1019282-00
II 8TC1413-Up 285 CARB 102 0R6656-00
II 8TC1-1412 310 EPA 2 1019292-00
II 8TC1-1412 310 EPA 2 0R6667-00
II 8TC1413-10980 310 EPA 101 1019296-00
II 8TC1413-10980 310 EPA 101 0R6649-00
II 8TC1413-UP 310 CARB 102 1019283-00
II 8TC1413-UP 310 CARB 102 0R6657-00
II 8TC1413-UP 310 MT Top1 CARB 113 1019307-00
II 8TC1413-UP 310 MT Top1 CARB 113 0R6664-00
II 8TC1413-UP 310 MT Top4 CARB 113 1022492-00
II 8TC1413-UP 310 MT Top4 CARB 113 0R6681-00
II 8TC1413-10980 310 PDCC EPA 108 1019303-00
II 8TC1413-10980 310 PDCC EPA 108 0R6655-00
II 8TC1413-UP 310 PDCC CARB 109 1019290-00
II 8TC1413-UP 310 PDCC CARB 109 0R6665-00
II 2EK1 - UP 310 Std 10 1019248-00
II 2EK1 - UP 310 Std 10 0R6632-00
II 2EK1 - UP 310 MT Top1 11 1019249-00
II 2EK1 - UP 310 MT Top1 11 0R6633-00
II 2EK1 - UP 310 MT Top4 11 1022490-00
II 2EK1 - UP 310 MT Top4 11 0R6679-00
II 2EK1 - UP 310 PDCC 12 1019250-00
II 2EK1 - UP 310 PDCC 12 0R6634-00
II.V 8TC9090 - 10980 310 EPA 101 1019296-00
II.V 8TC9090 - 10980 310 EPA 101 0R6649-00
II.V 8TC10981 - Up 310 CARB 102 1019283-00
II.V 8TC10981 - Up 310 CARB 102 0R6657-00
II.V 8TC10981 - Up 310 MT Top1 CARB 113 1022492-00
II.V 8TC10981 - Up 310 MT Top1 CARB 113 0R6681-00
II.V 2EK1 - UP 310 NAR 10 1019248-00
II.V 2EK1 - UP 310 NAR 10 0R6632-00
II.V 2EK1 - Up 310 MT Top1 11 1019249-00
II.V 2EK1 - Up 310 MT Top1 11 0R6633-00
III 4CK1 - Up 310@1800 10 1457832-00
III 4CK1 - Up 310 MT Top1 11 1457834-00
III 4CK1 - Up 310 MT Top4 11 1457849-00
III 4CK1 - Up 310 PDCC 12 1457851-00
II 8TC1 - 1412 330/350LT EPA 1 1019293-00
II 8TC1 - 1412 330/350LT EPA 1 0R6646-00
II 8TC1413 - 10980 330/350LT EPA 103 1019297-00
II 8TC1413 - 10980 330/350LT EPA 103 0R6650-00
II 8TC8792 - UP 330/350LT NAR LCV 114 1019284-00
II 8TC8792 - UP 330/350LT NAR LCV 114 0R6658-00
II 2EK1 - Up 330@1800 23 1019251-00
II 2EK1 - Up 330@1800 23 0R6635-00
II.V 2EK1 - Up 330@1800 23 1019251-00
II.V 2EK1 - Up 330@1800 23 0R6635-00
III 4CK1 - Up 330@1800 23 1457853-00
II 8TC1 - 1412 350 EPA 1 1019294-00
II 8TC1 - 1412 350 EPA 1 0R6647-00
II 8TC1413 - 10980 350 EPA 103 1019298-00
II 8TC1413 - 10980 350 EPA 103 0R6651-00
II 8TC8792 - UP 350 NAR LCV 114 1019285-00
II 8TC8792 - UP 350 NAR LCV 114 0R6659-00
II 8TC1413 - Up 350 EPA MT Top2 121 1022493-00
II 8TC1413 - Up 350 EPA MT Top2 121 0R6682-00
II 8TC1413 - Up 350 EPA MT Top4 121 1022494-00
II 8TC1413 - Up 350 EPA MT Top4 121 0R6683-00
II 2EK1 - Up 350@2000 13 1019252-00
II 2EK1 - Up 350@2000 13 0R6636-00
II 2EK1 - Up 350@1800 14 1019253-00
II 2EK1 - Up 350@1800 14 0R6637-00
II 2EK1 - Up 350@1800 LT 15 1019255-00
II 2EK1 - Up 350@1800 LT 15 0R6639-00
II 2EK1 - Up 350@1800 MT Top2 16 1019254-00
II 2EK1 - Up 350@1800 MT Top2 16 0R6638-00
II 2EK1 - Up 350@1800 MT Top4 16 1022491-00
II 2EK1 - Up 350@1800 MT Top4 16 0R6680-00
II.V 8TC9090 - 10980 350 EPA 114 1019285-00
II.V 8TC9090 - 10980 350 EPA 114 0R6659-00
II.V 8TC10981 - Up 350 NAR 121 1022493-00
II.V 8TC10981 - Up 350 NAR 121 0R6682-00
II.V 2EK1 - Up 350 Std Hi RPM 13 1019252-00
II.V 2EK1 - Up 350 Std Hi RPM 13 0R6636-00
II.V 2EK1 - Up 350 Std Lo RPM 14 1019253-00
II.V 2EK1 - Up 350 Std Lo RPM 14 0R6637-00
II.V 2EK1 - Up 350 Lo Torque 15 1019255-00
II.V 2EK1 - Up 350 Lo Torque 15 0R6639-00
II.V 2EK1 - Up 350 MT Top2 16 1019254-00
II.V 2EK1 - Up 350 MT Top2 16 0R6638-00
III 4CK1 - Up 350@2000 w/o Brksv 13 1457873-00
III 4CK1 - Up 350@2000 w/Brksv 25 3E9115-00
III 4CK1 - 3413 350@1800 14 1457867-00
III 4CK3414 - Up 350@1800 14 1457856-00
III 4CK1 - 10214 350@1800 LT 15 1457877-00
III 4CK10215 - Up 350@1800 LT 15 1457875-00
III 4CK1 - 3413 350 MT Top2 16 1457879-00
III 4CK 3414 - Up 350 MT Top2 16 1457881-00
III 4CK1 - 3413 350 MT Top4 16 1457884-00
III 4CK 3414 - Up 350 MT Top4 16 1457890-00
III 4CK1 - Up 365 Std w/o Brksv 24 1457899-00
III 4CK1 - Up 365 Std w/Brksv 27 3E9120-00
III 4CK1 - Up 365 MT Top2 w/o Brksv 26 1457911-00
III 4CK1 - Up 365 MT Top2 w/Brksv 28 3E9130-00
III 4CK1 - Up 365 MT Top4 w/o Brksv 26 1457916-00
III 4CK1 - Up 365 MT Top4 w/Brksv 28 1457923-00
III 4CK1 - Up 365 HT MT Top4 w/o 34 1457935-00
Brksv
III 4CK1 - Up 365 HT MT Top4 35 1457941-00
w/Brksv
II 8TC1413 - Up 375/400 LT CARB 105 1019286-00
II 8TC1413 - Up 375/400 LT CARB 105 0R6660-00
II 8TC1413 - 10980 375/400 LT EPA 104 1019299-00
II 8TC1413 - 10980 375/400 LT EPA 104 0R6652-00
II 8TC1413 - 10980 400 EPA 104 1019300-00
II 8TC1413 - 10980 400 EPA 104 0R6653-00
II 8TC1413 - Up 400 CARB 105 1019287-00
II 8TC1413 - Up 400 CARB 105 0R6661-00
II 2EK1 - Up 400 Std 17 1019256-00
II 2EK1 - Up 400 Std 17 0R6640-00
II.V 8TC9090 - 10980 400 EPA 104 1019300-00
II.V 8TC9090 - 10980 400 EPA 104 0R6653-00
II.V 8TC10981 - Up 400 CARB 105 1019287-00
II.V 8TC10981 - Up 400 CARB 105 0R6661-00
II.V 2EK1 - Up 400 Std 17 1019256-00
II.V 2EK1 - Up 400 Std 17 0R6640-00
III 4CK1 - Up 400 Std w/o Brksv 17 1457944-00
III 4CK1 - Up 400 Std w/Brksv 26 1457950-00
II 8TC1413 - 10980 425 EPA 106 1019301-00
II 8TC1413 - 10980 425 EPA 106 0R6654-00
II 8TC1413 - Up 425 CARB 107 1019288-00
II 8TC1413 - Up 425 CARB 107 0R6662-00
II 2EK1 - Up 425@2000 18 1019257-00
II 2EK1 - Up 425@2000 18 0R6641-00
II 2EK1 - Up 425@1800 21 1019258-00
II 2EK1 - Up 425@1800 21 0R6642-00
II 2EK1 - Up 425@2000 HT 19 1019259-00
II 2EK1 - Up 425@2000 HT 19 0R6643-00
II 2EK1 - Up 425@1800 HT 22 1019260-00
II 2EK1 - Up 425@1800 HT 22 0R6644-00
II.V 8TC1413 - 10980 425 EPA 106 1019301-00
II.V 8TC1413 - 10980 425 EPA 106 0R6654-00
II.V 8TC1413 - Up 425 CARB 107 1019288-00
II.V 8TC1413 - Up 425 CARB 107 0R6662-00
II.V 2EK1 - Up 425@2000 18 1019257-00
II.V 2EK1 - Up 425@2000 18 0R6641-00
II.V 2EK1 - Up 425@1800 21 1019258-00
II.V 2EK1 - Up 425@1800 21 0R6642-00
II.V 2EK1 - Up 425@2000 HT 19 1019259-00
II.V 2EK1 - Up 425@2000 HT 19 0R6643-00
II.V 2EK1 - Up 425@1800 HT 22 1019260-00
II.V 2EK1 - Up 425@1800 HT 22 0R6644-00
III 4CK1 - Up 425@2000 w/o Brksv 18 1457952-00
III 4CK1 - Up 425@2000 w/Brksv 29 1457954-00
III 4CK1 - 10214 425@1800 w/o Brksv 21 1457975-00
III 4CK10215 - Up 425@1800 w/o Brksv 21 1457971-00
III 4CK1 - 9352 425@2000 HT w/o Brksv 19 1457958-00
III 4CK9353 - Up 425@2000 HT w/o Brksv 19 1457956-00
III 4CK1 - 9352 425@2000 HT w/Brksv 30 1457962-00
III 4CK9353 - Up 425@2000 HT w/Brksv 30 1457960-00
III 4CK1 - 13151 425@1800 HT w/o Brksv 22 1457967-00
III 4CK13151 - Up 425@1800 HT w/o Brksv 22 1457965-00
III 4CK1 - Up 425@1800 HT w/Brksv 31 1457969-00
II 5YG1 - Up 460@1900 110 1019289-00
II 5YG1 - Up 460@1900 110 0R6663-00
II 2EK1 - Up 460@1900 110 1019261-00
II 2EK1 - Up 460@1900 110 0R6645-00
II.V 2EK1 - Up 460@1900 110 1019261-00
II.V 2EK1 - Up 460@1900 110 0R6645-00
III 4CK1 - Up 460@1900 w/o Brksv 20 1458002-00
III 4CK1 - Up 460@1900 w/Brksv 32 1458004-00
**************** METAL TURB0 WHEEL ONLY **************************
III 4CK1 - Up 460@1900 w/o Brksv 20 1457978-00
III 4CK1 - Up 460@1900 w/Brksv 32 1457980-00
3406E FLASH File Cross Reference - Updated 09/28/95
3406E FLASH FILE CROSS REFERENCE
Updated September 28,1995
Serial No. Flash Service Release
Description Range Part No. Replacement IC Date
310 HP 1150 PT 5EK00001 & 129-0227 129-0232 33 AUG95
UP
310 HP 1250 PT 5EK00001 & 129-0236 129-0238 34 AUG95
UP
310 HP 1150/1350PT 5EK00001 & 129-0239 129-0241 35 AUG95
MULTI-TORQUE UP
330HP 1350 PT 5EK00001 129-0242 129-0244 36 AUG95
UP
355 HP 1350 PT 5EK00001 - 120-4032 120-4034 6 JAN95
5EK01820
355 HP 1350 PT 5EK01821 & 129-0160 129-0162 22 AUG95
UP
355 HP 1350/1450PT 5EK00001 - 120-4029 120-4031 7 JAN95
MULTI-TORQUE 5EK01820
355 HP 1350/1450PT 5EK01821 & 129-0163 129-0171 23 AUG95
MULTI-TORQUE UP
375 HP 1450 PT 5EK00001 - 120-4023 120-4025 4 JAN95
5EK01820
375 HP 1450 PT 5EK01821 & 129-0172 129-0174 20 AUG95
UP
375 HP 1450/1550PT 5EK00001 - 120-4047 120-4049 10 JAN95
375 HP 1450/1550PT 5EK01821 - 129-0175 129-0177 21 AUG95
MULTI-TORQUE UP
410 HP 1450 PT 5EK00001 & 129-0203 129-0205 19 AUG95
UP
410 HP 1450 PT 5EK00001 & 129-0206 129-0210 29 AUG95
BRAKESAVER UP
410 HP 1550 PT 5EK00001 & 129-0211 129-0213 30 AUG95
UP
410 HP 1550 PT 5EK00001 & 129-0214 129-0216 31 AUG95
BRAKESAVER UP
435 HP 1450 PT 5EK00549 - 120-4038 120-4040 11 JAN95
5EK01184
435 HP 1550 PT 5EK00549 - 120-4035 120-4037 12 JAN95
5EK01184
435 HP 1550 PT 5EK01185 - 126-4361 126-4363 17 JUN95
5EK53003
435 HP 1550 PT 5EK53004 & 129-0251 129-0253 43 AUG95
UP
435 HP 1550 PT 5EK01185 - 126-4364 126-4366 18 JUN95
BRAKESAVER 5EK53003
435 HP 1550 PT 5EK53004 & 129-0254 129-0256 44 AUG95
BRAKESAVER UP
435 HP 1650 PT 5EK00001 - 120-4020 120-4022 3 JAN95
5EK00548
435 HP 1650 PT 5EK00549 - 120-4044 120-4046 13 JAN95
5EK01184
435 HP 1650 PT 5EK01185 - 126-4368 126-4373 15 JUN95
5EK53003
435 HP 1650 PT 5EK53004 & 129-0257 129-0259 45 AUG95
UP
435 HP 1650 PT 5EK00001 - 120-4026 120-4028 5 JAN95
BRAKESAVER 5EK00548
435 HP 1650 PT 5EK00549 - 120-4041 120-4043 14 JAN95
BRAKESAVER 5EK01184
435 HP 1650 PT 5EK01185 - 126-4375 126-4377 16 JUN95
BRAKESAVER 5EK53003
435 HP 1650 PT 5EK53004 & 129-0261 129-0263 46 AUG95
BRAKDSAVER UP
********* 435HP 1650 PT HIGH RPM PERFORANCE -- FLASH ONLY ***********
435 HP 1650 PT 5EK01185 - 125-3230 15 JUN95
5EK53003
435 HP 1650 PT 5EK01185 - 125-3237 16 JUN95
BRAKESAVER 5EK53003
435 HP 1650 PT 5EK53004 & 129-2595 45 AUG95
UP
435 HP 1650 PT 5EK53004 & 129-2598 46 AUG95
BRAKESAVER UP
455 HP 1650 PT 5EK00001 - 126-4444 126-4446 27 JUN95
5EK53003
455 HP 1650 PT 5EK53004 & 129-0265 129-0269 47 AUG95
UP
455 HP 1650 PT 5EK00001 - 126-4447 126-4449 28 JUN95
BRAKESAVER 5EK53003
455 HP 1650 PT 5EK53004 & 129-0271 129-0276 48 AUG95
BRAKESAVER UP
********* 455HP 1650 PT HIGH RPM PERFORANCE -- FLASH ONLY ***********
455 HP 1650 PT 5EK00001 - 130-8365 27 AUG95
5EK53003
455 HP 1650 PT 5EK00001 & 130-8367 28 AUG95
BRAKESAVER UP
475 HP 1650 PT 5EK00001 & 129-0178 129-0181 8 AUG95
UP
475 HP 1650 PT 5EK00001 & 129-0183 129-0186 24 AUG95
BRAKESAVER UP
475 HP 1750 PT 5EK00001 & 129-0189 129-0192 25 AUG95
UP
475 HP 1750 PT 5EK00001 & 129-0193 129-0196 26 AUG95
BRAKESAVER UP
********* 475HP 1750 PT HIGH RPM PERFORANCE -- FLASH ONLY ***********
475 HP 1750 PT 5EK00001 & 128-6848 25 JUN95
UP
475 HP 1750 PT 5EK00001 & 128-6851 26 JUN95
BRAKESAVER UP
500 1850 PT 5EK00001 & 129-0217 129-0219 9 AUG95
UP
500 HP 1850 PT 5EK00001 & 129-0220 129-0224 32 AUG95
BRAKESAVER UP
********* 500 HP 1850 PT HIGH RPM PERFORANCE -- FLASH ONLY ***********
500 HP 1850 PT 5EK00001 & 126-3887 9 JUN95
UP
500 HP 1850 PT 5EK00001 & 128-6569 32 JUN95
BRAKESAVER UP
****** September Availability ***************************************
550 HP 1850 PT 5EK00001 & 126-8385 126-8387 41 AUG95
UP
550 HP 1850 PT 5EK00001 & 126-9517 126-9519 42 AUG95
BRAKESAVER UP
OIL WELL SERVICE
435/500 HP 5EK01185 & 126-4486 126-4488 38 JUN95
1550/1650 PT UP
3406E LOW NOX KIT FLASH FIILE CROSS REFERENCE
Updated February 21, 2001
Note: The LOW NOx FLASH files each have an interlock code which has been
with an interlock code of 333, replaces the DEC98 PSO FLASH file 170-8128,
which had an interlock code of 33.
ENGINE RATING/ SERIAL NO. FLASH RELEASE
APPLICATION INFORMATION RANGE FILE IC DATE
310 HP 1150 PT 5EK05767 & UP 185-1177 333 DEC99
6TS00001 & UP
310 HP 1250 PT 5EK05767 & UP 185-1178 334 DEC99
6TS00001 & UP
310 HP 5EK05767 & UP 185-1179 335 DEC99
1150/1350@1200 6TS00001 & UP
330 HP 1350 PT 5EK05767 & UP 185-1180 336 DEC99
6TS00001 & UP
355 HP 1350 PT 5EK05767 & UP 185-1181 322 DEC99
(Still used on steel pistons) 6TS00001 & UP
355 HP 1350 PT 208.5 Fan On 5EK05767 & UP 185-1182 322 DEC99
355 HP 1350@1200 5EK05767-80006 185-1181 322 DEC99
Aluminum pistons (was 170-8174)
355 HP 1350 PT 208.5 Fan On 5EK05767-80006 185-1182 322 DEC99
Aluminum pistons (was 170-8175)
355 HP 1350/1450PT MULTI-TORQUE 5EK05767 & UP 185-1183 323 DEC99
355 HP 1350/1450PT MULTI-TORQUE 5EK05767 & UP 185-1184 323 DEC99
208.5 Fan On 6TS00001 & UP
355 HP 1350/1450 PT MULTI-TORQUE 5EK05767-80006 185-1184 323 DEC99
Aluminum Pistons (was 170-8173)
208.5 Fan On Aluminum Pistons
(was 170-8182)
375 HP 1450 PT 5EK05767 & UP 185-1186 355 DEC99
PAN WESTERN SPECIAL 6TS00001 & UP
375 HP 1450@1200 Aluminum pistons 5EK05767-80006 185-1185 320 DEC99
(was 170-8177)
375 HP 1450 PT 5EK05767 & UP 185-1185 320 DEC99
375HP 1450@1200 Multi-Torque 5EK05767-80006 185-1187 321 DEC99
Aluminum pistons (was 170-8111)
375 HP 1450/1550PT MULTI-TORQUE 5EK05767 & UP 185-1187 321 DEC99
375/435 HP MULTI-TORQUE 5EK67193 & UP 186-9901 367 DEC99
6TS00001 & UP
375/435 HP 1450/1650 5EK67193 & UP 186-9903 381 DEC99
Top Gear Only Multi-Torque 6TS00001 & UP
375/435 HP 1450/1650 PT 5EK67193 & UP 186-9902 428 DEC99
410 HP 1450@1200 Aluminum pistons 5EK05767-67192 185-1188 319 DEC99
(was 170-8176)
410 HP 1450 PT 5EK05767-67192 185-1188 319 DEC99
410 HP Brakesaver 1450@1200 5EK05767-67192 185-1189 329 DEC99
Aluminum pistons (was 170-8179)
410 HP 1450 PT BRAKESAVER 5EK05767-67192 185-1189 329 DEC99
410 HP 1550@1200 Aluminum pistons 5EK05767-67192 185-1190 330 DEC99
(was 170-8180)
410 HP 1550 PT 5EK05767-67192 185-1190 330 DEC99
410 HP Brakesaver 1550@1200 5EK05767-67192 185-1191 331 DEC99
Aluminum pistons (was 170-8181)
410 HP 1550 PT BRAKESAVER 5EK05767-67192 185-1191 331 DEC99
(Still used for steel pistons)
410 HP 1450/1550@1200 5EK67192&80006 186-9904 368 DEC99
Aluminum pistons (was 170-8183)
410 HP 1450/1550 5EK67193 & UP 186-9904 368 DEC99
410 HP Brakesaver 1450/1550@1200 5EK67193-80006 186-9905 369 DEC99
Aluminum pistons (was 170-8184)
410 HP 1450/1550 BRAKESAVER 5EK67193 & UP 186-9905 369 DEC99
ALLISION AUTO TRANSMISSION:
435 HP 1450 PT 5EK75900 & UP 186-9908 377 DEC99
6TS00001 & UP
435 HP 1550 PT 5EK05767-53003 185-1192 317 DEC99
435 HP 1550 PT 5EK53004-67192 185-1198 343 DEC99
435 HP 1550 PT BRAKESAVER 5EK05767-53003 185-1193 318 DEC99
435 HP 1550 PT BRAKESAVER 5EK53004-67192 185-1199 344 DEC99
435 HP 1650 PT 5EK05767-53003 185-1194 315 DEC99
435 HP 1650 PT 5EK53004-67192 185-1200 345 DEC99
435 HP 1550/1650 @ 1800/2100 5EK67193 & UP 186-9906 359 DEC99
6TS00001 & UP
435 HP 1650 PT BRAKESAVER 5EK05767-53003 185-1195 316 DEC99
435 HP 1650 PT BRAKESAVER 5EK53004-67192 185-1201 346 DEC99
435 HP 1550/1650 @ 1800/2100 5EK67193 & UP 186-9907 360 DEC99
BRAKESAVER 6TS00001 & UP
435@1800 Dual HP for PTO 5EK67193 & UP 185-1204 338 DEC99
500@2100 or 435@2100 6TS00001 & UP
435HP 1650 PT HIGH RPM PERFORMANCE - FIELD UPRATE ONLY, FLASH ONLY:
435 HP 1650 PT 5EK05767-53003 185-1196 315 DEC99
435 HP 1650 PT BRAKESAVER 5EK05767-53003 185-1197 316 DEC99
435 HP 1650 PT 5EK53004-67192 185-1202 345 DEC99
435 HP 1650 PT BRAKESAVER 5EK53004-67192 185-1203 346 DEC99
455 HP 1650 PT 5EK05767-53003 185-1205 327 DEC99
455 HP 1650 PT 5EK53004-67192 185-1209 347 DEC99
455 HP 1650 PT 5EK67193 & UP 186-9910 357 DEC99
@ 1800/2100 6TS00001 & UP
455 HP 1650 PT BRAKESAVER 5EK05767-53003 185-1206 328 DEC99
455 HP 1650 PT BRAKESAVER 5EK53004-67192 185-1210 348 DEC99
455 HP 1650 PT @ 1800/2100 5EK67193 & UP 186-9911 358 DEC99
455 MT 1550/1750 5EK67193 & UP 186-9912 379 DEC99
6TS00001 & UP
455 MT (BS) 5EK67193 & UP 186-9913 380 DEC99
1550/1750 PT 6TS00001 & UP
455HP 1650 PT HIGH RPM PERFORMANCE - FIELD UPRATE ONLY, FLASH ONLY:
455 HP 1650 PT 5EK05767-53003 185-1207 327 DEC99
455 HP 1650 PT BRAKESAVER 5EK05767-53003 185-1208 328 DEC99
455 HP 1650 PT 5EK53004-67193 185-1211 347 DEC99
455 HP 1650 PT BRAKESAVER 5EK53004-67193 185-1212 348 DEC99
475 HP 1650 PT 5EK05767-67192 185-1213 308 DEC99
475 HP 1650 PT BRAKESAVER 5EK05767-67192 185-1214 324 DEC99
475 HP 1750 PT 5EK05767-67192 185-1215 325 DEC99
475 HP 1750 PT BRAKESAVER 5EK05767-67192 185-1216 326 DEC99
475 HP 1650/1750 @ 1800/2100 5EK67193 & UP 186-9914 350 DEC99
6TS00001 & UP
475 HP 1650/1750 @ 1800/2100 5EK67193 & UP 186-9915 351 DEC99
475HP 1750 PT HIGH RPM PERFORMANCE - FIELD UPRATE ONLY, FLASH ONLY:
475 HP 1750 PT 5EK05767-67192 185-1217 325 DEC99
475 HP 1750 PT BRAKESAVER 5EK05767-67192 185-1218 326 DEC99
475/500 HP 1650/1850 PT 5EK67193 & UP 186-9918 382 DEC99
MULTI-TORQUE 6TS00001 & UP
475/500 HP 1650/1850 PT 5EK67193 & UP 186-9919 383 DEC99
MULTI-TORQUE BRAKESAVER 6TS00001 & UP
475/500 HP 1650/1750 5EK67193 & UP 186-9916 436 DEC99
TOP TWO GEARS ONLY MULTI-TORQUE 6TS00001 & UP
FIELD UPRATE ONLY
475/500 HP 1650/1750 BRAKESAVER 5EK67193 & UP 186-9917 437 DEC99
FIELD UPRATE ONLY
500 HP 1450 PT MOTORHOME 5EK67193 & UP 186-9920 354 DEC99
6TS00001 & UP
500 HP 1650 PT 5EK67193 & UP 204-3504 474 FEB01
6TS00001 & UP
500 HP 1750 @ 1200 BRAKESAVER 5EK67193 & UP 186-9923 395 DEC99
FLEET RATING 6TS00001 & UP
WARNING: ONCE THIS IS FLASHED THE INTERLOCK IS FROZEN AND CANNOT BE CHANGED
500 HP 1750 @ 1200 5EK67193 & UP 186-9922 394 DEC99
500 1850 PT 5EK05767-67192 185-1219 309 DEC99
500 1850 PT @ 1800/2100 5EK67193 & UP 186-9924 361 DEC99
6TS00001 & UP
500 1850 PT @ 1800/2100 5EK67193 & UP 185-1225 432 DEC99
2300RPM TEL FIELD UPRATE ONLY 6TS00001 & UP
500 HP 1850 PT BRAKESAVER 5EK05767-67192 185-1220 332 DEC99
500 HP 1850 PT @ 1800/2100 5EK67193 & UP 186-9925 362 DEC99
500 HP 1850 PT @ 1800/2100 BRKSVR 5EK67193 & UP 185-1226 433 DEC99
500 HP 1850 PT HIGH RPM PERFORMANCE - FIELD UPRATE ONLY, FLASH ONLY:
500 HP 1850 PT 5EK05767-67192 185-1221 309 DEC99
500 HP 1850 PT BRAKESAVER 5EK05767-67192 185-1222 332 DEC99
550 HP 1850 PT @ 2100 5EK05767 & UP 185-1223 341 DEC99
6TS00001 & UP
550 HP 1850 PT @ 2100 5EK67193 & UP 186-9926 434 DEC99
550 HP 1850 PT @ 2100 5EK05767 & UP 185-1224 342 DEC99
550 HP 1850 PT @ 2100 BRKSVR 5EK67193 & UP 186-9927 435 DEC99
OIL WELL SERVICE (OWS)
435/500 HP 1550/1650 PT OWS 5EK05767 & UP 185-1204 338 DEC99
435/500 HP OWS 5EK05767 & UP 186-9909 376 DEC99
355 HP 1350PT 1800/2100 1LW00001 & UP 192-5311 399 APR00
355 HP MULTI-TORQUE 1350/1450 1LW00001 & UP 192-5312 401 APR00
1800/2100
375 HP 1450PT 1800/2100 1LW00001 & UP 192-5313 405 APR00
375 HP MULTI-TORQUE 1450/1550 1LW00001 & UP 192-5314 406 APR00
1800/2100
375/435 HP MULTI-TORQUE 1LW00001 & UP 192-5315 409 APR00
1450/1550 PT 1800
1450/1650 PT 1800
375/435 HP 1450/1550 PT 1800 RPM 1LW00001 & UP 192-5316 459 APR00
FIELD UPRATE ONLY
375/435 HP 1450/1650PT 1LW00001 & UP 192-5317 410 APR00
1800 MULTI-TORQUE IN
TOP GEAR ONLY (ROCKWELL)
410 HP FIELD UPRATE ONLY 1LW00001 & UP 192-5318 407 APR00
435 HP 1550/1650PT 1800/2100 1LW00001 & UP 192-5320 411 APR00
435 HP 1550/1650PT 1LW00001 & UP 192-5321 412 APR00
1800/2100 BRAKESAVER
450 HP 1550/1650PT 2100 1LW00001 & UP 192-5319 452 APR00
(FIELD UPRATE ONLY FOR 410HP & BELOW)
455 HP 1550PT 2100 1LW00001 & UP 192-5322 438 APR00
455 HP 1550 PT 1LW00001 & UP 192-5323 439 APR00
2100 BRAKESAVER
455 HP 1650PT 1800/2100 1LW00001 & UP 192-5324 413 APR00
455 HP 1650PT 1800/2100 1LW00001 & UP 192-5325 414 APR00
BRAKESAVER
455 HP MULTI-TORQUE 1LW00001 & UP 192-5326 415 APR00
1550/1750PT 2100
455 HP MULTI-TORQUE 1LW00001 & UP 192-5327 416 APR00
1550/1750PT 2100 BRAKESAVER
475 HP 1650/1750PT 1800/2100 1LW00001 & UP 192-5328 419 APR00
475 HP 1650/1750PT 1LW00001 & UP 192-5329 420 APR00
475/500 HP 1650/1750PT 2100 RPM 1LW00001 & UP 192-5330 455 APR00
FIELD UPRATE ONLY
475/500 HP 1650/1750PT 2100 RPM 1LW00001 & UP 192-5331 456 APR00
BRAKESAVER FIELD UPRATE ONLY
475/500 HP 1650/1850PT 2100 RPM 1LW00001 & UP 192-5332 417 APR00
MULTI-TORQUE TOP 2 GEARS ONLY
475/500 HP 1650/1850PT 2100 RPM 1LW00001 & UP 192-5333 418 APR00
BRAKESAVER
500 HP 1650PT 2100 RPM 1LW00001 & UP 192-5334 462 APR00
500 HP FLEET 1750PT 2100 RPM 1LW00001 & UP 192-5335 425 APR00
WARNING: ONCE FLASHED THE INTERLOCK IS FROZEN AND CANNOT BE CHANGED
500 HP FLEET 1750PT 2100 RPM 1LW00001 & UP 192-5336 426 APR00
BRAKESAVER
500 HP 1850PT 1800/2100 1LW00001 & UP 192-5337 421 APR00
500 HP 1850PT 1800/2100 1LW00001 & UP 192-5339 441 APR00
500 HP 1850PT 1800/2100 1LW00001 & UP 192-5338 422 APR00
BRAKESAVER
500 HP 1850PT 1800/2100 BRAKESAVER 1LW00001 & UP 192-5340 442 APR00
550 HP 1850PT 2100 RPM 1LW00001 & UP 192-5341 423 APR00
550 HP 1850PT 2100 RPM 1LW00001 & UP 192-5343 443 APR00
550 HP 1850PT 2100 RPM BRAKESAVER 1LW00001 & UP 192-5342 424 APR00
550 HP 1850PT 2100 RPM BRAKESAVER 1LW00001 & UP 192-5344 444 APR00
F 3406E/3456/C15/C16/C18 FLASH FILE CROSS REFERENCE
Updated January 15, 2008 ajk
This file covers 3406E Truck engines (5DS/2WS/1LW/1MM), and 3406E/3456/C15/C18
Commercial/Machine applications.
NOTE:
Most of the original flash files for 5EK/6TS/1LW 3406E engines have been
removed from SIS Web. They have been replace by Low NOx files. See the
Low NOx files text.
WARNING!!!
9CK1 - 5000 and 5EK1 - 5000 can NOT be flashed with NOV95 software. The
Flash program may terminate at 20 to 25% complete when attempting to flash
these personality modules with NOV95 software.
be flashed with NOV95 software because the original personality module
was replaced with a compatible REMAN product during an earlier software update or
programming.
before programming it, a failure while flashing the personality module
in the affected range will render the engine inoperable. Once this
occurs, there are two options; 1) replace the personality module with a
106-9184 module and re-flash or 2) flash the original personality module
with pre-NOV95 software.
the Caterpillar mailbox for downloading. They are listed under the title
"3406E FLASH File Cross Reference - Updated 09/28/95".
355 HP 1350 PT 5EK00001-01820 170-8096 6 DEC98
355 HP 1450@1200 Multi-Torque 5EK00001-01820 170-8185 7 DEC98
Aluminum pistons
355 HP 1350/1450PT MULTI-TORQUE 5EK00001-01820 170-8097 7 DEC98
375 HP 1450 PT 5EK00001-01820 170-8098 4 DEC98
375 HP 1450/1550PT MULTI-TORQUE 5EK00001-01820 170-8099 10 DEC98
435 HP 1450 PT 5EK00549-01184 170-8102 11 DEC98
435 HP 1550 PT 5EK00549-01184 170-8103 12 DEC98
435 HP 1650 PT 5EK00001-00548 170-8100 3 DEC98
435 HP 1650 PT 5EK00549-01184 170-8104 13 DEC98
575 HP 1850PT 2100 RPM 5DS00324 & UP 170-8228 167 DEC98
For use with 159-8542 or 0R-7275 Turbo Group
575 HP 1850PT 2100 RPM BRAKESAVER 5DS00324 & UP 170-8229 168 DEC98
600 HP 2050PT 2100 RPM 5DS00001-00323 170-8230 96 DEC98
For use with 138-3200 or 0R-7176 Turbo Group
600 HP 2050PT 2100 RPM 5DS00324 & UP 170-8232 160 DEC98
600 HP 2050PT 2100 RPM 5DS00001-00323 170-8238 145 DEC98
600 HP 2050PT 2100 RPM BRAKESAVER 5DS00001-00323 170-8231 97 DEC98
600 HP 2050PT 2100 RPM BRAKESAVER 5DS00324 & UP 170-8233 161 DEC98
600 HP 2050PT 2100 RPM BRAKESAVER 5DS00001-00323 170-8239 146 DEC98
600 HP 2050PT 2100 RPM 5DS00324 & UP 170-8240 170 DEC98
600 HP 2050PT 2100 RPM BRAKESAVER 5DS00324 & UP 177-0097 171 DEC98
14 LITER Lo-HP 2WS ENGINE SERIAL NO. FLASH RELEASE
RATING INFORMATION RANGE FILE IC DATE
355HP 1350PT 1800/2100RPM 2WS00001 & UP 215-7824 14 MAR02
355HP MT 1350/1450PT 1800 RPM 2WS00001 & UP 215-7825 15 MAR02
375HP 1450PT 1800/2100RPM 2WS00001 & UP 215-7826 16 MAR02
375/435HP MT 1450/1550PT 1800PRM 2WS00001 & UP 215-7828 9 MAR02
375HP MT 1450/1550PT 1800RPM 2WS00001 & UP 215-7826 17 MAR02
1450/1550PT 2100RPM
375/435HP 1450/1550PT 1800 RPM 2WS00001 & UP 215-7829 19 MAR02
375/435HP 1450/1650PT 1800 RPM 2WS00001 & UP 215-7830 20 MAR02
TOP 1 GEAR MULTITORQUE
410HP 1450/1550PT 1800/2100RPM 2WS00001 & UP 215-7831 21 MAR02
FIELD UPRATE ONLY
450HP 1550/1650PT 2100RPM 2WS00001 & UP 215-7834 22 MAR02
FIELD UPRATE ONLY
14 LITER Hi-HP 2WS ENGINE SERIAL NO. FLASH RELEASE
435HP 1550/1650PT 1800/2100RPM 2WS00001 & UP 215-7832 23 MAR02
435HP 1550/1650PT 1800/2100RPM 2WS00001 & UP 215-7833 24 MAR02
BRAKESAVER
435/500HP 1550/1650 2100RPM 2WS00001 & UP 215-7846 61 MAR02
MULTITORQUE
455HP 1550PT 2100RPM OR 2WS00001 & UP 215-7835 25 MAR02
1650PT 1800/2100RPM
455HP 1550PT 2100RPM OR 2WS00001 & UP 215-7836 26 MAR02
455HP MT 1550/1750PT 2100 RPM 2WS00001 & UP 215-7837 27 MAR02
455HP MT 1550/1750PT 2100 RPM 2WS00001 & UP 215-7838 28 MAR02
BRAKESAVER
475HP 1650/1750PT 1800/2100RPM 2WS00001 & UP 270-7080 2 APR05
REPLACED 251-2224
475HP 1650/1750PT 1800/2100RPM 2WS00001 & UP 270-7079 30 APR05
BRAKESAVER
REPLACED 251-2223
475/500HP 1650/1850PT 2100 RPM 2WS00001 & UP 215-7841 31 MAR02
475/500HP 1650/1850PT 2100 RPM 2WS00001 & UP 215-7842 32 MAR02
475/500HP 1650/1750PT 2100 RPM 2WS00001 & UP 215-7843 33 MAR02
475/500HP 1650/1750PT 2100 RPM 2WS00001 & UP 215-7844 34 MAR02
500HP 1650PT 2100RPM, 2WS00001 & UP 215-7845 35 MAR02
500HP 1650PT 2100RPM BRAKESAVER 2WS00001 & UP 215-7848 36 MAR02
500HP 1850PT 1800/2100RPM 2WS00001 & UP 215-7852 37 MAR02
500HP 1750/1850PT 2100 RPM 2WS00001 & UP 215-7850 39 MAR02
500HP 1750/1850PT 2100 RPM 2WS00001 & UP 215-7851 40 MAR02
500HP 1850PT 1800/2100RPM 2WS00001 & UP 215-7847 59 MAR02
500HP 1850PT 1800/2100RPM 2WS00001 & UP 215-7849 60 MAR02
BRAKESAVER
500HP 1850PT 1800/2100RPM 2WS00001 & UP 215-7853 38 MAR02
550HP 1850PT 2100RPM 2WS00001 & UP 270-7085 41 APR05
REPLACED 251-2229
550HP 1850PT 2100RPM BRAKESAVER 2WS00001 & UP 270-7086 42 APR05
REPLACED 251-2230
550HP 1850PT 2100RPM 2WS00001 & UP 270-7081 43 APR05
REPLACED 251-2225
550HP 1850PT 2100RPM BRAKESAVER 2WS00001 & UP 270-7082 44 APR05
REPLACED 251-2226
16 LITER 1MM ENGINE SERIAL NO. FLASH RELEASE
575HP 1850PT 2100RPM 1MM00001 & UP 215-7858 45 MAR02
575HP 1850PT 2100RPM BRAKESAVER 1MM00001 & UP 215-7859 46 MAR02
575HP 1850PT 2100RPM 1MM00001 & UP 215-7861 47 MAR02
575HP 1850PT 2100RPM BRAKESAVER 1MM00001 & UP 215-7860 48 MAR02
575/600HP MT 1850/2050PT 2100RPM 1MM00001 & UP 215-7862 49 MAR02
575/600HP MT 1850/2050PT 2100RPM 1MM00001 & UP 215-7863 50 MAR02
BRAKESAVER
600HP 2050PT 2100RPM 1MM00001 & UP 270-7083 4 APR05
REPLACED 215-7864,237-0693,
241-0808,251-2227
600HP 2050PT 2100RPM BRAKESAVER 1MM00001 & UP 270-7084 52 APR05
REPLACED 215-7865,237-0694,
241-0809,251-2228
600HP 2050PT 2100RPM 1MM00001 & UP 270-7087 53 APR05
REPLACED 215-7866,237-0697,241-0812,251-2231
600HP 2050PT 2100RPM BRAKESAVER 1MM00001 & UP 270-7088 54 APR05
REPLACED 215-7867,237-0698,
241-0813,251-2232
Heavy-Duty Ratings for October 2002-up Engines
The boxes shown below indicate unique ratings families.
Ratings within these boxes share common iron sets and
can be rerated to another rating within the same box.
Ratings changes are only allowed within a particular box.
All ratings are subject to change without notice.
Adv HP Max. HP Peak Torque Gov Speed
*C-10 (10.3L MBJ) *
*305 315 1050 2100 *
*335 350 1250 2100 *
*C-12 (11.9L MBL) *
*355 370 1350 2100 *
*380 395 1450 2100 *
*410 425 1450 2100 *
*355/410 415 1350/1450 2100 *
*335 420 1550 2100 *
*410 425 1550 2100 *
*430 445 1550 2100 *
*380/430 445 1450/1550 2100 *
*430 445 1650 2100 *
*380/430 445 1450/1650 2100 *
*425 425 1550 2100 Firetruck/RV only*
*455 455 1550 2100 Firetruck/RV only*
*505 505 1550 2100 RV only *
*C-15 (14.6L MBN) *
*435 450 1550 2100 Brakesaver avail. *
*435 450 1650 2100 Brakesaver avail. *
*475 490 1650 2100 Brakesaver avail. *
*500 515 1650 2100 Field rerate only *
*435/500 515 1550/1650 2100 *
*435/500 515 1550/1650 2100 Oil well service *
*475 490 1750 2100 Brakesaver avail. *
*500 515 1850 2100 Brakesaver avail. *
*525 525 1850 2100 Brakesaver avail. *
*450/515 515 1550/1650 2100 RV only *
* C-18 (MDP / MEP) *
*625 2049 1900 *
*700 1900 1900 *
The 1500 lb.ft. low torque C-15 has been removed from our lineup. Also,
the C-15 515hp (RV only) rating has been changed to a MultiTorque. As
stated on the top of the chart, ratings changes are only allowed within
a particular box. All ratings are subject to change without notice.
FLASHFILES
C-10 GOV SERIAL NO. FLASH P/M RELEASE
HORSEPOWER TORQUE SPEED RANGE FILE CODE DATE
305 HP 1050 LB-FT 2100 RPM MBJ00001-UP 242-8336 220 AUG03
Replaced 228-8022, 235-1371 (old code 210)
335 HP 1250 LB-FT 2100 RPM MBJ00001-UP 272-6461 221 MAR05
Replaced 228-8023,235-1372,
242-8337 (old code 211)
335 HP 1250 LB-FT 2100 RPM MBJ00001-UP 242-8338 225 AUG03
Replaced 228-8024, 235-1373 Haliburton IAS (old code 215)
C-12 MBL00001-00999 Parts Service Only
355 HP 1350 LB-FT 2100 RPM MBL1-00999 239-5968 241 Jun03
REFERENCE 224-3448 IC 201
Replaced 232-3985
355/410 HP 1350/1450 LB-FT 2100 RPM MBL1-00999 239-5967 244 Jun03
MULTITORQUE REFERENCE 224-3449 IC 204
Replaced 232-3986
380 HP 1450 LB-FT 2100 RPM MBL1-00999 239-5966 242 Jun03
REFERENCE 224-3450 IC 202
Replaced 232-3987
410 HP 1450 LB-FT 2100 RPM MBL1-00999 239-5964 246 Jun03
REFERENCE 224-3452 IC 206
Replaced 232-3989
335 HP 1550 LB-FT 2100 RPM MBL1-00999 239-5969 240 Jun03
REFERENCE 224-3447 IC 200
Replaced 232-3984
380/430 HP 1450/1550 LB-FT 2100 RPM MBL1-00999 239-5965 248 Jun03
1450/1650 LB-FT
MULTITORQUE REFERENCE 224-3451 IC 208
Replaced 232-3988
410 HP 1550 LB-FT 2100 RPM MBL1-00999 239-5963 247 Jun03
REFERENCE 224-5869 IC 207
Replaced 232-3990
430 HP 1550/1650 LB-FT 2100 RPM MBL1-00999 239-5962 249 Jun03
REFERENCE 216-5006 & 224-3453 IC 209
Replaced 232-3991
C-12 MBL01000-up
355 HP 1350 LB-FT 2100 RPM MBL01000-UP 236-8686 221 May03
REPLACED 228-8027, 231-9235,235-1375
355/410 HP 1350/1450 LB-FT 2100 RPM MBL01000-UP 236-8687 224 May03
MULTITORQUE REPLACED 228-8028, 231-9236, 235-1377
380 HP 1450 LB-FT 2100 RPM MBL01000-UP 241-8404 222 Jul03
REPLACED 228-8029, 231-9237, 235-1738, 236-8688
410 HP 1450 LB-FT 2100 RPM MBL01000-UP 241-8403 226 Jul03
REPLACED 228-8031,231-9240,235-1381,236-8691
335 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6464 220 MAR05
REPLACED 228-8026,231-9234,
235-1374,236-8685
380/430 HP 1450/1550 LB-FT 2100 RPM MBL01000-UP 272-6465 235 MAR05
MULTITORQUE
REPLACED 228-8059,231-9238,
235-1379,236-8689
410 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6467 227 MAR05
REPLACED 228-8032,231-9241,
235-1382,236-8692
410 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6468 233 MAR05
Haliburton
REPLACED 228-8033,231-9242,
235-1383,236-8693
430 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6470 237 MAR05
REPLACED 228-8035,231-9244,
235-1385,236-8695
380/430 HP 1450/1650 LB-FT 2100 RPM MBL01000-UP 272-6466 236 MAR05
MULTITORQUE
REPLACED 228-8030,231-9239,
235-1380,236-8690
430 HP 1650 LB-FT 2100 RPM MBL01000-UP 272-6471 238 MAR05
REPLACED 229-1634,231-9245,
235-1386,236-8696
430 HP 1650 LB-FT 2100 RPM MBL01000-UP 272-6472 232 MAR05
Haliburton IAS
REPLACED 228-8036,231-9246,
235-1387,236-8697
425 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6469 234 MAR05
Firetruck & RV only
REPLACED 228-8034,231-9243,
235-1384,236-8694
455 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6473 260 MAR05
Firetrk/RV only (old code 230)
REPLACED 228-8037,231-9247,235-1380,
236-8698,242-8339
505 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6474 261 MAR05
RV only (old code 231)
REPLACED 228-8038,231-9248,
235-1389,236-8699,242-8340
450/515 HP 1550/1650 LB-FT 2100 RPM MBL00001-UP 272-6613 210 MAR05
MULTITORQUE/RV ONLY
REPLACED 228-8058,231-9253,
234-7584,236-8704
C-15
435 HP 1550/1650 LB-FT 2100 RPM MBN00001-UP 272-6609 206 MAR05
REPLACED 228-8040,231-9249,
234-7580,236-8700
435 HP 1550/1650 LB-FT 2100 RPM MBN00001-UP 272-6610 207 MAR05
BRAKESAVER
REPLACED 228-8041,231-9250,
234-7581,236-8701
435/500 HP 1550/1650 LB-FT 2100 RPM MBN00001-UP 272-6611 208 MAR05
MULTITORQUE
REPLACED 228-8042,231-9251,
234-7582,236-8702
435/500 HP 1550/1650 LB-FT 2100 RPM MBN00001-UP 272-6612 220 MAR05
MULTITORQUE/ (OWS) OIL WELL SERVICE
REPLACED 228-8043,231-9252,
234-7583,236-8703
475 HP 1650 LB-FT 2100 RPM MBN00001-UP 272-6614 212 MAR05
REPLACED 228-8044,231-9254,
234-7585,236-8705,251-3753
475 HP 1650 LB-FT 2100 RPM MBN00001-UP 272-6615 214 MAR05
BRAKESAVER
REPLACED 228-8045,231-9255,
234-7586,236-8706
500 HP 1650 LB-FT 2100/2300 RPM MBN00001-UP 272-6618 221 MAR05
FIELD UPRATE
REPLACED 228-8049,231-9258,
234-7589,236-8709
475 HP 1750 LB-FT 2100 RPM MBN00001-UP 272-6616 213 MAR05
REPLACED 228-8046,231-9256,
234-7587,236-8707
475 HP 1750 LB-FT 2100 RPM MBN00001-UP 272-6617 215 MAR05
BRAKESAVER
REPLACED 228-8047,231-9257,
234-7588,236-8708
500 HP 1850 LB-FT 2100 RPM MBN00001-UP 272-6619 226 MAR05
REPLACED 228-8050,231-9259,
234-7590,236-8710
500 HP 1850 LB-FT 2100 RPM MBN00001-UP 272-6620 227 MAR05
BRAKESAVER
REPLACED 228-8051,231-9260,
234-7591,236-8711
525 HP 1850 LB-FT 2100 RPM MBN00001-UP 272-6621 228 MAR05
REPLACED 228-8055,231-9261,
234-7592,236-8712
525 HP 1850 LB-FT 2100 RPM MBN00001-UP 272-6622 230 MAR05
BRAKESAVER
REPLACED 228-8056,231-9262,
234-7593,236-8713
525 HP 1850 LB-FT 2100/2300 RPM MBN00001-UP 272-6623 231 MAR05
FIELD UPRATE
REPLACED 228-8052,231-9263,
234-7594,236-8714
525 HP 1850 LB-FT 2100/2300 RPM MBN00001-UP 272-6624 232 MAR05
REPLACED 228-8053,231-9264
234-7595,236-8715
525 HP 1771 LB-FT 2100 RPM MBN00001-UP 268-0221 164 APR05
SNOWBLOWER
REPLACED 251-1628
C-18
625 HP 2049 LB-FT 1900 RPM MDP0001-up MEP0001-UP 268-0224 3 APR05
EURO3
REPLACED 184-8094,231-7596,232-2646,
235-6400,241-0814,251-1625
700 HP 1900 LB-FT 2100 RPM MDP0001-up MEP0001-UP 241-0817 1 JUN03
(UK HETT)
REPLACED 227-5521,232-2647,238-2680,239-4147
700 HP 1900 LB-FT 2100 RPM MDP0001-up MEP0001-UP 232-2648 1 NOV02
(Charmichael)
REPLACED 227-5522
700 HP 2000 RPM HWT-533KW CPD ACERT 318-7276 5 AUG07
UK COMMERCIAL DEFENSE PRODUCT-COLD TEST RATING
REPLACED 289-9686
European On Highway Truck
C-12
325 HP 1250 LB-FT 1900 RPM CPD00276-UP 267-5139 42 DEC04
EURO3
REPLACED 224-7278
380 HP 1400 LB-FT 1900 RPM CPD00276-UP 267-5140 43 DEC04
EURO3
REPLACED 224-7279
380/430 HP 1400/1550 LB-FT 1900 RPM CPD00276-UP 267-5141 44 DEC04
EURO3 M/T
REPLACED 224-7280
430 HP 1550 LB-FT 1900 RPM CPD00276-UP 267-5142 45 DEC04
EURO3
REPLACED 224-7281
C-16
680 HP 1951 LB-FT 2100 RPM 267-5143 162 JAN05
ARFF
REPLACED 251-1626
650 HP 1951 LB-FT 2100 RPM 297-8779 163 JUL06
SNOWBLOWER
REPLACED 251-1629,268-0223
C11/C13/C15 ACERT Flash File Cross Reference
Updated January 27, 2009 dba
On-Highway Truck Engines
NOTE: C11, C13,and C15 files are serial number range specific
FLASHFILES
C11 GOV SERIAL NO. FLASH P/M RELEASE
305 HP 1050 LB-FT 2100 RPM KCA1-1456 291-2050 20 MAR06
Replaced 256-6457,264-6355,270-0317
305 HP 1050 LB-FT 2100 RPM KCA1457-up 305-4391 30 NOV06
RFT Injectors
Replaced 256-5727,262-4382,265-9436,
270-0294,271-2914,291-2016
335 HP 1250 LB-FT 2100 RPM KCA1-01456 291-2051 21 MAR06
Replaced 256-6458,264-6356,270-0318
335 HP 1250 LB-FT 2100 RPM KCA1457-up 305-4392 31 NOV06
RFT Injectors
Replaced 256-5728,262-4383,270-0295,
271-2915,291-2017
335 HP 1250 LB-FT 2100 RPM KCA1-01456 291-2052 24 MAR06
Inlet Air Shutoff
Replaced 256-6461,264-6357,270-0319
335 HP 1250 LB-FT 2100 RPM KCA1457-up 305-4393 34 NOV06
Inlet Air Shutoff
Replaced 256-5731,262-4384,265-9438,
270-0296,271-2916,291-2018
350 HP 1350 LB-FT 2100 RPM KCA1-01456 291-2053 22 MAR06
Replaced 229-4911,249-7596,
251-3555,256-6459,264-6358,270-0321
350 HP 1350 LB-FT 2100 RPM KCA1457-up 305-4394 32 NOV06
RFT Injectors
Replaced 256-5729,262-4385,265-9439,
270-0297,271-2917,291-2019
350 HP 1350 LB-FT 2100 RPM KCA1457-up 305-4395 35 NOV06
Inlet Air Shutoff
Replaced 253-9429,262-4386
265-9440,270-0298,271-2918,291-2020
350HP 1450 lb-ft 2100 RPM KCA1-01456 294-4818 26 MAY06
Replaced 256-6462,264-6359,270-0322,
291-2054
350HP 1450 lb-ft 2100 RPM KCA1457-up 305-4396 36 NOV06
RFT Injectors
Replaced 262-4387,265-9441,270-0299,
271-2919,291-2021
370 HP 1350 LB-FT 2100 RPM KCA1-01456 291-2055 23 MAR06
Replaced 247-1273,249-7597,
251-3556,256-6460,264-6360,270-0323
370 HP 1350 LB-FT 2100 RPM KCA1457-up 305-4397 33 NOV06
RFT Injectors
Replaced 256-5730,262-4388,265-9442,
270-0300,271-2920,291-2022
370HP 1450 lb-ft 2100 RPM KCA1457-up 305-4398 37 NOV06
RFT Injectors
Replaced 262-4389,270-0301,271-2921,
291-2023
C13 GOV SERIAL NO. FLASH P/M RELEASE
335 HP 1550 LB-FT 2100 RPM KCB00508-6811 291-2056 37 MAR06
With factory installed 239-4908 injectors
Replaced 251-4585,256-5323,264-6684
380 HP 1450 LB-FT 2100 RPM KCB00508-5433* 291-2058 31 MAR06
Replaced 251-4580,256-5324,264-6686,
271-2867
380 HP 1400 LB-FT 2100 RPM KCB00508-6811 291-2057 38 MAR06
Replaced 251-4586,264-6685
410 HP 1450 LB-FT 2100 RPM KCB00508-6811 291-2059 32 MAR06
Replaced 251-4581,256-5325,264-6687,
271-2868
410 HP 1450/1550LB-FT M/T 2100 RPM KCB00508-6811 291-2060 46 MAR06
Oil Well Service (OWS)
Replaced 251-4594,264-6688
410 HP 1450/1650LB-FT M/T 2100 RPM KCB00508-6811 291-2061 43 MAR06
Gear Fast/Run Slow (For Eaton Top 2)
Replaced 251-4591,264-6689
410 HP 1450/1650LB-FT M/T 2100 RPM KCB00508-6811 291-2062 44 MAR06
Replaced 251-4592,264-6690
410 HP 1550 LB-FT 2100 RPM KCB00508-6811 291-2063 39 MAR06
Replaced 251-4587,264-6691
410 HP 1550 LB-FT IAS 2100 RPM KCB00508-6811 291-2069 40 MAR06
Inlet Air Shutoff
Replaced 251-4588,264-6692
430 HP 1550 LB-FT 2100 RPM KCB00508-5433* 291-2065 41 MAR06
Replaced 251-4589,264-6693
430 HP 1550 LB-FT 2100 RPM KCB00508-5433* 291-2069 42 MAR06
Inlet Air Shutoff
Replaced 251-4590,264-6697
430 HP 1550/1750LB-FT M/T 2100 RPM KCB00508-5433* 291-2067 45 MAR06
Replaced 245-5999,249-7599,251-4593,264-6695
430 HP 1650 LB-FT 2100 RPM KCB00508-5433* 291-2068 34 MAR06
Replaced 248-0777,249-7609,251-4582,264-6696
430 HP 1550/1750LB-FT MT 2100 RPM KCB00508-5433* 291-2066 35 MAR06
Gear Fast/Run Slow (Eaton 2)
Replaced 248-0776,249-7608,251-4583,264-6694
470 HP 1650 LB-FT 2100 RPM KCB00508-6811 264-6698 47 OCT04
RV RATING
Replaced 245-6000,251-4596
470 HP 1650 LB-FT 2100 RPM KCB6812-UP 262-4539 85 AUG04
RV RATING
With factory installed 249-0708 injectors
Replaced 251-5700,258-7365
525 HP 1650 LB-FT 2100 RPM KCB00508-2076 249-7606 36 DEC03
RV RATING
With factory installed 244-7695 injectors
525 HP 1650 LB-FT 2100 RPM KCB02077-6862 291-2072 51 MAR06
RV RATING
With factory installed 246-7697 injectors
Replaced 244-7695,256-5321,264-6700
525 HP 1650 LB-FT 2100 RPM KCB06863-UP 291-2076 87 MAR06
RV RATING
With factory installed 249-0697 injectors
Replaced 256-5319,264-6702
525 HP 1650 LB-FT 2100 RPM KCB6812-UP 318-9503 96 AUG07
RV RATING
(Only compatible with 259-8418 or 10R2878 turbo installed)
Replaced 262-4542,265-9579,272-3131,
285-3673,291-2048,307-1471
470/455HP 1650/1550LB-FT MT 2100 RPM KCB00508-6811 291-2071 48 MAR06
FT RATING
Replaced 245-0208,251-4597,264-6699
470/455HP 1650/1550LB-FT M/T 2100 RPM KCB6812-UP 262-4540 86 AUG04
FT RATING
Replaced 251-5702
525/455 HP 1650/1550 LB-FT 2100 RPM KCB00508-6862 249-7607 49 DEC03
FT RATING
With factory installed 223-7478, 246-7842 injectors
Replaced 242-8335,245-0210
525/455 HP 1650/1550 LB-FT 2100 RPM KCB00508-6862 291-2073 52 MAR06
FT RATING
With factory installed 246-7843 injectors
Replaced 249-0120,251-4595,
256-5322,264-6701
525/455 HP 1650 LB-FT 2100 RPM KCB00508-6862 291-2077 88 MAR06
FT RATING
Replaced 256-5320,264-6703
525/455 HP 1650/1550 LB-FT 2100 RPM MT KCB6812- UP 318-9504 97 AUG07
FT RATING
Replaced 259-8899,262-4543,265-9580,
272-3132,291-2049,303-8748,307-1472
335 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8821 75 Apr09
Replaced 258-7345,262-4518,265-9556,
272-3110,291-2024,295-1515,303-8722,307-1446,318-9476
335-7791,341-1475
380 HP 1400 LB-FT 2100 RPM KCB5434-UP 335-7792 76 AUG08
Replaced 258-7346,262-4519,265-9557,
272-3111,291-2025,295-1516,303-8723,307-1447,318-9477
380 HP 1450 LB-FT 2100 RPM KCB5434-UP 335-7793 71 AUG08
Replaced 258-7347,262-4520,265-9558,
271-2865,272-3112,291-2026,295-1517,
303-8724,307-1448318-9478
380 HP 1450 LB-FT 2100 RPM KCB5434-UP 335-7794 90 AUG08
Inlet Air Shutoff
Replaced 258-7348,262-4521,265-9559,272-3113,
291-2027,295-1518,303-8725,307-1449,318-9479
410 HP 1450 LB-FT 2100 RPM KCB5434-UP 346-8822 72 Apr09
Replaced 258-7349,262-4522,265-9560,
271-2866,272-3114,291-2028,295-1519,
303-8726,307-1450,318-9480,3357795,341-1479
410 HP 1450/1650LB-FT 2100 RPM KCB5434-UP 346-8825 81 Apr09
Replaced 258-7350,262-4523,265-9562,272-3116,
291-2029,295-1554,303-8727,307-1451,318-9481,
335-7796,341-1480
410 HP 1450/1650LB-FT M/T 2100 RPM KCB5434-UP 346-8826 82 Apr09
Replaced 258-7351,262-4525,265-9563,272-3117,
291-2030,295-1522,303-8729,307-1453,318-9483
335-7798,341-1482
410 HP 1450/1550LB-FT M/T 2100 RPM KCB5434-UP 346-8824 84 Apr09
Oil Well Service file (OWS)
Replaced 258-7352,262-4526,265-9564,272-3118,
291-2031,295-1523,303-8730,307-1454,318-9484,
335-7799,341-1483
410 HP 1450/1550LB-FT M/T 2100 RPM KCB5434-UP 346-8823 98 Apr09
Replaced 262-4524,265-9561,
272-3115,291-2074,295-1521,302-5726,
303-8728,307-1452,318-9482,335-7797,341-1148
410 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8827 77 Apr09
Replaced 251-5692,258-7353
262-4527,265-9565,272-3119,
291-2032,295-1524,303-8731,307-1455,318-9485,
335-7800,341-1484
410 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8828 78 Apr09
Inlet Air Shutoff
Replaced 258-7354
262-4528,265-9566,272-3120,291-2033,
295-1525,303-8732,307-1456,318-9486,
335-7801,341-1485
430 HP 1650 LB-FT 2100 RPM KCB5434-UP 346-8833 73 Apr09
Replaced 258-7359,262-4533,265-9571,
272-3125,291-2038,295-1530,303-8737,307-1461,318-9491,
335-7807, 341-1490
430 HP 1550/1750LB-FT 2100 RPM KCB5434-UP 346-8831 74 Apr09
(Eaton GFRS)
Replaced 258-7357,262-4531,265-9569,272-3123,
291-2036,295-1528,303-8735,307-1459,318-9489
335-7805,341-1488
430 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8829 79 Apr09
Replaced 258-7355,262-4529,265-9567,
271-4488,272-3121,291-2034,295-1526,
303-8733,307-1457,318-9487,335-7802,
341-1486
430 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8830 89 Apr09
Inlet Air Shutoff RFT Injectors
Replaced 258-7356,262-4530,265-9568,272-3122,
291-2035,295-1527,303-8734,307-1458,318-9488,
335-7804,341-1487
430 HP 1650 LB-FT IAS 2100 RPM KCB5434-UP 346-8834 80 Apr09
Inlet Air Shutoff
Replaced 258-7360,262-4534,265-9572,
272-3126,291-2039,295-1531,303-8738,307-1462,318-9492,
335-7808,341-1491
430 HP 1550/1750LB-FT MT 2100 RPM KCB5434-UP 346-8832 83 Apr09
Replaced 258-7358,262-4532,265-9570,
272-3124,291-2037,295-1529,303-8736,307-1460,318-9490,
335-7806,341-1489
455/485HP 1550/1650LB-FT 2100 RPM KCB5434-UP 345-2372 70 May09
M/T Fire Truck
Replaced 265-3168,265-9578,272-3130,
291-2043,295-1535,303-8742,307-1466,318-9496,335-7812,
341-1495
470 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8835 91 Apr09
Replaced 254-1626,258-7361
262-4535,265-9573,272-3127,
291-2040,295-1532,303-8739,307-1463,318-9493,
335-7809,341-1492
470 HP 1650LB-FT 2100 RPM KCB5434-UP 346-8837 94 Apr09
Replaced 262-4538,265-9575,272-3129,
291-2042,295-1534,303-8741,307-1465,318-9495,
335-7811,341-1494
470 HP 1550/1650LB-FT M/T 2100 RPM KCB5434-UP 346-8836 99 Apr09
Replaced 262-9713,265-9574,272-3128,
291-2041,295-1533,303-8740,307-1464,318-9494,
335-7810,341-1493
EURO Rating for use in Europe only - not for North America use
380 HP 2100 RPM MT-283 KW-EURO3 335-7813 66 AUG08
295-1536,303-8743,307-1467,318-9497
430 HP 2100 RPM MT-321 KW-EURO3 335-7814 67 AUG08
295-1537,303-8744,307-1468,318-9498
470 HP 2100 RPM MT-350 KW-EURO3 335-7815 68 AUG08
295-1538,303-8745,307-1469,318-9499
500 HP 2100 RPM MT-373 KW-EURO3 291-2047 69 MAR06
Replaced N/A
380 HP 2100 RPM 283 KW-EURO3 AISO 335-7816 202 AUG08
Replaced 308-3512,318-9500
430 HP 2100 RPM 321 KW-EURO3 AISO 335-7817 203 AUG08
Replaced 308-3514,318-9501
470 HP 2100 RPM 350 KW-EURO3 AISO 335-7818 204 AUG08
Replaced 308-3516,318-9502
C13 GOV FLASH P/M RELEASE
HORSEPOWER TORQUE SPEED FILE CODE DATE
2007 EMISSIONS EURO4 TRUCK
380 HP@2100/2300 RPM EURO4 S3C00001-UP 330-2021 35/135 JUN08
Replaced 295-6886,319-4910
430 HP@2100/2300 RPM EURO4 SC300001-UP 330-2022 36/136 JUN08
Replaced 295-6887,319-4911
470 HP@2100/2300 RPM EURO4 SC300001-UP 330-2023 37/137 JUN08
Replaced 295-6888,319-4912
2007 EMISSIONS ADEM A4 ECM ON HD ACERT HIGHWAY TRUCK
305 HP 1150 LB-FT 2100/2300 RPM LEE00001-UP 365-1126 40/140 Nov10
Replaced 311-6968,312-1397,314-3431,
316-1760,318-7028,320-0292,326-3606,
327-4486,333-5970,337-7326,343-5712,
348-4710
335 HP 1250 LB-FT 2100/2300 RPM LEE00001-UP 318-7029 41 SEP07
Replaced 311-6987,312-1398,314-3432,
316-1769
335 HP 1250 LB-FT 2100/2300 RPM LEE00001-UP 365-1127 42/142 Nov10
Replaced 314-3433,316-1762,318-7030,
320-0294,326-3607,327-4487,333-5971,
337-7327,343-5713,348-4711
350 HP 1350 LB-FT 2100/2300 RPM LEE00001-UP 365-1128 43/143 Nov10
Replaced 311-6989,312-1400,314-3434,
316-1763,318-7031,320-0295,326-3608,
327-4488,333-5972,337-7328,343-5714,
348-4712
350 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1129 45/145 Nov10
Replaced 311-6990,312-1401,314-3435,
316-1764,318-7032,320-0296,326-3609,
327-4489,333-5973,337-7329,343-5715,
348-4713
350 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1130 46/146 Nov10
Oil Well Service
Replaced 314-3436,316-1765,318-7033,
320-0297,326-3610,327-4490,333-5974,
337-7330,343-5716,348-4714
350 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 365-1131 47/147 Nov10
Replaced 311-6992,312-1403,314-3437,
316-1766,318-7034,320-0298,326-3611,
327-4491,333-5975,337-7331,343-5717,
348-4715
370 HP 1350 LB-FT 2100/2300 RPM LEE00001-UP 365-1132 48/148 Nov10
Replaced 311-6993,312-1404,314-3438,
316-1767,318-7035,320-0299,326-3612,
327-4492,333-5976,337-7332,343-5718,
348-4716
370 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1133 49/149 Nov10
Replaced 311-6994,312-1405,314-3439,
316-1768,318-7036,320-0300,326-3613,
327-4493,333-5977,337-7333,343-5719,
348-4717
380 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1135 67/167 Nov10
Supports Optional Pre-cooler
Replaced 314-3441,316-1770,318-7038,
320-0302,326-3615,327-4495,333-5979,
337-7335,343-5721,348-4719
380 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1136 52/152 Nov10
Replaced 311-6996,312-1407,314-3442,
316-1771,318-7039,320-0303,326-3616,
327-4496,333-5980,337-7336,343-5722,
348-4720
410 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1137 68/168 Nov10
Replaced 314-3443,316-1772,318-7040,
320-0304,326-3617,327-4497,333-5981,
337-7337,343-5723,348-4721
410 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7334 50/150 Nov10
Replaced 311-6995,312-1406,314-3440,
316-1769,318-7037,320-0301,326-3614,
327-4494,333-5978,337-7334,
410 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1138 53/153 Nov10
Replaced 311-6997,312-1408,314-3444,
316-1733,318-7041,320-0305,326-3618,
327-4498,333-5982,337-7338,343-5724,
348-4722
410HP 1450/1550 LB-FT 2100/2300 RPM LEE00001-UP 365-1139 69/169 Nov10
Multi-torque
Replaced 314-3445,316-1774,318-7042,
320-0306,326-3619,327-4499,333-5983,
337-7339,343-5725,348-4723
410HP 1450/1550 LB-FT 2100/2300 RPM LEE00001-UP 365-1140 54/154 Nov10
Multi-torque
Replaced 311-6998,312-1409,314-3446,
316-1775,318-7043,320-0307,326-3620,
327-4500,333-5984,337-7340,343-5726,
348-4724
410 HP 1450/1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7341 70/170 OCT08
Multi-torque
Replaced 314-3447,316-1776,318-7044,
320-0308,326-3621,327-4501,333-5985
410 HP 1450/1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7342 55/155 OCT08
Multi-torque
Replaced 311-6999,312-1410,314-3448,
316-1777,318-7045,320-0309,326-3622,
327-4502,333-5986
410 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7343 71/171 OCT08
Replaced 314-3449,316-1778,318-7046,
320-0310,326-3623,327-4503,333-5987
410 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7344 56/156 OCT08
Replaced 311-7000,312-1411,314-3450,
316-1779,318-7047,320-0311,326-3624,
327-4504,333-5988
430 HP 1550/1750 LB-FT 2100/2300 RPM LEE00001-UP 337-7346 58/158 OCT08
GFRS
Replaced 311-7002,312-1413,314-3452,
316-1781,318-7049,320-0314,326-3626,
327-4506,333-5990
430 HP 1550/1750 LB-FT 2100/2300 RPM LEE00001-UP 337-7347 59/159 OCT08
Multi-torque
Replaced 311-7003,312-1414,314-3452,
316-1782,318-7050,320-0315,326-3627,
327-4507,333-5991
430 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7345 57/157 OCT08
Replaced 311-7001,312-1412,314-3451,
316-1780,318-7048,320-0313,326-3625,
327-4505,333-5989
430 HP 1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7349 60/160 OCT08
Replaced 311-7004,312-1415,314-3454,
316-1784,318-7052,320-0317,326-3629,
327-4509,333-5993
470 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7350 61/161 OCT08
Replaced 311-7005,312-1416,314-3455,
316-1785,318-7053,320-0318,326-3630,
327-4510,333-5994
470 HP 1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7351 62/162 OCT08
Multi-torque
Replaced 311-70063,12-1417,314-3456,
316-1786,318-7054,320-0319,326-3631,
327-4511,333-5995
470 HP 1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7352 63/163 OCT08
Replaced 312-1418,314-3457,316-1787,
318-7055,320-0320,326-3632,327-4512,
333-5996
455 HP 1550 LB-FT 2100 RPM LEE00001-UP 337-7353 64/164 OCT08
485 HP 1650 LB-FT
Replaced 312-1419,314-3458,316-1788,
318-7056,320-0321,326-3633,327-4413,
333-5997
525 HP 1750 LB-FT 2100 RPM LEE00001-UP 337-7354 65/165 OCT08
RV
Replaced 312-1420,314-3459,315-5890,
316-1789,318-7057,320-0322,326-3634,
327-4514,333-5998
525 HP 1750 LB-FT 2100 RPM LEE00001-UP 337-7355 66/166 OCT08
Replaced 312-1421,314-3460,316-1790,
318-7058,320-0323,326-3635,327-4515,
333-5999
C15 GOV SERIAL NO. FLASH P/M RELEASE
435 HP 1650 LB-FT 2100 RPM BXS00001-02034 242-1857 34 AUG03
Replaced 241-8405
435 HP 1650 LB-FT 2100 RPM BXS2035 -up 305-4511 40 NOV06
Replaced 245-0197, 247-7543,
249-7619,253-6066,255-4933,
262-3727,271-2954,283-5127,291-2083
435 HP 1550/1750 LB-FT M/T 2100 RPM BXS00001-02034 242-1856 32 AUG03
Gear Fast/Run Slow (EATON 2)
Replaced 237-9213,241-8409
435 HP 1550/1750 LB-FT M/T 2100 RPM BXS2035-up 305-4508 44 NOV06
Replaced 245-0189,247-7541,
249-7617,253-6070,255-4931,
262-3724,271-2951,283-5124,291-2080
435 HP 1550/1750 LB-FT M/T 2100 RPM BXS00001-02034 244-2510 31 AUG03
435 HP 1550/1750 LB-FT 2100 RPM BXS02035-up 290-2167 20 FEB06
Gear Fast/Run Slow
2004 Iron ADEM 4 ECM only
Replaced 253-0038,261-6686,
264-7702,271-1372,283-1179
435 HP 1550/1650 LB-FT M/T 2100 RPM BXS2035-up 305-4507 60 NOV06
Replaced 258-6910,262-3723,
271-2950,283-5123,291-2079
435 HP 1550/1750 LB-FT M/T 2100 RPM BXS2035-up 305-4509 45 NOV06
Replaced 245-0181,245-0212,
249-7626,253-6071,255-4932,
262-3725,271-2952,283-5125,291-2081
435 HP 1550 LB-FT 2100 RPM BXS2035-up 305-4506 48 NOV06
Replaced 245-0195,247-7544,
249-7620,253-6074,255-4930,262-3722,
271-2949,283-5122,291-2078
435/500HP 1550/1650 LB-FT M/T 2100 RPM BXS02035-up 305-4510 54 NOV06
Replaced 249-2489,255-1267,
262-3726,271-2953,283-5126,291-2082
475 HP 1650 LB-FT 2100 RPM BXS00001-02034 242-1858 35 AUG03
Replaced 239-5256,241-8406
475 HP 1650 LB-FT 2100 RPM BXS2035-up 305-4512 41 NOV06
Replaced 245-0183,247-7538,
249-7614,253-6067,255-4934,
262-3728,271-2955,283-5128,291-2084
475 HP 1650 LB-FT 2100 RPM BXS2035-up 305-4513 50 NOV06
Brakesaver
Replaced 245-0201,249-7622,
253-6076,255-4935,262-3729,
271-2956,283-5129,291-2085
475 HP 1650/1850 LB-FT M/T 2100 RPM BXS2035-up 305-4515 47 NOV06
Replaced 245-0193,245-0213,
249-7869,253-6073,255-4937,
262-3731,271-2958,283-5131,291-2087
475 HP 1650/1850 LB-FT M/T 2100 RPM BXS2035-up 305-4514 46 NOV06
Replaced 245-0191,247-7542,
249-7618,253-6072,255-4936,
262-3730,271-2957,283-5130,291-2086
475 HP 1850 LB-FT 2100 RPM BXS00001-02034 242-1859 36 AUG03
Replaced 239-5257,241-8407
475 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4516 42 NOV06
Replaced 245-0185,247-7539,
249-7615,253-6068,255-4938,
262-3732,271-2959,283-5132,291-2088
475 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4517 51 NOV06
Brakesaver
Replaced 245-0203,249-7623,
253-6077,255-4939,262-3733,
271-2960,283-5133,291-2089
500 HP 1650 LB-FT 2100 RPM BXS02035-up 305-4518 55 NOV06
Replaced 249-2490,262-3734,
271-2961,283-4134,291-2090
500 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4519 49 NOV06
Replaced 245-0199,247-7545,
249-7621,253-6075,255-4940,
262-3735,271-2962,283-5135,291-2091
500 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4520 52 NOV06
Brakesaver
Replaced 245-0205,249-7624,
253-6078,255-4941,262-3736,
271-2963,283-5136,291-2092
500 HP 1850 LB-FT 2300 RPM BXS2035-up 305-4521 56 NOV06
Replaced 249-2491,255-1269,
262-3737,271-2964,283-5137,291-2093
550 HP 1850 LB-FT 2100 PRM BXS00001-02034 242-1860 37 AUG03
Replaced 239-5258,241-8408
550 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4522 43 NOV06
Replaced 245-0187,247-7540,
249-7616,253-6069,255-4942,
262-3738,271-2965,283-5138,291-2094
550 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4523 53 NOV06
Brakesaver
Replaced 245-0207,249-7625,
253-6079,255-4943,262-3739,
271-2966,283-5139,291-2095
550 HP 1850 LB-FT 2300 RPM BXS2035-up 305-4524 57 MAR06
Replaced 249-2492,255-1270,
262-3740,271-2967,283-5140,291-4347
HEAVY HAUL RATINGS
Please note the heavy haul production files are an enhancement for specific
heavy load applications. The files were not created to correct a problem with
engine performance in heavy haul applications. Previous heavy haul software
meets all specifications pertaining to performance. This software is basically
an improvement that may augment performance, engine response and fuel economy
if utilized correctly. The most effective improvement is driver training.
475 HP 1650 LB-FT 2100 RPM BXS2035-up 305-4525 61 NOV06
Replaced 288-8535,297-2417
Replaces BXS 291-2084/PM code 41 for use in Heavy Haul applications only
475 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4526 62 NOV06
Replaced 288-8536,297-2418
Replaces BXS 291-2088/PM code 42 for use in Heavy Haul applications only
550 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4527 63 NOV06
Replaced 288-8537,297-2419
Replaces BXS 291-2094/PM code 43 for use in Heavy Haul applications only
435 HP 1550 LB-FT 2100 RPM MXS00001-UP 329-8532 20 APR08
NXS00001-UP
Replaced 258-8358,264-0064,
264-7700,271-1370,283-1177,
290-2165,308-1274
435 HP 1550/1750 LB-FT 2100 RPM MXS00001-UP 329-8536 21 APR08
NXS00001-UP
Replaced 258-8359,264-7703,
271-1374,283-1181,290-2169,308-1278
435 HP 1550/1650 LB-FT M/T 2100 RPM MXS00001-up 329-8533 43 APR08
NXS00001-UP
Replaced 269-2109,271-1373,283-1180,
290-2168,308-1275
435/550HP 1550/1850 LB-FT 2100 RPM MXS00001-UP 308-1307 46 FEB07
NXS00001-UP
Multi-torque Oil Well Service Only
Replaced 277-3087
435 HP 1650 LB-FT 2100 RPM MXS00001-UP 329-8537 22 APR08
NXS00001-UP
Replaced 258-8360,264-0065,
264-7701,271-1371,283-1178,
290-2166,308-1279,312-5637
435/500HP 1550/1650 LB-FT 2100 RPM MXS00001-UP 329-8534 23 APR08
NXS00001-UP
Replaced 258-8361,264-7704,
271-1375,283-1182,290-2170,
296-6023,308-1276
435 HP 1550/1750 LB-FT 2100 RPM MXS00001-UP 329-8535 7 APR08
Gear Fast/Run Slow (Eaton 2) NXS00001-UP
Replaced 253-0058,261-6686,
264-7702,283-1179,290-2167,308-1277
475 HP 1650 LB-FT 2100/2300 RPM MXS00001-UP 329-8566 47 APR08
Multi-torque NXS00001-UP
Replaced 277-3088,308-1308
475 HP 1850 LB-FT 2100/2300 RPM MXS00001-UP 329-8567 48 APR08
Replaced 277-3089,308-1309
475 HP 1650 LB-FT 2100 RPM MXS00001-UP 329-8538 24 APR08
NXS00001-UP
Replaced 258-8362,264-7705,
271-1376,283-1183,290-2171,
295-6068,308-1280,312-5638
475 HP 1650 LB-FT 2100 RPM MXS00001-UP 329-8539 25 APR08
Brakesaver NXS00001-UP
Replaced 271-1377,283-1184,
290-2172,295-6069,308-1281
475 HP 1650/1850 LB-FT 2100 RPM MXS00001-UP 329-8540 26 APR08
Replaced 258-8364,264-0066,264-7709,
271-1380,283-1187,289-1281,290-2175,
292-6962,301-4633,308-1282
475 HP 1650/1850 LB-FT 2100 RPM MXS00001-UP 329-8541 27 APR08
Replaced 258-8365,264-0067,
264-7710,271-1381,283-1188,
289-1282,290-2176,292-6963,
301-4634,308-1283
475 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8542 28 APR08
NXS00001-UP
Replaced 258-8366,264-0068,
264-7707,271-1378,283-1185,
290-2173,292-6960,301-4631,308-1284
475 HP 1850 LB-FT 2100/2300 RPM MXS00001-UP 329-8543 29 APR08
Replaced 258-8367,264-7708,
271-1379,283-1186,289-1280,
290-2174,292-6961,301-4632,308-1285
500 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8545 30 APR08
NXS00001-UP
Replaced 258-8368,264-7711,
271-1382,283-1189,290-2177,308-1287
500 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8546 31 APR08
Replaced 258-8369,264-7712,
271-1383,283-1190,290-2178,308-1288
550 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8549 32 APR08
NXS00001-UP
Replaced 258-8370,264-7713,
271-1384,283-1191,290-2179,
308-1291,312-5639
550 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8550 33 APR08
Replaced 258-8371,264-7714,
271-1385,283-1192,290-2180,308-1292
Lower rated engines can not be uprated to 600/625 HP rating
600 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8553 9 APR08
NXS00001-UP
Replaced 256-1368,261-6687,264-7715,
269-0982,271-1386,283-1193,290-2181,
302-8942,307-2259,308-1295
600 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8554 10 APR08
Replaced 261-6688,264-7716,269-0983,
271-1387,283-1194,290-2182,308-1296
600 HP 1850 LB-FT 2300 RPM MXS00001-UP 323-5866 44 NOV07
MT Military LVSR NXS00001-UP
Replaced 291-0106
625 HP 2050 LB-FT 2100 RPM MXS00001-UP 329-8557 6 APR08
NXS00001-UP
Replaced 253-0037,261-6689,
264-7717,269-0984,271-1388,
283-1195,290-2183,308-1299,312-5640
625 HP 2050 LB-FT 2100 RPM MXS00001-UP 329-8558 8 APR08
Replaced 261-6690,264-7718,
269-0985,271-1389,283-1196,
290-2184,308-1300
UPRATE
500 HP 1650 LB-FT 2100 RPM MXS00001-UP 308-1286 34 FEB07
UPRATE ONLY NXS00001-UP
Replaced 263-2858,271-1390,
283-1197,290-2185
500 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8547 35 APR08
Replaced 263-2859,271-1391,
283-1198,290-2186,308-1289
500 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8548 36 APR08
NXS00001-UP
BRAKESAVER/UPRATE ONLY
Replaced 263-2860,271-1392,
283-1199,290-2187,308-1290
550 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8551 37 APR08
Replaced 263-2861,271-1393,
283-1200,290-2188,308-1293
550 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8552 38 APR08
BRAKESAVER/UPRATE ONLY NXS00001-UP
Replaced 263-2862,271-1394,
283-1201,290-2189,308-1294
600 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8555 39 APR08
Replaced 263-2863,271-1395,
283-1202,290-2190,308-1297
600 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8556 40 APR08
BRAKESAVER ONLY
Replaced 263-2864,271-1396,
283-1203,290-2191,308-1298
625 HP 2050 LB-FT 2300 RPM MXS00001-UP 329-8559 41 APR08
Replaced 263-2865,271-1397,
283-1204,290-2192,308-1301
625 HP 2050 LB-FT 2300 RPM MXS00001-UP 329-8560 42 APR08
BRAKESAVER ONLY
Replaced 263-2866,271-1398,283-1205,290-2193,308-1302
HEAVY HAUL RATINGS
Please note the heavy haul production files are an enhancement for specific heavy load applications.
The files were not created to correct a problem with engine performance in heavy haul applications.
Previous heavy haul software meets all specifications pertaining to performance.
This software is basically an improvement that may augment performance, engine response
and fuel economy if utilized correctly. The most effective improvement is driver training.
475 HP 1650 LB-FT 2100 RPM MXS00001-UP 329-8561 50 APR08
NXS00001-UP
Replaced 288--8538,291-2013,308-1303
Replaces MXS 290-2171/PM code 24 for use in Heavy Haul applications only
475 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8562 51 APR08
NXS00001-UP
Replaced 288-8539,291-2014,308-1304
Replaces MXS 290-2173/PM code 28 for use in Heavy Haul applications only
550 HP 1850 LB-FT 2100 RPM MXS00001-UP 308-1305 52 JAN07
NXS00001-UP
Replaced 288-8540,291-2015
Replaces MXS 290-2179/PM code 32 for use in Heavy Haul applications only
C15 GOV FLASH P/M RELEASE
2007 EMISSIONS ADEM A4 ECM ON HEAVY DUTY ACERT HIGHWAY TRUCK
435 HP 1550 LB-FT 2100/2300 RPM SDP00001-UP 365-1160 40/140 Nov10
Replaced 310-8351,311-6957,314-2915,
316-1845,318-6991,320-0362,326-3651,
327-4519,333-5944,334-1287,343-5744,
348-4745
435 HP 1650 LB-FT 2100/2300 RPM SDP00001-UP 365-1161 41/141 Nov10
Replaced 310-8352,311-6958,314-2916,
316-1846,318-6992,320-0363,326-3652,
327-4520,333-5945,334-1288,343-5745,
348-4746
435HP 1550/1750 LB-FT 2100/2300 RPM SDP00001-UP 365-1162 42/142 Nov10
Multi-torque/GFRSS
Replaced 309-1779,310-8353,311-6959,
314-2917,316-1847,318-6993,320-0364,
326-3653,327-4521,333-5946,334-1289,
343-5746,348-4747
435HP 1550/1650 LB-FT 2100/2300 RPM SDP00001-UP 365-1163 43/143 Nov10
Multi-torque
Replaced 310-8354,311-6960,314-2918,
316-1848,318-6994,320-0365,326-3654,
327-4522,333-5947,334-1290,343-5747,
348-4748
435HP 1550/1750 LB-FT 2100/2300 RPM SDP00001-UP 365-1164 44/144 Nov10
Multi-torque
Replaced 310-8355,311-6961,314-2919,
316-1849,318-6995,320-0366,326-3655,
327-4523,333-5948,334-1291,343-5748,
348-4749
435HP 1550/1650 LB-FT 2100/2300 RPM SDP00001-UP 365-1165 45/145 Nov10
Multi-torque/OWS
Replaced 310-8356,311-6962,314-2920,
316-1850,318-1924,318-6996,320-0367,
326-3656,327-4524,333-5949,334-1292,
343-5749,348-4750
475 HP 1650 LB-FT 2100/2300 RPM SDP00001-UP 365-1166 46/146 Nov10
Replaced 310-8357,311-6963,314-2921,
316-1851,318-6997,320-0368,326-3657,
327-4525,333-5950,334-1293,343-5750,
348-4751
475HP 1650/1750 LB-FT 2100/2300 RPM SDP00001-UP 365-1168 48/148 Nov10
Multi-torque
Replaced 310-8359,311-6965,314-2923,
316-1853,318-6999,320-0370,326-3659,
327-4527,333-5952,334-1295,343-5752,
348-4753
475 HP 1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1169 49/149 Nov10
Replaced 310-8360,311-6966,314-2924,
316-1854,318-7000,320-0371,326-3660,
327-4528,333-5953,334-1296,343-5753,
348-4754
475HP 1650/1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1171 51/151 Nov10
Multi-torque/GFRSS
Replaced 310-8362,311-6968,314-2926,
316-1856,318-7002,320-0373,326-3662,
327-4530,333-5955,334-1298,343-5755,
348-4756
475HP 1650/1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1172 52/152 Nov10
Multi-torque
Replaced 310-8363,311-6969,314-2927,
316-1857,318-7003,320-0374,326-3663,
327-4531,333-5956,334-1299,343-5756,
348-4757
500 HP 1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1174 54/154 Nov10
Replaced 310-8365,311-6971,314-2929,
316-1859,318-7005,320-0376,326-3665,
327-4533,333-5958,334-1301,343-5758,
348-4759
550 HP 1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1175 55/155 Nov10
Replaced 310-8366,311-6972,314-2930,
316-1860,318-7006,320-0377,326-3666,
327-4534,333-5959,334-1302,343-5759,
348-4760
600 HP 1850 LB-FT 2100 RPM SDP00001-UP 365-1177 57/157 Nov10
Replaced 311-6974,314-2932,316-1862,
318-7008,320-0379,326-3668,327-4536,
333-5961,334-1304,343-5761,348-4762
600 HP 1850 LB-FT ARF 2100 RPM SDP00001-UP 365-1178 58/158 Nov10
Replaced 318-7009,320-0380,326-3669,
327-4537,333-5962,334-1305,343-5762,
348-4763
600 HP 1850 LB-FT (RV) 2100 RPM SDP00001-UP 365-1179 59/159 Nov10
Replaced 311-6976,314-2934,315-5873,
316-1864,318-7010,320-0381,326-3670,
327-4538,333-5963,334-1306,343-5763,
348-4764
600 HP 2050 LB-FT 2100 RPM SDP00001-UP 365-1180 60/160 Nov10
Replaced 311-6977,314-2935,316-1865,
318-7011,320-0382,326-3671,327-4539,
333-5964,334-1307,343-5764,348-4765
600 HP 2050 LB-FT (RV) 2100 RPM SDP00001-UP 365-1181 62/162 Nov10
Replaced 311-6979,314-2937,315-5874,
316-1867,318-7013,320-0384,326-3672,
327-4540,333-5965,334-1308,343-5765,
348-4766
625 HP 2150 LB-FT 2100 RPM SDP00001-UP 365-1182 63/163 Nov10
Replaced 310-8374,311-6980,314-2938,
316-1868,318-7014,320-0385,326-3673,
327-4541,333-5966,334-1309,343-5766,
348-4767
625 HP 2050 LB-FT (RV) 2100 RPM SDP00001-UP 365-1183 65/165 Nov10
Replaced 311-6982,314-2940,315-5875,
316-1870,318-7016,320-0387,326-3674,
327-4542,333-5967,334-1310,343-5767,
348-4768
625 HP 1900 LB-FT 2100 RPM SDP00001-UP 365-1184 66/166 Nov10
Replaced 311-6983,314-2941,315-5876,
316-1871,318-7017,320-0388,326-3675,
327-4543,333-5968,334-1311,343-5768,
348-4769
EURO 4 Rating for use in Europe only - not for North America use
500 HP@2100/2300 RPM EURO4 348-6571 35/135 Jun09
Multi-torque
Replaced 295-6883,319-4913,330-2024,
335-6771
550 HP@2100/2300 RPM EURO4 348-6572 36/136 Jun09
Replaced 295-6884,319-4914,330-2025,
335-6772
625 HP@2100/2300 RPM EURO4 348-6573 37/137 Jun09
Replaced 295-6885,319-4915,330-2026,
335-6773
HEAVY HAUL RATINGS
475 HP 1650 LB-FT 2300 RPM SDP1-up 365-1167 47/147 Nov10
Replaced 314-2922,316-1852,318-6998,
320-0369,326-3658,327-4526,333-5951,
334-1294,343-5751,348-4752
For use in Heavy Haul applications only
475 HP 1850 LB-FT 2300 RPM SDP1-up 365-1170 50/150 Nov10
Replaced 314-2925,316-1855,318-7001,
320-0372,326-3661,327-4529,333-5954,
334-1297,343-5754,348-4755
550 HP 1850 LB-FT 2300 RPM SDP1-up 365-1176 56/156 Nov10
Replaced 314-2931,316-1861,318-7007,
320-0378,326-3667,327-4535,333-5960,
334-1303,343-5760,348-4761
Type of software: ECM Flash files for CAT ET
Make: Caterpillar
Region: WorldWide
Languages: DE, ES, FR, IT, JP, PT, CHS
OS: Window 7, Window 8, Window 10 32 & 64bit (Tested on window 10 1607 64bit)
High-Speed link download
Cat Factory flash files for the Flash memory programming of onboard ECMs. For this purpose, you need the latest activated version of Caterpillar Electronic Technician application and the genuine Cat Diagnostic Adapter Interface to connect with the vehicle.
Please check if your flash file is included using any desktop browser search function. For this purpose Click Ctrl+F to open the Find in page bar, type the search phrase in it.
FLASH FILE CROSS REFERENCE SAVED FROM SIS WEB
3126E HEUI Flash File Cross Reference
Updated Jan 21, 2004
Released software to meet 2.09.2 Clean Power Phase II, Adem 2000,
Version 6, 7, & 8 ECM, MY2001 EPA Emission for April 2001
Production with 24 MHz ECM,
Support for 3.5 NOx FEL Truck Consent Decree, and
GM Two Speed Axle Switch Update.
Description Serial Flash Part IC Release
No. Range No. Date
175 HP @ 2200 CKM 1 and up 246-8293 219 NOV03
420 @ 1500 EPA Cert
190 HP @ 2400 CKM 1 and up 246-8292 229 NOV03
420 @ 1500 EPA Cert.
190 HP @ 2300 CKM 1 and up 246-8291 227 NOV03
520 @ 1500 EPA Cert. ***** HIGH PERFORMANCE AT545 *****
210 HP @ 2400 CKM 1 and up 246-8290 228 NOV03
****** Standard Ratings ***************
210 HP @ 2200 CKM 1 and up 246-8289 222 NOV03
210 HP @ 2200 CKM 1 and up 246-8288 223 NOV03
605 @ 1500 EPA Cert.
230 HP @ 2200 CKM 1 and up 246-8287 206 NOV03
660 @ 1500 EPA Cert.
250 HP @ 2200 CKM 1 and up 246-8286 207 NOV03
250 HP @ 2200 CKM 1 to CKM10423 246-8285 208 NOV03
800 @ 1500 EPA Cert.
250 HP @ 2200 CKM10424 and up 246-8284 205 NOV03
275 HP @ 2200 CKM 1 and up 246-8283 209 NOV03
275 HP @ 2200 CKM 1 and up 246-8282 210 NOV03
860 @ 1500 EPA Cert.
300 HP @ 2200 CKM 1 and up 246-8281 211 NOV03
300 HP @ 2200 CKM 1 and up 246-8280 212 NOV03
******************** Emergency Ratings *****************************
275 HP @ 2200 CKM 1 and up 246-8279 213 NOV03
800 @ 1500 Emergency.
275 HP @ 2200 CKM 1 and up 246-8278 214 NOV03
860 @ 1500 Emergency.
300 HP @ 2200 CKM 1 and up 246-8277 215 NOV03
300 HP @ 2200 CKM 1 and up 246-8276 216 NOV03
330 HP @ 2400 CKM 1 and up 246-8275 217 NOV03
******************* RV Rating **************************************
330 HP @ 2400 CKM 1 and up 246-8274 218 NOV03
860 @ 1500 RV
3116 HEUI Flash File Cross Reference
Updated Jan 22, 2004
1WM 7LZ 8WL AND 7AS flash files for engine rebuild kits
ADEM II AND ADEM III Low Nox engine rebuild kit flash files
Updated July 6, 2001
******************* 3116 Standard Ratings **************************
170 HP @ 2200 8WL 1 and up 188-8046 301 JAN00
420 @ 1560 EPA LoNox Cert.
185 HP @ 2200 8WL 1 and up 188-8047 302 JAN00
520 @ 1560 EPA LoNox Cert.
190 HP @ 2300 8WL 1 and up 188-8053 303 JAN00
195 HP @ 2200 8WL 1 and up 188-8048 303 JAN00
215 HP @ 2200 8WL 1 and up 188-8049 304 JAN00
605 @ 1560 EPA LoNox Cert.
230 HP @ 2200 8WL 1 and up 188-8050 305 JAN00
660 @ 1560 EPA LoNox Cert.
250 HP @ 2200 8WL 1 and up 188-8051 306 JAN00
275 HP @ 2200 8WL 1 and up 188-8052 307 JAN00
750 @ 1470 EPA LoNox Cert.
********************** 3126 Standard Ratings ************************
175 HP @ 2400 1WM/7LZ 1 and up 188-8054 301 JAN00
420 @ 1440 EPA LoNox Cert.
190 HP @ 2200 1WM/7LZ/4ES 1 and up 188-8055 302 JAN00
520 @ 1440 EPA LoNox Cert.
210 HP @ 2400 1WM/7LZ 1 and up 188-8056 303 JAN00
210 HP @ 2200 1WM/7LZ/4ES 1 and up 188-8057 304 JAN00
605 @ 1440 EPA LoNox Cert.
230 HP @ 2200 1WM/7LZ/4ES 1 and up 188-8058 305 JAN00
660 @ 1440 EPA LoNox Cert.
250 HP @ 2200 1WM/7LZ/4ES 1 and up 188-8059 306 JAN00
250 HP @ 2200 1WM/7LZ 1 and up 188-8060 307 JAN00
800 @ 1440 EPA LoNox Cert.
275 HP @ 2200 1WM/7LZ 1 and up 188-8061 308 JAN00
275 HP @ 2200 1WM/7LZ 1 and up 188-8062 309 JAN00
860 @ 1440 EPA LoNox Cert.
300 HP @ 2200 1WM/7LZ 1 and up 188-8063 311 JAN00
300 HP @ 2200 1WM/7LZ 1 and up 188-8064 310 JAN00
300 HP 1WM1 and Up 130-7832 16 OCT96
860 @ 1440 OWS
***************** Emergency Vehicles ********************************
275 HP @ 2200 1WM 1 and up 188-8065 312 JAN00
275 HP @ 2200 1WM 1 and up 188-8066 313 JAN00
300 HP @ 2200 1WM 1 and up 188-8067 314 JAN00
300 HP @ 2200 1WM 1 and up 188-8068 315 JAN00
330 HP @ 2200 1WM 1 and up 188-8069 320 JAN00
330 HP @ 2200 1WM 1 and up 188-8070 321 JAN00
**************************CEC Rating*********************************
250 HP @ 2200 1WM 1 and up 188-8071 319 JAN00
**************** Hi-performance AT/MT/HT Rating *********************
190 HP @ 2300 1WM/7LZ 1 and up 188-8072 302 JAN00
********************** 3126B Standard Ratings ************************
175 HP @ 2400 7AS 1 and up 246-8248 301 NOV03
190 HP @ 2200 7AS 1 and up 246-8247 302 NOV03
190 HP @ 2300 7AS 1 and up 246-8246 302 NOV03
210 HP @ 2400 7AS 1 and up 246-8245 332 NOV03
210 HP @ 2200 7AS 1 and up 246-8244 303 NOV03
210 HP @ 2200 7AS 1 and up 246-8243 304 NOV03
************************** DINA Only *******************************
210 HP @ 2200 7AS 1 and up 246-8242 329 NOV03
230 HP @ 2200 7AS 1 and up 246-8241 305 NOV03
250 HP @ 2200 7AS 1 and up 246-8240 306 NOV03
250 HP @ 2200 7AS 1 and up 246-8239 307 NOV03
275 HP @ 2200 7AS 1 and up 246-8238 308 NOV03
275 HP @ 2200 7AS 1 and up 246-8237 309 NOV03
300 HP @ 2200 7AS 1 and up 246-8236 310 NOV03
300 HP @ 2200 7AS 1 and up 246-8235 311 NOV03
275 HP @ 2200 7AS 1 and up 246-8234 312 NOV03
275 HP @ 2200 7AS 1 and up 246-8233 313 NOV03
300 HP @ 2200 7AS 1 and up 246-8232 314 NOV03
300 HP @ 2200 7AS 1 and up 246-8231 315 NOV03
330 HP @ 2400 7AS 1 and up 246-8230 316 NOV03
***************** Recreational Vehicles *****************************
330 HP @ 2400 7AS 1 and up 246-8229 317 NOV03
Updated JAN 29, 2001
******************* FMTV Vehicles Only ********************************
275 HP @ 2200 6PZ 1 and up 224-4622 119 SEP02
330 HP @ 2400 7JZ 1 and up 224-4623 120 SEP02
350 HP @ 2400 1AJ 1 and up 224-4627 45 SEP02
820 @ 1500 EPA LoNox Cert.
TEST ECM Primer Software file 188-9579 MAR00
NOTE: Flash this file into ADEM 2000 Test ECM before loading any engine
flash file.
3126B 8YL HEUI Flash File Cross Reference
The reason for this SEP 00 release was to provide Software features
Including:
For all ratings except Euro II:
Released software to meet 2.09 Version 6&7, 4g S.S.NOx MY2000
EPA emission for Sep 2000 production with 24 MHz ECM, support for
GM2001i truck, consent decree torque and timing readout, updated
idle quality adjustment maps, and modify progressive shift.
For Euro II rating:
Released software to meet 2.09 Version 6&7, 6g S.S.NOx MY2000 EPA emission
for Sep 2000 production with 24 MHz ECM, support for GM2001i truck,
consent decree torque and timing readout, updated idle quality adjustment
This software update also contains a fix for false logging of injector faults.
Revision to Exhaust Brake Special Test. Improvements to reduce ECM Engine software
Lock-Up.
Enhancements for vehicles with Allision AT/MT/HT transmission. Combines
Interlock codes for use on GM = IC1 and NON GM = IC2 chassis.
NOTE: Duel Fuel and Steel Piston Parts Service Only files are not in this release.
Description Serial Flash Part IC IC2 Release
No. Range No. Date
*************** 175 and 190 HP can be used with *******************
************** Allison AT545 Transmission *******************
175 HP @ 2200 8YL 1 to 8YL34999 246-8273 101 151 NOV03
420 @ 1500 EPA Cert
175 HP @ 2200 8YL35000 and up 246-8272 169 169 DEC03
420 @ 1500 EPA Cert
190 HP @ 2300 8YL 1 to 8YL34999 246-8271 102 152 NOV03
190 HP @ 2300 8YL35000 and up 246-8270 170 170 DEC03
****** 210HP Rating with an Allison AT545 *************
****** Transmission *************
210 HP @ 2400 8YL 1 to 8YL34999 246-8269 103 153 NOV03
210 HP @ 2400 8YL35000 & 9SZ 1 and up 246-8268 171 171 DEC03
210 HP @ 2200 8YL 1 to 8YL34999 246-8267 104 154 NOV03
210 HP @ 2200 8YL35000 & 9SZ 1 and up 246-8266 172 172 DEC03
210 HP @ 2200 8YL 1 to 8YL34999 246-8265 105 155 NOV03
210 HP @ 2200 8YL35000 & 9SZ 1 and up 246-8264 173 173 DEC03
230 HP @ 2200 8YL & 9SZ 1 and up 246-8263 106 156 DEC03
250 HP @ 2200 8YL 1 TO 8YL68263 246-8262 107 157 NOV03
250 HP @ 2200 8YL68264 & 9SZ 1 and up 246-8261 187 187 DEC03
250 HP @ 2200 8YL 1 TO 8YL68263 246-8260 108 158 NOV03
250 HP @ 2200 8YL68264 & 9SZ 1 and up 246-8259 188 188 DEC03
275 HP @ 2200 8YL & 9SZ 1 and up 246-8258 109 159 DEC03
275 HP @ 2200 8YL & 9SZ 1 and up 246-8257 110 160 DEC03
300 HP @ 2200 8YL & 9SZ 1 and up 246-8256 111 161 DEC03
300 HP @ 2200 8YL & 9SZ 1 and up 246-8255 112 162 DEc03
275 HP @ 2200 8YL & 9SZ 1 and up 246-8254 113 163 DEC03
275 HP @ 2200 8YL & 9SZ 1 and up 246-8253 114 164 DEC03
300 HP @ 2200 8YL & 9SZ 1 and up 246-8252 115 165 DEC03
300 HP @ 2200 8YL & 9SZ 1 and up 246-8251 116 166 DEC03
330 HP @ 2400 8YL & 9SZ 1 and up 246-8250 117 167 DEC03
330 HP @ 2400 8YL & 9SZ 1 and up 246-8249 118 168 DEC03
860 @ 1500 RV
3126 HEUI (8HW) EURO 2 FLASH File Cross Reference
Description Serial NO. FLASH PART IC Release
Range NO. Date
190 HP 8HW00001 & up 146-9883 22 DEC97
520 @ 1440
210 HP 8HW00001 & up 146-9880 23 DEC97
605 @ 1440
275 HP 8HW00001 & up 187-2097 24 NOV99
830 @ 1440
300 HP 8HW00001 & up 187-2096 25 NOV99
860 @ 1440
********** FULL FEATURE ECM FILES *****************************************
Description Serial NO. FLASH PART IC IC2 Release
Range NO. Date
190 HP @ 2300 8SZ00532 & up 212-4002 125 125 OCT01
520 @ 1440
210 HP @ 2200 8SZ00532 & up 212-4001 126 126 OCT01
605 @ 1440
250 HP @ 2200 8SZ00532 & up 212-4000 127 127 OCT01
800 @ 1440
275 HP @ 2200 8SZ00001 & up 212-3999 128 128 OCT01
830 @ 1440
300 HP @ 2200 8SZ00001 & up 212-3998 129 129 OCT01
860 @ 1440
************** 3126E HEP Flash File Reference *****************
Updated December 6, 2002
Emergency Vehicle Ratings
Serial No. Range
Part Number
Interlock Code Rating/Application Information
HEP1 - HEP07579
227-9339 3126 Truck 330HP 860 lb-ft, 2400 RPM ER Date Code SEP02
Interlock Code = 251
Replaced 225-2366
HEP07580 & UP
231-2609 3126 Truck 330HP 860 lb-ft, 2400 RPM ER Date Code OCT02
Interlock Code = 298
HEP1 - HEP07579
227-9341 3126 Truck 300HP 860 lb-ft, 2200 RPM ER Date Code SEP02
Interlock Code = 250
Replaced 225-2368
HEP07580 & UP
230-1562 3126 Truck 300HP 860 lb-ft, 2200 RPM RV Date Code OCT02
Interlock Code = 297
HEP1 - HEP07579
227-9342 3126 Truck 300HP 800 lb-ft, 2200 RPM ER Date Code SEP02
Interlock Code = 249
Replaced 225-2369
HEP07580 & UP
230-1563 3126 Truck 300HP 800 lb-ft, 2200 RPM ER Date Code OCT02
Interlock Code = 296
HEP1 - HEP07579
227-9343 3126 Truck 275HP 860 lb-ft, 2200 RPM ER Date Code SEP02
Interlock Code = 248
Replaced 225-2370
HEP07580 & UP
230-1564 3126 Truck 275HP 860 lb-ft, 2200 RPM ER Date Code OCT02
Interlock Code = 295
HEP1 - HEP07579
227-9344 3126 Truck 275HP 800 lb-ft, 2200 RPM ER Date Code SEP02
Interlock Code = 247
Replaced 225-2371
HEP07580 & UP
230-1565 3126 Truck 275HP 800 lb-ft, 2200 RPM ER Date Code OCT02
Interlock Code = 294
Recreational Vehicle Ratings
Serial No. Range
Part Number
HEP1 - HEP07579
227-9340 3126 Truck 330HP 860 lb-ft, 2400 RPM RV Date Code SEP02
Interlock Code = 252
Replaced 225-2367
HEP07580 & UP
230-1561 3126 Truck 330HP 860 lb-ft, 2400 RPM RV Date Code OCT02
Interlock Code = 299
Truck Ratings
Serial No. Range
Part Number
HEP1 - HEP07579
227-9345 3126 Truck 300HP 860 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 246
Replaced 225-2372
HEP07580 & UP
230-1566 3126 Truck 300HP 860 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 293
HEP1 - HEP07579
227-9346 3126 Truck 300HP 800 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 245
Replaced 225-2373
HEP07580 & UP
230-1567 3126 Truck 300HP 800 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 292
HEP1 - HEP07579
227-9347 3126 Truck 275HP 860 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 244
Replaced 225-2374
HEP07580 & UP
230-1568 3126 Truck 275HP 860 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 291
HEP1 - HEP07579
227-9348 3126 Truck 275HP 800 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 243
Replaced 225-2375
HEP07580 & UP
230-1569 3126 Truck 275HP 800 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 290
HEP1 - HEP07579
227-9349 3126 Truck 250HP 800 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 242
Replaced 225-2376
HEP07580 & UP
230-1570 3126 Truck 250HP 800 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 289
HEP1 - HEP07579
227-9350 3126 Truck 250HP 660 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 241
Replaced 225-2377
HEP07580 & UP
230-1571 3126 Truck 250HP 660 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 288
HEP1 - HEP07579
227-9351 3126 Truck 230HP 660 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 240
Replaced 225-2378
HEP07580 & UP
236-2149 3126 Truck 230HP 540 lb-ft, 2300 RPM Date Code MAR03
Interlock Code = 239
HEP07580 & UP
230-1572 3126 Truck 230HP 660 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 287
HEP1 - HEP07579
227-9352 3126 Truck 210HP 605 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 257
Replaced 225-2380
HEP07580 & UP
230-1573 3126 Truck 210HP 605 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 286
HEP1 - HEP07579
227-9353 3126 Truck 210HP 520 lb-ft, 2200 RPM Date Code SEP02
Interlock Code = 256
Replaced 225-2380
HEP07580 & UP
230-1574 3126 Truck 210HP 520 lb-ft, 2200 RPM Date Code OCT02
Interlock Code = 285
HEP1 & UP
227-9354 3126 Truck 210HP 520 lb-ft, 2400 RPM Date Code SEP02
High Performance Interlock Code = 255
Replaced 225-2381
HEP1 & UP
227-9355 3126 Truck 190HP 520 lb-ft, 2300 RPM Date Code SEP02
High Performance Interlock Code = 254
Replaced 225-2382
HEP1 & UP
227-9356 3126 Truck 190HP 420 lb-ft, 2400 RPM Date Code SEP02
Interlock Code = 253
Replaced 225-2383
C7C9 On-Highway Engine Flash files
Updated December 20, 2010
IMPORTANT: It is very important to select the CORRECT flash file for the injector part
number that is in the engine!!! Engines that have the "factory installed injector p/n"
can use the flash file for the s/n range listed. However, for the s/n ranges noted
below, if a "single" injector is replaced "all six" injectors MUST be updated to the
same part number and the appropriate "flash file" and "etrim" files MUST be installed
to match the "new" part number injector!
Please refer to Truck Engine News SEBD6764 dated January 2004
Please check for rerateability using the rerate charts at https://truck.cat.com
C7 (2007 Emissions A4 ECM) "Mid HP Ratings" 190HP to 300HP:
C7S0001-up Date Code Interlock Flash File
C7 190HP @ 2500 RPM JUL08 40/140 334-2353
Replaced 308-5717,309-1838,312-4768,313-9518,
316-7964,319-5927,321-7212,324-7626.326-9115,
328-0693
C7 210HP @ 2500 RPM Dec10 41/141 348-5528
Replaced 308-5718,309-1839,312-4769,313-9519,
316-7965,319-5928,321-7213,324-7627,326-9116,
328-0694,334-2354
C7 210HP @ 2500 RPM JUL08 42/142 334-2355
Replaced 308-5719,309-1840,312-4770,313-9520,
316-7966,319-5929,321-7214,324-7628,326-9117,
328-0695
C7 230HP @ 2500 RPM JUL08 43/143 334-2356
Replaced 308-5720,309-1841,312-4771,313-9521,
316-7967,319-5930,321-7215,324-7629,326-9118,
328-0696
C7 230HP @ 2500 RPM JUL08 44/144 334-2357
Replaced 300-1766,307-8355,309-1842,312-4772
313-9522,316-5997,316-7968,319-5931,321-7216,
324-7630326-9119,328-0697
C7 230HP @ 2400 RPM JUL08 45/145 334-2358
Replaced 300-1768,308-5721,309-1843,312-4773
313-9523,316-7969,319-5932,321-7217,324-7631,
326-9120,328-0698
C7 250HP @ 2400 RPM JUL08 46/146 334-2359
Replaced 308-5722,309-1844,312-4774
313-9524,316-7970,319-5933,321-7218,324-7632,
326-9121,328-0699
C7 250HP @ 2400 RPM JUL08 47/147 334-2360
Replaced 308-5723,309-1845,312-4775
313-9525,316-7971,319-5934,321-7219,324-7633,
326-9122,328-0700
C7 275HP @ 2400 RPM JUL08 48/148 334-2361
Replaced 308-5724,309-1846,312-4776
313-9526,316-7972,319-5935,321-7220,324-7634,
326-9123,328-0701
C7 300HP @ 2400 RPM JUL08 49/149 334-2362
Replaced 300-1776,307-8356,309-1847,312-4777
313-9527,316-7973,319-5936,321-7221,324-7635,
326-9124,328-0702
C7 300HP @ 2400 RPM ER JUL08 50/150 334-2363
Replaced 312-4778,313-9528,316-7974,319-5937
321-7222,324-7636,326-9125,328-0703
C7 330HP @ 2400 RPM ER JUL08 51/151 334-2364
Replaced 312-4779,313-9529,316-7975,319-5938
321-7223,324-7637,326-9126,328-0704
C7 350HP @ 2400 RPM ER JUL08 52/152 334-2365
Replaced 312-4780,313-9530,316-7976,319-5939
321-7224,324-7638,326-9127,328-0705
C7 360HP @ 2400 RPM ER JUL08 57/157 334-2370
Replaced 322-4567,324-7643,326-9132,328-0710
C7 300HP @ 2400 RPM RV JUL08 53/153 334-2366
Replaced 312-4781,313-9531,316-7977,319-5940
321-7225,324-7639,326-9128,328-0706
C7 330HP @ 2400 RPM RV JUL08 54/154 334-2367
Replaced 312-4782,313-9532,316-7978,321-7226,
324-7640,326-9129,328-0707
C7 350HP @ 2400 RPM RV JUL08 55/155 334-2368
Replaced 312-4783,313-9533,316-7979,321-7227,
324-7641,326-9130,328-0708
C7 360HP @ 2400 RPM RV JUL08 56/156 334-2369
Replaced 313-9535,316--7980,321-7228,
324-7642,326-9131,328-0709
C7 (KAL, SAP, WAX) "Low HP Ratings" 190HP to 210HP:
NOTE: C7 "Low HP Ratings" 190HP to 210HP KAL1-07985 were factory built with Injector
p/n 233-3536. If a "single" 233-3536 injector is replaced with a 243-4502 injector
w/seals (241-3238 p/n on injector... not serviced) then "all six" injectors MUST be
updated to the same part number and the appropriate flash file and "etrim" files MUST
be installed to match the "new" part number injector! Use list below to determine flash
file based on installed injector number!
S/N Range Injector P/N Date Code Interlock Flash File
C7 KAL 190HP 520 lb-ft ...* Important see note above for complete detail
KAL 1 - 07985 w/ Factory installed 233-3536 Injectors APR04 IC 1 247-4649
Replaced 242-8316,243-4420
KAL1-07985 w/ "Field installed" 241-3238 Injectors SEP06 IC 25 300-0446
Replaced 248-7461,251-7438,
254-0804,259-5558,265-3311,277-5700,295-2303
KAL07986-UP, SAP1-UP, WAX1-UP
w/ "Factory installed" 241-3238 Injectors SEP06 IC 25 300-0446
C7 KAL 210HP 520 lb-ft ...* Important see note above for complete detail
KAL 1 - 07985 w/ Factory installed 233-3536 Injectors APR04 IC 3 247-4648
Replaced 242-1847,243-4421
KAL1-07985 w/ "Field installed" 241-3238 Injectors SEP06 IC 26 300-0447
Replaced 248-7460,251-7439,
254-0805,259-5559,265-3312,277-5701,295-2304
w/ "Factory installed" 241-3238 Injectors SEP06 IC 26 300-0447
C7 KAL 210HP 605 lb-ft ...* Important see note above for complete detail
KAL 1 - 07985 w/ Factory installed 233-3536 Injectors APR04 IC 4 247-4647
Replaced 242-8317,243-4422
KAL1-07985 w/ "Field installed" 241-3238 Injectors SEP06 IC 27 300-0448
Replaced 248-7459,251-7440,
254-0806,259-5560,277-5702,295-2305
w/ "Factory installed" 241-3238 Injectors SEP06 IC 27 300-0448
C7 (KAL, SAP, WAX) "Mid HP Ratings" 230HP to 250HP 660lbft:
NOTE: C7 "Mid HP Ratings" 230HP to 250HP 660lbft KAL1-11870 were factory built with
Injector p/n 236-6011. If a "single" 236-6011 injector is replaced with a 243-4503
injector w/seals (241-3239 p/n on injector... not serviced) then "all six" injectors
MUST be updated to the same part number and the appropriate flash file and "etrim"
files MUST be installed to match the "new" part number injector! Use list below to
determine flash file based on installed injector number!
C7 KAL 230HP 540 lb-ft ...* Important see note above for complete detail
KAL 1 - 11870 w/ Factory installed 236-6011 Injectors APR04 IC 18 247-4646
Replaced 242-1845,243-4423
KAL1-11870 w/ "Field installed" 241-3239 Injectors SEP06 IC 28 300-0449
Replaced 248-7458,251-7441,
259-5561,265-3314,271-1678,277-5703,295-2306
KAL11871-UP, SAP1-UP, WAX1-UP
w/ "Factory installed" 241-3239 Injectors SEP06 IC 28 300-0449
C7 KAL 230HP 660 lb-ft ...* Important see note above for complete detail
KAL 1 - 11870 w/ Factory installed 236-6011 Injectors APR04 IC 5 247-4645
Replaced 242-1844,243-4424
KAL1-11870 w/ "Field installed" 241-3239 Injectors SEP06 IC 29 300-0450
Replaced 248-7457,251-7442,
259-5563,265-3315,271-1679,277-5704,295-2307
w/ "Factory installed" 241-3239 Injectors SEP06 IC 29 300-0450
C7 KAL 250HP 660 lb-ft ...* Important see note above for complete detail
KAL 1 - 11870 w/ Factory installed 236-6011 Injectors APR04 IC 6 247-4644
Replaced 242-1843,243-4425
KAL1-11870 w/ "Field installed" 241-3239 Injectors AUG08 IC 30 335-8257
Replaced 248-7456,251-7443,
259-5564,265-3316,277-5705,295-2308,300-0451
w/ "Factory installed" 241-3239 Injectors AUG08 IC 30 335-8257
C7 (KAL, SAP, WAX) "Hi HP Ratings" 250HP 800lbft to 330HP:
NOTE: C7 "Hi HP Ratings" 250HP 800lbft to 330HP KAL1-12897 were factory built with
Injector p/n 233-3535. If a "single" 233-3535 injector is replaced with a 241-3400
injector w/seals (238-8091 p/n on injector... not serviced) then "all six" injectors
C7 KAL 250HP @ 2200 800 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 7 247-4643
Replaced 245-0834
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 41 300-0465
Replaced 248-7641,251-7457,
254-0999,259-5609,265-3334,272-5324,295-2333
KAL12898-UP, SAP1-UP, WAX1-UP
w/ "Factory installed" 238-8091 Injectors SEP06 IC 41 300-0465
C7 KAL 275HP 800 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 8 247-4642
Replaced 245-0835
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 42 300-0464
Replaced 248-7640,251-7456,
254-0998,259-5608,265-3333,272-5323,295-2332
w/ "Factory installed" 238-8091 Injectors SEP06 IC 42 300-0464
CARB (California Bus only) MAR04 IC 59 251-6210
C7 KAL 275HP 860 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 9 247-4640
Replaced 245-0837
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 43 300-0462
Replaced 248-7638,251-7454,
254-0996,259-5606,265-3331,272-5321,295-2330
w/ "Factory installed" 238-8091 Injectors SEP06 IC 43 300-0462
C7 KAL 300HP 800 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 10 247-4638
Replaced 245-0839
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 44 300-0460
Replaced 248-7636,251-7452,
254-0994,259-5604,265-3329,272-5319,295-2328
w/ "Factory installed" 238-8091 Injectors SEP06 IC 44 300-0460
CARB (California Bus only) MAR04 IC 60 251-6209
C7 KAL 300HP @ 2200 860 lb-ft ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 11 247-4636
Replaced 245-0841
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 45 300-0458
Replaced 248-7634, 251-7450, 254-0992,259-5602,
265-3326,272-5317,295-2326
w/ "Factory installed" 238-8091 Injectors SEP06 IC 45 300-0458
C7 KAL 330HP 860 lb-ft (Truck) ...* Important see note above for complete detail
KAL1-UP w/ "Field installed" 238-8091 Injectors SEP06 IC 53 300-0456
Replaced 248-7645,251-7448,
254-0990,259-5600,265-3323,272-5315,295-2324
w/ "Factory installed" 238-8091 Injectors SEP06 IC 53 300-0456
*********************************** EMERGENCY RATINGS (ER) ***************************
C7 KAL 275HP 800 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 12 247-4641
Replaced 245-0836
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 46 300-0463
Replaced 248-7639,251-7455,
254-0997,259-5607,265-3332,272-5322,295-2331
w/ "Factory installed" 238-8091 Injectors SEP06 IC 46 300-0463
C7 KAL 275HP 860 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 13 247-4639
Replaced 245-0838
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 47 300-0461
Replaced 248-7637,251-7453,
254-0995,259-5605,265-3330,272-5320,295-2329
w/ "Factory installed" 238-8091 Injectors SEP06 IC 47 300-0461
C7 KAL 300HP 800 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 14 247-4637
Replaced 245-0840
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 48 300-0459
Replaced 248-7635,251-7451,
254-0993,259-5603,265-3327,272-5318,295-2327
w/ "Factory installed" 238-8091 Injectors SEP06 IC 48 300-0459
C7 KAL 300HP 860 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 15 247-4635
Replaced 245-0842
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 49 300-0457
Replaced 248-7633,251-7449,
254-0991,259-5601,265-3324,272-5316,295-2325
w/ "Factory installed" 238-8091 Injectors SEP06 IC 49 300-0457
C7 KAL 330HP 860 lb-ft (ER) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 16 247-4634
Replaced 245-0843
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 50 300-0455
Replaced 248-7632,251-7447,
254-0989,259-5599,265-3322,272-5314,295-2323
w/ "Factory installed" 238-8091 Injectors SEP06 IC 50 300-0455
C7 KAL 350HP @ 2400 RPM (ER) SEP06 IC 54 300-0453
Replaced 272-1428,298-7453
******************************** RECREATION VEHICLE (RV) *******************************
C7 KAL 330HP 860 lb-ft (RV) ...* Important see note above for complete detail
KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 17 247-4633
Replaced 245-0844
KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 51 300-0454
Replaced 248-7631,251-7446,
254-0988,259-5598,265-3321,272-5313,295-2322
w/ "Factory installed" 238-8091 Injectors SEP06 IC 51 300-0454
C7 KAL 350HP @ 2400 860 lb-ft (RV) ...* Important see note above for complete detail
KAL1-UP w/ "Field installed" 238-8091 Injectors SEP06 IC 52 300-0452
Replaced 248-7630,251-7445,
254-0986,259-5597,265-3320,272-5312,295-2321
w/ "Factory installed" 238-8091 Injectors SEP06 IC 52 300-0452
******************** Family of Medium Tactical Vehicle (FMTV) **************************
C7 FML 275HP @ 2200 RPM 860 lb-ft (FMTV)
FML 1-UP w/ "Factory installed" 238-8091 Injectors NOV09 IC 55 353-8652
Replaced 248-7642,259-5595,266-4248,280-3274,
296-0076
C7 FMM 330HP @ 2400 RPM 860 lb-ft (FMTV)
FMM 1-UP w/ "Factory installed" 238-8091 Injectors NOV09 IC 56 353-8653
Replaced 248-7643,259-5596,266-4249,280-3275,
296-0077
C7 330HP @ 2600 RPM FMM 1-UP NOV09 IC 82 353-8655
Replaced 325-4611
C7 275HP @ 2600 RPM FML 1-UP NOV09 IC 83 353-8684
Replaced 330-4542
C7 350HP @ 2600 RPM JRT 1-UP NOV09 IC 80 355-2831
Replaced 286-5702,303-4272,335-9389,346-5217
C7 350HP @ 2400RPM-261KW (Bronco Tactical Vehicle) Mar09 IC 85 344-9633
Replaced N/A
C7 370HP @ 2600RPM-276KW (Bronco Tactical Vehicle) Aug09 IC 84 346-3689
Replaced 338-3672
EURO III Rating for use in Europe only - not for North America use**************
C7 GOV SERIAL NO. FLASH P/M RELEASE
HORSEPOWER TORQUE SPEED RANGE FILE CODE DATE
190 HP 2500 RPM 142 KW-EURO3 331-0117 71 APR08
Replaced 290-0419
210 HP 2500 RPM 157 KW-EURO3 331-0119 70 APR08
Replaced 290-0418
210 HP 2500 RPM 157 KW-EURO3 331-0118 72 APR08
Replaced 290-0420
230 HP 2400 RPM 172 KW-EURO3 331-0120 73 APR08
Replaced 290-0421
250 HP 2400 RPM 186 KW-EURO3 331-0121 74 APR08
Replaced 290-0422
275 HP 2400 RPM 205 KW-EURO3 331-0122 75 APR08
Replaced 290-0423
300 HP 2400 RPM 224 KW-EURO3 331-0123 76 APR08
Replaced 290-0424
330 HP 2400 RPM 246 KW-EURO3 331-0124 77 APR08
Replaced 290-0425
*********************************** C9 Files *****************************************
NOTE: C9 335HP and 350HP 9DG 1 -700 were factory built with Injector p/n 233-3534.
If a "single" 233-3534 injector is replaced with a 239-6871 Injector w/seals
(238-8092 p/n on injector... not serviced) then "all six" injectors
must be updated to the same part number and the appropriate flash file and "etrim"
Files must be installed to match the "new" part number injector. Use list below to
determine flash file based on installed injector number.
Reference Truck Engine News SEBD6774 November 2004
C9 MTB 285 HP @ 2100 RPM 890 lb-ft (Bus) JAN05 IC 20 270-9204
Replaced 246-4701,251-7416,265-2873
C9 MTB 330 HP @ 2100 RPM 1150 lb-ft (Bus) AUG07 IC 22 319-1842
HEV (Hybrid Electric Vehicle)
Replaced 255-1178,260-1435,286-9589
C9 MTB 330 HP @ 2100 RPM 1150 lb-ft (Bus) SEP04 IC 12 260-1438
MTB00001-00999
Replaced 242-8332,247-4650
C9 MTB 330 HP @ 2100 RPM 1150 lb-ft (Bus) FEB08 IC 21 326-2663
Replaced 246-4700, 251-7415,260-1449,
286-9588,319-1843
C9 9DG 335 HP @ 2100 RPM 1050 lb-ft (TRUCK)
9DG1-700 w/factory installed 233-3534 injectors OCT03 IC 10 247-4652
Replaced 242-1854
9DG1-700 w/field installed 238-8092 injectors MAR04 IC 18 252-0028
9DG1000-UP NOV06 IC 23 305-7997
Replaced 251-7420,260-1450,273-3788,
280-9032,292-5521,296-8233
C9 9DG 350 HP @ 2100 RPM 1100 lb-ft (TRUCK)
9DG1-700 w/factory installed 233-3534 injectors OCT03 IC 11 247-4651
Replaced 242-1852
9DG1-700 w/field installed 238-8092 injectors MAR04 IC 19 252-0029
9DG1000-UP JAN08 IC 24 324-7773
Replaced 251-7419,260-1451,273-3789,
280-9033,286-5300,296-8234,305-7998
C9 9DG 400 HP @ 2300 RPM NOV09 IC 39 355-2987
Replaced 275-2256
C9 9DG 400 HP @ 2200 RPM MAY05 IC 40 275-2257
Replaced N/A
C9 9DG 450 HP @ 2300 RPM Rating NOT Developed Nov09 IC 41 355-2988
Replaced 275-2258
C9 9DG 370 HP @ 2100 RPM 1100 lb-ft (RV) MAR04 IC 30 253-0979
Replaced 251-7418
C9 9DG 400 HP @ 2100 RPM 1100 lb-ft (RV) SEP07 IC 25 320-0329
Replaced 249-9196,251-7418,258-2347,
265-2872,282-8992,289-1223,305-7972
C9 9DG 335 HP @ 2300 RPM 1050 lb-ft (ER) JAN07 IC 42 308-4885
Replaced 264-1214,292-5522
C9 9DG 350 HP @ 2300 RPM 1100 lb-ft (ER) JAN07 IC 43 308-4886
Replaced 264-1215
C9 9DG 400 HP @ 2300 RPM 1100 lb-ft (ER) SEP07 IC 31 320-0330
Replaced 258-2348,282-8993,290-9008,305-7973
C9 9DG 350 HP @ 2100 RPM 1100 lb-ft JAN08 IC 44 324-7772
PSO (Parts service only)
Replaced 293-4644,299-5079,305-7971
C9 LFR 400 HP @ 2300 RPM 1100 lb-ft OCT06 IC 45 303-1504
Defense and Federal Products
Replaced N/A
C9 (2007 Emissions A4 ECM) "Mid HP Ratings" 300HP to 425HP:
C9S00001-up Date Code Interlock Flash File
C9 285HP @ 2200 RPM 890lb-ft JUN08 30/130 334-2371
Replaced 313-2608,313-9567,321-7469,324-7645,
328-0711
C9 335HP @ 2200 RPM 1150lb-ft JUN08 31/131 334-2372
Replaced 313-9568,321-7470,324-7646,328-0712
C9 335HP @ 2200 RPM 1150lb-ft JUN08 32/132 334-2373
Replaced 313-2610,313-9569,321-7471,324-7647,
328-0713
C9 350HP @ 2200 RPM 1250lb-ft JUN08 33/133 334-2374
Replaced 313-2611,313-9570,321-7472,324-7648,
328-0714
C9 365HP @ 2200 RPM 1250lb-ft JUN08 34/134 334-2375
Replaced 313-2612,313-9571,321-7473,324-7649,
328-0715
C9 400HP @ 2300 RPM 1250lb-ft (RV) JUN08 35/135 334-2376
Replaced 313-2613,313-9572,321-5296,321-7474,
324-7650,328-0716
C9 425HP @ 2300 RPM 1250lb-ft (RV) JUN08 37/137 334-2378
Replaced 313-2615,313-9574,321-5298,321-7476,
324-7652,328-0718
C9 425HP @ 2300 RPM 1350lb-ft (RV) JUN08 39/139 334-2380
Replaced 313-2617,313-9576,321-5300,321-7478,
324-7654,328-0720
C9 400HP @ 2300 RPM 1250lb-ft (FT) JUN08 36/136 334-2377
Replaced 313-2614,313-9573,321-5297,321-7475.
324-7651,328-0717
C9 425HP @ 2300 RPM 1250lb-ft (FT) JUN08 38/138 334-2379
Replaced 313-2616,313-9575,321-5299,321-7477,
324-7653,328-0719
C9 425HP @ 2300 RPM 1350lb-ft (FT) JUN08 40/140 334-2381
Replaced 313-2618,313-9577,321-5301,321-7479,
324-7655,328-0721
C-10/C-12/3176B LOW NOX FLASH FILE CROSS REFERENCE
UPDATED December 21, 2000
The Low NOx Software files listed below have the same interlock codes as the
Standard rating software for the specified engines with 300 added to the interlock
code.
LOW NOX EMISSIONS REBUILD SOFTWARE FOR '98 IRON C-10/C-12 ADEM II
PARTS SERVICE ONLY (PSO)
'98 MY C-10 IRON
DESCRIPTION GOV S/N FLASH ITRLCK RELEASE
305 HP 1800/2100 8YS1 - UP 191-9918 325 OCT 00
1150/1050 PT
305 HP 1800/2100 8YS1 - UP 191-9919 330 OCT 00
(208.5? FAN-ON TEMP)
1150/1050 PT
335 HP 1800/2100 8YS1 - UP 191-9921 326 OCT 00
1250/1350 PT
335 HP 1800/2100 8YS1 - UP 191-9922 331 OCT 00
(208.5? FAN-ON TEMP) 1250/1350 PT
335/370HP MT 1800 8YS1 - UP 191-9920 329 OCT 00
1250/1350 PT
350 HP 1800/2100 8YS1 - UP 191-9923 327 OCT 00
1350 PT
370 HP 1800 8YS1 - UP 191-9924 328 OCT 00
1350 PT
'98 MY C-12 IRON
335 HP 2100 9NS1 - UP 191-9926 329 OCT 00
1550 PT
355 HP 1800/2100 9NS1 - UP 191-9928 324 OCT 00
1350 PT
355 HP 1800 9NS1 - UP 191-9927 331 OCT 00
(208.5? FAN-ON TEMP) 1350 PT
355/410 MT 1800/2100 9NS1 - UP 191-9937 327 OCT 00
1350/1450/1550 PT
380 HP 1800/2100 9NS1 - UP 191-9930 321 OCT 00
1450 PT
380/410 MT 1800 9NS1 - UP 191-9935 328 OCT 00
1450/1550 PT
380/430 MT 1800 9NS1 - UP 191-9938 322 OCT 00
1450/1650 PT
380/430 MT 1800 9NS1 - UP 191-9936 322 OCT 00
(SERVICES 153-8417 - TOP 2 GEARS ONLY - MS CARRIERS CUSTOMER ONLY)
1450/1650 PT
395 HP 2100 9NS1 - UP 191-9931 325 OCT 00
1450 PT
410 HP 1800/2100 9NS1 - UP 191-9932 326 OCT 00
1450/1550 PT
425 HP 2100 9NS1 - UP 191-9934 330 OCT 00
(EMERGENCY VEHICLE, RV, AND BUS ONLY) 1450/1550 PT
430 HP 1800/2100 9NS1 - UP 191-9933 316 OCT 00
1650 PT
455 HP 2100 9NS1 - UP 191-9929 320 OCT 00
(EMERGENCY VEHICLE, RV, AND BUS ONLY) 1550 PT
LOW NOX REBUILD SOFTWARE - PARTS SERVICE ONLY (PSO)
'97 MY C-10 IRON
280 HP 1800 2PN1 - UP 190-0224 305 DEC 99
280 HP 2100 2PN1 - UP 190-0225 306 DEC 99
305 HP 1800 2PN1 - UP 190-0226 307 DEC 99
305 HP 2100 2PN1 - UP 190-0227 308 DEC 99
305 HP 1800 2PN1 - UP 190-0231 307 DEC 99
(208.5Œ FAN-ON TEMP)
325 HP 1800 2PN1 - UP 190-0229 310 DEC 99
(FIELD UPRATE FOR 280 OR 305 HP IRON)
325 HP 2100 2PN1 - UP 190-0228 309 DEC 99
335 HP 1800 2PN1 - UP 190-0221 302 DEC 99
335 HP 1800 2PN1 - UP 190-0230 302 DEC 99
335/370HP MT 1800 2PN1 - UP 190-0223 304 DEC 99
350 HP 1800 2PN1 - UP 190-0220 301 DEC 99
370 HP 1800 2PN1 - UP 190-0222 303 DEC 99
'97 MY C-12 IRON
335 HP 2100 1YN1 - UP 190-0241 315 DEC 99
355 HP 1800 1YN1 - UP 190-0233 302 DEC 99
355 HP 1800 1YN1 - UP 190-0242 323 DEC 99
355/410HP MT 1800 1YN1 - UP 190-0235 304 DEC 99
360 HP 2100 1YN1 - UP 190-0238 307 DEC 99
380 HP 1800 1YN1 - UP 190-0234 303 DEC 99
380/410HP MT 1800 1YN1 - UP 190-0236 305 DEC 99
390 HP 2100 1YN1 - UP 190-0239 308 DEC 99
410 HP 1800 1YN1 - UP 190-0232 301 DEC 99
410 HP 2100 1YN1 - UP 190-0237 306 DEC 99
425 HP 2100 1YN1 - UP 190-0240 309 DEC 99
3176B LOW NOX REBUILD SOFTWARE - PARTS SERVICE ONLY (PSO)
275 HP 1800 9CK1 - UP 188-8079 304 DEC 99
(STANDARD)
188-8091 304 DEC 99
(208.5ŒF FAN-ON TEMP)
300 HP 1800 9CK1 - UP 188-8080 305 DEC 99
325 HP 1800 9CK1-18308 188-8081 302 DEC 99
325 HP 1800 9CK18309-UP 188-8086 326 DEC 99
325/350 HP 1800 9CK18309-UP 188-8087 327 DEC 99
MULTI TORQUE
335/365 HP 1800 9CK1 - UP 188-8084 313 DEC 99
MULTI TORQUE
342 HP 1800 9CK1 - UP 188-8085 312 DEC 99
(OIL FIELD ONLY)
350 HP 1800 9CK1 - UP 188-8082 301 DEC 99
365 HP 1800 9CK1 - UP 188-8083 309 DEC 99
300 HP (2T7318) 1800 9CK1 - UP 188-8088 334 DEC 99
(FIELD UPRATE ONLY! W/ 275 HP IRON)
350 HP (2T7314) 1800 9CK1-18308 188-8089 335 DEC 99
(FIELD UPRATE ONLY! W/ 325 HP IRON)
365 HP (2T7316) 1800 9CK18309-UP 188-8090 336 DEC 99
(FIELD UPRATE ONLY! W/ 325 HP OR 350 HP IRON)
C-10 TRUCK 2001 MY - CLEAN POWER
DESCRIPTION GOV S/N FLASH P/M RELEASE
305 HP 1800/2100 3CS23000 - UP 215-7354 20 JAN02
1050/1150 PT
335 HP 1800/2100 3CS23000 - UP 215-7355 21 JAN02
1250 PT
350 HP 1800/2100 3CS23000 - UP 270-7024 22 APR05
1350 PT
REPLACED 215-7357,237-0713,
241-0760,251-1818
370 HP 1800 3CS23000 - UP 215-7358 23 JAN02
1350 PT
335/370 HP MT 1800 3CS23000 - UP 215-7359 24 JAN02
1250/1350 PT
C-10 TRUCK 2000 MY - EPA CERTIFIED
305 HP 1800/2100 3CS12000 - 22999 270-7006 10 APR05
REPLACED 220-6615,237-0699,
241-0759,251-1761
335 HP 1800/2100 3CS12000 - 22999 220-6617 11 MAR02
350 HP 1800/2100 3CS12000 - 22999 220-6619 12 MAR02
370 HP 1800 3CS12000 - 22999 220-6620 13 MAR02
335/370 HP MT 1800 3CS12000 - 22999 220-6622 14 MAR02
C-10 TRUCK '99 MY - EPA CERTIFIED
305 HP 1800/2100 3CS1 - 11999 215-7806 6 MAR02
335 HP 1800/2100 3CS1 - 11999 215-7807 2 MAR02
350 HP 1800/2100 3CS1 - 11999 215-7808 4 MAR02
370 HP 1800 3CS1 - 11999 215-7809 5 MAR02
335/370 HP MT 1800 3CS1 - 11999 215-7810 3 MAR02
Note: The LOW NOx FLASH files each have an personality module code which has been incremented by 300, compared to the interlock code of the original production FLASH file it is replacing. For example, FLASH file 185-1177,
with a personality module code of 333, replaces the DEC98 PSO FLASH file 170-8128, which had a personality module code of 33.
C-10 TRUCK - EPA CERTIFIED
305 HP 1800/2100 8YS1 - UP 191-9918 325 OCT00
(Replaces 191-2810)
305 HP 1800/2100 8YS1 - UP 191-9919 330 OCT00
(208.5° FAN-ON TEMP)(Replaces 191-2811)
335 HP 1800/2100 8YS1 - UP 191-9921 326 OCT00
(Replaces 191-2812)
335 HP 1800/2100 8YS1 - UP 191-9922 331 OCT00
208.5° FAN-ON TEMP)(Replaces 191-2813)
335/370HP MT 1800 8YS1 - UP 191-9920 329 OCT00
(Replaces 191-2817)
350 HP 1800/2100 8YS1 - UP 191-9923 327 OCT00
(Replaces 191-2814)
350 HP 1800/2100 8YS1 - UP 191-9925 327 OCT00
(208.5°F FAN-ON TEMP Replaces 191-2815)
370 HP 1800 8YS1 - UP 191-9924 328 OCT00
(Replaces 191-2816)
280 HP 1800 2PN1 - UP 190-0224 305 DEC99
(Replaces 170-8077)
280 HP 2100 2PN1 - UP 190-0225 306 DEC99
(Replaces 170-8078)
305 HP 1800 2PN1 - UP 190-0226 307 DEC99
(Replaces 170-8079)
305 HP 2100 2PN1 - UP 190-0227 308 DEC99
(Replaces 170-8080)
305 HP 1800 2PN1 - UP 190-0231 307 DEC99
(208.5? FAN-ON TEMP)(Replaces 170-8084)
325 HP 1800 2PN1 - UP 190-0229 310 DEC99
(Replaces 170-8082)
325 HP 2100 2PN1 - UP 190-0228 309 DEC99
(Replaces 170-8081)
335 HP 1800 2PN1 - UP 190-0221 302 DEC99
(Replaces 170-8074)
335 HP 1800 2PN1 - UP 190-0230 302 DEC99
(208.5? FAN-ON TEMP)(Replaces 170-8083)
335/370HP MT 1800 2PN1 - UP 190-0223 304 DEC99
(Replaces 170-8076)
350 HP 1800 2PN1 - UP 190-0220 301 DEC99
(Replaces 170-8073)
370 HP 1800 2PN1 - UP 190-0222 303 DEC99
(Replaces 170-8075)
C-12 TRUCK 2001 MY - CLEAN POWER
335 HP 2100 2KS72000 - UP 215-7360 50 JAN02
1550 PT
355 HP 1800/2100 2KS72000 - UP 215-7361 51 JAN02
1350 PT
380 HP 1800/2100 2KS72000 - UP 338-5263 52 OCT08
1450 PT
Replaced 215-7362,237-0714,
241-0766,251-1820,270-7026
395 HP 1800/2100 2KS72000 - UP 338-5260 53 OCT08
1450 PT
Replaced 215-7363,236-1023,
241-0765,251-1819,270-7025
355/410 MT 1800/2100 2KS72000 - UP 270-7031 54 APR05
1350/1450/1550 PT
Replaced 215-7364,241-0774,251-1825
380/410 MT 1800 2KS72000 - UP 270-7032 55 APR05
1450/1550 PT
Replaced 215-7365,241-0775,251-1826
410 HP 1800/2100 2KS72000 - UP 338-5262 56 OCT08
1450/1550 PT
Replaced 215-7366,237-9263,
241-0773,251-1824,270-7030,296-6024
425 HP 2100 2KS72000 - UP 215-7367 57 JAN02
1450/1550 PT
380/430 MT 1800 2KS72000 - UP 338-5264 58 OCT08
1450/1650 PT
Replaced 215-7368,237-0715,
241-0767,251-1821,270-7027
430 HP 1800/2100 2KS72000 - UP 338-5261 59 OCT08
1650 PT
Replaced 215-7369,237-0716,
241-0768,251-1822,270-7028
455 HP 2100 2KS72000 - UP 215-7370 60 JAN02
1550 PT
EMERGENCY VEHICLE,RV AND BUS ONLY
505 HP 2100 2KS72000 - UP 270-7029 61 APR05
1550 PT
RV/FT
Replaced 215-7373,226-2039,
237-0717,241-0769,251-1823
C-12 TRUCK 2000 MY - EPA CERTIFIED
335 HP 2100 2KS40000 - 71999 220-6623 20 MAR02
355 HP 1800/2100 2KS40000 - 71999 220-6624 21 MAR02
380 HP 1800/2100 2KS40000 - 71999 270-7011 22 APR05
1450 PT
REPLACED 220-6625,237-0700,
241-0762,251-1766
395 HP 1800/2100 2KS40000 - 71999 220-6627 23 MAR02
355/410 MT 1800/2100 2KS40000 - 71999 270-7012 24 APR05
Replaced 220-6629,237-0701,
241-0763,251-1767
380/410 MT 1800 2KS40000 - 71999 220-6630 25 MAR02
410 HP 1800/2100 2KS40000 - 71999 220-6631 26 MAR02
425 HP 2100 2KS40000 - 71999 220-6632 27 MAR02
380/430 MT 1800 2KS40000 - 71999 270-7014 28 APR05
Replaced 220-6633,237-9262,
241-0772,251-1769
430 HP 1800/2100 2KS40000 - 71999 270-7013 29 APR05
1650 PT
REPLACED 220-6634,237-0702,
241-0764,251-1768
455 HP 2100 2KS40000 - 71999 220-6635 30 MAR02
505 HP 2100 2KS40000 - 71999 220-6636 31 MAR02
1550 PT
RV/FT
C-12 TRUCK '99 MY - EPA CERTIFIED
SPEED F RANGE FILE CODE DATE
335 HP 2100 2KS1 - 39999 215-7811 11 MAR02
355 HP 1800/2100 2KS1 - 39999 215-7812 12 MAR02
380 HP 1800/2100 2KS1 - 39999 270-7010 4 APR05
Replaced 215-7813,241-0776,251-1765
355/410 MT 1800/2100 2KS1 - 39999 215-7817 3 MAR02
380/410 MT 1800 2KS1 - 39999 215-7818 9 MAR02
380/430 MT-4 1800 2KS1 - 39999 270-7009 10 APR05
(STANDARD RATING OR MT-4)
Replaced 215-7820,215,241-0771,251-1764
380/430 MT-2 1800 2KS1 - 39999 270-7008 14 APR05
Replaced 215-7819, 241-0770,251-1763
395 HP 1800/2100 2KS1 - 39999 215-7815 6 MAR02
410 HP 1800/2100 2KS1 - 39999 215-7816 7 MAR02
430 HP 1800/2100 2KS1 - 39999 270-7007 8 APR05
1650 PT
REPLACED 215-7822,237-0688,241-0761,251-1762
425 HP 2100 2KS1 - 39999 215-7821 15 MAR02
455 HP 2100 2KS1 - 39999 215-7823 16 MAR02
335 HP 2100 9NS1 - UP 191-9926 329 OCT00
(Replaces 191-2818)
355 HP 1800/2100 9NS1 - UP 191-9928 324 OCT00
(Replaces 191-2819)
355 HP 1800 9NS1 - UP 191-9927 331 OCT00
(208.5? FAN-ON TEMP)(Replaces 191-2820)
355/410 MT 1800/2100 9NS1 - UP 191-9937 327 OCT00
(Replaces 191-2827)
380 HP 1800/2100 9NS1 - UP 191-9930 321 OCT00
(Replaces 191-2821)
380/410 MT 1800 9NS1 - UP 191-9935 328 OCT00
(Replaces 191-2828)
380/430 MT 1800 9NS1 - UP 191-9938 322 OCT00
(Replaces 191-3727)
380/430 MT 1800 9NS1 - UP 191-9936 322 OCT00
(Replaces 168-7029)
395 HP 2100 9NS1 - UP 191-9931 325 OCT00
(Replaces 191-2822)
410 HP 1800/2100 9NS1 - UP 191-9932 326 OCT00
(Replaces 191-2823)
425 HP 2100 9NS1 - UP 191-9934 330 OCT00
(EMERGENCY VEHICLE, RV, AND BUS ONLY)(Replaces 191-2824)
430 HP 1800/2100 9NS1 - UP 191-9933 316 OCT00
(Replaces 191-2825)
455 HP 2100 9NS1 - UP 191-9929 320 OCT00
(EMERGENCY VEHICLE, RV, AND BUS ONLY) (Replaces 191-2826)
335 HP 1550 LB-FT 2100 1YN1 - UP 190-0241 315 DEC99
Replaced 170-8094
355 HP 1350 LB-FT 1800 1YN1 - UP 190-0233 302 DEC99
Replaced 170-8086
355 HP 1350 LB-FT 1800 1YN1 - UP 190-0242 323 DEC99
Replaced 170-8095
355/410HP MT 1800 1YN1 - UP 190-0235 304 DEC99
1350/1450/1550 LB-FT
Replaced 170-8088
360 HP 1350 LB-FT 2100 1YN1 - UP 190-0238 307 DEC99
Replaced 170-8091
380 HP 1450 LB-FT 1800 1YN1 - UP 190-0234 303 DEC99
Replaced 170-8087
380/410HP MT 1800 1YN1 - UP 190-0236 305 DEC99
1450/1550 LB-FT
Replaced 170-8089
390 HP 1450 LB-FT 2100 1YN1 - UP 190-0239 308 DEC99
Replaced 170-8092
410 HP 1800 1YN1 - UP 190-0232 301 DEC99
1450/1550 LB-FT
Replaced 170-8085
410 HP 2100 1YN1 - UP 190-0237 306 DEC99
1450/1550 LB-FT
Replaced 170-8090
425 HP 2100 1YN1 - UP 190-0240 309 DEC99
1450/1550 LB-FT
Replaced 170-8093
C-10/C-12 CLEAN POWER WITH AIR INLET SHUTOFF
335 HP 1800/2100 3CS23000 - UP 224-4619 26 AUG02
1250 PT
Replaced 215-7356,224-0816
410 HP 1800/2100 2KS72000 - UP 215-7371 63 JAN02
1450/1550 PT
410 HP 1800/2100 2KS72000 - UP 224-4620 67 AUG02
1450/1550 PT
Replaced 224-0817
430 HP 1800/2100 2KS72000 - UP 215-7372 62 JAN02
1650 PT
430 HP 1800/2100 2KS72000 - UP 224-4621 66 AUG02
1650 PT REPLACED 224-0818
C-10/C-12 WITH AIR INLET SHUTOFF
335 HP 1800/2100 3CS12000-22999 220-6618 15 MAR02
1250 PT
335 HP 1800/2100 3CS12000-22999 224-4616 17 AUG02
1250 PT REPLACED 224-0813
410 HP 1800/2100 2KS40000-71999 220-6637 35 MAR02
1450/1550 PT
410 HP 1800/2100 2KS40000-71999 224-4617 37 AUG02
1450/1550 PT REPLACED 224-0814
430 HP 1800/2100 2KS40000-71999 220-6638 34 MAR02
1650 PT
430 HP 1800/2100 2KS40000-71999 224-4618 36 AUG02
1650 PT REPLACED 224-0815
C-12 MTVR
355/410 MT 2100 9SM00001-1499 220-4351 18 APR02
355/410 MT 2100 9SM01500 - UP 220-4352 65 APR02
(Clean Power)
C13 TRUCK EURO3 (NOT FOR USE IN THE UNITED STATES)
380 HP 2100 JAM1 - UP 307-1467 66 DEC06
Replaced 273-8798,291-2044,295-1536
430 HP 2100 JAM1 - UP 307-1468 67 DEC06
Replaced 273-8799,291-2045,295-1537
470 HP 2100 JAM1 - UP 307-1469 68 DEC06
Replaced 273-8800,291-2046,295-1538
C-10/C-12 TRUCK EURO II CERTIFIED (NOT FOR USE IN THE UNITED STATES)
325 HP 1900 8YS1 - UP 191-0986 44 MAR 00
365 HP 1900 8YS1 - UP 191-0987 46 MAR 00
335 HP 1900 9NS1 - UP 191-0988 37 MAR 00
380 HP 1900 9NS1 - UP 191-0989 38 MAR 00
410 HP 1900 9NS1 - UP 191-0990 39 MAR 00
325 HP 1900 8YS1 - UP 158-9979 33 FEB 98
350 HP 1900 8YS1 - UP 158-9981 34 FEB 98
365 HP 1900 8YS1 - UP 158-9983 35 FEB 98
335 HP 1900 9NS1 - UP 158-2023 32 FEB 98
380 HP 1900 9NS1 - UP 153-9616 33 FEB 98
410 HP 1900 9NS1 - UP 153-9618 34 FEB 98
C-12 TRUCK EURO III CERTIFIED (NOT FOR USE IN THE UNITED STATES)
430 HP 1900 229-2780 47 APR 03
430 HP 1900 250-2988 47 APR 03
For GREECE truck engines
C-10 TRUCK EURO II CERTIFIED (NOT FOR USE IN THE UNITED STATES)
325 HP 1900 2PN1 - UP 120-8935 12 APR 99
350 HP 1900 2PN1 - UP 120-8951 11 APR 99
365 HP 1900 2PN1 - UP 120-8922 13 APR 99
C-10 CNF TRUCK - EPA CERTIFIED
335 HP (2000 MY) 1800/2100 3CS12000-22999 223-9987 11 APR 02
335 HP (1999 MY) 1800/2100 3CS1-11999 223-9986 2 APR 02
C-12 CNF TRUCK 2000 MY - EPA CERTIFIED
355 HP (1999 MY) 1800/2100 2KS00001 - 39999 223-9988 12 APR02
355 HP (2000 MY) 1800/2100 2KS40000 - 71999 223-9989 21 APR02
355 HP (2001 MY) 1800/2100 2KS72000 - UP 223-9992 51 APR02
355/410 HP (1999 MY) 1800/2100 2KS1 - 39999 223-9990 3 APR02
355/410 HP (2000 MY) 1800/2100 2KS40000 -71999 223-9991 24 APR02
355/410 HP (2001 MY) 1800/2100 2KS72000 - UP 223-9993 54 APR02
This Section is Industrail Engine with Truck Software
C13 440HP 2100 EMS1-UP 365-1096 205 Nov10
Replaced 312-3134
600HP 2100 PRM1-UP 364-9748 206 Nov10
Replaced 340-1103,347-3441,355-9837
C-15/C-16/C-18 Flash File Cross Reference
Truck Engines 6NZ and 7CZ and EGH (Gov.)
Updated January 15,2008 AJK
C-15 CLEAN POWER GOV SERIAL NO. FLASH P/M RELEASE
C-15 (6NZ) LOW HP ENGINE SERIAL NO. FLASH P/M RELEASE
RATING INFORMATION RANGE FILE CODE DATE
355 HP 1350 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7374 120 JAN02
REPLACED 208-5761
355 HP 1350/1450 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7375 121 JAN02
MULTITORQUE
REPLACED 208-5762
375 HP 1450 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7376 122 JAN02
REPLACED 208-5763
375 HP 1450/1550 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7377 123 JAN02
MULTITORQUE
REPLACED 208-5764
375/435 HP 1450/1550 LB-FT 1800 RPM 6NZ54000-UP 270-7116 124 APR05
MULTITORQUE
REPLACED 251-1526
410 HP 1450/1550 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7379 125 JAN02
REPLACED 208-5766
450 HP 1550/1650 LB-FT 2100 RPM 6NZ54000-UP 215-7383 129 JAN02
REPLACED 208-5770
C-15 (6NZ) HIGH HP ENGINE SERIAL NO. FLASH P/M RELEASE
435 HP 1550/1650 LB-FT 1800/2100 RPM 6NZ54000-UP 270-7115 126 APR05
REPLACED 251-1525
435HP 1550/1650 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7381 127 JAN02
MULTITORQUE
REPLACED 208-5768
435/500 HP 1550/1650 LB-FT 2100 RPM 6NZ54000-UP 300-1385 128 SEP06
MT SUPPORT ALLISON OWS 4700 TRANS
REPLACED 251-1533,270-7123
455 HP 1550/1650 LB-FT 1800/2100 RPM 6NZ54000-UP 338-5273 130 OCT08
REPLACED 251-1527,270-7117
455 HP 1550/1650 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7385 131 JAN02
MULTITORQUE
REPLACED 208-5773
455 HP 1550/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7386 132 JAN02
MULTITORQUE
REPLACED 208-5774
455 HP 1550/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7387 133 JAN02
MULTITORQUE BRAKESAVER
REPLACED 208-5775
475 HP 1650/1750 LB-FT 1800/2100 RPM 6NZ54000-UP 338-5268 134 OCT08
REPLACED 251-1528,270-7118
475HP 1650/1750 LB-FT 1800/2100 RPM 6NZ54000-UP 338-5269 135 OCT08
BRAKESAVER
REPLACED 251-1529,270-7119
475/500 HP 1650/1850 LB-FT 2100 RPM 6NZ54000-UP 215-7390 136 JAN02
TOP 2 GEAR MULTITORQUE
REPLACED 208-5778
475/500 HP 1650/1850 LB-FT 2100 RPM 6NZ54000-UP 215-7391 137 JAN02
REPLACED 208-5779
475/500 HP 1650/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7392 138 JAN02
REPLACED 208-5780
475/500HP 1650/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7393 139 JAN02
TOP 2 GEAR MULTITORQUE BRAKESAVER
REPLACED 208-5781
500HP 1650 LB-FT 2100 RPM 6NZ54000-UP 338-5272 140 OCT08
500HP FLEET 1750 LB-FT 2100 RPM
435/500 HP 1550/1650 LB-FT OIL WELL SERVICE
REPLACED 208-5782,215-7394,244-1565,328-1938
500 HP 1650/1750 LB-FT 2100 RPM 6NZ54000-UP 215-7395 141 JAN02
BRAKESAVER
REPLACED 208-5783
500 HP 1850 LB-FT 2300 RPM 6NZ54000-UP 215-7396 142 JAN02
REPLACED 208-5784
500 HP 1850 LB-FT 2300 RPM 6NZ54000-UP 215-7397 143 JAN02
BRAKESAVER
REPLACED 208-5785
500 HP 1750/1850 LB-FT 2100 RPM 6NZ54000-UP 215-7398 144 JAN02
REPLACED 208-5786
500 HP 1750/1850 LB-FT 2100 RPM 6NZ54000-UP 215-7399 145 JAN02
REPLACED 208-5787
500 HP 1850 LB-FT 1800/2100 RPM 6NZ54000-UP 338-5270 146 OCT08
REPLACED 208-5788,215-7400,
237-0723,241-0788,244-1568
500 HP 1850 LB-FT 1800/2100 RPM 6NZ54000-UP 215-7401 147 JAN02
BRAKESAVER
REPLACED 208-5789
550 HP 1850 LB-FT 2100 RPM 6NZ54000-UP 338-5274 148 OCT08
REPLACED 244-1567,305-2778,320-2698
550 HP 1850 LB-FT 2100 RPM 6NZ54000-UP 270-7120 149 APR05
BRAKESAVER
REPLACED 251-1530
550 HP 1850 LB-FT 2100 RPM 6NZ54000-UP 270-7121 150 APR05
2300 RPM TEL FIELD UPRATE ONLY
REPLACED 251-1531
550 HP 1850 LB-FT 2100 RPM 6NZ54000-UP 270-7122 151 APR05
BRAKESAVER
REPLACED 251-1532
355HP 1350PT 1800/2100RPM 6NZ1-53999 220-6640 70 MAR02
355HP 1350/1450PT 1800 RPM 6NZ1-53999 220-6641 71 MAR02
1350/1450PT 2100 RPM
MULTITORQUE
375HP 1450PT 1800/2100RPM 6NZ1-53999 220-6642 72 MAR02
375/435HP 1450/1550PT 1800PRM 6NZ1-53999 220-6644 55 MAR02
1450/1650PT 1800 RPM
MULTITORQUE
375HP MT 1450/1550PT 1800RPM 6NZ1-53999 220-6643 73 MAR02
1450/1550PT 2100RPM
410HP 1450/1550PT 1800/2100RPM 6NZ1-53999 220-6645 74 MAR02
FIELD UPRATE ONLY
450HP 1550/1650PT 2100RPM 6NZ1-53999 220-6650 78 MAR02
FIELD UPRATE ONLY
435HP 1550/1650PT 1800/2100RPM 6NZ1-53999 270-7073 75 APR05
Replaced 220-6646,241-0793,251-2217
435HP 1550/1650PT 1800/2100RPM 6NZ1-53999 220-6647 76 MAR02
BRAKESAVER
435/500HP 1550/1650 2100RPM 6NZ1-53999 270-7074 77 APR05
MULTITORQUE
Replaced 220-6649,241-0794,
251-2218
455HP 1550PT 2100RPM OR 6NZ1-53999 220-6651 79 MAR02
1650PT 1800/2100RPM
455HP 1550PT 2100RPM OR 6NZ1-53999 220-6652 80 MAR02
1650PT 1800/2100RPM BRAKESAVER
455HP 1550/1750PT 2100 RPM 6NZ1-53999 220-6653 81 MAR02
MULTITORQUE
455HP 1550/1750PT 2100 RPM 6NZ1-53999 220-6654 82 MAR02
BRAKESAVER MULTITORQUE
475HP 1650/1750PT 1800/2100RPM 6NZ1-53999 270-7067 6 APR05
REPLACED 220-6655,237-0703,
241-0777,251-2211
475HP 1650/1750PT 1800/2100RPM 6NZ1-53999 270-7068 83 APR05
BRAKESAVER
REPLACED 220-6657, 2370704,
241-0778,251-2212
475/500HP 1650/1850PT 2100 RPM 6NZ1-53999 220-6658 84 MAR02
475/500HP 1650/1850PT 2100 RPM 6NZ1-53999 220-6659 85 MAR02
475/500HP 1650/1750PT 2100 RPM 6NZ1-53999 220-6660 86 MAR02
475/500HP 1650/1750PT 2100 RPM 6NZ1-53999 220-6661 87 MAR02
500HP 1650PT 2100RPM, 6NZ1-53999 220-6662 88 MAR02
500HP FLEET 1750PT 2100RPM or
435/500HP 1550/1650 OIL WELL SERVICE
500HP 1650PT 2100RPM BRAKESAVER 6NZ1-53999 220-6664 89 MAR02
OR 500HP FLEET 1750PT 2100RPM BRAKESAVER
500HP 1850PT 1800/2100RPM 6NZ1-53999 220-6665 90 MAR02
2300RPM TEL FIELD UPRATE ONLY
500HP 1750/1850PT 2100 RPM 6NZ1-53999 220-6667 92 MAR02
500HP 1750/1850PT 2100 RPM 6NZ1-53999 220-6668 93 MAR02
500HP 1850PT 1800/2100RPM 6NZ1-53999 220-8235 94 MAR02
500HP 1850PT 1800/2100RPM 6NZ1-53999 220-8236 95 MAR02
BRAKESAVER
500HP 1850PT 1800/2100RPM 6NZ1-53999 220-6666 91 MAR02
BRAKESAVER 2300RPM TEL FIELD UPRATE ONLY
550HP 1850PT 2100RPM 6NZ1-53999 270-7069 7 APR05
REPLACED 220-8237, 237-0705,241-0779,251-2213
550HP 1850PT 2100RPM BRAKESAVER 6NZ1-53999 270-7070 96 APR05
REPLACED 220-8238, 237-0706,
241-0780,251-2214
550HP 1850PT 2100RPM 6NZ1-53999 270-7071 97 APR05
REPLACED 220-8239, 237-0707,241-0781,251-2215
550HP 1850PT 2100RPM BRAKESAVER 6NZ1-53999 270-7072 98 APR05
REPLACED 220-8240, 237-0708,241-0782,251-2216
C-16 CLEAN POWER GOV SERIAL NO. FLASH P/M RELEASE
575HP 1850PT 2100RPM 7CZ02800-UP 215-7406 152 JAN02
REPLACED 208-5794
575HP 1850PT 2100RPM 7CZ02800-UP 215-7407 153 JAN02
BRAKESAVER REPLACED 208-5795
575HP 1850PT 2100RPM 7CZ02800-UP 215-7408 154 JAN02
REPLACED 208-5796 TEL 2300RPM
575HP 1850PT 2100RPM 7CZ02800-UP 215-7409 155 JAN02
BRAKESAVER REPLACED 208-5797 TEL 2300RPM
575/600HP 1850/2050PT 2100RPM 7CZ02800-UP 215-7410 156 JAN02
MULTITORQUE REPLACED 208-5798
575/600HP 1850/2050PT 2100RPM 7CZ02800-UP 215-7411 157 JAN02
REPLACED 208-5799
600HP 2050PT 2100RPM 7CZ02800-UP 338-5275 158 OCT08
REPLACED 208-5800,215-7412,237-0728,
241-0800,251-1534,270-7124
600HP 2050PT 2100RPM 7CZ02800-UP 270-7125 159 APR05
BRAKESAVER
REPLACED 208-5801,215-7413,237-0729,241-0801,251-1535
600HP 2050PT 2100RPM 7CZ02800-UP 270-7126 160 APR05
TEL 2300RPM
REPLACED 208-5802,215-7414,237-0730,
241-0802,251-1536
600HP 2050PT 2100RPM 7CZ02800-UP 270-7127 161 APR05
BRAKESAVER TEL 2300RPM
REPLACED 208-5803,215-7415,237-0731,
241-0803,251-1537
650HP 2050PT 2100RPM 7CZ02800-UP 267-5143 162 JAN05
Aircraft Rescue Firetruck only - Oshkosh
REPLACED 208-0523,251-1626
680HP 1951PT 2100RPM 7CZ02800-UP 267-5143 162 JAN05
REPLACED 232-2644,243-0022,251-1626
C-16 (7CZ) ENGINE SERIAL NO. FLASH P/M RELEASE
575HP 1850PT 2100RPM 7CZ1-02799 220-8241 56 MAR02
REPLACES 198-3265
575HP 1850PT 2100RPM BRAKESAVER 7CZ1-02799 220-8242 99 MAR02
REPLACES 198-3266
575HP 1850PT 2100RPM 7CZ1-02799 220-8243 101 MAR02
REPLACES 198-3267
575HP 1850PT 2100RPM BRAKESAVER 7CZ1-02799 220-8244 100 MAR02
REPLACES 198-3268
575/600HP 1850/2050PT 2100RPM 7CZ1-02799 220-8245 102 MAR02
REPLACES 198-3269
MULTITORQUE
575/600HP MT 1850/2050PT 2100RPM 7CZ1-02799 220-8246 103 MAR02
BRAKESAVER
REPLACES 198-3270
600HP 2050PT 2100RPM 7CZ1-02799 270-7075 8 APR05
REPLACES 198-3271,220-8247,237-0709,
241-0796,251-2219
600HP 2050PT 2100RPM BRAKESAVER 7CZ1-02799 270-7076 104 APR05
REPLACES 198-3272,220-8248,237-0710,
241-0797,251-2220
600HP 2050PT 2100RPM 7CZ1-02799 270-7077 105 APR05
REPLACES 198-3273,220-8249,237-0711,
241-0798,251-2221
600HP 2050PT 2100RPM BRAKESAVER 7CZ1-02799 270-7078 106 APR05
REPLACES 198-3274,220-8250,237-0712,
241-0799,251-2222
650HP 2050PT 2100PRM 220-4294 162 FEB02
AIRCRAFT/FIRE FIGHTING APPLICATION
650HP 1951PT 2100/2300 TEL 7CZ1-02799 251-1629 163 APR04
REPLACES 232-2643, 235-6399,241-0816
C-18
C-18 700HP @2300RPM 1900PT@2100RPM MEP1-UP 241-0817 1 JUN03
Military only
REPLACED 217-3928,224-9318,227-5521,232-2647,
238-2680,239-4147
C-18 700HP @2300RPM 1900PT@2100RPM MEP1-UP 232-2648 1 NOV02
Military only
REPLACED 226-4417,227-5522
C-16 EGH
525 HP 1773 LB-FT 2100/2300 TEL 6NZ54000-UP 268-0221 164 APR05
(Government/Military) EGH
REPLACED 251-1628
2yg & 7lg Personality Module Cross Reference with Chips not Flashfiles
3176 2YG & 7LG PERSONALITY MODULE CROSS REFERENCE
UPDATED 6/22/95
DESCRIPTION S/N PART RE-MAN INTERLOCK RELEASE
RANGE NUMBER PART NUMBER CODE DATE
250 HP 2YG1 - UP 114-6689 0R6891 3 JUL 93
STANDARD
250 HP 2YG1 - UP 114-6707 0R6895 5 JUL 93
URBAN BUS
275 HP 2YG1 - UP 114-6691 0R6892 4 JUL 93
STANDARD
300 HP 2YG1 - UP 114-6694 0R6893 1 JUL 93
STANDARD
325 HP 2YG1 - UP 114-6698 0R6894 2 JUL 93
STANDARD
325 TO 350 2YG1 - UP 113-8969 NOT AVAIL 29 JUL 93
UPGRADE KIT
250 HP 7LG1-07499 112-2074 0R6851 8 JUL 93
STANDARD
250 HP 7LG1-07499 112-2078 0R6855 13 JUL 93
URBAN BUS
275 HP 7LG1-07499 112-2075 0R6852 9 JUL 93
STANDARD
275 HP 7LG1-07499 112-2082 NOT AVAIL 9 JUL 93
J1922
275 HP 7LG1-07499 112-2079 NOT AVAIL 9 JUL 93
BULK HAULER
300 HP 7LG1-07499 112-2076 0R6853 10 JUL 93
STANDARD
300 HP 7LG1-07499 112-2085 NOT AVAIL 10 JUL 93
J1922
300 HP 7LG1-07499 112-2080 NOT AVAIL 10 JUL 93
BULK HAULER
325 HP 7LG1-07499 112-2077 0R6854 11 JUL 93
STANDARD
325 HP 7LG1-07499 112-2087 0R6856 11 JUL 93
J1922
325 HP 7LG1-07499 112-2081 NOT AVAIL 11 JUL 93
BULK HAULER
325 TO 350 7LG1-07499 115-3011 NOT AVAIL 30 JUL 93
UPGRADE KIT
275 HP 7LG07500-15999 112-2072 0R6857 19 JUL 93
STANDARD
275 HP 7LG07500-15999 112-2068 0R6861 19 JUL 93
J1922
275 HP 7LG07500-15999 112-2063 NOT AVAIL 19 JUL 93
BULK HAULER
300 HP 7LG07500-15999 112-2071 0R6858 20 JUL 93
STANDARD
300 HP 7LG07500-15999 112-2067 0R6862 20 JUL 93
J1922
300 HP 7LG07500-15999 112-2062 NOT AVAIL 20 JUL 93
BULK HAULER
325 HP 7LG07500-15999 112-2070 0R6859 16 JUL 93
STANDARD
325 HP 7LG07500-15999 112-2065 0R6863 16 JUL 93
J1922
325 HP 7LG07500-15999 112-2061 NOT AVAIL 16 JUL 93
BULK HAULER
350 HP 7LG07500-15999 112-2069 0R6860 16 JUL 93
STANDARD
350 HP 7LG07500-15999 112-2064 0R6864 16 JUL 93
J1922
350 HP 7LG07500-15999 112-2060 NOT AVAIL 16 JUL 93
BULK HAULER
275 HP 7LG16000-UP 111-4156 0R6841 28 JUL 93
STANDARD
275 HP 7LG16000-UP 111-4150 0R6846 28 JUL 93
J1922
275 HP 7LG16000-UP 111-4188 NOT AVAIL 28 JUL 93
BULK HAULER
300 HP 7LG16000-UP 111-4154 0R6842 27 JUL 93
STANDARD
300 HP 7LG16000-UP 111-4148 0R6847 27 JUL 93
J1922
300 HP 7LG16000-UP 111-4186 NOT AVAIL 27 JUL 93
BULK HAULER
325 HP 7LG16000-UP 111-4158 0R6843 26 JUL 93
STANDARD
325 HP 7LG16000-UP 111-4146 0R6848 26 JUL 93
J1922
325 HP 7LG16000-UP 111-4184 NOT AVAIL 26 JUL 93
BULK HAULER
350 HP 7LG16000-UP 111-4152 0R6844 25 JUL 93
STANDARD
350 HP 7LG16000-UP 111-4144 0R6849 25 JUL 93
J1922
350 HP 7LG16000-UP 111-4182 NOT AVAIL 25 JUL 93
BULK HAULER
360 HP 7LG16000-UP 111-4160 0R6845 24 JUL 93
STANDARD
360 HP 7LG16000-UP 111-4173 0R6850 24 JUL 93
J1922
360 HP 7LG16000-UP 111-4162 NOT AVAIL 24 JUL 93
BULK HAULER
325 HP 7LG CHALLENGER 3E5491 OR6573 18 OCT 91
3176B FLASH FILE CROSS REFERENCE
UPDATED 5/21/98
WARNING!!!
The original personality modules in some 3176B and 3406E engines between
9CK1 - 5000 and 5EK1 - 5000 can NOT be flashed with NOV95 or newer
software. The Flash program may terminate at 20 to 25% complete when
attempting to flash these personality modules with NOV95 or newer software.
Many of the personality modules in the affected serial number range can be
flashed with NOV95 or newer software because the original personality
module was replaced with a compatible one during an earlier software update
or ECM replacement. However, before attempting to flash the personality
modules on engines in the affected range, make sure that there is a
106-9184 personality module available. If the flash attempt fails, try
again. If both attempts terminate at 20 to 25% complete, replace the
personality module with the 106-9184 module and repeat the flash
programming.
Since the flash process erases the file from the personality module before
programming it, a failure while flashing the personality module in the
affected range will render the engine inoperable. Once this occurs, there
are two options; 1) replace the personality module with a 106-9184 module
and re-flash or 2) flash the original personality module with pre-NOV95
software.
Option 1 is the preferred method since it makes the engine compatible with
all future software releases. However, if a new personality module is not
available option 2 can be used. The pre-NOV95 files have been put back on
the Caterpillar mailbox for downloading. They are listed below along with
the current files.
The latest flash files call for default injector codes to be entered. The
default injector code for 3176B, C-10, and C-12 engines is 2300.
TRUCK (Factory Ratings)
DESCRIPTION GOV S/N FLASH SERVICE ITRLCK RELEASE
SPEED RANGE CODE REPLACEMENT CODE DATE
275 HP 1800 9CK1 - UP 146-9259 146-9261 4 MAR 97
(STANDARD)
146-9368 4 MAR 97
125-7999 125-8001 4 JUN 95
(STANDARD)
300 HP 1800 9CK1 - UP 146-9262 146-9264 5 MAR 97
125-8002 125-8004 5 JUN 95
325 HP 1800 9CK1-18308 159-2840 2 FEB 98
129-2589 129-2591 2 JUN 95
325 HP 1800 9CK18309-UP 159-2838 26 FEB 98
(STANDARD)
141-9470 26 AUG 96
125-8018 125-8021 26 JUN 95
(STANDARD)
325/350 HP 1800 9CK18309-UP 159-2839 27 FEB 98
MULTI TORQUE 125-8022 125-8024 27 JUN 95
335/365 HP 1800 9CK1 - UP 159-2837 13 FEB 98
MULTI TORQUE 125-8012 125-8014 13 JUN 95
TRUCK (Factory Ratings)(cont'd)
342 HP 1800 9CK1 - UP 146-9276 146-9278 12 MAR 97
(OIL FIELD ONLY) 125-8015 125-8017 12 JUN 95
350 HP 1800 9CK1 - UP 159-2835 1 FEB 98
125-8005 125-8007 1 JUN 95
365 HP 1800 9CK1 - UP 159-2836 9 FEB 98
125-8008 125-8010 9 JUN 95
* MAR 97 effective with factory built 3176B engine S/N 9CK32702.
TRUCK (Field Uprate Ratings)
300 HP (2T7318)1800 9CK1 - UP 159-2841 34 FEB 98
132-9662 132-9664 34 FEB 96
350 HP (2T7314)1800 9CK1-18308 159-2842 35 FEB 98
132-9666 132-9668 35 FEB 96
365 HP (2T7316)1800 9CK18309-UP 159-2843 36 FEB 98
132-9671 132-9673 36 FEB 96
365 HP (2T7316)1800 9CK1 - UP 159-2843 36 FEB 98
(FIELD UPRATE ONLY! W/ 350 HP IRON)
3406B/C PEEC, PEEC II, PEEC 2.5, AND ELECTRONIC_PERSONALITY MODULE CROSS REF
PERSONALITY MODULE CROSS-REFERENCE
October 20,1997
ECM Eng S/N Range HP Rating IC PM
II 8TC1-1412 285 EPA 2 1019291-00
II 8TC1-1412 285 EPA 2 0R6666-00
II 8TC1413-10980 285 EPA 101 1019295-00
II 8TC1413-10980 285 EPA 101 0R6648-00
II 8TC1413-Up 285 CARB 102 1019282-00
II 8TC1413-Up 285 CARB 102 0R6656-00
II 8TC1-1412 310 EPA 2 1019292-00
II 8TC1-1412 310 EPA 2 0R6667-00
II 8TC1413-10980 310 EPA 101 1019296-00
II 8TC1413-10980 310 EPA 101 0R6649-00
II 8TC1413-UP 310 CARB 102 1019283-00
II 8TC1413-UP 310 CARB 102 0R6657-00
II 8TC1413-UP 310 MT Top1 CARB 113 1019307-00
II 8TC1413-UP 310 MT Top1 CARB 113 0R6664-00
II 8TC1413-UP 310 MT Top4 CARB 113 1022492-00
II 8TC1413-UP 310 MT Top4 CARB 113 0R6681-00
II 8TC1413-10980 310 PDCC EPA 108 1019303-00
II 8TC1413-10980 310 PDCC EPA 108 0R6655-00
II 8TC1413-UP 310 PDCC CARB 109 1019290-00
II 8TC1413-UP 310 PDCC CARB 109 0R6665-00
II 2EK1 - UP 310 Std 10 1019248-00
II 2EK1 - UP 310 Std 10 0R6632-00
II 2EK1 - UP 310 MT Top1 11 1019249-00
II 2EK1 - UP 310 MT Top1 11 0R6633-00
II 2EK1 - UP 310 MT Top4 11 1022490-00
II 2EK1 - UP 310 MT Top4 11 0R6679-00
II 2EK1 - UP 310 PDCC 12 1019250-00
II 2EK1 - UP 310 PDCC 12 0R6634-00
II.V 8TC9090 - 10980 310 EPA 101 1019296-00
II.V 8TC9090 - 10980 310 EPA 101 0R6649-00
II.V 8TC10981 - Up 310 CARB 102 1019283-00
II.V 8TC10981 - Up 310 CARB 102 0R6657-00
II.V 8TC10981 - Up 310 MT Top1 CARB 113 1022492-00
II.V 8TC10981 - Up 310 MT Top1 CARB 113 0R6681-00
II.V 2EK1 - UP 310 NAR 10 1019248-00
II.V 2EK1 - UP 310 NAR 10 0R6632-00
II.V 2EK1 - Up 310 MT Top1 11 1019249-00
II.V 2EK1 - Up 310 MT Top1 11 0R6633-00
III 4CK1 - Up 310@1800 10 1457832-00
III 4CK1 - Up 310 MT Top1 11 1457834-00
III 4CK1 - Up 310 MT Top4 11 1457849-00
III 4CK1 - Up 310 PDCC 12 1457851-00
II 8TC1 - 1412 330/350LT EPA 1 1019293-00
II 8TC1 - 1412 330/350LT EPA 1 0R6646-00
II 8TC1413 - 10980 330/350LT EPA 103 1019297-00
II 8TC1413 - 10980 330/350LT EPA 103 0R6650-00
II 8TC8792 - UP 330/350LT NAR LCV 114 1019284-00
II 8TC8792 - UP 330/350LT NAR LCV 114 0R6658-00
II 2EK1 - Up 330@1800 23 1019251-00
II 2EK1 - Up 330@1800 23 0R6635-00
II.V 2EK1 - Up 330@1800 23 1019251-00
II.V 2EK1 - Up 330@1800 23 0R6635-00
III 4CK1 - Up 330@1800 23 1457853-00
II 8TC1 - 1412 350 EPA 1 1019294-00
II 8TC1 - 1412 350 EPA 1 0R6647-00
II 8TC1413 - 10980 350 EPA 103 1019298-00
II 8TC1413 - 10980 350 EPA 103 0R6651-00
II 8TC8792 - UP 350 NAR LCV 114 1019285-00
II 8TC8792 - UP 350 NAR LCV 114 0R6659-00
II 8TC1413 - Up 350 EPA MT Top2 121 1022493-00
II 8TC1413 - Up 350 EPA MT Top2 121 0R6682-00
II 8TC1413 - Up 350 EPA MT Top4 121 1022494-00
II 8TC1413 - Up 350 EPA MT Top4 121 0R6683-00
II 2EK1 - Up 350@2000 13 1019252-00
II 2EK1 - Up 350@2000 13 0R6636-00
II 2EK1 - Up 350@1800 14 1019253-00
II 2EK1 - Up 350@1800 14 0R6637-00
II 2EK1 - Up 350@1800 LT 15 1019255-00
II 2EK1 - Up 350@1800 LT 15 0R6639-00
II 2EK1 - Up 350@1800 MT Top2 16 1019254-00
II 2EK1 - Up 350@1800 MT Top2 16 0R6638-00
II 2EK1 - Up 350@1800 MT Top4 16 1022491-00
II 2EK1 - Up 350@1800 MT Top4 16 0R6680-00
II.V 8TC9090 - 10980 350 EPA 114 1019285-00
II.V 8TC9090 - 10980 350 EPA 114 0R6659-00
II.V 8TC10981 - Up 350 NAR 121 1022493-00
II.V 8TC10981 - Up 350 NAR 121 0R6682-00
II.V 2EK1 - Up 350 Std Hi RPM 13 1019252-00
II.V 2EK1 - Up 350 Std Hi RPM 13 0R6636-00
II.V 2EK1 - Up 350 Std Lo RPM 14 1019253-00
II.V 2EK1 - Up 350 Std Lo RPM 14 0R6637-00
II.V 2EK1 - Up 350 Lo Torque 15 1019255-00
II.V 2EK1 - Up 350 Lo Torque 15 0R6639-00
II.V 2EK1 - Up 350 MT Top2 16 1019254-00
II.V 2EK1 - Up 350 MT Top2 16 0R6638-00
III 4CK1 - Up 350@2000 w/o Brksv 13 1457873-00
III 4CK1 - Up 350@2000 w/Brksv 25 3E9115-00
III 4CK1 - 3413 350@1800 14 1457867-00
III 4CK3414 - Up 350@1800 14 1457856-00
III 4CK1 - 10214 350@1800 LT 15 1457877-00
III 4CK10215 - Up 350@1800 LT 15 1457875-00
III 4CK1 - 3413 350 MT Top2 16 1457879-00
III 4CK 3414 - Up 350 MT Top2 16 1457881-00
III 4CK1 - 3413 350 MT Top4 16 1457884-00
III 4CK 3414 - Up 350 MT Top4 16 1457890-00
III 4CK1 - Up 365 Std w/o Brksv 24 1457899-00
III 4CK1 - Up 365 Std w/Brksv 27 3E9120-00
III 4CK1 - Up 365 MT Top2 w/o Brksv 26 1457911-00
III 4CK1 - Up 365 MT Top2 w/Brksv 28 3E9130-00
III 4CK1 - Up 365 MT Top4 w/o Brksv 26 1457916-00
III 4CK1 - Up 365 MT Top4 w/Brksv 28 1457923-00
III 4CK1 - Up 365 HT MT Top4 w/o 34 1457935-00
Brksv
III 4CK1 - Up 365 HT MT Top4 35 1457941-00
w/Brksv
II 8TC1413 - Up 375/400 LT CARB 105 1019286-00
II 8TC1413 - Up 375/400 LT CARB 105 0R6660-00
II 8TC1413 - 10980 375/400 LT EPA 104 1019299-00
II 8TC1413 - 10980 375/400 LT EPA 104 0R6652-00
II 8TC1413 - 10980 400 EPA 104 1019300-00
II 8TC1413 - 10980 400 EPA 104 0R6653-00
II 8TC1413 - Up 400 CARB 105 1019287-00
II 8TC1413 - Up 400 CARB 105 0R6661-00
II 2EK1 - Up 400 Std 17 1019256-00
II 2EK1 - Up 400 Std 17 0R6640-00
II.V 8TC9090 - 10980 400 EPA 104 1019300-00
II.V 8TC9090 - 10980 400 EPA 104 0R6653-00
II.V 8TC10981 - Up 400 CARB 105 1019287-00
II.V 8TC10981 - Up 400 CARB 105 0R6661-00
II.V 2EK1 - Up 400 Std 17 1019256-00
II.V 2EK1 - Up 400 Std 17 0R6640-00
III 4CK1 - Up 400 Std w/o Brksv 17 1457944-00
III 4CK1 - Up 400 Std w/Brksv 26 1457950-00
II 8TC1413 - 10980 425 EPA 106 1019301-00
II 8TC1413 - 10980 425 EPA 106 0R6654-00
II 8TC1413 - Up 425 CARB 107 1019288-00
II 8TC1413 - Up 425 CARB 107 0R6662-00
II 2EK1 - Up 425@2000 18 1019257-00
II 2EK1 - Up 425@2000 18 0R6641-00
II 2EK1 - Up 425@1800 21 1019258-00
II 2EK1 - Up 425@1800 21 0R6642-00
II 2EK1 - Up 425@2000 HT 19 1019259-00
II 2EK1 - Up 425@2000 HT 19 0R6643-00
II 2EK1 - Up 425@1800 HT 22 1019260-00
II 2EK1 - Up 425@1800 HT 22 0R6644-00
II.V 8TC1413 - 10980 425 EPA 106 1019301-00
II.V 8TC1413 - 10980 425 EPA 106 0R6654-00
II.V 8TC1413 - Up 425 CARB 107 1019288-00
II.V 8TC1413 - Up 425 CARB 107 0R6662-00
II.V 2EK1 - Up 425@2000 18 1019257-00
II.V 2EK1 - Up 425@2000 18 0R6641-00
II.V 2EK1 - Up 425@1800 21 1019258-00
II.V 2EK1 - Up 425@1800 21 0R6642-00
II.V 2EK1 - Up 425@2000 HT 19 1019259-00
II.V 2EK1 - Up 425@2000 HT 19 0R6643-00
II.V 2EK1 - Up 425@1800 HT 22 1019260-00
II.V 2EK1 - Up 425@1800 HT 22 0R6644-00
III 4CK1 - Up 425@2000 w/o Brksv 18 1457952-00
III 4CK1 - Up 425@2000 w/Brksv 29 1457954-00
III 4CK1 - 10214 425@1800 w/o Brksv 21 1457975-00
III 4CK10215 - Up 425@1800 w/o Brksv 21 1457971-00
III 4CK1 - 9352 425@2000 HT w/o Brksv 19 1457958-00
III 4CK9353 - Up 425@2000 HT w/o Brksv 19 1457956-00
III 4CK1 - 9352 425@2000 HT w/Brksv 30 1457962-00
III 4CK9353 - Up 425@2000 HT w/Brksv 30 1457960-00
III 4CK1 - 13151 425@1800 HT w/o Brksv 22 1457967-00
III 4CK13151 - Up 425@1800 HT w/o Brksv 22 1457965-00
III 4CK1 - Up 425@1800 HT w/Brksv 31 1457969-00
II 5YG1 - Up 460@1900 110 1019289-00
II 5YG1 - Up 460@1900 110 0R6663-00
II 2EK1 - Up 460@1900 110 1019261-00
II 2EK1 - Up 460@1900 110 0R6645-00
II.V 2EK1 - Up 460@1900 110 1019261-00
II.V 2EK1 - Up 460@1900 110 0R6645-00
III 4CK1 - Up 460@1900 w/o Brksv 20 1458002-00
III 4CK1 - Up 460@1900 w/Brksv 32 1458004-00
**************** METAL TURB0 WHEEL ONLY **************************
III 4CK1 - Up 460@1900 w/o Brksv 20 1457978-00
III 4CK1 - Up 460@1900 w/Brksv 32 1457980-00
3406E FLASH File Cross Reference - Updated 09/28/95
3406E FLASH FILE CROSS REFERENCE
Updated September 28,1995
Serial No. Flash Service Release
Description Range Part No. Replacement IC Date
310 HP 1150 PT 5EK00001 & 129-0227 129-0232 33 AUG95
UP
310 HP 1250 PT 5EK00001 & 129-0236 129-0238 34 AUG95
UP
310 HP 1150/1350PT 5EK00001 & 129-0239 129-0241 35 AUG95
MULTI-TORQUE UP
330HP 1350 PT 5EK00001 129-0242 129-0244 36 AUG95
UP
355 HP 1350 PT 5EK00001 - 120-4032 120-4034 6 JAN95
5EK01820
355 HP 1350 PT 5EK01821 & 129-0160 129-0162 22 AUG95
UP
355 HP 1350/1450PT 5EK00001 - 120-4029 120-4031 7 JAN95
MULTI-TORQUE 5EK01820
355 HP 1350/1450PT 5EK01821 & 129-0163 129-0171 23 AUG95
MULTI-TORQUE UP
375 HP 1450 PT 5EK00001 - 120-4023 120-4025 4 JAN95
5EK01820
375 HP 1450 PT 5EK01821 & 129-0172 129-0174 20 AUG95
UP
375 HP 1450/1550PT 5EK00001 - 120-4047 120-4049 10 JAN95
375 HP 1450/1550PT 5EK01821 - 129-0175 129-0177 21 AUG95
MULTI-TORQUE UP
410 HP 1450 PT 5EK00001 & 129-0203 129-0205 19 AUG95
UP
410 HP 1450 PT 5EK00001 & 129-0206 129-0210 29 AUG95
BRAKESAVER UP
410 HP 1550 PT 5EK00001 & 129-0211 129-0213 30 AUG95
UP
410 HP 1550 PT 5EK00001 & 129-0214 129-0216 31 AUG95
BRAKESAVER UP
435 HP 1450 PT 5EK00549 - 120-4038 120-4040 11 JAN95
5EK01184
435 HP 1550 PT 5EK00549 - 120-4035 120-4037 12 JAN95
5EK01184
435 HP 1550 PT 5EK01185 - 126-4361 126-4363 17 JUN95
5EK53003
435 HP 1550 PT 5EK53004 & 129-0251 129-0253 43 AUG95
UP
435 HP 1550 PT 5EK01185 - 126-4364 126-4366 18 JUN95
BRAKESAVER 5EK53003
435 HP 1550 PT 5EK53004 & 129-0254 129-0256 44 AUG95
BRAKESAVER UP
435 HP 1650 PT 5EK00001 - 120-4020 120-4022 3 JAN95
5EK00548
435 HP 1650 PT 5EK00549 - 120-4044 120-4046 13 JAN95
5EK01184
435 HP 1650 PT 5EK01185 - 126-4368 126-4373 15 JUN95
5EK53003
435 HP 1650 PT 5EK53004 & 129-0257 129-0259 45 AUG95
UP
435 HP 1650 PT 5EK00001 - 120-4026 120-4028 5 JAN95
BRAKESAVER 5EK00548
435 HP 1650 PT 5EK00549 - 120-4041 120-4043 14 JAN95
BRAKESAVER 5EK01184
435 HP 1650 PT 5EK01185 - 126-4375 126-4377 16 JUN95
BRAKESAVER 5EK53003
435 HP 1650 PT 5EK53004 & 129-0261 129-0263 46 AUG95
BRAKDSAVER UP
********* 435HP 1650 PT HIGH RPM PERFORANCE -- FLASH ONLY ***********
435 HP 1650 PT 5EK01185 - 125-3230 15 JUN95
5EK53003
435 HP 1650 PT 5EK01185 - 125-3237 16 JUN95
BRAKESAVER 5EK53003
435 HP 1650 PT 5EK53004 & 129-2595 45 AUG95
UP
435 HP 1650 PT 5EK53004 & 129-2598 46 AUG95
BRAKESAVER UP
455 HP 1650 PT 5EK00001 - 126-4444 126-4446 27 JUN95
5EK53003
455 HP 1650 PT 5EK53004 & 129-0265 129-0269 47 AUG95
UP
455 HP 1650 PT 5EK00001 - 126-4447 126-4449 28 JUN95
BRAKESAVER 5EK53003
455 HP 1650 PT 5EK53004 & 129-0271 129-0276 48 AUG95
BRAKESAVER UP
********* 455HP 1650 PT HIGH RPM PERFORANCE -- FLASH ONLY ***********
455 HP 1650 PT 5EK00001 - 130-8365 27 AUG95
5EK53003
455 HP 1650 PT 5EK00001 & 130-8367 28 AUG95
BRAKESAVER UP
475 HP 1650 PT 5EK00001 & 129-0178 129-0181 8 AUG95
UP
475 HP 1650 PT 5EK00001 & 129-0183 129-0186 24 AUG95
BRAKESAVER UP
475 HP 1750 PT 5EK00001 & 129-0189 129-0192 25 AUG95
UP
475 HP 1750 PT 5EK00001 & 129-0193 129-0196 26 AUG95
BRAKESAVER UP
********* 475HP 1750 PT HIGH RPM PERFORANCE -- FLASH ONLY ***********
475 HP 1750 PT 5EK00001 & 128-6848 25 JUN95
UP
475 HP 1750 PT 5EK00001 & 128-6851 26 JUN95
BRAKESAVER UP
500 1850 PT 5EK00001 & 129-0217 129-0219 9 AUG95
UP
500 HP 1850 PT 5EK00001 & 129-0220 129-0224 32 AUG95
BRAKESAVER UP
********* 500 HP 1850 PT HIGH RPM PERFORANCE -- FLASH ONLY ***********
500 HP 1850 PT 5EK00001 & 126-3887 9 JUN95
UP
500 HP 1850 PT 5EK00001 & 128-6569 32 JUN95
BRAKESAVER UP
****** September Availability ***************************************
550 HP 1850 PT 5EK00001 & 126-8385 126-8387 41 AUG95
UP
550 HP 1850 PT 5EK00001 & 126-9517 126-9519 42 AUG95
BRAKESAVER UP
OIL WELL SERVICE
435/500 HP 5EK01185 & 126-4486 126-4488 38 JUN95
1550/1650 PT UP
3406E LOW NOX KIT FLASH FIILE CROSS REFERENCE
Updated February 21, 2001
Note: The LOW NOx FLASH files each have an interlock code which has been
with an interlock code of 333, replaces the DEC98 PSO FLASH file 170-8128,
which had an interlock code of 33.
ENGINE RATING/ SERIAL NO. FLASH RELEASE
APPLICATION INFORMATION RANGE FILE IC DATE
310 HP 1150 PT 5EK05767 & UP 185-1177 333 DEC99
6TS00001 & UP
310 HP 1250 PT 5EK05767 & UP 185-1178 334 DEC99
6TS00001 & UP
310 HP 5EK05767 & UP 185-1179 335 DEC99
1150/1350@1200 6TS00001 & UP
330 HP 1350 PT 5EK05767 & UP 185-1180 336 DEC99
6TS00001 & UP
355 HP 1350 PT 5EK05767 & UP 185-1181 322 DEC99
(Still used on steel pistons) 6TS00001 & UP
355 HP 1350 PT 208.5 Fan On 5EK05767 & UP 185-1182 322 DEC99
355 HP 1350@1200 5EK05767-80006 185-1181 322 DEC99
Aluminum pistons (was 170-8174)
355 HP 1350 PT 208.5 Fan On 5EK05767-80006 185-1182 322 DEC99
Aluminum pistons (was 170-8175)
355 HP 1350/1450PT MULTI-TORQUE 5EK05767 & UP 185-1183 323 DEC99
355 HP 1350/1450PT MULTI-TORQUE 5EK05767 & UP 185-1184 323 DEC99
208.5 Fan On 6TS00001 & UP
355 HP 1350/1450 PT MULTI-TORQUE 5EK05767-80006 185-1184 323 DEC99
Aluminum Pistons (was 170-8173)
208.5 Fan On Aluminum Pistons
(was 170-8182)
375 HP 1450 PT 5EK05767 & UP 185-1186 355 DEC99
PAN WESTERN SPECIAL 6TS00001 & UP
375 HP 1450@1200 Aluminum pistons 5EK05767-80006 185-1185 320 DEC99
(was 170-8177)
375 HP 1450 PT 5EK05767 & UP 185-1185 320 DEC99
375HP 1450@1200 Multi-Torque 5EK05767-80006 185-1187 321 DEC99
Aluminum pistons (was 170-8111)
375 HP 1450/1550PT MULTI-TORQUE 5EK05767 & UP 185-1187 321 DEC99
375/435 HP MULTI-TORQUE 5EK67193 & UP 186-9901 367 DEC99
6TS00001 & UP
375/435 HP 1450/1650 5EK67193 & UP 186-9903 381 DEC99
Top Gear Only Multi-Torque 6TS00001 & UP
375/435 HP 1450/1650 PT 5EK67193 & UP 186-9902 428 DEC99
410 HP 1450@1200 Aluminum pistons 5EK05767-67192 185-1188 319 DEC99
(was 170-8176)
410 HP 1450 PT 5EK05767-67192 185-1188 319 DEC99
410 HP Brakesaver 1450@1200 5EK05767-67192 185-1189 329 DEC99
Aluminum pistons (was 170-8179)
410 HP 1450 PT BRAKESAVER 5EK05767-67192 185-1189 329 DEC99
410 HP 1550@1200 Aluminum pistons 5EK05767-67192 185-1190 330 DEC99
(was 170-8180)
410 HP 1550 PT 5EK05767-67192 185-1190 330 DEC99
410 HP Brakesaver 1550@1200 5EK05767-67192 185-1191 331 DEC99
Aluminum pistons (was 170-8181)
410 HP 1550 PT BRAKESAVER 5EK05767-67192 185-1191 331 DEC99
(Still used for steel pistons)
410 HP 1450/1550@1200 5EK67192&80006 186-9904 368 DEC99
Aluminum pistons (was 170-8183)
410 HP 1450/1550 5EK67193 & UP 186-9904 368 DEC99
410 HP Brakesaver 1450/1550@1200 5EK67193-80006 186-9905 369 DEC99
Aluminum pistons (was 170-8184)
410 HP 1450/1550 BRAKESAVER 5EK67193 & UP 186-9905 369 DEC99
ALLISION AUTO TRANSMISSION:
435 HP 1450 PT 5EK75900 & UP 186-9908 377 DEC99
6TS00001 & UP
435 HP 1550 PT 5EK05767-53003 185-1192 317 DEC99
435 HP 1550 PT 5EK53004-67192 185-1198 343 DEC99
435 HP 1550 PT BRAKESAVER 5EK05767-53003 185-1193 318 DEC99
435 HP 1550 PT BRAKESAVER 5EK53004-67192 185-1199 344 DEC99
435 HP 1650 PT 5EK05767-53003 185-1194 315 DEC99
435 HP 1650 PT 5EK53004-67192 185-1200 345 DEC99
435 HP 1550/1650 @ 1800/2100 5EK67193 & UP 186-9906 359 DEC99
6TS00001 & UP
435 HP 1650 PT BRAKESAVER 5EK05767-53003 185-1195 316 DEC99
435 HP 1650 PT BRAKESAVER 5EK53004-67192 185-1201 346 DEC99
435 HP 1550/1650 @ 1800/2100 5EK67193 & UP 186-9907 360 DEC99
BRAKESAVER 6TS00001 & UP
435@1800 Dual HP for PTO 5EK67193 & UP 185-1204 338 DEC99
500@2100 or 435@2100 6TS00001 & UP
435HP 1650 PT HIGH RPM PERFORMANCE - FIELD UPRATE ONLY, FLASH ONLY:
435 HP 1650 PT 5EK05767-53003 185-1196 315 DEC99
435 HP 1650 PT BRAKESAVER 5EK05767-53003 185-1197 316 DEC99
435 HP 1650 PT 5EK53004-67192 185-1202 345 DEC99
435 HP 1650 PT BRAKESAVER 5EK53004-67192 185-1203 346 DEC99
455 HP 1650 PT 5EK05767-53003 185-1205 327 DEC99
455 HP 1650 PT 5EK53004-67192 185-1209 347 DEC99
455 HP 1650 PT 5EK67193 & UP 186-9910 357 DEC99
@ 1800/2100 6TS00001 & UP
455 HP 1650 PT BRAKESAVER 5EK05767-53003 185-1206 328 DEC99
455 HP 1650 PT BRAKESAVER 5EK53004-67192 185-1210 348 DEC99
455 HP 1650 PT @ 1800/2100 5EK67193 & UP 186-9911 358 DEC99
455 MT 1550/1750 5EK67193 & UP 186-9912 379 DEC99
6TS00001 & UP
455 MT (BS) 5EK67193 & UP 186-9913 380 DEC99
1550/1750 PT 6TS00001 & UP
455HP 1650 PT HIGH RPM PERFORMANCE - FIELD UPRATE ONLY, FLASH ONLY:
455 HP 1650 PT 5EK05767-53003 185-1207 327 DEC99
455 HP 1650 PT BRAKESAVER 5EK05767-53003 185-1208 328 DEC99
455 HP 1650 PT 5EK53004-67193 185-1211 347 DEC99
455 HP 1650 PT BRAKESAVER 5EK53004-67193 185-1212 348 DEC99
475 HP 1650 PT 5EK05767-67192 185-1213 308 DEC99
475 HP 1650 PT BRAKESAVER 5EK05767-67192 185-1214 324 DEC99
475 HP 1750 PT 5EK05767-67192 185-1215 325 DEC99
475 HP 1750 PT BRAKESAVER 5EK05767-67192 185-1216 326 DEC99
475 HP 1650/1750 @ 1800/2100 5EK67193 & UP 186-9914 350 DEC99
6TS00001 & UP
475 HP 1650/1750 @ 1800/2100 5EK67193 & UP 186-9915 351 DEC99
475HP 1750 PT HIGH RPM PERFORMANCE - FIELD UPRATE ONLY, FLASH ONLY:
475 HP 1750 PT 5EK05767-67192 185-1217 325 DEC99
475 HP 1750 PT BRAKESAVER 5EK05767-67192 185-1218 326 DEC99
475/500 HP 1650/1850 PT 5EK67193 & UP 186-9918 382 DEC99
MULTI-TORQUE 6TS00001 & UP
475/500 HP 1650/1850 PT 5EK67193 & UP 186-9919 383 DEC99
MULTI-TORQUE BRAKESAVER 6TS00001 & UP
475/500 HP 1650/1750 5EK67193 & UP 186-9916 436 DEC99
TOP TWO GEARS ONLY MULTI-TORQUE 6TS00001 & UP
FIELD UPRATE ONLY
475/500 HP 1650/1750 BRAKESAVER 5EK67193 & UP 186-9917 437 DEC99
FIELD UPRATE ONLY
500 HP 1450 PT MOTORHOME 5EK67193 & UP 186-9920 354 DEC99
6TS00001 & UP
500 HP 1650 PT 5EK67193 & UP 204-3504 474 FEB01
6TS00001 & UP
500 HP 1750 @ 1200 BRAKESAVER 5EK67193 & UP 186-9923 395 DEC99
FLEET RATING 6TS00001 & UP
WARNING: ONCE THIS IS FLASHED THE INTERLOCK IS FROZEN AND CANNOT BE CHANGED
500 HP 1750 @ 1200 5EK67193 & UP 186-9922 394 DEC99
500 1850 PT 5EK05767-67192 185-1219 309 DEC99
500 1850 PT @ 1800/2100 5EK67193 & UP 186-9924 361 DEC99
6TS00001 & UP
500 1850 PT @ 1800/2100 5EK67193 & UP 185-1225 432 DEC99
2300RPM TEL FIELD UPRATE ONLY 6TS00001 & UP
500 HP 1850 PT BRAKESAVER 5EK05767-67192 185-1220 332 DEC99
500 HP 1850 PT @ 1800/2100 5EK67193 & UP 186-9925 362 DEC99
500 HP 1850 PT @ 1800/2100 BRKSVR 5EK67193 & UP 185-1226 433 DEC99
500 HP 1850 PT HIGH RPM PERFORMANCE - FIELD UPRATE ONLY, FLASH ONLY:
500 HP 1850 PT 5EK05767-67192 185-1221 309 DEC99
500 HP 1850 PT BRAKESAVER 5EK05767-67192 185-1222 332 DEC99
550 HP 1850 PT @ 2100 5EK05767 & UP 185-1223 341 DEC99
6TS00001 & UP
550 HP 1850 PT @ 2100 5EK67193 & UP 186-9926 434 DEC99
550 HP 1850 PT @ 2100 5EK05767 & UP 185-1224 342 DEC99
550 HP 1850 PT @ 2100 BRKSVR 5EK67193 & UP 186-9927 435 DEC99
OIL WELL SERVICE (OWS)
435/500 HP 1550/1650 PT OWS 5EK05767 & UP 185-1204 338 DEC99
435/500 HP OWS 5EK05767 & UP 186-9909 376 DEC99
355 HP 1350PT 1800/2100 1LW00001 & UP 192-5311 399 APR00
355 HP MULTI-TORQUE 1350/1450 1LW00001 & UP 192-5312 401 APR00
1800/2100
375 HP 1450PT 1800/2100 1LW00001 & UP 192-5313 405 APR00
375 HP MULTI-TORQUE 1450/1550 1LW00001 & UP 192-5314 406 APR00
1800/2100
375/435 HP MULTI-TORQUE 1LW00001 & UP 192-5315 409 APR00
1450/1550 PT 1800
1450/1650 PT 1800
375/435 HP 1450/1550 PT 1800 RPM 1LW00001 & UP 192-5316 459 APR00
FIELD UPRATE ONLY
375/435 HP 1450/1650PT 1LW00001 & UP 192-5317 410 APR00
1800 MULTI-TORQUE IN
TOP GEAR ONLY (ROCKWELL)
410 HP FIELD UPRATE ONLY 1LW00001 & UP 192-5318 407 APR00
435 HP 1550/1650PT 1800/2100 1LW00001 & UP 192-5320 411 APR00
435 HP 1550/1650PT 1LW00001 & UP 192-5321 412 APR00
1800/2100 BRAKESAVER
450 HP 1550/1650PT 2100 1LW00001 & UP 192-5319 452 APR00
(FIELD UPRATE ONLY FOR 410HP & BELOW)
455 HP 1550PT 2100 1LW00001 & UP 192-5322 438 APR00
455 HP 1550 PT 1LW00001 & UP 192-5323 439 APR00
2100 BRAKESAVER
455 HP 1650PT 1800/2100 1LW00001 & UP 192-5324 413 APR00
455 HP 1650PT 1800/2100 1LW00001 & UP 192-5325 414 APR00
BRAKESAVER
455 HP MULTI-TORQUE 1LW00001 & UP 192-5326 415 APR00
1550/1750PT 2100
455 HP MULTI-TORQUE 1LW00001 & UP 192-5327 416 APR00
1550/1750PT 2100 BRAKESAVER
475 HP 1650/1750PT 1800/2100 1LW00001 & UP 192-5328 419 APR00
475 HP 1650/1750PT 1LW00001 & UP 192-5329 420 APR00
475/500 HP 1650/1750PT 2100 RPM 1LW00001 & UP 192-5330 455 APR00
FIELD UPRATE ONLY
475/500 HP 1650/1750PT 2100 RPM 1LW00001 & UP 192-5331 456 APR00
BRAKESAVER FIELD UPRATE ONLY
475/500 HP 1650/1850PT 2100 RPM 1LW00001 & UP 192-5332 417 APR00
MULTI-TORQUE TOP 2 GEARS ONLY
475/500 HP 1650/1850PT 2100 RPM 1LW00001 & UP 192-5333 418 APR00
BRAKESAVER
500 HP 1650PT 2100 RPM 1LW00001 & UP 192-5334 462 APR00
500 HP FLEET 1750PT 2100 RPM 1LW00001 & UP 192-5335 425 APR00
WARNING: ONCE FLASHED THE INTERLOCK IS FROZEN AND CANNOT BE CHANGED
500 HP FLEET 1750PT 2100 RPM 1LW00001 & UP 192-5336 426 APR00
BRAKESAVER
500 HP 1850PT 1800/2100 1LW00001 & UP 192-5337 421 APR00
500 HP 1850PT 1800/2100 1LW00001 & UP 192-5339 441 APR00
500 HP 1850PT 1800/2100 1LW00001 & UP 192-5338 422 APR00
BRAKESAVER
500 HP 1850PT 1800/2100 BRAKESAVER 1LW00001 & UP 192-5340 442 APR00
550 HP 1850PT 2100 RPM 1LW00001 & UP 192-5341 423 APR00
550 HP 1850PT 2100 RPM 1LW00001 & UP 192-5343 443 APR00
550 HP 1850PT 2100 RPM BRAKESAVER 1LW00001 & UP 192-5342 424 APR00
550 HP 1850PT 2100 RPM BRAKESAVER 1LW00001 & UP 192-5344 444 APR00
F 3406E/3456/C15/C16/C18 FLASH FILE CROSS REFERENCE
Updated January 15, 2008 ajk
This file covers 3406E Truck engines (5DS/2WS/1LW/1MM), and 3406E/3456/C15/C18
Commercial/Machine applications.
NOTE:
Most of the original flash files for 5EK/6TS/1LW 3406E engines have been
removed from SIS Web. They have been replace by Low NOx files. See the
Low NOx files text.
WARNING!!!
9CK1 - 5000 and 5EK1 - 5000 can NOT be flashed with NOV95 software. The
Flash program may terminate at 20 to 25% complete when attempting to flash
these personality modules with NOV95 software.
be flashed with NOV95 software because the original personality module
was replaced with a compatible REMAN product during an earlier software update or
programming.
before programming it, a failure while flashing the personality module
in the affected range will render the engine inoperable. Once this
occurs, there are two options; 1) replace the personality module with a
106-9184 module and re-flash or 2) flash the original personality module
with pre-NOV95 software.
the Caterpillar mailbox for downloading. They are listed under the title
"3406E FLASH File Cross Reference - Updated 09/28/95".
355 HP 1350 PT 5EK00001-01820 170-8096 6 DEC98
355 HP 1450@1200 Multi-Torque 5EK00001-01820 170-8185 7 DEC98
Aluminum pistons
355 HP 1350/1450PT MULTI-TORQUE 5EK00001-01820 170-8097 7 DEC98
375 HP 1450 PT 5EK00001-01820 170-8098 4 DEC98
375 HP 1450/1550PT MULTI-TORQUE 5EK00001-01820 170-8099 10 DEC98
435 HP 1450 PT 5EK00549-01184 170-8102 11 DEC98
435 HP 1550 PT 5EK00549-01184 170-8103 12 DEC98
435 HP 1650 PT 5EK00001-00548 170-8100 3 DEC98
435 HP 1650 PT 5EK00549-01184 170-8104 13 DEC98
575 HP 1850PT 2100 RPM 5DS00324 & UP 170-8228 167 DEC98
For use with 159-8542 or 0R-7275 Turbo Group
575 HP 1850PT 2100 RPM BRAKESAVER 5DS00324 & UP 170-8229 168 DEC98
600 HP 2050PT 2100 RPM 5DS00001-00323 170-8230 96 DEC98
For use with 138-3200 or 0R-7176 Turbo Group
600 HP 2050PT 2100 RPM 5DS00324 & UP 170-8232 160 DEC98
600 HP 2050PT 2100 RPM 5DS00001-00323 170-8238 145 DEC98
600 HP 2050PT 2100 RPM BRAKESAVER 5DS00001-00323 170-8231 97 DEC98
600 HP 2050PT 2100 RPM BRAKESAVER 5DS00324 & UP 170-8233 161 DEC98
600 HP 2050PT 2100 RPM BRAKESAVER 5DS00001-00323 170-8239 146 DEC98
600 HP 2050PT 2100 RPM 5DS00324 & UP 170-8240 170 DEC98
600 HP 2050PT 2100 RPM BRAKESAVER 5DS00324 & UP 177-0097 171 DEC98
14 LITER Lo-HP 2WS ENGINE SERIAL NO. FLASH RELEASE
RATING INFORMATION RANGE FILE IC DATE
355HP 1350PT 1800/2100RPM 2WS00001 & UP 215-7824 14 MAR02
355HP MT 1350/1450PT 1800 RPM 2WS00001 & UP 215-7825 15 MAR02
375HP 1450PT 1800/2100RPM 2WS00001 & UP 215-7826 16 MAR02
375/435HP MT 1450/1550PT 1800PRM 2WS00001 & UP 215-7828 9 MAR02
375HP MT 1450/1550PT 1800RPM 2WS00001 & UP 215-7826 17 MAR02
1450/1550PT 2100RPM
375/435HP 1450/1550PT 1800 RPM 2WS00001 & UP 215-7829 19 MAR02
375/435HP 1450/1650PT 1800 RPM 2WS00001 & UP 215-7830 20 MAR02
TOP 1 GEAR MULTITORQUE
410HP 1450/1550PT 1800/2100RPM 2WS00001 & UP 215-7831 21 MAR02
FIELD UPRATE ONLY
450HP 1550/1650PT 2100RPM 2WS00001 & UP 215-7834 22 MAR02
FIELD UPRATE ONLY
14 LITER Hi-HP 2WS ENGINE SERIAL NO. FLASH RELEASE
435HP 1550/1650PT 1800/2100RPM 2WS00001 & UP 215-7832 23 MAR02
435HP 1550/1650PT 1800/2100RPM 2WS00001 & UP 215-7833 24 MAR02
BRAKESAVER
435/500HP 1550/1650 2100RPM 2WS00001 & UP 215-7846 61 MAR02
MULTITORQUE
455HP 1550PT 2100RPM OR 2WS00001 & UP 215-7835 25 MAR02
1650PT 1800/2100RPM
455HP 1550PT 2100RPM OR 2WS00001 & UP 215-7836 26 MAR02
455HP MT 1550/1750PT 2100 RPM 2WS00001 & UP 215-7837 27 MAR02
455HP MT 1550/1750PT 2100 RPM 2WS00001 & UP 215-7838 28 MAR02
BRAKESAVER
475HP 1650/1750PT 1800/2100RPM 2WS00001 & UP 270-7080 2 APR05
REPLACED 251-2224
475HP 1650/1750PT 1800/2100RPM 2WS00001 & UP 270-7079 30 APR05
BRAKESAVER
REPLACED 251-2223
475/500HP 1650/1850PT 2100 RPM 2WS00001 & UP 215-7841 31 MAR02
475/500HP 1650/1850PT 2100 RPM 2WS00001 & UP 215-7842 32 MAR02
475/500HP 1650/1750PT 2100 RPM 2WS00001 & UP 215-7843 33 MAR02
475/500HP 1650/1750PT 2100 RPM 2WS00001 & UP 215-7844 34 MAR02
500HP 1650PT 2100RPM, 2WS00001 & UP 215-7845 35 MAR02
500HP 1650PT 2100RPM BRAKESAVER 2WS00001 & UP 215-7848 36 MAR02
500HP 1850PT 1800/2100RPM 2WS00001 & UP 215-7852 37 MAR02
500HP 1750/1850PT 2100 RPM 2WS00001 & UP 215-7850 39 MAR02
500HP 1750/1850PT 2100 RPM 2WS00001 & UP 215-7851 40 MAR02
500HP 1850PT 1800/2100RPM 2WS00001 & UP 215-7847 59 MAR02
500HP 1850PT 1800/2100RPM 2WS00001 & UP 215-7849 60 MAR02
BRAKESAVER
500HP 1850PT 1800/2100RPM 2WS00001 & UP 215-7853 38 MAR02
550HP 1850PT 2100RPM 2WS00001 & UP 270-7085 41 APR05
REPLACED 251-2229
550HP 1850PT 2100RPM BRAKESAVER 2WS00001 & UP 270-7086 42 APR05
REPLACED 251-2230
550HP 1850PT 2100RPM 2WS00001 & UP 270-7081 43 APR05
REPLACED 251-2225
550HP 1850PT 2100RPM BRAKESAVER 2WS00001 & UP 270-7082 44 APR05
REPLACED 251-2226
16 LITER 1MM ENGINE SERIAL NO. FLASH RELEASE
575HP 1850PT 2100RPM 1MM00001 & UP 215-7858 45 MAR02
575HP 1850PT 2100RPM BRAKESAVER 1MM00001 & UP 215-7859 46 MAR02
575HP 1850PT 2100RPM 1MM00001 & UP 215-7861 47 MAR02
575HP 1850PT 2100RPM BRAKESAVER 1MM00001 & UP 215-7860 48 MAR02
575/600HP MT 1850/2050PT 2100RPM 1MM00001 & UP 215-7862 49 MAR02
575/600HP MT 1850/2050PT 2100RPM 1MM00001 & UP 215-7863 50 MAR02
BRAKESAVER
600HP 2050PT 2100RPM 1MM00001 & UP 270-7083 4 APR05
REPLACED 215-7864,237-0693,
241-0808,251-2227
600HP 2050PT 2100RPM BRAKESAVER 1MM00001 & UP 270-7084 52 APR05
REPLACED 215-7865,237-0694,
241-0809,251-2228
600HP 2050PT 2100RPM 1MM00001 & UP 270-7087 53 APR05
REPLACED 215-7866,237-0697,241-0812,251-2231
600HP 2050PT 2100RPM BRAKESAVER 1MM00001 & UP 270-7088 54 APR05
REPLACED 215-7867,237-0698,
241-0813,251-2232
Heavy-Duty Ratings for October 2002-up Engines
The boxes shown below indicate unique ratings families.
Ratings within these boxes share common iron sets and
can be rerated to another rating within the same box.
Ratings changes are only allowed within a particular box.
All ratings are subject to change without notice.
Adv HP Max. HP Peak Torque Gov Speed
*C-10 (10.3L MBJ) *
*305 315 1050 2100 *
*335 350 1250 2100 *
*C-12 (11.9L MBL) *
*355 370 1350 2100 *
*380 395 1450 2100 *
*410 425 1450 2100 *
*355/410 415 1350/1450 2100 *
*335 420 1550 2100 *
*410 425 1550 2100 *
*430 445 1550 2100 *
*380/430 445 1450/1550 2100 *
*430 445 1650 2100 *
*380/430 445 1450/1650 2100 *
*425 425 1550 2100 Firetruck/RV only*
*455 455 1550 2100 Firetruck/RV only*
*505 505 1550 2100 RV only *
*C-15 (14.6L MBN) *
*435 450 1550 2100 Brakesaver avail. *
*435 450 1650 2100 Brakesaver avail. *
*475 490 1650 2100 Brakesaver avail. *
*500 515 1650 2100 Field rerate only *
*435/500 515 1550/1650 2100 *
*435/500 515 1550/1650 2100 Oil well service *
*475 490 1750 2100 Brakesaver avail. *
*500 515 1850 2100 Brakesaver avail. *
*525 525 1850 2100 Brakesaver avail. *
*450/515 515 1550/1650 2100 RV only *
* C-18 (MDP / MEP) *
*625 2049 1900 *
*700 1900 1900 *
The 1500 lb.ft. low torque C-15 has been removed from our lineup. Also,
the C-15 515hp (RV only) rating has been changed to a MultiTorque. As
stated on the top of the chart, ratings changes are only allowed within
a particular box. All ratings are subject to change without notice.
FLASHFILES
C-10 GOV SERIAL NO. FLASH P/M RELEASE
HORSEPOWER TORQUE SPEED RANGE FILE CODE DATE
305 HP 1050 LB-FT 2100 RPM MBJ00001-UP 242-8336 220 AUG03
Replaced 228-8022, 235-1371 (old code 210)
335 HP 1250 LB-FT 2100 RPM MBJ00001-UP 272-6461 221 MAR05
Replaced 228-8023,235-1372,
242-8337 (old code 211)
335 HP 1250 LB-FT 2100 RPM MBJ00001-UP 242-8338 225 AUG03
Replaced 228-8024, 235-1373 Haliburton IAS (old code 215)
C-12 MBL00001-00999 Parts Service Only
355 HP 1350 LB-FT 2100 RPM MBL1-00999 239-5968 241 Jun03
REFERENCE 224-3448 IC 201
Replaced 232-3985
355/410 HP 1350/1450 LB-FT 2100 RPM MBL1-00999 239-5967 244 Jun03
MULTITORQUE REFERENCE 224-3449 IC 204
Replaced 232-3986
380 HP 1450 LB-FT 2100 RPM MBL1-00999 239-5966 242 Jun03
REFERENCE 224-3450 IC 202
Replaced 232-3987
410 HP 1450 LB-FT 2100 RPM MBL1-00999 239-5964 246 Jun03
REFERENCE 224-3452 IC 206
Replaced 232-3989
335 HP 1550 LB-FT 2100 RPM MBL1-00999 239-5969 240 Jun03
REFERENCE 224-3447 IC 200
Replaced 232-3984
380/430 HP 1450/1550 LB-FT 2100 RPM MBL1-00999 239-5965 248 Jun03
1450/1650 LB-FT
MULTITORQUE REFERENCE 224-3451 IC 208
Replaced 232-3988
410 HP 1550 LB-FT 2100 RPM MBL1-00999 239-5963 247 Jun03
REFERENCE 224-5869 IC 207
Replaced 232-3990
430 HP 1550/1650 LB-FT 2100 RPM MBL1-00999 239-5962 249 Jun03
REFERENCE 216-5006 & 224-3453 IC 209
Replaced 232-3991
C-12 MBL01000-up
355 HP 1350 LB-FT 2100 RPM MBL01000-UP 236-8686 221 May03
REPLACED 228-8027, 231-9235,235-1375
355/410 HP 1350/1450 LB-FT 2100 RPM MBL01000-UP 236-8687 224 May03
MULTITORQUE REPLACED 228-8028, 231-9236, 235-1377
380 HP 1450 LB-FT 2100 RPM MBL01000-UP 241-8404 222 Jul03
REPLACED 228-8029, 231-9237, 235-1738, 236-8688
410 HP 1450 LB-FT 2100 RPM MBL01000-UP 241-8403 226 Jul03
REPLACED 228-8031,231-9240,235-1381,236-8691
335 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6464 220 MAR05
REPLACED 228-8026,231-9234,
235-1374,236-8685
380/430 HP 1450/1550 LB-FT 2100 RPM MBL01000-UP 272-6465 235 MAR05
MULTITORQUE
REPLACED 228-8059,231-9238,
235-1379,236-8689
410 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6467 227 MAR05
REPLACED 228-8032,231-9241,
235-1382,236-8692
410 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6468 233 MAR05
Haliburton
REPLACED 228-8033,231-9242,
235-1383,236-8693
430 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6470 237 MAR05
REPLACED 228-8035,231-9244,
235-1385,236-8695
380/430 HP 1450/1650 LB-FT 2100 RPM MBL01000-UP 272-6466 236 MAR05
MULTITORQUE
REPLACED 228-8030,231-9239,
235-1380,236-8690
430 HP 1650 LB-FT 2100 RPM MBL01000-UP 272-6471 238 MAR05
REPLACED 229-1634,231-9245,
235-1386,236-8696
430 HP 1650 LB-FT 2100 RPM MBL01000-UP 272-6472 232 MAR05
Haliburton IAS
REPLACED 228-8036,231-9246,
235-1387,236-8697
425 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6469 234 MAR05
Firetruck & RV only
REPLACED 228-8034,231-9243,
235-1384,236-8694
455 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6473 260 MAR05
Firetrk/RV only (old code 230)
REPLACED 228-8037,231-9247,235-1380,
236-8698,242-8339
505 HP 1550 LB-FT 2100 RPM MBL01000-UP 272-6474 261 MAR05
RV only (old code 231)
REPLACED 228-8038,231-9248,
235-1389,236-8699,242-8340
450/515 HP 1550/1650 LB-FT 2100 RPM MBL00001-UP 272-6613 210 MAR05
MULTITORQUE/RV ONLY
REPLACED 228-8058,231-9253,
234-7584,236-8704
C-15
435 HP 1550/1650 LB-FT 2100 RPM MBN00001-UP 272-6609 206 MAR05
REPLACED 228-8040,231-9249,
234-7580,236-8700
435 HP 1550/1650 LB-FT 2100 RPM MBN00001-UP 272-6610 207 MAR05
BRAKESAVER
REPLACED 228-8041,231-9250,
234-7581,236-8701
435/500 HP 1550/1650 LB-FT 2100 RPM MBN00001-UP 272-6611 208 MAR05
MULTITORQUE
REPLACED 228-8042,231-9251,
234-7582,236-8702
435/500 HP 1550/1650 LB-FT 2100 RPM MBN00001-UP 272-6612 220 MAR05
MULTITORQUE/ (OWS) OIL WELL SERVICE
REPLACED 228-8043,231-9252,
234-7583,236-8703
475 HP 1650 LB-FT 2100 RPM MBN00001-UP 272-6614 212 MAR05
REPLACED 228-8044,231-9254,
234-7585,236-8705,251-3753
475 HP 1650 LB-FT 2100 RPM MBN00001-UP 272-6615 214 MAR05
BRAKESAVER
REPLACED 228-8045,231-9255,
234-7586,236-8706
500 HP 1650 LB-FT 2100/2300 RPM MBN00001-UP 272-6618 221 MAR05
FIELD UPRATE
REPLACED 228-8049,231-9258,
234-7589,236-8709
475 HP 1750 LB-FT 2100 RPM MBN00001-UP 272-6616 213 MAR05
REPLACED 228-8046,231-9256,
234-7587,236-8707
475 HP 1750 LB-FT 2100 RPM MBN00001-UP 272-6617 215 MAR05
BRAKESAVER
REPLACED 228-8047,231-9257,
234-7588,236-8708
500 HP 1850 LB-FT 2100 RPM MBN00001-UP 272-6619 226 MAR05
REPLACED 228-8050,231-9259,
234-7590,236-8710
500 HP 1850 LB-FT 2100 RPM MBN00001-UP 272-6620 227 MAR05
BRAKESAVER
REPLACED 228-8051,231-9260,
234-7591,236-8711
525 HP 1850 LB-FT 2100 RPM MBN00001-UP 272-6621 228 MAR05
REPLACED 228-8055,231-9261,
234-7592,236-8712
525 HP 1850 LB-FT 2100 RPM MBN00001-UP 272-6622 230 MAR05
BRAKESAVER
REPLACED 228-8056,231-9262,
234-7593,236-8713
525 HP 1850 LB-FT 2100/2300 RPM MBN00001-UP 272-6623 231 MAR05
FIELD UPRATE
REPLACED 228-8052,231-9263,
234-7594,236-8714
525 HP 1850 LB-FT 2100/2300 RPM MBN00001-UP 272-6624 232 MAR05
REPLACED 228-8053,231-9264
234-7595,236-8715
525 HP 1771 LB-FT 2100 RPM MBN00001-UP 268-0221 164 APR05
SNOWBLOWER
REPLACED 251-1628
C-18
625 HP 2049 LB-FT 1900 RPM MDP0001-up MEP0001-UP 268-0224 3 APR05
EURO3
REPLACED 184-8094,231-7596,232-2646,
235-6400,241-0814,251-1625
700 HP 1900 LB-FT 2100 RPM MDP0001-up MEP0001-UP 241-0817 1 JUN03
(UK HETT)
REPLACED 227-5521,232-2647,238-2680,239-4147
700 HP 1900 LB-FT 2100 RPM MDP0001-up MEP0001-UP 232-2648 1 NOV02
(Charmichael)
REPLACED 227-5522
700 HP 2000 RPM HWT-533KW CPD ACERT 318-7276 5 AUG07
UK COMMERCIAL DEFENSE PRODUCT-COLD TEST RATING
REPLACED 289-9686
European On Highway Truck
C-12
325 HP 1250 LB-FT 1900 RPM CPD00276-UP 267-5139 42 DEC04
EURO3
REPLACED 224-7278
380 HP 1400 LB-FT 1900 RPM CPD00276-UP 267-5140 43 DEC04
EURO3
REPLACED 224-7279
380/430 HP 1400/1550 LB-FT 1900 RPM CPD00276-UP 267-5141 44 DEC04
EURO3 M/T
REPLACED 224-7280
430 HP 1550 LB-FT 1900 RPM CPD00276-UP 267-5142 45 DEC04
EURO3
REPLACED 224-7281
C-16
680 HP 1951 LB-FT 2100 RPM 267-5143 162 JAN05
ARFF
REPLACED 251-1626
650 HP 1951 LB-FT 2100 RPM 297-8779 163 JUL06
SNOWBLOWER
REPLACED 251-1629,268-0223
C11/C13/C15 ACERT Flash File Cross Reference
Updated January 27, 2009 dba
On-Highway Truck Engines
NOTE: C11, C13,and C15 files are serial number range specific
FLASHFILES
C11 GOV SERIAL NO. FLASH P/M RELEASE
305 HP 1050 LB-FT 2100 RPM KCA1-1456 291-2050 20 MAR06
Replaced 256-6457,264-6355,270-0317
305 HP 1050 LB-FT 2100 RPM KCA1457-up 305-4391 30 NOV06
RFT Injectors
Replaced 256-5727,262-4382,265-9436,
270-0294,271-2914,291-2016
335 HP 1250 LB-FT 2100 RPM KCA1-01456 291-2051 21 MAR06
Replaced 256-6458,264-6356,270-0318
335 HP 1250 LB-FT 2100 RPM KCA1457-up 305-4392 31 NOV06
RFT Injectors
Replaced 256-5728,262-4383,270-0295,
271-2915,291-2017
335 HP 1250 LB-FT 2100 RPM KCA1-01456 291-2052 24 MAR06
Inlet Air Shutoff
Replaced 256-6461,264-6357,270-0319
335 HP 1250 LB-FT 2100 RPM KCA1457-up 305-4393 34 NOV06
Inlet Air Shutoff
Replaced 256-5731,262-4384,265-9438,
270-0296,271-2916,291-2018
350 HP 1350 LB-FT 2100 RPM KCA1-01456 291-2053 22 MAR06
Replaced 229-4911,249-7596,
251-3555,256-6459,264-6358,270-0321
350 HP 1350 LB-FT 2100 RPM KCA1457-up 305-4394 32 NOV06
RFT Injectors
Replaced 256-5729,262-4385,265-9439,
270-0297,271-2917,291-2019
350 HP 1350 LB-FT 2100 RPM KCA1457-up 305-4395 35 NOV06
Inlet Air Shutoff
Replaced 253-9429,262-4386
265-9440,270-0298,271-2918,291-2020
350HP 1450 lb-ft 2100 RPM KCA1-01456 294-4818 26 MAY06
Replaced 256-6462,264-6359,270-0322,
291-2054
350HP 1450 lb-ft 2100 RPM KCA1457-up 305-4396 36 NOV06
RFT Injectors
Replaced 262-4387,265-9441,270-0299,
271-2919,291-2021
370 HP 1350 LB-FT 2100 RPM KCA1-01456 291-2055 23 MAR06
Replaced 247-1273,249-7597,
251-3556,256-6460,264-6360,270-0323
370 HP 1350 LB-FT 2100 RPM KCA1457-up 305-4397 33 NOV06
RFT Injectors
Replaced 256-5730,262-4388,265-9442,
270-0300,271-2920,291-2022
370HP 1450 lb-ft 2100 RPM KCA1457-up 305-4398 37 NOV06
RFT Injectors
Replaced 262-4389,270-0301,271-2921,
291-2023
C13 GOV SERIAL NO. FLASH P/M RELEASE
335 HP 1550 LB-FT 2100 RPM KCB00508-6811 291-2056 37 MAR06
With factory installed 239-4908 injectors
Replaced 251-4585,256-5323,264-6684
380 HP 1450 LB-FT 2100 RPM KCB00508-5433* 291-2058 31 MAR06
Replaced 251-4580,256-5324,264-6686,
271-2867
380 HP 1400 LB-FT 2100 RPM KCB00508-6811 291-2057 38 MAR06
Replaced 251-4586,264-6685
410 HP 1450 LB-FT 2100 RPM KCB00508-6811 291-2059 32 MAR06
Replaced 251-4581,256-5325,264-6687,
271-2868
410 HP 1450/1550LB-FT M/T 2100 RPM KCB00508-6811 291-2060 46 MAR06
Oil Well Service (OWS)
Replaced 251-4594,264-6688
410 HP 1450/1650LB-FT M/T 2100 RPM KCB00508-6811 291-2061 43 MAR06
Gear Fast/Run Slow (For Eaton Top 2)
Replaced 251-4591,264-6689
410 HP 1450/1650LB-FT M/T 2100 RPM KCB00508-6811 291-2062 44 MAR06
Replaced 251-4592,264-6690
410 HP 1550 LB-FT 2100 RPM KCB00508-6811 291-2063 39 MAR06
Replaced 251-4587,264-6691
410 HP 1550 LB-FT IAS 2100 RPM KCB00508-6811 291-2069 40 MAR06
Inlet Air Shutoff
Replaced 251-4588,264-6692
430 HP 1550 LB-FT 2100 RPM KCB00508-5433* 291-2065 41 MAR06
Replaced 251-4589,264-6693
430 HP 1550 LB-FT 2100 RPM KCB00508-5433* 291-2069 42 MAR06
Inlet Air Shutoff
Replaced 251-4590,264-6697
430 HP 1550/1750LB-FT M/T 2100 RPM KCB00508-5433* 291-2067 45 MAR06
Replaced 245-5999,249-7599,251-4593,264-6695
430 HP 1650 LB-FT 2100 RPM KCB00508-5433* 291-2068 34 MAR06
Replaced 248-0777,249-7609,251-4582,264-6696
430 HP 1550/1750LB-FT MT 2100 RPM KCB00508-5433* 291-2066 35 MAR06
Gear Fast/Run Slow (Eaton 2)
Replaced 248-0776,249-7608,251-4583,264-6694
470 HP 1650 LB-FT 2100 RPM KCB00508-6811 264-6698 47 OCT04
RV RATING
Replaced 245-6000,251-4596
470 HP 1650 LB-FT 2100 RPM KCB6812-UP 262-4539 85 AUG04
RV RATING
With factory installed 249-0708 injectors
Replaced 251-5700,258-7365
525 HP 1650 LB-FT 2100 RPM KCB00508-2076 249-7606 36 DEC03
RV RATING
With factory installed 244-7695 injectors
525 HP 1650 LB-FT 2100 RPM KCB02077-6862 291-2072 51 MAR06
RV RATING
With factory installed 246-7697 injectors
Replaced 244-7695,256-5321,264-6700
525 HP 1650 LB-FT 2100 RPM KCB06863-UP 291-2076 87 MAR06
RV RATING
With factory installed 249-0697 injectors
Replaced 256-5319,264-6702
525 HP 1650 LB-FT 2100 RPM KCB6812-UP 318-9503 96 AUG07
RV RATING
(Only compatible with 259-8418 or 10R2878 turbo installed)
Replaced 262-4542,265-9579,272-3131,
285-3673,291-2048,307-1471
470/455HP 1650/1550LB-FT MT 2100 RPM KCB00508-6811 291-2071 48 MAR06
FT RATING
Replaced 245-0208,251-4597,264-6699
470/455HP 1650/1550LB-FT M/T 2100 RPM KCB6812-UP 262-4540 86 AUG04
FT RATING
Replaced 251-5702
525/455 HP 1650/1550 LB-FT 2100 RPM KCB00508-6862 249-7607 49 DEC03
FT RATING
With factory installed 223-7478, 246-7842 injectors
Replaced 242-8335,245-0210
525/455 HP 1650/1550 LB-FT 2100 RPM KCB00508-6862 291-2073 52 MAR06
FT RATING
With factory installed 246-7843 injectors
Replaced 249-0120,251-4595,
256-5322,264-6701
525/455 HP 1650 LB-FT 2100 RPM KCB00508-6862 291-2077 88 MAR06
FT RATING
Replaced 256-5320,264-6703
525/455 HP 1650/1550 LB-FT 2100 RPM MT KCB6812- UP 318-9504 97 AUG07
FT RATING
Replaced 259-8899,262-4543,265-9580,
272-3132,291-2049,303-8748,307-1472
335 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8821 75 Apr09
Replaced 258-7345,262-4518,265-9556,
272-3110,291-2024,295-1515,303-8722,307-1446,318-9476
335-7791,341-1475
380 HP 1400 LB-FT 2100 RPM KCB5434-UP 335-7792 76 AUG08
Replaced 258-7346,262-4519,265-9557,
272-3111,291-2025,295-1516,303-8723,307-1447,318-9477
380 HP 1450 LB-FT 2100 RPM KCB5434-UP 335-7793 71 AUG08
Replaced 258-7347,262-4520,265-9558,
271-2865,272-3112,291-2026,295-1517,
303-8724,307-1448318-9478
380 HP 1450 LB-FT 2100 RPM KCB5434-UP 335-7794 90 AUG08
Inlet Air Shutoff
Replaced 258-7348,262-4521,265-9559,272-3113,
291-2027,295-1518,303-8725,307-1449,318-9479
410 HP 1450 LB-FT 2100 RPM KCB5434-UP 346-8822 72 Apr09
Replaced 258-7349,262-4522,265-9560,
271-2866,272-3114,291-2028,295-1519,
303-8726,307-1450,318-9480,3357795,341-1479
410 HP 1450/1650LB-FT 2100 RPM KCB5434-UP 346-8825 81 Apr09
Replaced 258-7350,262-4523,265-9562,272-3116,
291-2029,295-1554,303-8727,307-1451,318-9481,
335-7796,341-1480
410 HP 1450/1650LB-FT M/T 2100 RPM KCB5434-UP 346-8826 82 Apr09
Replaced 258-7351,262-4525,265-9563,272-3117,
291-2030,295-1522,303-8729,307-1453,318-9483
335-7798,341-1482
410 HP 1450/1550LB-FT M/T 2100 RPM KCB5434-UP 346-8824 84 Apr09
Oil Well Service file (OWS)
Replaced 258-7352,262-4526,265-9564,272-3118,
291-2031,295-1523,303-8730,307-1454,318-9484,
335-7799,341-1483
410 HP 1450/1550LB-FT M/T 2100 RPM KCB5434-UP 346-8823 98 Apr09
Replaced 262-4524,265-9561,
272-3115,291-2074,295-1521,302-5726,
303-8728,307-1452,318-9482,335-7797,341-1148
410 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8827 77 Apr09
Replaced 251-5692,258-7353
262-4527,265-9565,272-3119,
291-2032,295-1524,303-8731,307-1455,318-9485,
335-7800,341-1484
410 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8828 78 Apr09
Inlet Air Shutoff
Replaced 258-7354
262-4528,265-9566,272-3120,291-2033,
295-1525,303-8732,307-1456,318-9486,
335-7801,341-1485
430 HP 1650 LB-FT 2100 RPM KCB5434-UP 346-8833 73 Apr09
Replaced 258-7359,262-4533,265-9571,
272-3125,291-2038,295-1530,303-8737,307-1461,318-9491,
335-7807, 341-1490
430 HP 1550/1750LB-FT 2100 RPM KCB5434-UP 346-8831 74 Apr09
(Eaton GFRS)
Replaced 258-7357,262-4531,265-9569,272-3123,
291-2036,295-1528,303-8735,307-1459,318-9489
335-7805,341-1488
430 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8829 79 Apr09
Replaced 258-7355,262-4529,265-9567,
271-4488,272-3121,291-2034,295-1526,
303-8733,307-1457,318-9487,335-7802,
341-1486
430 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8830 89 Apr09
Inlet Air Shutoff RFT Injectors
Replaced 258-7356,262-4530,265-9568,272-3122,
291-2035,295-1527,303-8734,307-1458,318-9488,
335-7804,341-1487
430 HP 1650 LB-FT IAS 2100 RPM KCB5434-UP 346-8834 80 Apr09
Inlet Air Shutoff
Replaced 258-7360,262-4534,265-9572,
272-3126,291-2039,295-1531,303-8738,307-1462,318-9492,
335-7808,341-1491
430 HP 1550/1750LB-FT MT 2100 RPM KCB5434-UP 346-8832 83 Apr09
Replaced 258-7358,262-4532,265-9570,
272-3124,291-2037,295-1529,303-8736,307-1460,318-9490,
335-7806,341-1489
455/485HP 1550/1650LB-FT 2100 RPM KCB5434-UP 345-2372 70 May09
M/T Fire Truck
Replaced 265-3168,265-9578,272-3130,
291-2043,295-1535,303-8742,307-1466,318-9496,335-7812,
341-1495
470 HP 1550 LB-FT 2100 RPM KCB5434-UP 346-8835 91 Apr09
Replaced 254-1626,258-7361
262-4535,265-9573,272-3127,
291-2040,295-1532,303-8739,307-1463,318-9493,
335-7809,341-1492
470 HP 1650LB-FT 2100 RPM KCB5434-UP 346-8837 94 Apr09
Replaced 262-4538,265-9575,272-3129,
291-2042,295-1534,303-8741,307-1465,318-9495,
335-7811,341-1494
470 HP 1550/1650LB-FT M/T 2100 RPM KCB5434-UP 346-8836 99 Apr09
Replaced 262-9713,265-9574,272-3128,
291-2041,295-1533,303-8740,307-1464,318-9494,
335-7810,341-1493
EURO Rating for use in Europe only - not for North America use
380 HP 2100 RPM MT-283 KW-EURO3 335-7813 66 AUG08
295-1536,303-8743,307-1467,318-9497
430 HP 2100 RPM MT-321 KW-EURO3 335-7814 67 AUG08
295-1537,303-8744,307-1468,318-9498
470 HP 2100 RPM MT-350 KW-EURO3 335-7815 68 AUG08
295-1538,303-8745,307-1469,318-9499
500 HP 2100 RPM MT-373 KW-EURO3 291-2047 69 MAR06
Replaced N/A
380 HP 2100 RPM 283 KW-EURO3 AISO 335-7816 202 AUG08
Replaced 308-3512,318-9500
430 HP 2100 RPM 321 KW-EURO3 AISO 335-7817 203 AUG08
Replaced 308-3514,318-9501
470 HP 2100 RPM 350 KW-EURO3 AISO 335-7818 204 AUG08
Replaced 308-3516,318-9502
C13 GOV FLASH P/M RELEASE
HORSEPOWER TORQUE SPEED FILE CODE DATE
2007 EMISSIONS EURO4 TRUCK
380 HP@2100/2300 RPM EURO4 S3C00001-UP 330-2021 35/135 JUN08
Replaced 295-6886,319-4910
430 HP@2100/2300 RPM EURO4 SC300001-UP 330-2022 36/136 JUN08
Replaced 295-6887,319-4911
470 HP@2100/2300 RPM EURO4 SC300001-UP 330-2023 37/137 JUN08
Replaced 295-6888,319-4912
2007 EMISSIONS ADEM A4 ECM ON HD ACERT HIGHWAY TRUCK
305 HP 1150 LB-FT 2100/2300 RPM LEE00001-UP 365-1126 40/140 Nov10
Replaced 311-6968,312-1397,314-3431,
316-1760,318-7028,320-0292,326-3606,
327-4486,333-5970,337-7326,343-5712,
348-4710
335 HP 1250 LB-FT 2100/2300 RPM LEE00001-UP 318-7029 41 SEP07
Replaced 311-6987,312-1398,314-3432,
316-1769
335 HP 1250 LB-FT 2100/2300 RPM LEE00001-UP 365-1127 42/142 Nov10
Replaced 314-3433,316-1762,318-7030,
320-0294,326-3607,327-4487,333-5971,
337-7327,343-5713,348-4711
350 HP 1350 LB-FT 2100/2300 RPM LEE00001-UP 365-1128 43/143 Nov10
Replaced 311-6989,312-1400,314-3434,
316-1763,318-7031,320-0295,326-3608,
327-4488,333-5972,337-7328,343-5714,
348-4712
350 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1129 45/145 Nov10
Replaced 311-6990,312-1401,314-3435,
316-1764,318-7032,320-0296,326-3609,
327-4489,333-5973,337-7329,343-5715,
348-4713
350 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1130 46/146 Nov10
Oil Well Service
Replaced 314-3436,316-1765,318-7033,
320-0297,326-3610,327-4490,333-5974,
337-7330,343-5716,348-4714
350 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 365-1131 47/147 Nov10
Replaced 311-6992,312-1403,314-3437,
316-1766,318-7034,320-0298,326-3611,
327-4491,333-5975,337-7331,343-5717,
348-4715
370 HP 1350 LB-FT 2100/2300 RPM LEE00001-UP 365-1132 48/148 Nov10
Replaced 311-6993,312-1404,314-3438,
316-1767,318-7035,320-0299,326-3612,
327-4492,333-5976,337-7332,343-5718,
348-4716
370 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1133 49/149 Nov10
Replaced 311-6994,312-1405,314-3439,
316-1768,318-7036,320-0300,326-3613,
327-4493,333-5977,337-7333,343-5719,
348-4717
380 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1135 67/167 Nov10
Supports Optional Pre-cooler
Replaced 314-3441,316-1770,318-7038,
320-0302,326-3615,327-4495,333-5979,
337-7335,343-5721,348-4719
380 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1136 52/152 Nov10
Replaced 311-6996,312-1407,314-3442,
316-1771,318-7039,320-0303,326-3616,
327-4496,333-5980,337-7336,343-5722,
348-4720
410 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1137 68/168 Nov10
Replaced 314-3443,316-1772,318-7040,
320-0304,326-3617,327-4497,333-5981,
337-7337,343-5723,348-4721
410 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7334 50/150 Nov10
Replaced 311-6995,312-1406,314-3440,
316-1769,318-7037,320-0301,326-3614,
327-4494,333-5978,337-7334,
410 HP 1450 LB-FT 2100/2300 RPM LEE00001-UP 365-1138 53/153 Nov10
Replaced 311-6997,312-1408,314-3444,
316-1733,318-7041,320-0305,326-3618,
327-4498,333-5982,337-7338,343-5724,
348-4722
410HP 1450/1550 LB-FT 2100/2300 RPM LEE00001-UP 365-1139 69/169 Nov10
Multi-torque
Replaced 314-3445,316-1774,318-7042,
320-0306,326-3619,327-4499,333-5983,
337-7339,343-5725,348-4723
410HP 1450/1550 LB-FT 2100/2300 RPM LEE00001-UP 365-1140 54/154 Nov10
Multi-torque
Replaced 311-6998,312-1409,314-3446,
316-1775,318-7043,320-0307,326-3620,
327-4500,333-5984,337-7340,343-5726,
348-4724
410 HP 1450/1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7341 70/170 OCT08
Multi-torque
Replaced 314-3447,316-1776,318-7044,
320-0308,326-3621,327-4501,333-5985
410 HP 1450/1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7342 55/155 OCT08
Multi-torque
Replaced 311-6999,312-1410,314-3448,
316-1777,318-7045,320-0309,326-3622,
327-4502,333-5986
410 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7343 71/171 OCT08
Replaced 314-3449,316-1778,318-7046,
320-0310,326-3623,327-4503,333-5987
410 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7344 56/156 OCT08
Replaced 311-7000,312-1411,314-3450,
316-1779,318-7047,320-0311,326-3624,
327-4504,333-5988
430 HP 1550/1750 LB-FT 2100/2300 RPM LEE00001-UP 337-7346 58/158 OCT08
GFRS
Replaced 311-7002,312-1413,314-3452,
316-1781,318-7049,320-0314,326-3626,
327-4506,333-5990
430 HP 1550/1750 LB-FT 2100/2300 RPM LEE00001-UP 337-7347 59/159 OCT08
Multi-torque
Replaced 311-7003,312-1414,314-3452,
316-1782,318-7050,320-0315,326-3627,
327-4507,333-5991
430 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7345 57/157 OCT08
Replaced 311-7001,312-1412,314-3451,
316-1780,318-7048,320-0313,326-3625,
327-4505,333-5989
430 HP 1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7349 60/160 OCT08
Replaced 311-7004,312-1415,314-3454,
316-1784,318-7052,320-0317,326-3629,
327-4509,333-5993
470 HP 1550 LB-FT 2100/2300 RPM LEE00001-UP 337-7350 61/161 OCT08
Replaced 311-7005,312-1416,314-3455,
316-1785,318-7053,320-0318,326-3630,
327-4510,333-5994
470 HP 1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7351 62/162 OCT08
Multi-torque
Replaced 311-70063,12-1417,314-3456,
316-1786,318-7054,320-0319,326-3631,
327-4511,333-5995
470 HP 1650 LB-FT 2100/2300 RPM LEE00001-UP 337-7352 63/163 OCT08
Replaced 312-1418,314-3457,316-1787,
318-7055,320-0320,326-3632,327-4512,
333-5996
455 HP 1550 LB-FT 2100 RPM LEE00001-UP 337-7353 64/164 OCT08
485 HP 1650 LB-FT
Replaced 312-1419,314-3458,316-1788,
318-7056,320-0321,326-3633,327-4413,
333-5997
525 HP 1750 LB-FT 2100 RPM LEE00001-UP 337-7354 65/165 OCT08
RV
Replaced 312-1420,314-3459,315-5890,
316-1789,318-7057,320-0322,326-3634,
327-4514,333-5998
525 HP 1750 LB-FT 2100 RPM LEE00001-UP 337-7355 66/166 OCT08
Replaced 312-1421,314-3460,316-1790,
318-7058,320-0323,326-3635,327-4515,
333-5999
C15 GOV SERIAL NO. FLASH P/M RELEASE
435 HP 1650 LB-FT 2100 RPM BXS00001-02034 242-1857 34 AUG03
Replaced 241-8405
435 HP 1650 LB-FT 2100 RPM BXS2035 -up 305-4511 40 NOV06
Replaced 245-0197, 247-7543,
249-7619,253-6066,255-4933,
262-3727,271-2954,283-5127,291-2083
435 HP 1550/1750 LB-FT M/T 2100 RPM BXS00001-02034 242-1856 32 AUG03
Gear Fast/Run Slow (EATON 2)
Replaced 237-9213,241-8409
435 HP 1550/1750 LB-FT M/T 2100 RPM BXS2035-up 305-4508 44 NOV06
Replaced 245-0189,247-7541,
249-7617,253-6070,255-4931,
262-3724,271-2951,283-5124,291-2080
435 HP 1550/1750 LB-FT M/T 2100 RPM BXS00001-02034 244-2510 31 AUG03
435 HP 1550/1750 LB-FT 2100 RPM BXS02035-up 290-2167 20 FEB06
Gear Fast/Run Slow
2004 Iron ADEM 4 ECM only
Replaced 253-0038,261-6686,
264-7702,271-1372,283-1179
435 HP 1550/1650 LB-FT M/T 2100 RPM BXS2035-up 305-4507 60 NOV06
Replaced 258-6910,262-3723,
271-2950,283-5123,291-2079
435 HP 1550/1750 LB-FT M/T 2100 RPM BXS2035-up 305-4509 45 NOV06
Replaced 245-0181,245-0212,
249-7626,253-6071,255-4932,
262-3725,271-2952,283-5125,291-2081
435 HP 1550 LB-FT 2100 RPM BXS2035-up 305-4506 48 NOV06
Replaced 245-0195,247-7544,
249-7620,253-6074,255-4930,262-3722,
271-2949,283-5122,291-2078
435/500HP 1550/1650 LB-FT M/T 2100 RPM BXS02035-up 305-4510 54 NOV06
Replaced 249-2489,255-1267,
262-3726,271-2953,283-5126,291-2082
475 HP 1650 LB-FT 2100 RPM BXS00001-02034 242-1858 35 AUG03
Replaced 239-5256,241-8406
475 HP 1650 LB-FT 2100 RPM BXS2035-up 305-4512 41 NOV06
Replaced 245-0183,247-7538,
249-7614,253-6067,255-4934,
262-3728,271-2955,283-5128,291-2084
475 HP 1650 LB-FT 2100 RPM BXS2035-up 305-4513 50 NOV06
Brakesaver
Replaced 245-0201,249-7622,
253-6076,255-4935,262-3729,
271-2956,283-5129,291-2085
475 HP 1650/1850 LB-FT M/T 2100 RPM BXS2035-up 305-4515 47 NOV06
Replaced 245-0193,245-0213,
249-7869,253-6073,255-4937,
262-3731,271-2958,283-5131,291-2087
475 HP 1650/1850 LB-FT M/T 2100 RPM BXS2035-up 305-4514 46 NOV06
Replaced 245-0191,247-7542,
249-7618,253-6072,255-4936,
262-3730,271-2957,283-5130,291-2086
475 HP 1850 LB-FT 2100 RPM BXS00001-02034 242-1859 36 AUG03
Replaced 239-5257,241-8407
475 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4516 42 NOV06
Replaced 245-0185,247-7539,
249-7615,253-6068,255-4938,
262-3732,271-2959,283-5132,291-2088
475 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4517 51 NOV06
Brakesaver
Replaced 245-0203,249-7623,
253-6077,255-4939,262-3733,
271-2960,283-5133,291-2089
500 HP 1650 LB-FT 2100 RPM BXS02035-up 305-4518 55 NOV06
Replaced 249-2490,262-3734,
271-2961,283-4134,291-2090
500 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4519 49 NOV06
Replaced 245-0199,247-7545,
249-7621,253-6075,255-4940,
262-3735,271-2962,283-5135,291-2091
500 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4520 52 NOV06
Brakesaver
Replaced 245-0205,249-7624,
253-6078,255-4941,262-3736,
271-2963,283-5136,291-2092
500 HP 1850 LB-FT 2300 RPM BXS2035-up 305-4521 56 NOV06
Replaced 249-2491,255-1269,
262-3737,271-2964,283-5137,291-2093
550 HP 1850 LB-FT 2100 PRM BXS00001-02034 242-1860 37 AUG03
Replaced 239-5258,241-8408
550 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4522 43 NOV06
Replaced 245-0187,247-7540,
249-7616,253-6069,255-4942,
262-3738,271-2965,283-5138,291-2094
550 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4523 53 NOV06
Brakesaver
Replaced 245-0207,249-7625,
253-6079,255-4943,262-3739,
271-2966,283-5139,291-2095
550 HP 1850 LB-FT 2300 RPM BXS2035-up 305-4524 57 MAR06
Replaced 249-2492,255-1270,
262-3740,271-2967,283-5140,291-4347
HEAVY HAUL RATINGS
Please note the heavy haul production files are an enhancement for specific
heavy load applications. The files were not created to correct a problem with
engine performance in heavy haul applications. Previous heavy haul software
meets all specifications pertaining to performance. This software is basically
an improvement that may augment performance, engine response and fuel economy
if utilized correctly. The most effective improvement is driver training.
475 HP 1650 LB-FT 2100 RPM BXS2035-up 305-4525 61 NOV06
Replaced 288-8535,297-2417
Replaces BXS 291-2084/PM code 41 for use in Heavy Haul applications only
475 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4526 62 NOV06
Replaced 288-8536,297-2418
Replaces BXS 291-2088/PM code 42 for use in Heavy Haul applications only
550 HP 1850 LB-FT 2100 RPM BXS2035-up 305-4527 63 NOV06
Replaced 288-8537,297-2419
Replaces BXS 291-2094/PM code 43 for use in Heavy Haul applications only
435 HP 1550 LB-FT 2100 RPM MXS00001-UP 329-8532 20 APR08
NXS00001-UP
Replaced 258-8358,264-0064,
264-7700,271-1370,283-1177,
290-2165,308-1274
435 HP 1550/1750 LB-FT 2100 RPM MXS00001-UP 329-8536 21 APR08
NXS00001-UP
Replaced 258-8359,264-7703,
271-1374,283-1181,290-2169,308-1278
435 HP 1550/1650 LB-FT M/T 2100 RPM MXS00001-up 329-8533 43 APR08
NXS00001-UP
Replaced 269-2109,271-1373,283-1180,
290-2168,308-1275
435/550HP 1550/1850 LB-FT 2100 RPM MXS00001-UP 308-1307 46 FEB07
NXS00001-UP
Multi-torque Oil Well Service Only
Replaced 277-3087
435 HP 1650 LB-FT 2100 RPM MXS00001-UP 329-8537 22 APR08
NXS00001-UP
Replaced 258-8360,264-0065,
264-7701,271-1371,283-1178,
290-2166,308-1279,312-5637
435/500HP 1550/1650 LB-FT 2100 RPM MXS00001-UP 329-8534 23 APR08
NXS00001-UP
Replaced 258-8361,264-7704,
271-1375,283-1182,290-2170,
296-6023,308-1276
435 HP 1550/1750 LB-FT 2100 RPM MXS00001-UP 329-8535 7 APR08
Gear Fast/Run Slow (Eaton 2) NXS00001-UP
Replaced 253-0058,261-6686,
264-7702,283-1179,290-2167,308-1277
475 HP 1650 LB-FT 2100/2300 RPM MXS00001-UP 329-8566 47 APR08
Multi-torque NXS00001-UP
Replaced 277-3088,308-1308
475 HP 1850 LB-FT 2100/2300 RPM MXS00001-UP 329-8567 48 APR08
Replaced 277-3089,308-1309
475 HP 1650 LB-FT 2100 RPM MXS00001-UP 329-8538 24 APR08
NXS00001-UP
Replaced 258-8362,264-7705,
271-1376,283-1183,290-2171,
295-6068,308-1280,312-5638
475 HP 1650 LB-FT 2100 RPM MXS00001-UP 329-8539 25 APR08
Brakesaver NXS00001-UP
Replaced 271-1377,283-1184,
290-2172,295-6069,308-1281
475 HP 1650/1850 LB-FT 2100 RPM MXS00001-UP 329-8540 26 APR08
Replaced 258-8364,264-0066,264-7709,
271-1380,283-1187,289-1281,290-2175,
292-6962,301-4633,308-1282
475 HP 1650/1850 LB-FT 2100 RPM MXS00001-UP 329-8541 27 APR08
Replaced 258-8365,264-0067,
264-7710,271-1381,283-1188,
289-1282,290-2176,292-6963,
301-4634,308-1283
475 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8542 28 APR08
NXS00001-UP
Replaced 258-8366,264-0068,
264-7707,271-1378,283-1185,
290-2173,292-6960,301-4631,308-1284
475 HP 1850 LB-FT 2100/2300 RPM MXS00001-UP 329-8543 29 APR08
Replaced 258-8367,264-7708,
271-1379,283-1186,289-1280,
290-2174,292-6961,301-4632,308-1285
500 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8545 30 APR08
NXS00001-UP
Replaced 258-8368,264-7711,
271-1382,283-1189,290-2177,308-1287
500 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8546 31 APR08
Replaced 258-8369,264-7712,
271-1383,283-1190,290-2178,308-1288
550 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8549 32 APR08
NXS00001-UP
Replaced 258-8370,264-7713,
271-1384,283-1191,290-2179,
308-1291,312-5639
550 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8550 33 APR08
Replaced 258-8371,264-7714,
271-1385,283-1192,290-2180,308-1292
Lower rated engines can not be uprated to 600/625 HP rating
600 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8553 9 APR08
NXS00001-UP
Replaced 256-1368,261-6687,264-7715,
269-0982,271-1386,283-1193,290-2181,
302-8942,307-2259,308-1295
600 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8554 10 APR08
Replaced 261-6688,264-7716,269-0983,
271-1387,283-1194,290-2182,308-1296
600 HP 1850 LB-FT 2300 RPM MXS00001-UP 323-5866 44 NOV07
MT Military LVSR NXS00001-UP
Replaced 291-0106
625 HP 2050 LB-FT 2100 RPM MXS00001-UP 329-8557 6 APR08
NXS00001-UP
Replaced 253-0037,261-6689,
264-7717,269-0984,271-1388,
283-1195,290-2183,308-1299,312-5640
625 HP 2050 LB-FT 2100 RPM MXS00001-UP 329-8558 8 APR08
Replaced 261-6690,264-7718,
269-0985,271-1389,283-1196,
290-2184,308-1300
UPRATE
500 HP 1650 LB-FT 2100 RPM MXS00001-UP 308-1286 34 FEB07
UPRATE ONLY NXS00001-UP
Replaced 263-2858,271-1390,
283-1197,290-2185
500 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8547 35 APR08
Replaced 263-2859,271-1391,
283-1198,290-2186,308-1289
500 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8548 36 APR08
NXS00001-UP
BRAKESAVER/UPRATE ONLY
Replaced 263-2860,271-1392,
283-1199,290-2187,308-1290
550 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8551 37 APR08
Replaced 263-2861,271-1393,
283-1200,290-2188,308-1293
550 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8552 38 APR08
BRAKESAVER/UPRATE ONLY NXS00001-UP
Replaced 263-2862,271-1394,
283-1201,290-2189,308-1294
600 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8555 39 APR08
Replaced 263-2863,271-1395,
283-1202,290-2190,308-1297
600 HP 1850 LB-FT 2300 RPM MXS00001-UP 329-8556 40 APR08
BRAKESAVER ONLY
Replaced 263-2864,271-1396,
283-1203,290-2191,308-1298
625 HP 2050 LB-FT 2300 RPM MXS00001-UP 329-8559 41 APR08
Replaced 263-2865,271-1397,
283-1204,290-2192,308-1301
625 HP 2050 LB-FT 2300 RPM MXS00001-UP 329-8560 42 APR08
BRAKESAVER ONLY
Replaced 263-2866,271-1398,283-1205,290-2193,308-1302
HEAVY HAUL RATINGS
Please note the heavy haul production files are an enhancement for specific heavy load applications.
The files were not created to correct a problem with engine performance in heavy haul applications.
Previous heavy haul software meets all specifications pertaining to performance.
This software is basically an improvement that may augment performance, engine response
and fuel economy if utilized correctly. The most effective improvement is driver training.
475 HP 1650 LB-FT 2100 RPM MXS00001-UP 329-8561 50 APR08
NXS00001-UP
Replaced 288--8538,291-2013,308-1303
Replaces MXS 290-2171/PM code 24 for use in Heavy Haul applications only
475 HP 1850 LB-FT 2100 RPM MXS00001-UP 329-8562 51 APR08
NXS00001-UP
Replaced 288-8539,291-2014,308-1304
Replaces MXS 290-2173/PM code 28 for use in Heavy Haul applications only
550 HP 1850 LB-FT 2100 RPM MXS00001-UP 308-1305 52 JAN07
NXS00001-UP
Replaced 288-8540,291-2015
Replaces MXS 290-2179/PM code 32 for use in Heavy Haul applications only
C15 GOV FLASH P/M RELEASE
2007 EMISSIONS ADEM A4 ECM ON HEAVY DUTY ACERT HIGHWAY TRUCK
435 HP 1550 LB-FT 2100/2300 RPM SDP00001-UP 365-1160 40/140 Nov10
Replaced 310-8351,311-6957,314-2915,
316-1845,318-6991,320-0362,326-3651,
327-4519,333-5944,334-1287,343-5744,
348-4745
435 HP 1650 LB-FT 2100/2300 RPM SDP00001-UP 365-1161 41/141 Nov10
Replaced 310-8352,311-6958,314-2916,
316-1846,318-6992,320-0363,326-3652,
327-4520,333-5945,334-1288,343-5745,
348-4746
435HP 1550/1750 LB-FT 2100/2300 RPM SDP00001-UP 365-1162 42/142 Nov10
Multi-torque/GFRSS
Replaced 309-1779,310-8353,311-6959,
314-2917,316-1847,318-6993,320-0364,
326-3653,327-4521,333-5946,334-1289,
343-5746,348-4747
435HP 1550/1650 LB-FT 2100/2300 RPM SDP00001-UP 365-1163 43/143 Nov10
Multi-torque
Replaced 310-8354,311-6960,314-2918,
316-1848,318-6994,320-0365,326-3654,
327-4522,333-5947,334-1290,343-5747,
348-4748
435HP 1550/1750 LB-FT 2100/2300 RPM SDP00001-UP 365-1164 44/144 Nov10
Multi-torque
Replaced 310-8355,311-6961,314-2919,
316-1849,318-6995,320-0366,326-3655,
327-4523,333-5948,334-1291,343-5748,
348-4749
435HP 1550/1650 LB-FT 2100/2300 RPM SDP00001-UP 365-1165 45/145 Nov10
Multi-torque/OWS
Replaced 310-8356,311-6962,314-2920,
316-1850,318-1924,318-6996,320-0367,
326-3656,327-4524,333-5949,334-1292,
343-5749,348-4750
475 HP 1650 LB-FT 2100/2300 RPM SDP00001-UP 365-1166 46/146 Nov10
Replaced 310-8357,311-6963,314-2921,
316-1851,318-6997,320-0368,326-3657,
327-4525,333-5950,334-1293,343-5750,
348-4751
475HP 1650/1750 LB-FT 2100/2300 RPM SDP00001-UP 365-1168 48/148 Nov10
Multi-torque
Replaced 310-8359,311-6965,314-2923,
316-1853,318-6999,320-0370,326-3659,
327-4527,333-5952,334-1295,343-5752,
348-4753
475 HP 1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1169 49/149 Nov10
Replaced 310-8360,311-6966,314-2924,
316-1854,318-7000,320-0371,326-3660,
327-4528,333-5953,334-1296,343-5753,
348-4754
475HP 1650/1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1171 51/151 Nov10
Multi-torque/GFRSS
Replaced 310-8362,311-6968,314-2926,
316-1856,318-7002,320-0373,326-3662,
327-4530,333-5955,334-1298,343-5755,
348-4756
475HP 1650/1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1172 52/152 Nov10
Multi-torque
Replaced 310-8363,311-6969,314-2927,
316-1857,318-7003,320-0374,326-3663,
327-4531,333-5956,334-1299,343-5756,
348-4757
500 HP 1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1174 54/154 Nov10
Replaced 310-8365,311-6971,314-2929,
316-1859,318-7005,320-0376,326-3665,
327-4533,333-5958,334-1301,343-5758,
348-4759
550 HP 1850 LB-FT 2100/2300 RPM SDP00001-UP 365-1175 55/155 Nov10
Replaced 310-8366,311-6972,314-2930,
316-1860,318-7006,320-0377,326-3666,
327-4534,333-5959,334-1302,343-5759,
348-4760
600 HP 1850 LB-FT 2100 RPM SDP00001-UP 365-1177 57/157 Nov10
Replaced 311-6974,314-2932,316-1862,
318-7008,320-0379,326-3668,327-4536,
333-5961,334-1304,343-5761,348-4762
600 HP 1850 LB-FT ARF 2100 RPM SDP00001-UP 365-1178 58/158 Nov10
Replaced 318-7009,320-0380,326-3669,
327-4537,333-5962,334-1305,343-5762,
348-4763
600 HP 1850 LB-FT (RV) 2100 RPM SDP00001-UP 365-1179 59/159 Nov10
Replaced 311-6976,314-2934,315-5873,
316-1864,318-7010,320-0381,326-3670,
327-4538,333-5963,334-1306,343-5763,
348-4764
600 HP 2050 LB-FT 2100 RPM SDP00001-UP 365-1180 60/160 Nov10
Replaced 311-6977,314-2935,316-1865,
318-7011,320-0382,326-3671,327-4539,
333-5964,334-1307,343-5764,348-4765
600 HP 2050 LB-FT (RV) 2100 RPM SDP00001-UP 365-1181 62/162 Nov10
Replaced 311-6979,314-2937,315-5874,
316-1867,318-7013,320-0384,326-3672,
327-4540,333-5965,334-1308,343-5765,
348-4766
625 HP 2150 LB-FT 2100 RPM SDP00001-UP 365-1182 63/163 Nov10
Replaced 310-8374,311-6980,314-2938,
316-1868,318-7014,320-0385,326-3673,
327-4541,333-5966,334-1309,343-5766,
348-4767
625 HP 2050 LB-FT (RV) 2100 RPM SDP00001-UP 365-1183 65/165 Nov10
Replaced 311-6982,314-2940,315-5875,
316-1870,318-7016,320-0387,326-3674,
327-4542,333-5967,334-1310,343-5767,
348-4768
625 HP 1900 LB-FT 2100 RPM SDP00001-UP 365-1184 66/166 Nov10
Replaced 311-6983,314-2941,315-5876,
316-1871,318-7017,320-0388,326-3675,
327-4543,333-5968,334-1311,343-5768,
348-4769
EURO 4 Rating for use in Europe only - not for North America use
500 HP@2100/2300 RPM EURO4 348-6571 35/135 Jun09
Multi-torque
Replaced 295-6883,319-4913,330-2024,
335-6771
550 HP@2100/2300 RPM EURO4 348-6572 36/136 Jun09
Replaced 295-6884,319-4914,330-2025,
335-6772
625 HP@2100/2300 RPM EURO4 348-6573 37/137 Jun09
Replaced 295-6885,319-4915,330-2026,
335-6773
HEAVY HAUL RATINGS
475 HP 1650 LB-FT 2300 RPM SDP1-up 365-1167 47/147 Nov10
Replaced 314-2922,316-1852,318-6998,
320-0369,326-3658,327-4526,333-5951,
334-1294,343-5751,348-4752
For use in Heavy Haul applications only
475 HP 1850 LB-FT 2300 RPM SDP1-up 365-1170 50/150 Nov10
Replaced 314-2925,316-1855,318-7001,
320-0372,326-3661,327-4529,333-5954,
334-1297,343-5754,348-4755
550 HP 1850 LB-FT 2300 RPM SDP1-up 365-1176 56/156 Nov10
Replaced 314-2931,316-1861,318-7007,
320-0378,326-3667,327-4535,333-5960,
334-1303,343-5760,348-4761
- Perkins EST 2015A v1.0 01.2015
- CAT ET 2015C v1.0 + Patch Full
- CAT ET 2015A Patch and Activation
- Caterpillar SIS 2017 Full [01.2017]
- Caterpillar Factory Password Generator for ET
- Caterpillar Service Manual,Schematic, Parts Manual Operation and Maintenance Manual Full DVD Part 2
- CAT ET2015A Activator
- How To Install Cat SIS FULL WITH 3D IMAGES [01.2021] + Unlock Files
- Caterpillar ET Electronic Technician 2016A v1.0 01.2016
- Caterpillar Flash Files 2016 Newest
- Caterpillar SIS 2016 Full [01.2016]
- CAT ET 2017A v1.0 KG Unlocked
- Caterpillar SIS 2019 Full [01.2019]
- CAT ET 2015B v1.0 + Patch Full
