Hyundai
86
176,834
Case IH Axial Rotary Combines AXIAL-FLOW 7260 8260 9260 Operators Manual 92671771 2025
Brand: Case IH
Type of Machine: Axial Rotary Combines
Model: Case IH AXIAL-FLOW 7260, AXIAL-FLOW 8260, AXIAL-FLOW 9260 Axial Rotary Combines
PIN HAJF7E5RLSG260101 and above
Part Number: 92671771
Publication Date: 2025
Number of Pages: 818 Pages
GENERAL INFORMATION
Note to the Owner​
Intended use​
Engine tampering​
Electro-Magnetic Compatibility (EMC)​
Cybersecurity declarations​
Manual scope​
Product identification​
Operator's manual storage on the machine​
Machine orientation​
SAFETY INFORMATION
Basic safety rules​
Safety signs – Overview​
General safety rules​
General maintenance safety rules​
Wheel and tire safety​
Transporting on public roads​
Fire prevention​
Fire extinguisher​
Battery safety​
Battery disconnect switch​
Seat belt precautions​
Instructional seat safety​
Operator presence system​
Power Take-Off (PTO) safety rules —Safety rules​
Warning lights​
Air conditioning system​
Reverse alarm​
Personal Protective Equipment (PPE)​
Do Not Operate hang tag​
Hazardous chemicals​
Electrical storm safety​
Utility safety​
Mounting and dismounting precautions​
Operating the machine​
Connecting a header​
Hydraulic system safety​
Working at heights​
Ecology and the environment​
Illustrations​
Lift cylinder lockout​
Feeder fore/aft tilt – Lockout (if equipped)​
Urgent stop button​
Airborne noise emission​
Vehicle vibration levels​
Machine disposal​
Safety signs – Right-hand side​
Safety signs – Front​
Safety signs – Left-hand side​
Safety signs – Rear​
Safety signs – Hood mounted chopper only​
Safety signs – Top​
CONTROLS AND INSTRUMENTS
Access to operator's platform​
Folding ladder​
Cab layout​
Emergency exit​
Operator's seat​
Operator's seat​
Seat belt – Operator’s seat​
Heated floor mat​
Instructional seat​
Instructional seat – Overview​
Seat belt – Instructional seat​
Under seat cooler​
Forward controls​
Steering column​
Urgent stop button​
Foot controls​
Right-hand side controls​
Threshing controls​
Cleaning controls​
Residue controls​
Start console​
Multi-Function Handle (MFH)​
Unloading tube​
Pivoting unloading spout – if equipped​
Quick stop​
Feedrate control​
AFS Accuguide™​
Automatic Header Height Control (AHHC)​
Configurable header position control – Header position switch​
Configurable reel position control​
Configurable position control Setting​
Feeder fore/aft tilt – In cab adjustment​
Grain tank unloading drive​
Shift button​
Right-hand console​
Drive engagement switches​
Reel drive – Controls​
Rotor speed – Switch​
Concave clearance – Controls​
Rotor discharge deflector switch​
Adjustable cage vane switch​
Cleaning fan speed control – Switch​
Pre-sieve opening – Switch​
Upper sieve – Switch​
Lower sieve – Switch​
Gear selector​
Throttle control​
Chopper counter knife – Position switch​
Spreader speed – Control switch​
Spread distribution – switch​
Deflector – Right-hand switch​
Deflector – Left-hand switch​
Parking brake​
Powered Rear Axle (PRA) – Control​
High/Low – Control​
Header height control​
Feeder – Controls​
Vertical knife – Control​
Display​
Armrest - Overview​
Rearward controls​
Rear window​
Cab features – Storage and fuse access​
Overhead controls​
Overhead controls​
Sun screens​
Cab climate control system​
Overhead storage​
Cab radio - DEA730 radio​
Phone app​
Interior lamps​
Communication equipment – Mounting​
Exterior controls​
Exterior switches – Locations​
Battery disconnect switch – operation​
Display​
AFS®Pro 1200 display – Introduction​
AFS®Pro 1200 display – Overview​
Notification bar​
Machine status area​
Work switch status​
Faults & Warnings​
Global Navigation Satellite System (GNSS)​
Applications​
Help​
Clock​
User Profiles​
Menu - Settings​
Menu screens​
System settings​
Header settings​
Combine settings​
Procedures & Calibration​
Diagnostics​
Header diagnostics​
Combine diagnostics​
Productivity​
Overview​
Calibrations​
Procedures​
Calibrations​
Steering valve – Sample​
Calibration error list​
Procedures​
Kill stall​
Sieves – Pressure sensor test​
Rotor Loss Sensor – Test​
Axial Trac suspended tracks – Tension / Untension​
Sieve Loss Sensor – Test​
Run screens​
Sensitivity settings​
Clean out control​
Machine lighting​
Lighting and mirrors​
Machine access​
Engine platform access​
Side shields - Open/Close​
Service platforms and shielding​
Rotor module – Access​
Grain tank access​
Grain tank – Covers/extensions​
Adjustable threshing cage – Access​
Straw chopper – Service step​
Lifting points – Locations​
OPERATING INSTRUCTIONS
Commissioning the unit​
Before driving the combine​
Axial Trac​
Track Transmission Unlock​
Starting the unit​
Daily start up procedure​
Starting the engine – Cold weather​
Engine control system - Control​
Stopping the unit​
Stopping the engine​
Moving the unit​
Moving the machine​
Road travel​
Operator platform extension – Removal​
Operator platform extension – Installation​
Axial Trac – Road travel​
Axial Trac – Track pre-conditioning​
Parking brake – Manual release​
Transmission – Manual shifting​
Parking the unit​
Wheel chock​
TRANSPORT OPERATIONS
Preparing for road transport​
Attaching a trailer​
Shipping transport​
Transporting on a trailer – Tie downs for shipping​
Recovery transport​
Towing the machine​
WORKING OPERATIONS
General information​
Introduction to harvesting​
Performance indicators​
Losses​
Initial crop settings - AFX Rotor​
Initial crop settings – Small tube rotor 40E​
Initial crop settings – Small tube rotor 36E​
Kill-Stall diagnosis​
Crop setup values – Crop condition adjustment​
HEADER HEIGHT CONTROL​
Header height control overview​
Header height control – Manual mode​
Header height control – Sensitivity​
Header height control – Return To Cut (RTC) mode​
Header height control – Auto Header Height Control (AHHC)​
Header height control – Pressure float mode​
Automatic Crop Settings (ACS)​
AFS Harvest Command™​
AFS Harvest Command™ – Overview​
AFS Harvest Command™ – Activation​
AFS Harvest Command™ – Run screen​
AFS Harvest Command™ – Basic tab​
AFS Harvest Command™ – Advanced tab​
AFS Harvest Command™ – Sensitivities tab​
AFS Harvest Command™ – Headland tab​
AFS Harvest Command™ – Ranges tab​
AFS Harvest Command™ – Status tab​
AFS Harvest Command™ – Information​
AFS Harvest Command™ – Operation​
AFS Harvest Command™ – Sensitivity adjustment​
HEADER CONNECTION​
Disconnecting a header​
Header setup​
Combine corn header – Set up​
Grain header – Set up​
Draper/Varifeed™ header – Set up​
Pickup header – Set up​
FEEDING​
Feeding​
Rock trap​
Feeder cradle – Manual adjustment​
Feeder cradle – Angle adjustment per tire size​
Feeder drum – Adjust lower stop​
Feeder chain – Adjustment​
Feeder chain – Link removal​
Reel speed​
Feeder reverse system - Overview​
Feedrate control​
THRESHING​
Rotor​
Rotor configurations – AFX Rotors​
Rotor configurations – 40E Rotor​
Rotor configurations – 36E Rotor​
Rotor cage – Module overview​
Concave – Position overview​
Rotor cage – Position adjustment​
Rotor cage – Leveling​
Rotor cage – Side shift adjustment​
Rotor cage – H–frame stop bolt adjustment​
Threshing and separation​
Suggested start up configurations for major crops​
Rotor overview​
Rotor De-slug​
CLEANING​
Cleaning – Overview​
Sieves – Removal​
Sieves – Installation​
Aggressive throwing angle kit​
Cleaning fan​
Automatic cleaning fan speed – If equipped​
GRAIN HANDLING​
Tailings system​
Grain storage​
Clean grain elevator drive – Change speeds​
Unloading​
Unloading​
Folding unload tube – Transport lock​
RESIDUE HANDLING​
Residue handling​
Discharge deflector​
Straw chopper – Adjustments​
Magnacut chopper​
Straw chopper – Magnacut chopper​
Knife replacement – Magnacut counter knife​
Knife replacement – Chopper​
Shear bar​
Horizontal Disc Spreader​
Residue handling – Horizontal disc spreader configuration​
Vertical impeller spreader​
Vertical impeller spreader – Position​
Vertical impeller spreader – Spread width adjustment​
Vertical impeller spreader – Manual adjustment​
Vertical impeller spreader – In cab spreader controls (if equipped)​
Auto Spread Control​
Center divider – Adjustment​
Center divider – Impeller clearance adjustment​
Spreader chutes – Manual adjustment​
Windrow door​
Windrow chute​
Chaff pan​
In cab residue mode control​
In cab residue mode control – Troubleshooting​
Residue handling – Vertical impeller spreader configuration​
Hood mounted chopper​
Hood mounted chopper – Overview​
Initial settings​
Internal deflectors​
Chopper speed​
Counter knife​
Spreader board – Height adjustment​
Fin position​
Chaff board​
Windrow roller​
Chaff spreader - Crop setting and Straw fingers​
Windrow operation​
Counter knife – Blades​
Straw chopper​
Hood mounted chopper – Sieve removal​
Troubleshooting​
Residue handling – Hood mounted chopper configuration​
MAINTENANCE
Maintenance - Overview​
Torque specifications for hardware​
Torque - Standard torque data for hydraulic connections​
Chain wear tables - Roller chain​
Battery – Overview​
Battery vent system – Overview​
Battery – Charging and jump starting​
General specification - Biodiesel fuels​
Organic Acid Technology (OAT) coolant​
Recommended engine oil for operating temperature ranges​
Maintenance planning​
Maintenance chart​
Every 10 hours or daily during the first week​
Wheel bolt torque​
Every 10 hours or daily​
Stationary air screen​
Check the engine oil level​
Power Take Off (PTO) gearbox oil level​
Hydraulic oil tank – Oil level​
Rock trap​
Deaeration tank coolant level​
Quadtrac® – Inspection​
ActiveTrac 4-Roller Track – Suspended track Inspection​
Hood mounted chopper – Cleaning​
Hood mounted chopper – Straw chopper blades​
Hood mounted chopper – Counter knife blades​
Every 50 hours​
Tire pressure – Check​
Cab fresh air filter​
Cab air recirculation filter​
Feeder conveyor chain​
Chain and belt tension​
Track roller - Check Oil level check​
Quadtrac® – Alignment​
Magnacut chopper – Speed adjustment​
Hood mounted chopper – Drive system inspection​
Hood mounted chopper – Drive belt tension​
Every 100 hours​
100-hour grease points​
Feeder chain drive – Grease​
Chain maintenance​
Every 300 hours​
300 hour grease points​
Bubble-up gearbox oil – Oil level check​
Transmission oil level​
Final drive oil level​
Lower unloading gearbox – Oil level​
Feeder conveyor gearbox – Oil Level​
Header drive gearbox oil – Oil level​
Rotor gearbox oil – Oil level​
ActiveTrac 4-Roller Track – Alignment​
Every 600 hours or beginning of the season​
Tailings sensor – Lens inspection​
Every 600 hours​
600 hour grease points​
Header drive gearbox oil​
Feeder conveyor gearbox​
Transmission – Change oil​
Final drive oil – Change oil​
Lower unloading gearbox – Change oil​
Unloading elbow oil level​
Tailings gearbox​
Bubble-up gearbox oil – Change oil​
Rotor gearbox oil​
Self leveling cleaning shoe pivot​
Power Take-Off (PTO) gearbox – Oil change​
Hydraulic oil return filter – Replace​
Hydraulic charge filter – Replace​
Engine oil and filter​
Fuel prefilter/water separator​
Engine mounted fuel filter​
Engine crankcase breather filter​
Hood mounted chopper – Drive bushing service​
Fuel tank breather​
Every 1200 hours or two years​
Fuel tank strainer​
Every 1200 hours​
Hydraulic reservoir, oil, and filters​
Power Take Off (PTO) – Lube filter​
Every 1500 hours​
Quadtrac® – Oil change 30 inch and 36 inch tracks​
ActiveTrac 4-roller Track and non-suspended tracks – Oil change​
Every 2400 hours​
Engine valve adjustment​
Every 4000 hours or every four years​
Engine coolant replacement​
As required maintenance​
Machine cleaning​
Machine cleaning​
GrainCam™ – Cleaning​
Tailings – Sensor cleaning​
Tailings sensor – Lens replacement​
Filling the fuel tank​
Air cleaner - Replace​
Air cleaner safety element​
Quadtrac®​
Stationary air screen – Externally aspirated inlet screen​
Windshield washer resevoir​
Fuel system bleeding​
Roof lights​
Clean fresh air intake screen​
Hood mounted chopper – Drive belt replacement​
Steering toe in​
Rear axle steering cylinder - Adjust​
Steering stop bolts – Adjustment​
Fuse and relay locations​
Fuses and relays​
Storage​
Post-season – Service​
Preseason service​
TROUBLESHOOTING
Fault code resolution​
Display alarms​
Automatic Temperature Control (ATC) system – Alarms​
GrainCam™ – Alarms​
SPECIFICATIONS
Tire care​
Drive tire – Overview​
Wheel removal​
Single drive wheel – Mounting​
Floatation drive wheel – Mounting​
Dual drive wheel – Mounting​
Temporary transport – Single wheel​
Axial Trac​
Steering wheel​
Steering axle – Overview​
Powered Rear Axle (PRA) – Hose routing​
Spindle height position​
Tread width – Rear axle​
Approved tires and tracks – 7260/8260/9260​
Machine specifications​
Capacities​
ACCESSORIES
Optional equipment​
FORMS AND DECLARATIONS
Delivery report - Owner Copy​
Delivery report - Dealer Copy​
Service record - 1st 50 Hour, Customer Copy​
Service record - 1st 50 Hour, Dealer Copy​
Axial Trac – Workshop data sheet​
Axial Trac – Difficult to align - Report​
