Bomag Single Drum Roller BW211D-40 To BW213PD-40 Operating Instructions 00815881
Brand: Bomag
Type of Machine: Single Drum Roller
Type of Manual: Operating Instructions
Model: Bomag Single Drum Roller
BW211D-40, BW212D-40, BW213D-40, BW211BWPD-40, BW212PD-40, BW213PD-40,
Part Number: 00815881
Publication Date: 2008
Number of Pages: 130 Pages
Technical Data
Safety regulations
Indicators and Controls
3.1 General notes
3.2 Description of indicators and control elements
3.3 Display and control elements BTM
3.4 Description of indicating and control elements
BTM
3.5 Line diagram (EVIB)
3.6 Description of line diagram (EVIB)
3.7 Bar diagram (EVIB)
Operation
4.1 General notes
4.2 Tests before starting to operate
4.3 Disarming the anti-theft protection
4.4 Starting the engine
4.5 Starting with jump wires
4.6 Driving the machine
4.7 Switching the vibration on and off
4.8 Operating the parking brake, stopping the machine
4.9 Shutting the engine down
4.10 Emergency exit
4.11 Adjusting the steering wheel
4.12 Adjusting the seat
4.13 Operating the hood
4.14 Towing in case of an engine failure
4.15 Transport
4.16 BTM 05 settings before start-up
4.17 Measuring pass with BTM
4.18 Finishing compaction of a track
4.19 Printing measuring data after completing compaction
4.20 Changing the paper roll in the measuring value printer
4.21 Changing the printer ribbon in the measuring value printer
Maintenance
5.1 General notes on maintenance
5.2 Fuels and lubricants
5.3 Table of fuels and lubricants
5.4 Running-in instructions
5.5 Maintenance chart
5.6 Check the engine oil level
5.7 Check, clean the water separator
5.8 Checking the fuel level
5.9 Checking the hydraulic oil level
5.10 Checking the coolant level
5.11 Checking the dust separator on the oil bath air filter
5.12 Checking the tire pressure
5.13 Clean the cooling fins on engine and hydraulic oil cooler
5.14 Check the oil level in the drive axle
5.15 Checking the oil level in left/right wheel hubs
5.16 Checking the oil level in the vibration bearing housings
5.17 Changing engine oil and oil filter cartridges
5.18 Draining the fuel tank sludge
5.19 Service the battery
5.20 Check condition and tension of refrigerant compressor V-belt, replace the Vbelt
5.21 Service the air conditioning
5.22 Check, adjust the valve clearance
5.23 Checking / replacing the ribbed V-belt
5.24 Change the fuel filter cartridge
5.25 Change the fuel pre-filter cartridge
5.26 Check the engine mounts
5.27 Change the oil in the drive axle
5.28 Changing the oil in the wheel hubs
5.29 Changing the oil for the vibration bearings
5.30 Retighten the fastening of the axle on the frame
5.31 Tightening the wheel nuts
5.32 Checking the ROPS
5.33 Cleaning the oil bath air filter
5.34 Changing the hydraulic oil and the breather filter
5.35 Changing the hydraulic oil filter
5.36 Changing the coolant
5.37 Checking the injection valves
5.38 Cleaning, changing the dry air filter cartridge
5.39 Adjusting the scrapers
5.40 Adjusting the parking brake
5.41 Changing the tires
5.42 Changing the fresh air filter in the cabin
5.43 Tightening torques
5.44 Engine conservation
Trouble shooting
6.1 General notes
6.2 Engine
Brand: Bomag
Technical Data
Safety regulations
3.1 General notes
BTM
Operation
4.1 General notes
4.10 Emergency exit
4.15 Transport
Maintenance
Trouble shooting
6.1 General notes
6.2 Engine
- BOMAG Tampers - Model BT60-BT80 shop manual
- Bomag Single Drum Wheel Drive Vibratory Roller BW142 BW142D BW142PD BW172 BW172D BW172PD Repair Instructions
- Bomag Instructions for repair BW-100 AD-3,BW-100AC-3,BW-120AC-3,BW-120AC-3
- BOMAG BW 100 AD/AC Series 4 BW 120 AD/AC Series 4 SERVICE TRAINING
- Bomag BPR 65,70D Maintenance Manual
- Bomag Circuit Diagram BW 100/120 AD/AC−3, BW 125 ADH, BW 135−138 AD/AC, C747B...C754B
- Bomag BMP 8500 Service Manual -BOSS
- Bomag BW211D-4, BW211PD-4 Operating & Maintenance Instructions
- BOMAG - Workshop Service Manuals
- Bomag Instructions for repair BW213DH-3,BW213PDH-3,BW214DH-3,BW214PDH-3
- Bomag BMP 8500 Electrical Schematic
- Bomag BW216-219DH-4 Service Training Manual
- BOMAG Roller BW24R - Operation and Maintenance manual
- Bomag BPR 50,55D & 60-65D Maintenance Manual
- Bomag BW141 AD-4,BW151AD- 4BW151 AC-4,BW161 ADCV Operation Maintenance
