American Lincoln Srubber Sweeper 7765 7760 Operator Manual
Brand: American-Lincoln
Type of Machine: Srubber, Sweeper
Model: 7765 / 7760 Scrubber/Sweeper
7765: 505-255, 505-258, 505-256, 505-259, 505-257, 505-260
7760: 505-255CE, 505-258CE, 505-257CE, 505-260CE
Form Number: 56041667
Date: 2007
Number Of Pages: 40 Pages
INTRODUCTION
INTRODUCTION
PARTS AND SERVICE
NAMEPLATE
UN-CRATING
MACHINE OPERATION
PREPARING THE MACHINE FOR OPERATION
CAUTIONS AND WARNINGS
CONSIGNES DE PRUDENCE ET DE SECURITE
OPERATION OF CONTROLS AND GAUGES
IGNITION SWITCH
LIGHT SWITCH
TURN SIGNAL (OPTION)
GLOW PLUG SWITCH
HORN PUSH BUTTON
SIDE BROOM LIFT
MAIN BROOM SWITCH
SIDE BROOM SWITCH
DUST CONTROL SWITCH
FILTER SHAKER SWITCH
WATER TEMPERATURE GAUGE
HOUR METER
FUEL GAUGE
OIL PRESSURE GAUGE
VOLT METER
SCRUB BRUSHES SWITCH
BRUSH ROTATION SWITCH
BRUSH PRESSURE SWITCH
SQUEEGEE BLADE SWITCH
HIGH RECOVERY WARNING LIGHT
LOW SOLUTION WARNING LIGHT
HOPPER LIFT
HOPPER SAFETY LOCK ARM
HOPPER DUMP DOOR
MANUAL DUMP HOPPER
SOLUTION CONTROL
SWEEPING BROOM LIFT CONTROL
THROTTLE
CHECK ENGINE LIGHT
PARKING BRAKE
FOOT BRAKE
ACCELERATOR & DIRECTIONAL CONTROL PEDAL
BACK-UP ALARM SWITCH
SEAT ADJUSTMENT
ESP SYSTEM OPERATING INSTRUCTIONS
ESP RECYCLING CONTROL PANEL
ESP RECYCLING SYSTEM ON/OFF SWITCH
SOLUTION HIGH WARNING LIGHT
DETERGENT LOW WARNING LIGHT
DETERGENT FLOW KNOB
THE SCRUBBING SYSTEM - HOW IT WORKS
NON-RECYCLING SCRUBBING SYSTEM - HOW IT WORKS
RECOVERY OR ESP SYSTEM - HOW IT WORKS
THE SWEEPING & DUST CONTROL SYSTEM - HOW IT WORKS
FILLING THE SOLUTION TANK - NON-RECYCLING (STANDARD)
FILLING THE SOLUTION TANK - ESP
PRE-START CHECKLIST
BEFORE STARTING THE ENGINE
STARTING THE ENGINE
POST-START CHECKLIST
TRANSPORTING THE MACHINE
BEGINNING THE CLEANING OPERATION
HELPFUL HINTS FOR CLEANING OPERATION
POST-OPERATION & CLEAN-UP INSTRUCTIONS
TO STOP THE CLEANING OPERATION
POST-OPERATION CHECKLIST
TO DRAIN THE SOLUTION TANK
TO CLEAN THE SOLUTION TANK
TO DRAIN THE RECOVERY TANK
TO CLEAN THE RECOVERY TANK
TO EMPTY THE DEBRIS HOPPER
TOWING INSTRUCTIONS
SERVICE CHART
GENERAL MACHINE MAINTENANCE
LUBRICATION
ENGINE
MAIN BROOM REMOVAL
MAIN BROOM LEVEL ADJUSTMENT
ADJUSTING MAIN BROOM WEAR PATTERN
SIDE BROOM LEVEL ADJUSTMENT
SIDE BROOM REPLACEMENT
FLAPS
SCRUB BRUSH REPLACEMENT
COVERS AND LATCHES
SOLUTION CONTROL - STANDARD
SOLUTION CONTROL - ESP
RECYCLING PUMP ESP SYSTEM
ESP SYSTEM STORAGE
REAR SQUEEGEE
SQUEEGEE CASTER WHEELS
ADJUSTING CASTERS
GENERAL TROUBLESHOOTING
TECHNICAL SPECIFICATIONS
Date: 2007
INTRODUCTION
INTRODUCTION
PARTS AND SERVICE
NAMEPLATE
UN-CRATING
MACHINE OPERATION
IGNITION SWITCH
LIGHT SWITCH
GLOW PLUG SWITCH
HORN PUSH BUTTON
SIDE BROOM LIFT
MAIN BROOM SWITCH
SIDE BROOM SWITCH
DUST CONTROL SWITCH
HOUR METER
FUEL GAUGE
OIL PRESSURE GAUGE
VOLT METER
HOPPER LIFT
HOPPER DUMP DOOR
MANUAL DUMP HOPPER
SOLUTION CONTROL
THROTTLE
CHECK ENGINE LIGHT
PARKING BRAKE
FOOT BRAKE
SEAT ADJUSTMENT
DETERGENT FLOW KNOB
PRE-START CHECKLIST
STARTING THE ENGINE
TOWING INSTRUCTIONS
SERVICE CHART
LUBRICATION
ENGINE
MAIN BROOM REMOVAL
FLAPS
COVERS AND LATCHES
ESP SYSTEM STORAGE
REAR SQUEEGEE
ADJUSTING CASTERS
- Ingersoll Rand Vibratory Compactors DD24 Parts Manual
- Ingersoll Rand SD-100 Schematic, Repair & Troubleshooting Manual 2022
- Kalmar Reach Stackers 40-45T DRF 400-450 Maintenance Manual
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Ingersoll Rand Vibratory Compactors SD-100D C Parts Manual
- ZF – ERGOPOWER TRANSMISSION 4 WG-130/160 Service
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- PALFINGER PC 2300 Hydraulic Crane Spare Parts List
- PALFINGER PC 1300 Hydraulic Crane Spare Parts List
- Parts catalog Isuzu 3LA1, 3LB1, 3LD1
- Hamm 3516, 3518 ,3520 ,3516 P, 3518 P ,3520 P Spare parts List
- HATZ Diesel 2W35,3W35,3W35T,4W35,4W35T Workshop Manual
- PALFINGER PC 3300 Hydraulic Crane Spare Parts List
- Schwing Service Training - Training Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
