Driver
98
288,393
American Lincoln Scrubber SR7770HC Operator's Manual Instruction Book & Parts List
Brand: American-Lincoln
Type of Machine: Scrubber
Type of Manual: Operator's Manual, Instruction Book, Parts List
Model: American Lincoln SR7770HC Scrubber
Part Number: 2-86-00301
Serial Number: 777001
Date: 2002
Number Of Pages: 159 Pages
SPECIFICATIONS
MACHINE DIMENSIONS
STANDARD HARDWARE & TORQUE VALUES
HYDRAULIC TORQUE REQUIREMENTS
DECIMAL - METRIC CONVERSION TABLE
MACHINE OPERATION
SAFETY INSTRUCTIONS
OPERATION OF CONTROLS AND GAUGES
IGNITION SWITCH
LIGHT SWITCH
HORN PUSH BUTTON
CHECK ENGINE (WARNING LIGHT)
WATER TEMPERATURE GAUGE
HOUR METER
FUEL GAUGE
OIL PRESSURE GAUGE
VOLT METER
SCRUB BRUSHES SWITCH
BRUSH ROTATION SWITCH
SCRUB DECK SWITCH
SQUEEGEE BLADE SWITCH
HIGH LEVEL WARNING LIGHT
LOW LEVEL WARNING LIGHT
SOLUTION CONTROL
DETERGENT FLOW KNOB
TURN SIGNAL (OPTION)
THROTTLE
CHOKE
PARKING BRAKE
FOOT BRAKE
ACCELERATOR & DIRECTIONAL CONTROL PEDAL
BACKUP ALARM SWITCH
SEAT ADJUSTMENT
ESP SYSTEM OPERATING INSTRUCTIONS
ESP RECYCLING SYSTEM ON/OFF SWITCH
NON-RECYCLING SCRUBBING SYSTEM - HOW IT WORKS
OPERATING MODE INSTRUCTIONS
NORMAL, HIGH CAPACITY, ESP
FILLING TANK 1 - NON-RECYCLING (STANDARD)
FILLING TANK 1 - HIGH CAPACITY or ESP
PRE-START CHECKLIST
BEFORE STARTING THE ENGINE
STARTING THE ENGINE
POST START CHECKLIST
TRANSPORTING THE MACHINE
BEGINNING THE CLEANING OPERATION
ENDING THE CLEANING OPERATION
POST OPERATION CHECKLIST
DRAINING TANK 1
CLEANING TANK 1
DRAINING TANKS 2 & 3
CLEANING TANKS 2 & 3
DOUBLE LID TANK 3
TOWING INSTRUCTIONS
SERVICE CHART
HELPFUL HINTS FOR CLEANING OPERATION
GENERAL MACHINE MAINTENANCE
LUBRICATION
OPENING THE ENGINE COVER
HYDRAULICS
FILLING THE HYDRAULIC RESERVOIR
CLEANING THE HYDRAULIC SYSTEM
REPLACING THE RETURN FILTER ELEMENT
RECYCLING PUMP ESP SYSTEM
ESP SYSTEM STORAGE
RECOVERY TANK LID ACCESS
REAR SQUEEGEE
SQUEEGEE CASTER WHEELS
CASTER WHEEL ADJUSTMENT
BRAKE ADJUSTMENT
AIR INTAKE SYSTEM
AIR FILTER
REPLACING THE AIR FILTER
REMOVING THE AIR FILTER ELEMENT
CLEANING THE AIR FILTER ELEMENT
INSPECTING THE AIR FILTER ELEMENT
COOLING SYSTEM
COOLANT LEVEL
RADIATOR
DRIVE BELTS
BATTERY
GAS TANK
LP GAS SYSTEM
LP GAS VAPORIZER-REGULATOR QUICK CHECK
LP GAS FUEL TANK
NEUTRAL ADJUSTMENT
PARTS LIST LEGEND
GENERAL TROUBLESHOOTING
ORDERING PARTS
TABLE OF CONTENTS - CHAPTER TWO
FRONT TANK
SCRUB DECK 60”
SCRUB DECK LIFT
TRANSFER PUMP
RECOVERY TRANSFER
LOWER DOORS GROUP
REAR AND SIDE SQUEEGEES
SQUEEGEE LIFT
SWING SQUEEGEE SUPPORT
SOLUTION TANK
SOLUTION CONTROL GROUP
RECOVERY TANK LID
VACUUM MOTOR & FLOAT
RECOVERY TANK
FRONT BUMPER GROUP
FRONT WHEEL AND BRAKE
REAR WHEEL
BRAKE LINKAGE
FOR/REV CONTROL – FORD
MAIN FRAME
DRIVER COMPARTMENT
CONSOLE GROUP
INSTRUMENT PANEL (GAS)
INSTRUMENT PANEL (LP)
SQUEEGEE, SCRUB DECK, STEERING CYLINDERS AND FITTINGS
REAR WHEEL MOTORS AND FITTINGS
HYDRAULIC RESERVOIR, FILTER, AND FITTINGS
DRIVE PUMP AND FITTINGS
VACUUM MOTOR & OIL COOLER
POWER STEERING UNIT AND FITTINGS
RETURN MANIFOLD AND FITTINGS
MAIN CONTROL VALVE & FITTINGS
AUXILIARY PUMP AND FITTINGS - FORD
HYDRAULIC HOSE SYSTEM
ENGINE COVER
FUEL TANK
LP TANK
FORD GAS ENGINE
FORD LP ENGINE
RADIATOR AND SHROUD
DECALS
NOTES
CONNECTION DIAGRAM, GAS CONTROL PANEL
CONNECTION DIAGRAM, LP CONTROL PANEL
CONNECTION DIAGRAM, ENGINE ELECTRICAL (GAS & LP)
ELECTRICAL SCHEMATIC
HYDRAULIC SCHEMATIC
TABLE OF CONTENTS - CHAPTER 3
OVERHEAD GUARD OPTION
BRUSH OPTIONS
BUMPER OPTION
BUMPER ASSEMBLY
BACK-UPALARM
VACUUM WAND OPTION
LIGHTS OPTIONS
TURN SIGNAL OPTION
WARNING LIGHTS (STANDARD)
WARNING LIGHTS WITH OVERHEAD GUARD
FIRE EXTINGUISHER OPTION
FLAME ARRESTING GAS CAP OPTION
SUSPENSION SEAT
DEBRIS BASKET OPTION
ESP OPTION
FORD ENGINE SHUTDOWN OPTION
TIRE OPTIONS
SPARE PARTS KIT, GAS/LP
INDEX
WARRANTY
