AGCOStar Tractor 8360 8425 Parts Catalog 79017290
Brand: AGCOStar
Model:
AGCOStar 8360 Tractor
AGCOStar 8425 Tractor
Part Number: 79017290
Number of Pages: 418 Pages
Publication Information
Engine - Frame Installation
Engine - Engine Group - Ddc
Engine - Engine Group - Cummins
Engine - Timing Lines - Cummins
Engine - Engine Mounting - Ddc
Engine - Engine Mounting - Cummins
Engine - Throttle Control
Engine - Starting Aid - Ddc
Engine - Ether Start
Engine - Fan - Ddc
Engine - Fan - Cummins
Engine - Front Pulley
Engine - Radiator - Ddc
Engine - Radiator - Cummins
Engine - Main Fuel Tank, Prior S N 100500
Engine - Fuel Tank Installation, Eff. S N 100500
Engine - Fuel Cooler & Lines -Ddc
Engine - Fuel Lines - Cummins
Intake And Exhaust - Air Cleaner And Piping, Ddc
Intake And Exhaust - Air Cleaner And Piping, 8360 Cummins,
Intake And Exhaust - Air Cleaner Asy - 14
Intake And Exhaust - Air Cleaner Asy - 16
Intake And Exhaust - Air Cleaner And Piping, Cummins 8425 -
Intake And Exhaust - Precleaner Kit
Intake And Exhaust - Muffler - Ddc
Intake And Exhaust - Exhaust - Cummins
Intake And Exhaust - Charge Air Cooler
Electrical - Main
Electrical - Alternator - Ddc
Electrical - Alternator - Cummins
Electrical - Alternator Components - 130 Amp, Delco #1117965
Electrical - Starting Motor Components
Electrical - Rear Frame Lighting
Electrical - Outrigger Lights
Electrical - Cab Lighting
Electrical - Console, Prior S N 100200
Electrical - Console Panel, Eff. S N 100200
Electrical - Console Components, Eff. S N 100200
Electrical - Panel Module Asy.
Electrical - Field Facts Monitor
Electrical - Radar Speed Sensing
Electrical - Differential Lock
Electrical - Radio
Electrical - Battery
Electrical - Connectors
Transmission - Roadranger Valve
Transmission - Hoses & Connections
Transmission - A-5000 Slave Valve
Transmission - Air Filter Regulator
Transmission - Shift Bar Housing
Transmission - Master Lever Control
Transmission - Shift Yoke Assembly
Transmission - Clutch Release Assembly
Transmission - Src Control
Transmission - Case Assembly
Transmission - Mainshaft Asy.
Transmission - Countershaft Asy.
Transmission - Input Shaft & Drive Gear
Transmission - Reverse Idler
Transmission - Integral Oil Pump
Transmission - Auxiliary Case Asy.
Transmission - Mainshaft & Synchro (Aux.)
Transmission - Counterhsaft & Bearings (Aux.)
Transmission - Range Cylinder
Transmission - Splitter Cylinder
Transmission - Auxiliary Drive Gear
Transmission - Harness, Tubing
Transmission - Shift Shaft Asy., Src Control
Transmission - Shaft Asy., Src Control
Transmission - Shaft Asy., Src Inner
Transmission - Transmission & Clutch - Ddc
Transmission - Transmission & Clutch-Cummins
Transmission - Manual Clutch - Dual Plate
Transmission - Oil Cooler & Mounting
Transmission - Transmission Control
Transfer Case - Drive Shafts, Prior S N 100200
Transfer Case - Drive Shafts, Eff. S N 100200
Transfer Case - Housing Asy.
Transfer Case - Housing Components, 8425
Transfer Case - Filter & Lines
Transfer Case - Hydraulic Lines, Prior S N 100200
Transfer Case - Case Hydraulic Lines, Eff. S N 100200
Transfer Case - Handbrake
Transfer Case - Brake Caliper Components, Prior S N 100272
Transfer Case - Brake Caliper Components, Eff. S N 100272 -
Transfer Case - Brake Caliper Components, Eff. S N 100400
Transfer Case - Cab Clutch & Brake Controls, Prior S N 100400
Transfer Case - Cab Clutch & Brake Controls, Eff. S N 100400
Transfer Case - Rear Axle, 8360, Prior S N 100200 (8425)
Transfer Case - Rear Axle, Eff. S N 1000006
Transfer Case - Rear Axle Housing, Differential Carrier
Transfer Case - Differential Carrier Housing, Differential
Transfer Case - Differential Carrier With Limited Slip,
Transfer Case - Axle Housing & Wheel Hub, Eff. S N 100200
Transfer Case - Differential - Rear, Prior S N 100006
Transfer Case - Differential - Rear, Eff. S N 100006
Transfer Case - Rear Axle Shafts, Planetary Gear, Wheel
Transfer Case - Axle Shafts, Planetary Gear Wheel Drive, Eff.
Hydraulics - Tank Asy.
Hydraulics - Hydraulic Lines & Fittings, Ddc, Prior S N
Hydraulics - Hydraulic Lines & Fittings, Cummins, Eff S N
Hydraulics - Zero Pressure Return
Hydraulics - Valve - Priority Lines & Fittings - Ddc
Hydraulics - Valve - Priority Lines & Fittings, Cummins -
Hydraulics - Auxiliary - Hydraulics, Prior Cummins S N
Hydraulics - Auxiliary - Hydraulics, Cummins Eff. S N 100106
Hydraulics - Auxiliary - Hydraulic Controls, Prior S N 100200
Hydraulics - Auxiliary - Hydraulic Controls, Eff. S N 100200
Hydraulics - Auxiliary - Remote Couplers, Prior S N 100200
Hydraulics - Auxiliary - Remote Couplers, Eff. S N 100200
Hydraulics - Auxiliary - Remote Valve And Mount, Eff. S N
Hydraulics - 5th Remote Valve
Hydraulics - Remote Valve - Components
Hydraulics - Filter Asy
Hydraulics - Charge Pump - Ddc
Hydraulics - Main Pump Asy. - Ddc
Hydraulics - Idler Assembly - Hydraulic Pump
Hydraulics - Main Pump Assembly - Ddc
Hydraulics - Load Adaptor Components
Hydraulics - Main Hydraulic Pump Components
Hydraulics - Main Pump Assembly - Cummins, Prior S N 100106
Hydraulics - Pump, Prior S N 100106
Hydraulics - Pump Gear, Prior S N 100106
Hydraulics - Main Pump Assembly - Cummins, Eff. S N 100106
Hydraulics - Pump, Eff. S N 100106
Hydraulics - Pump - Gear, Eff. S N 100106
Hydraulics - Pump Lines & Fittings - Cummins, Prior S N
Hydraulics - Pump Lines & Fittings - Cummins, Eff S N 100106
Hydraulics - Air Compressor & Tank - Ddc
Hydraulics - Air Compressor & Tank - Cummins
Hydraulics - Air Compressor Components
Power Steering - Steering Controls, Prior S N 100200
Power Steering - Steering Controls, Eff. S N 100200
Power Steering - Valve - Ddc
Power Steering - Valve - Cummins, Prior S N 100106
Power Steering - Valve - Cummins, Eff S N 100106
Power Steering - Cylinder
Power Steering - Cylinder Components
Power Steering - Steering Lines
Front Axle - Axle Housing, Differential Carrier, Housing,
Front Axle - Axle Housing & Wheel Hub, Eff. S N 100200
Front Axle - Differential Carrier Housing, Differential Lock,
Front Axle - Differential Carrier Housing W O D L, Eff. S N
Front Axle - Differential, Prior S N 100006
Front Axle - Differential, Eff. S N 100006
Front Axle - Differential W Out Lock, Eff. S N 100200
Front Axle - Differential Carrier With Limited Slip,
Front Axle - Axle Shafts, Planetary Gear Wheel Drive, Prior
Front Axle - Axle Shafts, Planetary Gear Wheel Drive, Eff.
Hitch - Drawbar - 2 , 8360
Hitch - Drawbar - 3 , 8425
Wheels - Wheels, 8360, 8425 Prior S N 100200
Wheels - Wheels, 8425 (Eff. S N 100200)
Frame Attachments - Front Weights
Frame Attachments - Rear Weights
Body - Hood & Firewall, Prior S N 100400
Body - Bulkhead Seal
Body - Grille & Light, Prior S N 100400
Body - Grille & Light, Eff. S N 100400
Body - Lower Grille Asy., Prior S N 100400
Body - Lower Grille Asy., Eff. S N 100400
Body - Lower Gille Assembly, Grille Sealing Kit
Body - Grille Seal - Ddc
Body - Grille Seal - Cummins
Body - Side Panel - Ddc
Body - Side Panel - Cummins (8425)
Body - Rear Fenders
Body - Roof
Cab - Body
Cab - Cab Mounting
Cab - Cab Throttle Control - Ddc
Cab - Cab Throttle Control - Cummins, Prior S N 100200
Cab - Cab Throttle Control - Cummins, Eff. S N 100200
Cab - Exterior Insulation
Cab - Door
Cab - Front Side Window
Cab - Front Wiper
Cab - Rear Wiper
Cab - Front & Rear Washer, Prior S N
Cab - Front & Rear Washer, Eff. S N
Cab - Glass & Interior Trim
Cab - Interior Insulation
Cab - Instrument Console, Prior S N 100200
Cab - Instrument Console, Eff. S N 100200
Cab - Console Rh, Prior 100200
Cab - Console Rh, Eff. 100200
Cab - Seat
Cab - Air Ride Seat & Suspension, Eff. S N 100
Cab - Air Recirculation
Cab - Plenum Asy
Cab - Panel Asy - Upper Control
Cab - Heater
Cab - A C Comppressor - Ddc
Cab - A C Comppressor - Cummins
Cab - A C Condenser Mounting - Ddc
Cab - A C Condenser Mounting - Cummins
Cab - Decals
Cab - Speed Charts
Recommended Dealer List
Brand: AGCOStar
Model:
Engine - Fan - Ddc
Electrical - Main
Electrical - Radio
Body - Rear Fenders
Body - Roof
Cab - Body
Cab - Cab Mounting
Cab - Door
Cab - Front Wiper
Cab - Rear Wiper
Cab - Seat
Cab - Plenum Asy
Cab - Heater
Cab - Decals
Cab - Speed Charts
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
