AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
Brand: AGCO Allis
Type of Machine: Sickle Bar Mower
Model: 3, 5, 7, B, C, B-IND, WC
Part Number: 9001530B
Number of Pages: 226 Pages
Frame, Hitch & Lift - Hitch & Break - Back, No. 3 Mower
Frame, Hitch & Lift - Lift Shaft, Linkage & Spring
Frame, Hitch & Lift - Lift Shaft, Linkage And Spring
Frame, Hitch & Lift - Main Frame, No. 3 Mower
Frame, Hitch & Lift - Hydraulic Hose Extension
Frame, Hitch & Lift - Hand Lift, No. 3 Mower
Frame, Hitch & Lift - Yoke, Dragbar & Pull Brace
Frame, Hitch & Lift - Attaching Parts
Frame, Hitch & Lift - Attaching Parts, Ca Tractor
Frame, Hitch & Lift - Attaching Parts, Wc Tractor
Frame, Hitch & Lift - Attaching Parts, Wd Tractor
Frame, Hitch & Lift - Attaching Parts, Wd No. 3 Mower
Drives - Telescoping Tube, Cover Plate Joint, No. 3 Mower
Drives - Telescoping Tube, Snap Ring Joint, No. 3 Mower
Drives - Drive Guard, No. 3 Mower
Drives - Upper Drive, No. 3 Mower
Drives - Final Drive, No. 3 Mower
Cutter Bar - Cutter Bar, No. 3 Mower
Cutter Bar - Pitman & Knife, No. 3 Mower
Cutter Bar - Outer Shoe Divider, No. 3 Mower
Cutter Bar - Mower Guards, No. 3 Mower
Cutter Bar - Cutter Bar - Low Cut, No. 3 Mower
Cutter Bar - Swathboard & Outer Shoe, No. 3 Mower
Frame, Hitch & Lift - Lift Shaft, No. 5 Mower
Frame, Hitch & Lift - Lift Shaft And Hand Lift
Frame, Hitch & Lift - Lift Shaft And Hydraulic Lift
Frame, Hitch & Lift - Main Frame, No. 5 Mower
Frame, Hitch & Lift - Dragbar & Yoke, No. 5 Mower
Frame, Hitch & Lift - Attaching Parts, B And C Tractors
Drive - Drive Tube, No. 5 Mower
Cutter Bar - No. 5 Mower
Cutter Bar - Pitman & Knife, No. 5 Mower
Cutter Bar - Cutter Bar - Low Cut, No. 5 Mower
Cutter Bar - Mower Guards, No. 5 Mower
Cutter Bar - Swathboard & Outer Shoe, No. 5 Mower
Cutter Bar - Outer Shoe Divider, No. 5 Mower
Frame, Hitch & Lift - Main Frame, No. 7 Mower
Frame, Hitch & Lift - Lift Rod & Release Lever, No. 7 Mower
Frame, Hitch & Lift - Lift Shaft Linkage & Coupler
Frame, Hitch & Lift - Balance Spring Linkage & Pivot Bar
Frame, Hitch & Lift - Tongue Assembly, Trail Type Mower
Frame, Hitch & Lift - Hitch Ball & Socket, No. 7 Mower
Frame, Hitch & Lift - Axle & Wheels, Trail Type Mower
Frame, Hitch & Lift
Drive - P.T.O. Hitch Joints, No. 7 Mower
Drive - Drive Housing Support, No. 7 Mowers
Drive - Upper Sheave Support Assembly, No. 7 Mower
Drive - Flywheel & Connecting Rods, No. 7 Mower
Drive - P.T.O. Shaft & Shield, Rear Mounted Mower
Drive - P.T.O. Shaft & Shields, Trail Type Mower
Drive - P.T.O. Shaft & Shield, Used On S N 6601 & Up
Cutter Bar - Inner Shoe Asy., All Mowers, No. 7 Mower
Cutter Bar - Cutter Bar & Knife (5 8 Thick)
Cutter Bar - Pasture Clipping Attachment, No. 7 Mower
Cutter Bar - Outer Shoe Divider, No. 7 Mower
Cutter Bar - Mower Guards, No. 7 Mower
Frame, Hitch & Lift - Main Frame, B Tractor
Frame, Hitch & Lift - Main Frame, B & C Tractor
Frame, Hitch & Lift - Lift Linkage & Master Lift Shaft
Frame, Hitch & Lift - Lift Linkage, C Tractor
Frame, Hitch & Lift - Lift Linkage & Ram Shaft, B Tractor
Frame, Hitch & Lift - Lift Lever & Shaft, B Tractor
Frame, Hitch & Lift - Lift Shaft & Hand Lift, B & C Mower
Frame, Hitch & Lift - Dragbar & Yoke, B & C Mower
Drive - Drive Tube, Mounted Mower, B & C Tractor
Cutter Bar - B & C Mower
Cutter Bar - Pitman & Knife, B & C Mower
Cutter Bar - Outer Shoe Divider, B & C
Cutter Bar - B & C , Mower Guards
Cutter Bar - B & C , Swathboard & Outer Shoe
Cutter Bar - B & C , Cutter Bar - Low Cut
Frame, Hitch & Lift - Main Frame, B Industrial
Frame, Hitch & Lift - Hand Lift, B Industrial
Frame, Hitch & Lift - Hydraulic Lift, Mounted Mower
Frame, Hitch & Lift - Hydraulic Ram, B Industrial
Frame, Hitch & Lift - Hydraulic Pump & Ram
Frame, Hitch & Lift - Dragbar & Yoke, B Industrial
Drive - Drive Tube, Mounted Mower, B Industrial
Cutter Bar - B Industrial
Cutter Bar - Swathboard & Outer Shoe, B Industrial
Cutter Bar - Pitman & Knife, B Industrial
Cutter Bar - Mower Guards, B Industrial
Cutter Bar - Outer Shoe Divider, B Industrial
Frame, Hitch & Lift - Main Frame, Wc Tractor
Frame, Hitch & Lift - Hand Lift Wc Tractor
Frame, Hitch & Lift - Lift Shaft, Wc Tractor
Frame, Hitch & Lift - Dragbar & Yoke, Wc Tractor
Drive - Drive, Wc , Used Prior To Feb., 1937
Drive - Drive, Eff. Feb., 1937 Thru March, 1938
Drive - Drive, Eff. April, 1938 Thru Sept., 1938
Drive - Drive, Reinforced, Wc , Eff. Oct., 1938
Drive - Drive Tube, Wc Tractor
Drive - Chain Drive, Wc Tractor, Used Prior To March, 1940
Drive - Power Take-Off Throwout, Wc Tractor
Cutter Bar, Cutter Bar, Wc Mower
Cutter Bar - Pitman & Knife, Wc Mower
Cutter Bar - Cutter Bar - Low Cut Wc
Cutter Bar - Mower Guards Wc
Cutter Bar - Swathboard & Outer Shoe Wc
