AGCOStar Tractor 4800 4900 Series Parts Catalog 79017470
Brand: AGCOStar
Model:
AGCOStar 4800 Series Tractor
AGCOStar 4900 Series Tractor
Part Number: 79017470
Number of Pages: 257 Pages
Publication Information
Engine - Engine, 4800
Engine - Front And Rear Frame, 4800, 4840, 4880 & 4900
Engine - Cooling System, 4800
Engine - Cooling System, 4840
Engine - Cooling System, 4880
Engine - Cooling System, 4900
Engine - Fuel Tank And Lines, 4800, 4840, 4880 & 4900
Engine - Throttle Controls, 4800, 4840, 4880 & 4900
Intake And Exhaust - Air Intake And Ether Injection, 4800 &
Intake And Exhaust - Air Intake And Ether Injection, 4880 &
Intake And Exhaust - Exhaust System, 4800 & 4840
Intake And Exhaust - Exhaust System, 4880 & 4900
Electrical - Electrical Wiring, 4800, 4840, 4880 & 4900
Electrical - Battery And Cables, 4800, 4840, 4880 & 4900
Electrical - Starter And Solenoid
Electrical - Starter And Solenoid Con't.
Electrical - Alternator
Electrical - Lighting, 4800, 4840, 4880 & 4900, Eff. Tractor
Electrical - Lighting, 4800, 4840, 4880 & 4900, Prior Tractor
Electrical - Instrument Panel, 4800, 4840, 4880 & 4900
Transmission - Clutch And Transmission Mounts, 4800, 4840,
Transmission - Clutch Controls, 4900
Transmission - Single Clutch, Less Pto, 4800, 4840, 4880 &
Transmission - Dual Clutch, With Pto, 4800, 4840, 4880 & 4900
Transmission - Single And Dual Clutch, 4800,4840,4880 & 4900
Transmission - Transmission Controls, 4800, 4840, 4880 & 4900
Transmission - Transmission Housing, Side Cover, Rails And
Transmission - Transmission, Multi-Power, 4800, 4840, 4880 &
Transmission - P.T.O. Brake, Multi-Power, 4800, 4840, 4880 &
Transmission - Clutch And Transmission Lines, 4800, 4840,
Transmission - Multi-Power And P.T.O. Valve, 4800 & 4840
Transmission - Multi-Power And P.T.O. Valve, 4880 & 4900
Transmission - Multi-Power And P.T.O. Controls, 4800, 4840,
Transmission - Transmission Pump And Cooler Lines, 4800,
Hydraulucs - Hydraulic Pump, Transmission
Hydraulucs - Hydraulic Pumps, Steering And Lift, 4800, 4840,
Hydraulucs - Hydraulic Oil Filter, 4800, 4840, 4880 & 4900
Hydraulucs - Auxiliary Hydraulic Controls, 4800, 4840, 4880 &
Hydraulucs - Auxiliary Hydraulics, 4800, 4840, 4880 & 4900,
Hydraulucs - Hydraulic Lift Controls, 4800, 4840, 4880 & 4900
Hydraulucs - Hydraulic Lift System, W 3 Point Linkage-With
Hydraulucs - Hydraulic Lift System, Without 3 Point Linkage
Hydraulucs - Hydraulic Lift Cylinders, 4800 & 4840
Hydraulucs - Hydraulic Lift Cylinders, 4880 & 4900
Hydraulucs - Auxiliary Hydraulic Valve, 3 Spool & 4 Spool,
Hydraulucs - Auxiliary Hydraulic Valve, 3 Spool, 4800, 4840,
Hydraulucs - Draft Control Valve, 4800, 4840, 4880 & 4900
Power Steering - Steering Wheel And Column, Tilt And
Power Steering - Steering Wheel And Column, Tilt, Prior
Power Steering - Steering And Oil Cooler, Valve, Pump, Tank
Power Steering - Orbital Steering Pump
Power Steering - Steering Cylinders, 4800, 4840, 4880 & 4900
Transfer Case - Front Drive Shafts, 4800, 4840, 4880 & 4900
Transfer Case - P.T.O. And Rear Axle Drive, 4800, 4840, 4880
Transfer Case - P.T.O. And Rear Drive Shaft, 4800, 4840, 4880
Transfer Case - P.T.O. Drop Box, 4800, 4840, 4880 & 4900
Transfer Case - Front Center Housing, 4800, 4840, 4880 & 4900
Transfer Case - Rear Center Housing And P.T.O. Drive, 4800,
Transfer Case - Differential, Front, Max-Trac Non-Slip, 4800,
Transfer Case - Differential, Front, True-Trac Non-Slip,
Transfer Case - Differential, Front, 4800, 4840, 4880 & 4900
Transfer Case - Differential, Rear, 4800, 4840, 4880 & 4900
Transfer Case - Front And Rear Axle, 4800, 4840, 4880 & 4900
Transfer Case - Main Brake Controls, 4800, 4840 4880 & 4900
Transfer Case - Brake Cylinder, 4800, 4840, 4880 & 4900
Transfer Case - Hand Brake Controls, 4800, 4840, 4880 & 4900
Transfer Case - Main And Hand Brake, 4800, 4840, 4880 & 4900
Wheels - Dual Wheels, Manual, 4800 & 4840
Body - Front And Rear Hood And Griller, 4800, 4840, 4880 &
Cab - Seat And Suspension, Eff. Tractor S N 9d004281 & Up,
Cab - Seat Suspension, Eff. Tractor S N 9d004281 & Up, Brown
Cab - Seat Suspension, Tractor S N 9d001472-9d004281, Black
Cab - Seat Suspension, Eff. S N 9d001472-9d004281, Black
Cab - Seat And Suspension, Prior Tractor S N 9d001472, Black
Hitch - Rear Lift Cover, 4800, 4840, 4880 & 4900
Hitch - Rear Lift Linkage, 4800, 4840, 4880 & 4900
Hitch - Rapid Coupler, With Fixed Lower Links, 4800, 4840,
Hitch - Drawbar, Roller Type, 4800, 4840, 4880 & 4900
Cab - Cab, Mounting Brackets, Steps & Mirrors, 4800, 4840,
Cab - Cab Galss And Floor Mats, 4800, 4840, 4880 & 4900
Cab - Cab Door, Eff. Tractor S N 9d004281 & Up, 4800, 4840,
Cab - Plenum Chamber And Blower, 4800, 4840, 4880 & 4900
Cab - Heater, 4800, 4840, 4880 & 4900
Cab - Air Conditioning, 4800, 4840, 4880 & 4900
Cab - Compressor, Eff. Tractor S N 9d004001 & Up
Cab - Compressor, Eff. Tractor S N 9d001637 To 9d004001
Cab - Compressor, Prior Tractor S N 9d001637
Cab - Windshield Wiper And Washer, 4800, 4840, 4880 & 4900
Labels - Labels, 4800
Labels - Labels, 4840
Labels - Labels, 4880
Labels - Labels, 4900
Accessories - Paint, Sealant, Transmission Oil, 4800,4840,
Recommended Dealer Stock
