AGCO EDT Electronic Diagnostic Tool V1.107.21194.578 Updated 2021.3 08.2021 Update Files
Size: 37 Gb (.iso file)
Region: All-Region
Interface Languages: English, Dutch, French, Finnish, German, Spanish, Portuguese, Danish, Russian, Polish, Italian, Turkish, Swedish Sweden, Chinese, Norwegian- Bokmal.
Database Languages: Only English
Version: V1.107.21194.578 Updated 2021.3 08.2021
Type of software: AGCO EDT (Electronic Diagnostic Tool)
Year/Release Date: 08.2021
OS: Windows 7, Windows 8, Windows 8.1, Windows 10 x64 & x86 (Tested on window 7 64bit ultimate & Window 10 pro 1607 64bit)
Amount of disk: 1 DVD
Installation: Multiple PCs
Instruction: Present
Medicine: Present
Supporter: Present
Print Functions: Present
High-Speed Link Download
Instruction:
1. Install the 2016 version. "CLICK HERE" to see and pay for it.
2. Download 08.2021 Version and make follow instructions inside.
agcoedtdiagnosticsoftware06.2021, agcoedtnewversion, agcoedtnewupdate, agcoedthowtoinstall, agcoedtdiagnostictool,
Electronic Diagnostic Tool (EDT) 2021 AGCO can be used by dealership technicians to interface with specific machines that have a Controller Area Network (CAN) BUS as part of the electronic system architecture. EOL (End Of Line) programming, diagnosis and documentation system for FENDT tractors. Those in-field diagnostic programs help technician accurately diagnose and solve a technical problem quickly by getting to the root cause and giving guidance on how to best solve it.
WinEEM3 and WinEEM4 is an easy tool for the monitoring and adjustment program to SisuDiesel Electronic Control Unit (ECU). Programs can be used with EEM2, EEM3, EEM4 ECU. CAN bus used to communicate with ECU.
You can make full diagnostic, programming and troubleshoot problem of current brands:
• AGCO
• Challenger
• FENDT
• FELLA
• GLEANER
• Laverda
• Massey Ferguson
• RoGator
• SpraCoupe
• TerraGator
• Valtra
• WHITE Planters
New Update V1.107.21194.578 Updated 2021.3 08.2021 Informations: " CLICK HERE "
New Update:
Release Notes - 6/2/2021 - Update 2021.3
EDT NOTES:
EDT Version: 1.101.21103.808
Bug Fixes:
•Minor updates for diagnostics.
Vehicles Affected:
•Valtra: T-Series, N-Series, A-Series
Vehicle Version:
•3.27
General:
•AC15.34, AC15.35, AC16.0 and AC19.34 removed from South America region
Diagnostics:
•4WD page for N3 / T3 Versu and Direct facelift added
•Cruise pages added for EEM3 Versu and Direct
•PTO data flow diagram page added for N2 / T2 tractors
•PTO Sigma page added for N2 / T2 tractors
Calibrations:
•Powershuttle, Powershift and Clutch Pedal names standardized on calibration page
Diagnostic Tests:
•Diagnostic help file added for Visco Fan Test
•Forced Engine Torque Curve tool set visible under diagnostic test tab
Diagnostic Trouble Codes:
•Fault code descriptions updated
Plug-Ins:
•AG3000 v8.4, Fixed a bug with clearing the stored DTC codes
•PVED-CL v5.16, Fixed a problem with parameters write to the EEPROM
Vehicles Affected:
•Massey Ferguson: MF 6700S Stage 5 Series
•Massey Ferguson: MF 7700S Stage 5 Series
Vehicle Version:
•2.7
General:
•Add an improved calibration procedure for WAS Center (Steering, Middle position)
Plug-Ins:
•New CEA-Guide content ◦Add VD03 V1.143 L26 version
•New ACM content ◦Add Ukraine as a selectable country code in the replacement process
◦Fix the read of hardware version in graphical surface for 411 devices
◦Improve the detection of hardware version
◦Update software V04.01.36
◦Improve some graphical surfaces
Software:
•New SRC14-34 software V5.49 for Dyna-VT models ◦Improve display of Memo A switch when Isobus function on lever is active in NT03 and tractor with T-Handle configuration
◦Fix a bug on the steering system
◦Fix delay to stop the PTO to be compliant with the regulation
◦Fix the measurement of effort on rear hitch
Vehicles Affected:
•Massey Ferguson: Global Series 4700-5700-6700
•Valtra: A100
•Valtra: AC51.5, AC52.5, AC53.5, AC54.5, AC55.5, AC56.5
Vehicle Version:
•6.4
Software:
•New Continental software V2.09 ◦Add some missing diagnostic signal for braking system
◦Fix a bug of the save of counter hours
◦Fix engine speed limitation during PTO clutch start phase
◦Support engine curve 2 for Brazilian tractors
•New Transmission ISC software V2.21.0 ◦Improve smoothness of shuttling
•New Linkage software V1.31.0 ◦Remove PTO alarm in stationary mode on non MR tractors
Vehicles Affected:
•Massey Ferguson: 6700R Series
•Valtra: A4Hitech Series
Vehicle Version:
•6.4
Plug-Ins:
Vehicles Affected:
•Challenger: MT600E with TMC Display
•Massey Ferguson: 8700 with Datatronic 5 Series
•Massey Ferguson: MF 8700S Series
•Valtra: S4 with SmartTouch Display Series
Vehicle Version:
•5.60
General:
Plug-Ins:
Software:
•New T4F engine software for models with new fuel tank (84AWF models - NA only) ◦Cold start improvements
◦Defrost timer improvement
•New SRC14-34 software V5.50 for MF and Challenger models ◦Fix failure of the Hall effect sensor to get engine speed value (X25) by reading the value from engine ECU (CAN frame)
Vehicles Affected:
•Fendt: IDEAL Combines
•Massey Ferguson: IDEAL Combines
Vehicle Version:
•1.32
Software:
•GQS: 1.0.5.1266
•NT01:9.2.26
•AP Engine: 1.2.13 Rev.2 (All Regions)
•MAN Engine D3876LE125 for Western Europe, MY18, Class 9, with new temp. sensor rework
•MAN Engine D4276LE121, D4276LE122, Class 10
Vehicles Affected:
•Massey Ferguson: 1700 Series
Vehicle Version:
•2.29
Software:
•Checksums for the 1700 engine flash have been corrected.
Vehicles Affected:
•Fendt: 4160V, 4180V, Rotana 130 F, Rotana 160 V, Rotana 180 V
•Lely: RP 130 F, RP 160 V, RP 180 V
•Massey Ferguson: RB 3130 F, RB 4160 V, RB 4180 V
Vehicle Version:
•1.8
Software:
•New Software 2.29.5
Vehicles Affected:
•Fendt: Rotana 130 F, Rotana 160 V
•Lely: RPC 130 F, RPC 160 V
•Massey Ferguson: RB 3130 F Protec, RB 3160 V Protec
Vehicle Version:
•1.6
Software:
•New Software 2.39.5
Vehicles Affected:
•Fendt: C-Series 2015: 5275CA, 5275CPLA, 6335CA, 6335CPLA
•Fendt: L-Series 2015: 5255L, 6275L
•Laverda: M300 Series 2015: M300A, M310A
•Laverda: M400 Series 2015: M400A, M400LCA, M400LCIA, M410A, M410LCA
•Massey Ferguson: ACTIVA S Series 2015: 7345S, 7347S
•Massey Ferguson: BETA Series 2015: 7360A, 7360PLA, 7370A, 7370PLA
Vehicle Version:
•2.19
General:
•New software released: ◦EXT-LT Version: 1.69
◦NT01 Version: 6749
◦NT05 Version: 6749
Vehicles Affected:
•Challenger: 644
•Fendt: 5220E
•Laverda: M200
•Massey Ferguson: 7244
Vehicle Version:
•4.2
General:
•M180 Stage V engine software: Version 6.1.1 Rev. 1
•5185 E Stage V engine software: Version 6.1.1 Rev. 1
•7340 Stage V engine software: Version 6.1.1 Rev. 1
Vehicles Affected:
•Fendt: RG344,RG355,RG366 MY21
Vehicle Version:
•1.2
Configuration:
•Add calibration option for upcoming plumbing change in configuration menu. Position of clean water tank sensor will be changed. (visible as pop up by software update)
Software:
MY2021:
-Sprayer ECU RG300M-M-01.01.00
Enhancements
•RGRU-1112 – Added peer control for N-sensors
•RGRU-1170 – Add section phasing buttons to separate softkey mask
Fixes
•RGRU-1146 – Fixed rate control eeprom load failure
•RGRU-1159 – Fixed autorinse does not move to the next step when there is foam in the tank
•RGRU-1183 - Fixed boom height control sensor selection listbox from appearing after VT reload
•RGRU-1052 – Fixed sections UI on main screen unclear when sections > 74
•RGRU-1204 – Fixed when pump is idle RMP is increased when switching 5 way valve
•RGRU-1117 - Boomfolding: reverted tilt speed so it matches with the progress bar again
Vehicles Affected:
•Fendt: RG645,RG655,RG665 MY21
Vehicle Version:
•1.2
Software:
MY2021:
Sprayer ECU: AGCO_RG600M-I_01.01.00
Enhancements
Fixes
Note: software versions of Chassis ECU, NT01,VD03, Novatel Antenna, and PVED must match, so please make sure all of these components have the up to date software installed.
Vehicles Affected:
•Massey Ferguson: 5700 Dyna-4 Tractors
•Valtra: AC71.5
Vehicle Version:
•2.7
General:
•Add Tier3 models
Software:
•New Dashboard IC1 software V1.64 for MF ◦Fix the delay to stop the PTO to be compliant with the regulation
◦Compatibility with Tier3 Engine without urea
Vehicles Affected:
•Fendt: 5255 L, 5255 L PL, 6275 L, 6275 L PL, 5275 C, 5275 C SL 5275 C PL, 5275 C PLI, 6335 C, 6335 C PL, 6335 C PLI
•Laverda: M 300, M 300 LC, M310, M310 LC, M 400, M 400 LC, M 400 LCI, M410, M410 LC, M410 LCI
•Massey Ferguson: 7345 S, 7345 S PL, 7347 S, 7347 S PL, 7360, 7360PL, 7360 PLI, 7370, 7370 PL, 7370 PLI, 7360 AL 4
Vehicle Version:
•0.34
General:
•New: ◦EXT-LT Version: 1.69
◦NT01 Version: 6749
◦NT05 Version: 6749
◦M410, M410 LC, M410 LCI Stage V engine software: Version 6.1.1 Rev. 1
◦6335, 6335 PL, 6335 PLI Stage V engine software: Version 6.1.1 Rev. 1
◦7370, 7370 PL, 7370 PLI Stage V engine software: Version 6.1.1 Rev. 1
◦General diagnostic graphical surfaces updates
Vehicles Affected:
•Challenger: MT 700 Series
•Fendt: Vario MT 900 Series
•Challenger: MT 800 Series
•Fendt: Vario MT 1100 Series
Vehicle Version:
•2.02
Software:
•Released Chassis EXT software package 5.01.02 ◦Updated Transmission parameters to lower HM2 clutch speeds
Vehicles Affected:
•Gleaner: S96, S97, S98
Vehicle Version:
•5.53
Software:
•VD03:3.143
•Novatel Smart7:ES7PR0603RN0000
•Trimble AG-382:9.38.007.4
•Engine file updates for S97, S98 models.
Vehicles Affected:
•Challenger: MT400E Series
•Challenger: MT500E Series
•Iseki: i5700 Series
•Iseki: i6700 Series
•Iseki: i7700 Series
•Massey Ferguson: 5700S Series
•Massey Ferguson: 5700SL Series
•Massey Ferguson: 6700S Series
•Massey Ferguson: 7700 Made in Brazil Series
•Massey Ferguson: 7700 Series
•Massey Ferguson: 7700S Series
•Valtra: T195-250 Series
Vehicle Version:
•7.3
Plug-Ins:
Software:
•New T4F engine software for 6700S tractors (49AWF models) ◦Update of emission calibration to fix issue with emission fault code
◦Improvement of the parameter of governor speed to fix the issue of engine speed instability
◦Improvement of defrost time of the DEF
•New CCD/C1000 Software V3.4.4 ◦Fix data transfer with USB stick
•New Dashboard IC1 software V5.8.7 for Dyna-4 and Dyna-6 tractors ◦Possibility to assign 2 functions to H3/H4 in loader mode
◦Fix the issue of the flow setting of the 3rd Live loader spool valve
◦Fix issue of the front linkage which was impossible to lock
•New Dashboard IC1 software V5.3.9 for Dyna-VT tractors ◦Possibility to assign 2 functions to H3/H4 in loader mode
•New SRC14-34 LK software V04.16 ◦Improve guidance behaviour when speed is above 10 kph
◦Fix ISOBUS issues
◦Fix issue on front hitch trigger
◦Add the possibility to set up to 50 cm the mounting error offset
Region: All-Region
Medicine: Present
Supporter: Present
Instruction:
• AGCO
• Challenger
• FENDT
• FELLA
• GLEANER
• Laverda
• Massey Ferguson
• RoGator
• SpraCoupe
• TerraGator
• Valtra
• WHITE Planters
New Update:
EDT NOTES:
Bug Fixes:
Vehicles Affected:
Vehicle Version:
•3.27
General:
Diagnostics:
Calibrations:
Diagnostic Tests:
Plug-Ins:
Vehicles Affected:
Vehicle Version:
•2.7
General:
Plug-Ins:
Software:
Vehicles Affected:
•Valtra: A100
Vehicle Version:
•6.4
Software:
Vehicles Affected:
Vehicle Version:
•6.4
Plug-Ins:
Vehicles Affected:
Vehicle Version:
•5.60
General:
Plug-Ins:
Software:
Vehicles Affected:
Vehicle Version:
•1.32
Software:
•GQS: 1.0.5.1266
•NT01:9.2.26
Vehicles Affected:
Vehicle Version:
•2.29
Software:
Vehicles Affected:
Vehicle Version:
•1.8
Software:
Vehicles Affected:
Vehicle Version:
•1.6
Software:
Vehicles Affected:
Vehicle Version:
•2.19
General:
◦NT01 Version: 6749
◦NT05 Version: 6749
Vehicles Affected:
•Challenger: 644
•Fendt: 5220E
•Laverda: M200
Vehicle Version:
•4.2
General:
Vehicles Affected:
Vehicle Version:
•1.2
Configuration:
Software:
MY2021:
Enhancements
Fixes
Vehicles Affected:
Vehicle Version:
•1.2
Software:
MY2021:
Enhancements
Fixes
Vehicles Affected:
•Valtra: AC71.5
Vehicle Version:
•2.7
General:
•Add Tier3 models
Software:
Vehicles Affected:
Vehicle Version:
•0.34
General:
◦NT01 Version: 6749
◦NT05 Version: 6749
Vehicles Affected:
Vehicle Version:
•2.02
Software:
Vehicles Affected:
Vehicle Version:
•5.53
Software:
•VD03:3.143
Vehicles Affected:
Vehicle Version:
•7.3
Plug-Ins:
Software:
◦Fix ISOBUS issues
- AGCO EDT (Electronic Diagnostic Tool) v1.75 [03.2016] Full + Instruction
- AGCO Full Database NA + UK + AU + SA Parts & Workshop Service Manual 2021
- Massey Ferguson Epsilon Service Manuals [03.2015]
- AGCO EDT (Electronic Diagnostic Tool) v1.77 [02.2017] Full + Instruction
- MASSEY FERGUSON Europe Parts Catalog [03.2015]
- AGCO VALTRA Epsilon UK Parts Books [10.2017] Full Instruction + Keys
- VALTRA Epsilon Parts and Service [01.2015] Full + Keys
- Massey Ferguson Service & Workshop Europe [05.2017] Full + Keys
- Massey Ferguson Epsilon Spare Parts 2012
- AGCO Fendt Workshop Manual NA [06.2017] Full + Keys
- MASSEY FERGUSON UK Parts Catalog [10.2017] Full + Serial
- FENDT EUROPE Parts & Service [01.2015] Full + Keys
- Massey Ferguson Europe Service Manuals [01.2016] Full + Keys
- FENDT EU Service & Workshop Europe [05.2017] Full + Keys
- MASSEY FERGUSON North America Parts Catalog [02.2015] Full + Keys
