AGCO EDT 09.2025 Electronic Diagnostic Tool
- Download this document, you need 18750 Gallons
Size: 44.5GB (WinRAR Files)
Interface Languages: English, Dutch, French, Finnish, German, Spanish, Portuguese, Danish, Russian, Polish, Italian, Turkish, Swedish, Chinese, Norwegian Bokmål.
Database Languages: Only English
Type of software: AGCO EDT (Electronic Diagnostic Tool)
Type of vehicle: Agricultural
Update: 09.2025
OS: Windows 10, Windows 11 64 & 86 bit (Tested on Windows 10 Pro 22H2 64-bit)
Supporter: Present
Send an email to get the password: "admin@autorepairmanuals.ws, Gallons@autorepairmanuals.ws"
NOTE: " DO NOT HAVE FENDIAS IN THIS AGCO EDT"
Release Notes – 8/27/2025 – Update 2025.4
Update: 09.2025
Supporter: Present
EDT NOTES:
EDT Version: 1.128.25190.1121
Bug Fixes:
Enhancements:
- Updated WinSCP to version 6.5.2
- Minor improvements to diagnostic functionality.
Vehicles Affected:
- Challenger: WR9900 Series
- Massey Ferguson: WR9900 Series
Vehicle Version:
- 1.67
Software:
- NT03 v5.00.17
- Fix header float conversion between imperial and metric
- Fix USB icon stays active when USB is removed
- Fix secondary monitor freeze in some circumstances
- Fix primary monitor crash when shifting into rear steer
- Fix guidance overlap not being maintained in both directions
- Fix not applying overlap after key switch but still showing right value
Vehicles Affected:
- Massey Ferguson: Square Balers: 2224, 2233, 2234, 2234XD, 2244
- Fendt: Square Balers: 990, 1270, 1290, 1290XD, 12130
Vehicle Version:
- 1.37
Diagnostics:
- Add virtual CAN-Bus to monitor availability of ECUs while connected to ISOBUS connector.
- Make backup of EEPROM before upgrading software
Configuration:
- Add possibility to change electronic/mechanical knotter trip without an authorization key
Software:
- EXT 01.14.01
- Fix sending amount of cut bales to ACM and Infotrac at startup
- Fix sending cutter override alarm when override is active and not only while button is pressed
- Change delay for missing machine speed to 60 seconds to give ACM time to get started
- Fix having active parking brake alarms after parking brake has been turned off
- Fix displaying a double indicator when both load bullets are not sending values
- Improve load bullet diagnostics
- Fix having infobox items available for moisture system that was previously connected
Vehicles Affected:
- Challenger: 660B made in Brazil, 670B made in Brazil, 680B made in Brazil
- Massey Ferguson: 9695 made in Brazil, 9795 made in Brazil, 9895 made in Brazil
- Valtra: BC6800, BC7800, BC8800
Vehicle Version:
- 1.36
Configuration:
- The “internal error” no longer occurs when opening the Combine Setup configuration page.
Vehicles Affected:
- Challenger: 520C
- Challenger: 540C
- Challenger: 560C
- Massey Ferguson: 9595S
- Massey Ferguson: 9695S
- Massey Ferguson: 9795S
- Massey Ferguson: 9895S
- Valtra: 6800
- Valtra: 7800
Vehicle Version:
- 1.62
General:
- Software update for EMU and VMM, replacement of the MVEC with HCDM
- Guidance System only AGS-2
- Monitor only X35
Diagnostics:
- Shaft Speeds: added block with active tailboard – spinners speed
- Replaced all the relays of MVECs with HCDMs
Configuration:
- Added 2 more options for discharge type: Chopper -active tailboard, straw spreader – Hyd
Software:
- VMM ver. BB: 5.38 b63; LL: 0.66 b101
- EMU ver. 6.6
Plug-Ins:
- Removed AGCOCOMMAND, AG3000
Vehicles Affected:
- Massey Ferguson: 2700-4700 Series
- Massey Ferguson: 6700R Series
- Massey Ferguson: Global Series 4700-5700-6700
- Valtra: A100
- Valtra: A100Hitech Series
- Valtra: A4, A4S
- Valtra: A4Hitech Series
- Valtra: AC52.5, AC54.5, AC56.5
- AGCO EDT (Electronic Diagnostic Tool) v1.75 [03.2016] Full + Instruction
- AGCO Full Database NA + UK + AU + SA Parts & Workshop Service Manual 2021
- AGCO EDT (Electronic Diagnostic Tool) v1.77 [02.2017] Full + Instruction
- AGCO Epsilon 2.1.80 03.2018
- AGCO Epsilon 2.1.80 05.2019 Full
- AGCO EPSILON KG for all 24 Brands
- AGCO Epsilon Security Key [31.10.2017]
- AGCO AG Agricultural ALL Database EU Updated [11.2020]
- AGCO AG Agricultural EU Updated 03.2021 ALL Database Part and Workshop Repair Manual
- AGCO EDT Electronic Diagnostic Tool v.1.92.20028.884 [04.2020] Update Files
- AGCO AG Agricultural ALL Database NA + UK + AU Updated [06.2019]
- AGCO Epsilon Security Key [30.04.2017]
- AGCO AG Agricultural ALL Database NA Updated [03.2020]
- AGCO EDT Electronic Diagnostic Tool Updated 1.107.21194.578 2021.4.OC1 10.2021 Diagnostic Software DVD
- AGCO EDT Electronic Diagnostic Tool Updated 05.2022 Diagnostic Solution
