AGCO Allis Tractor WC WF Power Unit W201 Parts Catalog 79001545
Brand: AGCO Allis
Type of Machine: Tractor, Power Unit
Model:
AGCO Allis WC Tractor
AGCO Allis WF Tractor
AGCO Allis W201 Power Unit
Part Number: 79001545
Number of Pages: 245 Pages
Piston & Connecting Rod
Camshaft
Crankshaft & Flywheel
Cylinder Head - Used Prior To Eng. No. 2899000
Cylinder Head - Used On Eng. 289000 & Up
Valves & Rocker Arms - Used Prior To Eng. No. 289000
Valves & Rocker Arms - Used On Eng. 289000 & Up
Timing Gear Cover
Oil Pump - Pump No. 226259
Oil Pump - Pump No. 229540
Oil Pump
Oil Sump
Oil Filter & Lines
Intake & Exhaust Manifold
Intake & Exhaust Manifold - Water Cooled
Air Cleaner
Air Cleaner - W-201 Power Unit
Water Pump & Fan
Water Manifold - Used Prior Eng. W-98779
Water Manifold - Used Eng. No. W-98779 Thru No. 288999
Water Manifold - Used On Eng. No. 289000 & Up
Radiator - Used Wc-74330 & Up, Wf-1904 & Up
Governor
Governor Control
Governor Control - Wf Tractor (Used On Tr. Wf-1904 & Up)
Carburetor - Zenith Models 124-1 2to & 124-1 2top
Carburetor - Zenith Models 61ax7 & 161x7
Carburetor - Marvel-Schebler (Model Tsx-159)
Carburetor - Gasoline & Natural Gas, W-201 Power Unit
Choke Control - Used On Tr. Wc-78605 Thru Wc-101725
Magneto Ground & Choke Control
Fuel Tanks, Filter, Lines & Hood
Fuel Tank, Filter, Lines & Hood
Fuel Tank, Filter & Lines - W-201 Power Unit
Fuel Filter - W-201 Power Unit
Fuel Pump - W-201 Power Unit
Ignition - Base Mounted Magneto (Used Prior Eng. W-3522)
Ignition - Flange Mounted Magneto (Used Eng. W-3522 & Up)
Electric Starting - W-201 Power Unit
Electric Starting
Electric Lighting - Used On Wc-74330 & Up & On Wf-1904 & Up
Protective Controls - W-201 Power Unit (Used Prior Year 1941)
Protective Controls - W-201 Power Unit (Eff. Year 1941)
Instrument Panel & Controls - W-201 Power Unit
Main Frame
Base Frame - Standard, W-201 Power Unit
Base Frame - Outboard Bearing, W-201 Power Unit
Hood & Side Plates - W-201 Power Unit
Wheel Guards, Foot Rests & Tool Box - Wc Tractor
Wheel Guards, Foot Rests & Tool Box - Wf Tractor
Wheel Guard, Foot Rests & Tool Box - Wf Tractor
Driver's Seat
Tools & Miscellaneous
Starting Crank - Wf Tractor
Starting Crank - For Tractors W Standard Dual Wheels
Starting Crank - Wc Tractors
Starting Crank - W-201 Power Unit
Engine Clutch
Clutch Housing - W-201 Power Unit
Engine Clutch Housing
Clutch Control
Clutch Control - W-201 Power Unit
Clutch Shaft - Wc & Wf Tractors
Clutch Shaft - Standard, W-201 Power Unit
Clutch Shaft - Outboard Bearing, W-201 Power Unit
Transmission - Wc & Wf Tractors
Transmission Control
Final Drive
Rear Axle Housing (Tractor S N Ending With S )
Belt Pulley - Wc & Wf Tractors
Power Take-Off - Belt Pulley Driven, Wc Tractor
Power Take-Off - Transmission Driven (Used In Year 1935 & Up)
Power Lift - Wc Tractors
Drawbar & Platform - Wc Tractor
Drawbar & Platform - For Power Take-Off; Not A.S.A.E. Std.
Drawbar & Platform - For Power Take-Off; A.S.A.E. Standard
Drawbar & Platform - Wf Tractors
Wide Front Axle - Wc Tractor
Front Axle - Wf Tractor
Front Axle - Standard Dual Front Wheels, Wc Tractor
Front Axle - Single Front Wheel, Wc Tractors
Front Support - Wf Tractor
Front Support - Wc Tractor
Steering Gear - Lavine, Wf Tractor (Used Prior To Wf-1904)
Steering Gear - Ross, Wf Tractor (Used On Tr. Wf-1904 & Up)
Steering Gear - Wc Tractor
Front Wheels - Standard Tractor 24 X 4 Steel
Front Wheels - Wide Front Axle 28 X 6 Steel, Wc Tractor
Front Wheels - F Standard Tractor 5.25 X 17 Air Tires
Front Wheel - Standard Tractor 5.50 X 16 Air Tires
Front Wheels - Std. Tractor 5.50 X 16 Air Tires, Wf Tractor
Front Wheel - Single Front 9.00 X 10 Air Tire, Wc Tractor
Front Wheels - Wide Front Axle - 6.00 X 16 Air Tires
Rear Wheels - 40 X 6 Steel, Wc & Wf Tractors
Rear Wheels - 40 X 2 Steel, Wc & Wf Tractors
Rear Wheels - Standard Tractor 11.25 X 24 Air Tires
Rear Wheels - Standard Tractor 11 X 28 Air Tires
Rear Wheels - 9.00 X 28, 7.50 X 36 & 9.00 X 36 Air Tires
Wheel Weights - Rear, Wc & Wf Tractors
Assemblies Or Packaged Parts
Hardware List
Brand: AGCO Allis
Model:
Camshaft
Timing Gear Cover
Oil Pump
Oil Sump
Oil Filter & Lines
Air Cleaner
Water Pump & Fan
Governor
Governor Control
Electric Starting
Main Frame
Driver's Seat
Engine Clutch
Clutch Control
Final Drive
Hardware List
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
