AGCO Allis Tractor B IB C Power Unit B125 60H Parts Catalog 79001543
Brand: AGCO Allis
Type of Machine: Tractor, Power Unit
Model:
AGCO Allis B Tractor
AGCO Allis IB Tractor
AGCO Allis C Tractor
AGCO Allis B125 Power Unit
AGCO Allis 60H Power Unit
Part Number: 79001543
Number of Pages: 218 Pages
Engine - Cylinder Block
Engine - Crankshaft & Flywheel
Engine - Piston & Connecting Rod
Engine - Camshaft
Engine - Valves & Rocker Arms
Engine - Oil Sump
Engine - Oil Pump
Air Intake & Exhaust - Intake & Exhaust Manifold, Gasoline
Air Intake & Exhaust - Intake & Exhaust Manifold, Low Octane
Air Intake & Exhaust - Air Cleaner
Air Intake & Exhaust - Air Cleaner (Used Prior To Tr. B-101)
Air Intake & Exhaust - Air Pre-Cleaner
Cooling System - Water Pump & Fan
Cooling System - Water Manifold (Used Prior To Eng. Be-23815)
Cooling System - Water Manifold (Used On Eng. Be-23815 & Up)
Cooling System - Radiator (Used Prior To Tr. B-101)
Cooling System - Radiator (Used On Pu-65705b & Up)
Fuel System - Carburetor, Zenith
Fuel System - Carburetor, Marvel-Schebler
Fuel System - Choke Control
Fuel System - Fuel Pump
Fuel System - Fuel Tank & Lines (Used On Tr. B-101 & Up)
Fuel System - Fuel Filter
Fuel System - Governor
Fuel System - Governor, For 1850 Rpm Engine
Fuel System - Governor Control
Fuel System - Governor Control, Used On Tr. Ib-1001 & Up
Elect. & Instruments - Ignition, Magneto
Elect. & Instruments - Ignition, Battery - Distributor
Elect. & Instruments - Distributor, Used W Battery Ignition
Elect. & Instruments - Electric Starting
Elect. & Instruments - Electric Lighting
Elect. & Instruments - Warning Lamp
Elect. & Instruments - Protective Controls
Sheet Metal, Frame & Seat - Hood & Side Plates
Sheet Metal, Frame & Seat - Front Weights
Sheet Metal, Frame & Seat - Main Frame
Sheet Metal, Frame & Seat - Tools & Miscellaneous
Sheet Metal, Frame & Seat - Wheel Guards - For Std. Tractor
Sheet Metal, Frame & Seat - Wheel Guards, F Special Tractors
Sheet Metal, Frame & Seat - Seat
Sheet Metal, Frame & Seat - Seat (Used On Tr. Ib-1001 & Up)
Clutch Housing - For Standard Clutch, Rockford
Clutch - Rockford Model Tt-9
Clutch - Rockford, Model Rm - 8-1 2 & 9
Clutch Control
Clutch Control - Used On Pu-65705b & Up
Clutch - Clutch Shaft
Clutch - Clutch Shaft, For Reduction Unit
Drive Train - Torque Tube, Clutch Housing
Drive Train - Reduction Gear
Drive Train - Transmission Case & Cover
Drive Train - Transmission Gears & Shafts
Drive Train - Transmission Control
Drive Train - Differential
Drive Train - Final Drive & Rear Axle
Drive Train - Power Take-Off
Brake System - Hand Brake
Brake System - Foot Brake
Brake Control - Used Prior To Tr. Ib-1001
Hitch - Snap Coupler & Drawbar Supports, Model B Tractor
Hitch - Lift Arm Latch, Snap Coupler System
Hitch - Drawbar (Used Prior To Tr. B-40201)
Axle, Steering & Wheels - Front Axle, F Std. & Asparagus Tr.
Axle, Steering & Wheels - Front Axle (Model Ib)
Axle, Steering & Wheels - Adjustable Front Axle
Axle, Steering & Wheels - Front Axle, F Single Front Wheel
Axle, Steering & Wheels - Front Axle, F Std. Dual Front Wheel
Axle, Steering & Wheels - Steering Gear, Gemmer
Axle, Steering & Wheels - Steering Gear, Ross
Axle, Steering & Wheels - Front Support
Axle, Steering & Wheels - Front Wheel (Used Prior B-101)
Axle, Steering & Wheels - Single Front Wheel
Axle, Steering & Wheels - Rear Wheel, For Standard Air Tires
Axle, Steering & Wheels - Rear Wheel, For Special Air Tires
Axle, Steering & Wheels - Weights
Hydraulic System - Hydraulic Pump
Hydraulic System - Hydraulic Pump Control
Hydraulic System - Hydraulic Control Valve
Hydraulic System - Hydraulic Cylinder & Hoses, Second Type
Hydraulic System - Front Hydraulic Cylinder
Hydraulic System - Delayed Action Valve, B Tractor
Assemblies & Packaged Parts
Hardware List
