AGCO Allis Tractor 9130 9150 Parts Catalog 79010347
Brand: AGCO Allis
Model:
AGCO Allis 9130 Tractor
AGCO Allis 9150 Tractor
Part Number: 79010347
Number of Pages: 347 Pages
Engine - Crankcase
Engine - Oil Pan
Engine - Spray Nozzle & Idler Gear Bearing
Engine - Cylinder, Pieces Cyl. Unit
Engine - Piston
Engine - Cylinder Head, Unit Pieces
Engine - Flywheel
Engine - Flywheel Housing
Engine - Driving Parts
Engine - Camshaft
Engine - Idler
Engine - Lube Oil Pump & Lines
Engine - Oil Filter Heater Valve Asy.
Engine - Piping
Engine - By-Pass Line
Engine - Fuel Filter
Engine - Leak Oil Pipes
Engine - Injection Pump
Engine - Injection Lines
Engine - Flame Type Pin Plug
Engine - Cold Start Relay
Engine - Breather
Engine - Charge Air Pipe
Engine - Air Feed
Engine - Hydr. Cooling Air Blower
Engine - Oil Cooler, Hydraulic
Engine - Exhaust Pipe
Engine - Turbocharger
Engine - Turbocharger, Components
Engine - Intercooler
Engine - Air Shield
Engine - Stay Plate
Engine - Air Cowling Base
Engine - Baffle Mounting Plate
Engine - Transport Eye
Engine - Locking Parts For Hydraulic Pump
Engine - Attachments
Engine - Stop-Switch Mounting
Engine - Oil Pressure Switch
Engine - Cooling Air Duct, Tube Assembly
Engine - Throttle Controls, 9150 Prior To S N 1200
Engine - Throttle Controls, 9150 Eff. S N 1200-1541
Engine - Throttle Controls, 9130, 9150 Eff. S N 1542
Engine - Ether Starting Aid
Air Intake And Exhaust - Air Cleaner
Air Intake And Exhaust - Air Cleaner, Components
Air Intake And Exhaust - Muffler And Exhaust Pipes
Fuel System - Water Separator, 9150, Prior To S N 1200
Fuel System - Water Separator, 9150, Eff. S N 1200 Thru 1364
Fuel System - Water Separator, 9150 Eff. S N 1365-1474
Fuel System - Water Separator, 9130, 9150 Eff. S N 1475
Fuel System - Lower Fuel Tank & Lines, Prior 9150 S N 1200
Fuel System - Lower Fuel Tank & Lines, Eff. 9130,
Fuel System - Upper Fuel Tank & Lines
Fuel System - Fuel Cooler And Lines
Electrical - Alternator And Starting Motor
Electrical - Alternator, 105 Amp, Delco #1105539 Or #10479927
Electrical - Starting Motor-27mt, Components
Electrical - Condenser Fan, Fan & Mounting
Electrical - Lights
Electrical - Head Lamp
Electrical - Working Lamps, Canopy-Front
Electrical - Tail Lamp
Electrical - Flood Lamp
Electrical - Warning Lamps, Front & Rear
Electrical - Auxiliary Light Connector
Electrical - Ashtray & Lighter
Electrical - Instrument Panel
Electrical - Right Hand Instrument Panel, Gauges,
Electrical - Left Hand & Lower Instrument Panel,
Electrical - Radio, Speaker Plates & Grilles
Electrical - Cab Electrical System
Transmission - Clutch
Transmission - Clutch, Components
Transmission - Clutch Pedal & Linkage
Transmission - Power Shift Transmission Shift,
Transmission - Power Shift Transmission, Cover, Filter & Pump
Transmission - Power Shift Transmission, Oil Pump
Transmission - Hydraulic Oil Cooler & Lines
Transmission - Oil Cooler & Lines, Three Speed
Transmission - Rear Housing
Transmission - Transmission Input Shaft
Transmission - Transmission, Counter Shaft & Reverse Idler
Transmission - Transmission Pinion Shaft
Transmission - Gear Shift
Transmission - Park Lock, Lever & Linkage
Transmission - Brakes
Transmission - Brake Pedal & Linkage
Transmission - Brake Valve & Lines
Transmission - Differential & Differential Lock
Transmission - Rear Axle & Planetary
Transmission - Rear Wheel, Center & Hub
Transmission - Pto, Drive Shaft, Clutch & Brake
Transmission - Pto, Dual Speed
Transmission - Pto & Differential Lock Valve,
Hydraulics - Hydraulic Housing & Cover
Hydraulics - Hydraulic & Lube Charge Pump
Hydraulics - Hydraulic Oil Filter
Hydraulics - Hydraulic Pump, Pressure Control Valve & Lines
Hydraulics - Pressure Control Valve
Hydraulics - Servo Valve Control Lever & Linkage
Hydraulics - Remote Valve Control Levers & Linkage
Hydraulics - Lever Coupling, Cylinder & Hoses, Remote
Hydraulics - Hydraulic Lever Couplings
Hydraulics - Lift Cylinder, 1-1 2 X 11-1 2, Cessna
Hitch, Lift And Drawbar - Three Point Hitch, Draft Sensitive
Hitch, Lift And Drawbar - Three Point Hitch, Draft Sensing
Hitch, Lift And Drawbar - Rockshaft, Lift Arms &
Hitch, Lift And Drawbar - Three Point Hitch, Category Iii
Hitch, Lift And Drawbar - Increased Capacity
Hitch, Lift And Drawbar - Quick Hitch, Category
Hitch, Lift And Drawbar - Drawbar
Hitch, Lift And Drawbar - Wide Swing Drawbar
Steering, Axles & Wheels - Steering Column And Pedal Support
Steering, Axles & Wheels - Power Steering Control Unit
Steering, Axles & Wheels - Steering Control Unit
Steering, Axles & Wheels - Power Steering Cylinders
Steering, Axles & Wheels - Power Steering Cylinder, 2wd
Steering, Axles & Wheels - Front Axle Carrier And
Steering, Axles & Wheels - Tie Rod
Steering, Axles & Wheels - Adjustable Front Axle, 2wd
Steering, Axles & Wheels - Front Wheels, 2wd & Awd
Steering, Axles & Wheels - Transfer Drive Awd
Steering, Axles & Wheels - Control Linkage - Awd
Steering, Axles & Wheels - Front Axle And Steering Lines, Awd
Steering, Axles & Wheels - Front Axle Drive Shaft, Awd
Steering, Axles & Wheels - Differential Carrier,
Steering, Axles & Wheels - Axle Housing, Shaft & Tie Rod, Awd
Steering, Axles & Wheels - Steering Joint Housing &
Steering, Axles & Wheels - Planetary Drive, Awd
Steering, Axles & Wheels - Steering Cylinder, Awd
Sheet Metal & Frame - Front Main Frame
Sheet Metal & Frame - Hood And Side Panels
Sheet Metal & Frame - Front Cowl And Grille
Sheet Metal & Frame - Tool Box
Sheet Metal & Frame - Front Weights
Sheet Metal & Frame - Front Fenders, Awd
Sheet Metal & Frame - Step, Battery Box & Cables
Sheet Metal & Frame - Decals
Cab - Cab Body
Cab - Cab Headliner And Foam Panel
Cab - Cab Windows
Cab - Cab Door
Cab - Cab Mounting, & Rh Console
Cab - Mirrors, Outside Cab
Cab - Seat & Suspension
Cab - Seat Suspension
Cab - Seat
Cab - Air Ride Seat & Suspension
Cab - Windshield Wiper, Prior 9130 S N 1125,
Cab - Cab Air Conditioner, Evaporator & Heater Housing
Cab - Cab Heater
Cab - Cab Blower
Cab - Cab Air Conditioner, Condenser & Evaporator
Cab - Cab Air Conditioner, Compressor, Clutch & Pulley
Cab - Air Conditioner Compressor
Cab - Air Conditioner Compressor Clutch
