AGCO Allis Tractor 8050 Parts Catalog 79006286
Brand: AGCO Allis
Model: AGCO Allis 8050 Tractor
Part Number: 79006286
Number of Pages: 406 Pages
Parts Catalog Information
Engine - Gasket Sets
Engine - Gasket Sets, (Continued)
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel & Adapter Plate
Engine - Piston & Connecting Rod
Engine - Timing Gear Cover
Engine - Lubricating System, Oil Pump
Engine - Lubricating System, Oil Pan
Engine - Lubricating System, Oil Cooler & Filter
Engine - Bypass Oil Filter, Lines & Bracket
Air Intake & Exhaust System - Manifolds, Intake & Exhaust
Air Intake & Exhaust System - Turbocharger, Components, Airesearch
Air Intake & Exhaust System - Turbocharger, Lines
Air Intake & Exhaust System - Air Cleaner & Muffler, Non-Aspirated
Air Intake & Exhaust System - Air Cleaner & Muffler, Aspirated
Air Intake & Exhaust System - Pre-Cleaner, Pre-Cleaner Extension
Cooling System - Water Pump
Cooling System - Radiator
Cooling System - Thermostat
Cooling System - Water Conditioner, Prior S N 70-30710
Cooling System - Belts & Pulleys
Fuel System - Fuel Injection System, Pump & Lines
Fuel System - Fuel Injection System, Lines, Prior S N 70-30602
Fuel System - Fuel Injection System, Lines, Eff. S N 70-30602
Fuel System - Fuel Injection System, Fuel Injector
Fuel System - Water Separator
Fuel System - Ether Starting System
Fuel System - Tanks & Lines
Fuel System - Fuel Shut-Off & Throttle, Prior S N 2197
Fuel System - Fuel Shut-Off & Throttle, Eff. S N 2197
Electrical & Instruments - Chassis Electrical System, Analog Wiring W Fuse Block
Electrical & Instruments - Chassis Electrical System, Digital Wiring W Fuse Block
Electrical & Instruments - Engine Electrical System, Wiring
Electrical & Instruments - Instrument Panel, Analog
Electrical & Instruments - Instrument Panel, Digital
Electrical & Instruments - Engine Electrical System, Batteries & Cables
Electrical & Instruments - Engine Electrical System, Starting Motor -- Delco
Electrical & Instruments - Engine Electrical System, Starting Motor -- Allis-Chalmers
Electrical & Instruments - Electrical System, Cab Lighting
Electrical & Instruments - Electrical System, Rops Lighting
Electrical & Instruments - Electrical Lighting, Work Lamp
Electrical & Instruments - Electrical System, Stadium Lights
Electrical & Instruments - Electrical System, Air Conditioning, Heater & Blower
Electrical & Instruments - Electrical System, Wiper & Control
Electrical & Instruments - Engine Electrical System, Alternator, 80 Ampere
Electrical & Instruments - Engine Electrical System, Alternator, 100 Ampere
Electrical & Instruments - Electrical System, Tape Player & Radio - Bowman
Electrical & Instruments - Electrical System, Tape Player & Radio - Audiovox
Electrical & Instruments - Wiring, Remote Electric Socket
Sheet Metal, Frame & Seat - Front Support & Side Frame
Sheet Metal, Frame & Seat - Front Support & Side Frames -- Fwa
Sheet Metal, Frame & Seat - Grille, Hood & Hood Support
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Battery Box
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Console
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Control Module
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Steps & Bracketing
Sheet Metal, Frame & Seat - Steering, Control
Sheet Metal, Frame & Seat - Steering, Steering Column
Sheet Metal, Frame & Seat - Seat Mounting, Olympic Seat, Marathon Seat, Luxury Seat - Prior S N 2831
Sheet Metal, Frame & Seat - Seat Mounting, Luxury Seat - Eff. S N 2831, Olympic Seat - Eff. S N 3191
Sheet Metal, Frame & Seat - Seat Suspension, Prior S N 2185
Sheet Metal, Frame & Seat - Seat Suspension, Eff. S N 2185
Sheet Metal, Frame & Seat - Seat, Fold-Up, Marathon
Sheet Metal, Frame & Seat - Seat, Luxury Cloth
Sheet Metal, Frame & Seat - Decals
Drive Train - Transmission -- 2wd, Housing -- Power Director
Drive Train - Transmission -- Fwa, Housing -- Power Director
Drive Train - Transmission, Torque Limiter, Power Director Tractor
Drive Train - Transmission, Input Shaft, Power Director Tractor
Drive Train - Transmission, Power Director Clutch
Drive Train - Transmission, Main Shaft -- Power Director
Drive Train - Transmission, Countershaft -- Power Director, 20-Speed
Drive Train - Transmission, Gear Shift & Linkage
Drive Train - Controls, Manual Shift
Drive Train - Transmission, Housing, Power Shift Tractor -- 2wd
Drive Train - Transmission, Housing, Power Shift Tractor -- Fwa
Drive Train - Transmission, Torque Limiter, Power Shift Tractor
Drive Train - Transmission, Front Bearing
Drive Train - Transmission, A1, A2, B1 & B2 Clutch Housing, Power Shift Tractor
Drive Train - Transmission, C1 & C2 Clutch Housing, Power Shift Tractor
Drive Train - Transmission, Rear Bearing, Power Shift
Drive Train - Transmission, Front Carrier Asy., Power Shift
Drive Train - Transmission, Middle Carrier Asy., Power Shift
Drive Train - Transmission, Shaft & Gears, Power Shift
Drive Train - Transmission, Range Shaft & Gears -- 2wd
Drive Train - Transmission, Range Shaft & Gears -- Fwa
Drive Train - Controls, Inching -- Power Shift
Drive Train - Controls, Speed Selector -- Power Shift
Drive Train - Controls, Park Lock & Range Shift Cable Controls
Drive Train - Controls, Differential Lock
Drive Train - P.T.O., Main Shaft & Idler
Drive Train - P.T.O., Clutch & Brake
Drive Train - P.T.O., 2-Speed Output Shaft
Drive Train - P.T.O., 1000 Rpm Output Shaft
Drive Train - Differential & Final Drive, Housing -- 2wd
Drive Train - Differential & Final Drive, Housing -- Fwa
Drive Train - Differential & Final Drive, Differential
Drive Train - Differential & Final Drive, Rear Axle
Drive Train - Differential & Final Drive, Rear Axle, Hi-Clearance
Drive Train - Differential & Final Drive, Housing - Rear Axle, Hi-Clearance
Drive Train - Fwa Final Drive, Drive Line Clutch Asy.
Drive Train - Fwa Final Drive, Clutch -- Idler Shaft, Eff. S N 2965
Drive Train - Fwa Final Drive, Clutch -- Idler Shaft, Prior S N 2965
Drive Train - Fwa Final Drive, Drive Line -- Mechanics
Drive Train - Fwa Final Drive, Wheel Hub & Gears
Drive Train - Fwa Final Drive, Front Axle Shafts
Drive Train - Fwa Final Drive, Axle Housing & Steering Knuckle
Drive Train - Fwa Differential & Final Drive, Ring Gear &
Drive Train - Fwa Differential & Final Drive, Differential Asy. -- No Spin
Brake
Brake - Brake, Controls, Prior S N 2780
Brake - Brake, Controls, Eff. S N 2780
Hitch & Lift - Lift Shaft, Housing
Hitch & Lift - 3-Point Hitch, Torsion Bar, Lift Link, Upper & Lower Link
Hitch & Lift - Drawbar, Standard
Hitch & Lift - Drawbar, Wide Swing
Hitch & Lift - Hitch, Quick
Hitch & Lift - Hitch, Quick, Heavy Duty
Axles, Steering & Wheels - Axle, Front, Hi-Clearance
Axles, Steering & Wheels - Steering, Tie Rod
Axles, Steering & Wheels - Wheels, Front
Axles, Steering & Wheels - Wheel -- Rear, Non-Power Adjust,
Axles, Steering & Wheels - Wheel -- Rear, Power Adjust
Axles, Steering & Wheels - Weight Mtg. Hardware, Non-Power
Hydraulic System - Lines, Power Steering -- 2wd
Hydraulic System - Lines, Power Steering -- Fwa
Hydraulic System - Pump, Dual -- 2wd
Hydraulic System - Pump, Dual -- Fwa
Hydraulic System - Valve, Power Steering
Hydraulic System - Cylinder, Power Steering -- 2wd
Hydraulic System - Cylinder, Power Steering -- Fwa
Hydraulic System - Lines, Power Director
Hydraulic System - Valve, Power Director
Hydraulic System - Solenoid Valve, P.D. Valve, Prior S N 3097
Hydraulic System - Solenoid Valve, P.D. Valve, Eff. S N 3097
Hydraulic System - Controls, Power Director, Cable Controls
Hydraulic System - Lines, Power Shift
Hydraulic System - Lines & Filter, Power Shift
Hydraulic System - Valve, Power Shift
Hydraulic System - Lines, P.T.O., Brake & Differential Lock, Internal
Hydraulic System - Lines, P.T.O., Brake & Differential Lock, External
Hydraulic System - Lines, P.T.O., Brake & Differential Lock, Lubricating
Hydraulic System - Valve, P.T.O.
Hydraulic System - Controls, Cable Controls -- P.T.O.
Hydraulic System - Piston Pump, W Drive Shaft Seal
Hydraulic System - Compensator Asy., Prior S N 2082 2wd P.S.; S N 2098 2wd P.D.;, Prior S N 2041 Fwa P.S.; S N 2040 Fwa P.D.
Hydraulic System - Compensator Asy., Eff. S N 2082 2wd P.S.; S N 2098 2wd P.D.;, Eff. S N 2041 Fwa P.S.; S N 2040 Fwa P.D.
Hydraulic System - Controls, Position & Traction Booster, Cable Controls
Hydraulic System - Controls, Position & Traction Booster, Control Levers, Prior S N 2197
Hydraulic System - Controls, Position & Traction Booster, Position Control Levers, Eff. S N 2197
Hydraulic System - Controls, Traction Booster, Eff. S N 2197
Hydraulic System - Lines, Piston Pump, Remote Valve & Lift -- 2wd
Hydraulic System - Lines, Piston Pump, Remote Valve & Lift -- Fwa
Hydraulic System - Fwa Valve & Lines
Hydraulic System - Valve, Inlet
Hydraulic System - Valve, Draft Control
Hydraulic System - Draft Valve Control
Hydraulic System - Seal Kit, W Lift & 2, 3 Or 4 Remotes
Hydraulic System - Cylinder, Lift -- Std.
Hydraulic System - Cylinder, Lift -- Heavy Duty
Hydraulic System - Lines, Breakaway Coupler, Prior S N 2383
Hydraulic System - Lines, Breakaway Coupler -- Lever
Hydraulic System - Filter, Differential
Hydraulic System - Valve, Brake
Hydraulic System - Valve, Differential Lock
Hydraulic System - Solenoid Valve, With 2 Spade Terminal Coil
Hydraulic System - Solenoid Valve, With 2 Wire Coil
Cab - Cab Frame, Exterior
Cab - Rops Frame, Exterior
Cab - Cab Frame, Interior
Cab - Rops Frame, Interior
Cab - Cab, Cab Support, Prior S N 1890
Cab - Doors, Cab -- L.H. & R.H.
Cab - Cab Windows, Glass, Gaskets & Hardware
Cab - Air Conditioning -- Heating, Lines -- Tractor End
Cab - Air Conditioning -- Heating, Lines -- Cab End
Cab - Air Conditioning -- Heating, Blower
Cab - Air Conditioning -- Heating, Compressor, Prior S N 1837
Cab - Air Conditioning -- Heating, Compressor, Eff. S N 1837
Cab - Recommended Dealer Stock
Brand: AGCO Allis
Engine - Crankshaft
Brake
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
