AGCO Allis Tractor 7580 Parts Catalog 79004881
Brand: AGCO Allis
Model: AGCO Allis 7580 Tractor
Part Number: 79004881
Number of Pages: 356 Pages
Engine - Gasket Sets
Engine - Gasket Sets, (Continued)
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel
Engine - Piston & Connecting Rod
Engine - Lubricating System, Oil Pump
Engine - Lubricating System, Oil Pan
Engine - Lubricating System, Oil Cooler & Filter
Engine - Lubricating System, Bypass Oil Filter
Engine - Timing Gear Cover
Air Intake & Exhaust System - Manifolds, Intake & Exhaust
Air Intake & Exhaust System - Turbocharger, Components
Air Intake & Exhaust System - Turbocharger, Lines
Air Intake & Exhaust Sys. - Air Cleaner, Pre-Cleaner &Muffler
Air Intake & Exhaust Sys. - Indicator,Air Cleaner Restriction
Cooling System - Water Pump
Cooling System - Thermostat
Cooling System - Belts
Cooling System - Water Conditoner
Cooling System - Radiator
Fuel System - Fuel Injection System, Pump - Housing & Drive
Fuel System - Fuel Injection System, Pump - Advance
Fuel System - Fuel Injection System, Pump - Governor
Fuel System - Fuel Injection Sys.,Pump -Hydraulic Head &Roto
Fuel System - Fuel Injection System, Lines, (Allis-Chalmers)
Fuel System - Fuel Injection System, Lines, (Bosch)
Fuel System - Fuel Injection System, Fuel Injector, (Bosch)
Fuel System - Fuel Injection System, Filter
Fuel System - Fuel Injection System, Hand Primer Pump
Fuel System - Electric Fuel Pump, (Eff. S N 2505)
Fuel System - Ether Starting System
Fuel System - Controls, Fuel Shut-Off & Throttle
Electrical & Instruments - Engine Electrical System
Electrical & Instruments - Instruments, Wiring
Electrical & Instruments - Instruments, Gauges & Panel
Electrical & Instruments - Instruments, Cab Wiring
Electrical & Instruments - Electrical System
Electrical & Instruments - Electrical Lighting, Cab Lighting
Electrical & Instruments - Wiring, Remote Electric Socket
Electrical & Instruments - Electrical Lighting, Head Lamp
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Front Frame
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Rear Frame
Sheet Metal, Frame & Seat - Fuel Tank & Lines
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Fenders
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Cover
Sheet Metal, Frame & Seat - Steering, Control
Sheet Metal, Frame & Seat - Console, Eff. S N 1605
Sheet Metal, Frame & Seat - Seat, Linkage, Prior S N 2085
Sheet Metal, Frame & Seat - Seat, Fold-Up, Prior S N 2085
Sheet Metal, Frame & Seat - Seat, Suspension, Luxury Cloth
Sheet Metal, Frame & Seat - Seat, Luxury Cloth, Eff. S N 1605
Sheet Metal, Frame & Seat - Decals
Drive Train - Transmission, Housing
Drive Train - Transmission, Torque Limiter
Drive Train - Transmission, Power Director
Drive Train - Transmission, Main Shaft- With Bushings
Drive Train - Transmission, Main Shaft - Without Bushings
Drive Train - Transmission, Countershaft
Drive Train - Transmission, Gearshift & Linkage
Drive Train - Controls, Manual Shift, Eff. S N 1605
Drive Train - Front Main Housing, Front Differential
Drive Train - Differential & Final Drive, Front Axle
Drive Train - Housings, Drop Box & P.T.O.
Drive Train - Drop Box, Range Shafts & Gears
Drive Train - Front Gear Box, P.T.O. & Pump Drive
Drive Train - Transmission, Range Shift Control
Drive Train - Controls, Range Shift & Park Lock
Drive Train - Differential & Final Drive, Housing, Rear
Drive Train - P.T.O., Main Shaft & Idler - Rear
Drive Train - P.T.O., Clutch & Brake
Drive Train - P.T.O., 1000 Rpm Output Shaft
Drive Train - Differential & Final Drive, Rear
Drive Train - Differential & Final Drive, Rear Axle
Drive Train - Drive Line, Front Axle
Drive Train - Drive Line, Rear Axle
Drive Train - Drive Line, P.T.O.
Brake
Brake - Brake, Controls
Hitch & Lift - Lift Shaft, Housng
Hitch & Lift - 3-Point Hitch, Torsion Bar, Lift Link
Hitch & Lift - Drawbar, Standard
Hitch & Lift - Drawbar, Wide Swing
Hitch & Lift - Hitch, Quick
Axle, Steering & Wheels - Wheels, Front & Rear
Hydraulic System - Lines, Hydraulic Pump & Power Steering
Hydraulic System - Relief Valve, Eff. S N 2504
Hydraulic System - Pump, Dual Gear Power Steering, Prior S N
Hydraulic System - Valve, Power Steering, Prior S N 2105
Hydraulic System - Valve, Power Steering, Eff. S N 3002
Hydraulic System - Cylinder, Power Steering, Prior S N 2028
Hydraulic System - Cylinder, Power Steering, Eff. S N 2028
Hydraulic System - Power Director Lube & Cooler
Hydraulic System - Rear Cooler & Mounting
Hydraulic System - Lines, Cooler, Rear
Hydraulic System - Valve, Power Director
Hydraulic System - Valve, Power Director Shifting Valve
Hydraulic System - Controls, Power Director, Cable Controls
Hydraulic System - Lines, P.T.O. & Brake, External
Hydraulic System - Lines, P.T.O. & Brake, Internal
Hydraulic System - Valve, Brake, Prior S N 2493
Hydraulic System - Valve, P.T.O., Prior S N 2054
Hydraulic System - P.T.O. Valve, Eff. S N 2054 Thru 2990
Hydraulic System - P.T.O. Valve, Eff. S N 2991
Hydraulic System - Gerotor Adapter, Lines, Prior S N 2650
Hydraulic System - Lines, Gerotor Adapter, Eff. S N 2650
Hydraulic System - Pump, Gerotor
Hydraulic System - Piston Pump, With Drive Shaft Seal
Hydraulic System - Lines, Piston Pump, Remote Valve & Lift
Hydraulic System - Valve, Inlet - With Lift
Hydraulic System - Valve, Remote
Hydraulic System - Console Controls
Hydraulic System - Seal Kit, With Lift
Hydraulic System - Seal Kit, Without Lift
Hydraulic System - Lines, Breakaway Coupler (3 & 4 Remote)
Hydraulic System - Filter, Differential
Cab - Cab, Front View, Prior S N 1605
Cab - Cab, Rear View, Prior S N 1605
Cab - Cab, Frame, (Eff S N 1605)
Cab - Cab Door, Left, (Eff. S N 1605)
Cab - Cab, Cab Support, (Eff. S N 1605)
Cab - Cab Windows, Glass, Gaskets & Hardware, (Eff. S N 1605)
Cab - Liners
Cab - Air Conditioning - Heating, Lines & Compressor Mounting
Cab - Air Conditioning - Heating, Compressor
